Results 11 to 20 of 34
Thread: P0638, fixed, cleared code, then no start
    Did you know you can use VCDS to teach yourself using VCDS blocks & how to back trace by unplugging sensor on rail and observation of DTC/blocks to reflect the value if you believe a caption isn't documented, now did you read VCDS captions?
  2. #12
    Jan 2020
    Richardson, TX, USA
    I did not, I'm still learning my way around parts of the program, and am a novice with it. Did the log I post show anything of significance? Other than the engine speed, I do not know what the values of those fields are supposed to be.
  3. #13
    Read the blocks and captions in VCDS and you tell me?
    I see pressures and RPM of something in that log what blocks are they identified as in VCDS captions?
  4. #14
    Jan 2020
    Richardson, TX, USA
    Group 28 shows: engine RPM, ignition timing, *empty block*, and pressure (of what? Hpfp maybe?)
    Group 40 shows: engine RPM, load (of what?), Lambda, Lambda
    Hovering the mouse over each block does not show any captions. In some groups it does, but for whatever reason it is not doing so here, so I am unable to interpret what the values mean and what the specified range is. The manual talks about label files, but I am unable to read them when they are opened since they're encrypted
  5. #15
    Quote Originally Posted by bill1975 View Post
    Groups 028 and 040 were never documented by VW as far as I can tell.
    Fuel pressure should be in 020 and/or 021.
  6. #16
    Jan 2020
    Richardson, TX, USA
    Thanks Uwe. Both those channels show the same data, I logged both of them.
    Based on the captions in VCDS, everything looks normal except "High Fuel Pressure (specified), in group 20, "High Fuel Pressure (specified)" shows it should have a range of 250-300 bar at idle, while in group 21 it shows that it should read 220-330 bar at idle. The log shows it settles at 336 bar. a minute or two later after the logging stopped it went to 328 bar. I'm not sure what that is linked to. Here is the log:
    Tuesday	21	January	2020	18:14:10:53989-VCID:3D70BF6464A34BA78C-8068	VCDS Version: Release 19.6.2 (x64)	Data version: 20190930 DS308.0
    03L 997 030 R		R4 2.0l TDI G000AG  9983
    	Group A:	'020				Group B:	'021
    		Engine Speed	High Fuel Pressure	High Fuel Pressure	High Fuel Pressure		Engine Speed	High Fuel Pressure	High Fuel Pressure	Quantity Measuring
    	TIME	(G28)	(specified)	(actual)	Control Valve	TIME	(G28)	(specified)	(actual)	Control Valve
    Marker	STAMP	 /min	 bar	 bar	 %	STAMP	 /min	 bar	 bar	 %
    	0.08	0	296	0	9.5	0.21	0	296	0	33.1
    	0.32	0	296	0	9.5	0.45	0	296	0	33.1
    	0.59	0	296	0	9.5	0.71	0	296	0	33.1
    	0.84	0	296	0	9.5	0.96	0	296	0	33.1
    	1.11	0	296	0	9.5	1.23	0	296	0	33.1
    	1.35	0	296	0	9.5	1.48	0	296	0	33.1
    	1.62	0	296	0	9.5	1.75	0	296	0	33.1
    	1.87	0	296	0	9.5	1.99	0	296	0	33.1
    	2.14	0	296	0	9.5	2.26	0	296	0	33.1
    	2.38	0	296	0	9.5	2.51	0	296	0	33.1
    	2.65	0	296	0	9.5	2.78	0	296	0	33.1
    	2.9	0	296	0	9.5	3.03	0	296	0	33.1
    	3.17	0	296	0	9.5	3.29	115	320	0	45.8
    	3.41	161	344	16	31.6	3.54	184	344	72	41
    	3.68	345	392	184	30	3.81	621	344	296	45.8
    	3.93	989	520	408	30	4.06	1127	456	424	32.4
    	4.2	1058	384	416	25.3	4.32	1035	336	384	33.1
    	4.45	1012	320	360	23.7	4.57	989	320	344	33.9
    	4.72	966	320	336	22.9	4.84	943	320	328	34.7
    	4.96	943	320	328	22.1	5.09	920	320	328	34.7
    	5.24	897	320	320	22.1	5.35	897	320	312	33.9
    	5.48	874	320	304	21.3	5.6	874	320	312	33.1
    	5.74	851	328	312	21.3	5.87	851	336	320	33.1
    	6	828	336	328	21.3	6.12	828	336	328	32.4
    	6.26	805	336	328	21.3	6.39	805	344	336	31.6
    	6.51	828	344	336	20.5	6.64	805	344	336	30.8
    	6.78	828	344	344	20.5	6.9	805	344	344	30.8
    	7.03	828	344	344	20.5	7.15	828	344	344	30.8
    	7.3	828	344	344	20.5	7.42	828	344	344	30.8
    	7.54	828	344	336	20.5	7.67	828	344	344	30.8
    	7.81	828	336	344	20.5	7.93	828	336	344	30.8
    	8.06	828	336	344	20.5	8.18	828	336	344	30.8
    	8.32	828	336	344	20.5	8.45	828	344	344	30.8
    	8.57	828	336	336	20.5	8.7	828	336	336	30.8
    	8.84	828	336	344	19.7	8.96	828	336	344	30.8
    	9.09	828	336	344	20.5	9.21	828	336	336	30.8
    	9.36	828	336	336	20.5	9.48	828	336	336	30.8
    	9.6	828	336	336	19.7	9.73	828	336	336	30.8
    	9.87	828	336	344	20.5	10	828	336	336	30.8
    	10.12	828	336	336	20.5	10.24	828	336	336	30.8
    	10.4	828	336	336	19.7	10.53	828	336	344	30.8
    	10.65	828	336	344	19.7	10.78	828	336	336	30.8
    	10.92	828	336	336	20.5	11.04	828	336	336	30.8
    	11.17	828	336	336	19.7	11.29	828	336	344	30.8
    	11.43	828	336	344	20.5	11.56	828	336	336	30.8
    	11.68	828	336	336	20.5	11.81	828	336	336	30.8
    	11.95	828	336	336	19.7	12.08	828	336	336	30.8
    	12.2	828	336	336	19.7	12.32	828	336	336	30.8
    	12.46	828	336	336	19.7	12.59	828	336	336	30.8
    	12.71	828	336	336	19.7	12.84	828	336	336	30.8
    	12.98	828	336	336	19.7	13.11	828	336	336	30.8
    	13.23	828	336	336	19.7	13.35	828	336	336	30.8
    	13.5	828	336	336	19.7	13.62	828	336	336	30.8
    	13.74	828	336	336	19.7	13.87	828	336	336	30.8
    	14.01	828	336	336	19.7	14.14	828	336	336	30.8
    	14.26	828	336	336	19.7	14.39	828	336	336	30.8
    	14.53	828	336	336	19.7	14.65	828	336	336	30.8
    	14.78	828	336	336	19.7	14.9	828	336	336	30.8
    	15.04	828	336	336	19.7	15.17	828	336	336	30.8
    	15.29	828	336	336	19.7	15.42	828	336	336	30.8
    	15.57	828	336	336	19.7	15.7	828	336	344	30.8
    	15.82	828	336	344	19.7	15.95	828	336	328	30.8
    ALSO, after this, I ran an errand, when I came back the glow plug light was blinking again and it returned the same P0638 code. The car drove fine. I have no idea why the glow plug light comes on for things that have nothing to do with the glow plugs. I did an autoscan:
    Tuesday,21,January,2020,19:17:41:53989
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUBJBFM6BA046812   License Plate:
    Mileage: 144940km-90061mi   Repair Order:
    Chassis Type: FM-AU35 (8P0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 56 62 72
              77
    VIN: WAUBJBFM6BA046812   Mileage: 144940km-90061miles
    Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 R    HW: 03L 906 019 CT
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H08---    Serial number: AUX7Z0J8FN10EJ
       Coding: 0350078
       Shop #: WSC 09198 003 1048576
       VCID: 3D70BF6464A34BA78C-8068
    001592 - Throttle Body Actuator Bank 1 (J338)
                   P0638 - 000 - Implausible Signal - MIL ON
                        Fault Status: 11100000
                        Mileage: 144930 km
                        Date: 2020.01.21
                        Time: 18:59:07
                        Voltage: 12.16 V
                        Lambda: 99.4 %
                        Bin. Bits: 00000000
    Readiness: 0 0 0 1 1
       Part No SW: 02E 300 052 G    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 9136
       Revision: 05151112    Serial number: 00001008200462
       Shop #: WSC 06314 000 00000
       VCID: 183E4EF02B414E8F7F-804C
       Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
       Component: ESP MK60EC1   H31 0106
       Revision: 00H31001
       Coding: 1150400F49260000881302E5921B0042BF0C00
       VCID: 78FE6E70CB01AE8F9F-802C
       Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
       Component: KlimavollautomatH09 0170
       Revision: 000311      Serial number: 8P0820043BN
       VCID: 79F86B74300BB787E0-802C
    Address 09: Cent. Elect.
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7K0587993
       Coding: 0000100
       VCID: 3662A048419598FF4D-8062
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
       Component: Airbag AU1042 H07 0200
       Revision: --------    Serial number: 003FC001ATTD
       Coding: 303142393041303030384A55304C38503053
       ROD: EV_Airba10AURB4.rod
       VCID: 50AEF6D00B31D6CF77-8004
       Subsystem 1 - Part No SW: 8P0 910 339 C    HW: 8P0 959 339 C
       Component: BF-Gewichtss.  H02 0030
       Serial number: 5810000R0000004WTY
       Serial number: 3572DRB40000C78931A-
       Serial number: 3582DRB40000C7892A0Z
       Serial number: 35128RB400005C0A791J
       Serial number: 35228RB400005C0AF1EX
       Serial number: 35547RB400005C63859S
       Serial number: 35647RB400005C63855P
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0014042
       VCID: 4682D0883175087FDD-8012
       Component: E0221           H04 0100
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 982 S    HW: 8P0 920 982 S
       Component: KOMBIINSTR. VDO H01 0090
       Revision: D0H01003    Serial number: 2248J003001632
       Coding: 0272288
       Shop #: WSC 31198 001 1048576
       VCID: 4998DBB4206BE70730-801C
    00003 - Control Module
                        Fault Status: 01100101
                        Mileage: 144786 km
                        Date: 2020.01.19
                        Time: 20:20:29
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 8P0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H32 5304
       Revision:   H32       Serial number: 290710F2001674
       Coding: ED907F0610070200002102
       VCID: 70EE56506371F6CF57-8024
       Revision: D0H01003    Serial number: AUX7Z0J8FN10EJ
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0001205
    00943 - Heated Exterior Mirror; Driver Side (Z4)
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 232    3001
       Revision: 00H17000
       VCID: 31689354A8FBBFC718-8064
    Address 46: Central Conv.
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158086279092
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0001205
       VCID: 4A9AE4B8256DEC1F39-801E
       Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
       Component: R Concert2+     H02 0293
       Revision: 00H02000    Serial number: AUZ1Z3K1264127
       Coding: 0750112
       VCID: 73E4595C1267CDD7AA-8026
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0001168
       Shop #: WSC 06314 000 1012544
       VCID: 428ACC981D5D345FF1-8016
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0001168
       VCID: 4384C99C02473D57FA-8016
       Part No SW: 8P1 862 336     HW: 8P1 862 336
       Component: FSE_256x BT     H41 0650
       Revision: 00000000    Serial number: 00000005038769
       Coding: 0001277
       VCID: 75E067441C13D3E784-8020
    End-------------------------(Elapsed Time: 02:17)--------------------------
    So, my guess is that the Anti shudder valve (or throttle valve) could be faulty. I'm still not sure why the car suddenly was so difficult to start after I cleaned it, and since then has started and ran just fine. Also not sure if the slightly high fuel pressure is a concern.
    Given the weird 00003 error code that neither I or you were able to figure out in a previous thread, is it possible there is an electrical issue? I checked the grounding point next to the battery and it was fine. I don't know if there are other grounds to look for, or if this is even worth pursuing.
    A couple other points in case they are relevant - when I tested the battery with a multimeter, it showed 12.5v with the car off, and 13.8v with the car running, which seems good. Also, the resistance of the glow plugs seemed good (one plug showed 1.1 ohms, the other three were at .8 ohms
  7. #17
    Mileage: 144930 km
    Date: 2020.01.21
    Time: 18:59:07
    Voltage: 12.16 V
    Lambda: 99.4 %
    Bin. Bits: 00000000
    Dont you think if you fix this or wiring problems it would be a good start?
    Most important question, isn't this repair under warranty extension and free or even under useful life warranty?
  8. #18
    Jan 2020
    Richardson, TX, USA
    The first suggestion, from what I read, was to clean it, which I did a few days ago, as I mentioned in my first post. The code stayed away for a few days until this evening. On your suggestion, I looked at the wiring from the glow plug harness and it showed no wear. I have not yet traced the wiring from the ASV and when I looked at it over the weekend I could not see where it went to.
    And yes, I assume the the ASV would be covered under the dieselgate warranty but I dont know for sure. I decided it would be easier to try cleaning it first then making a dealer appointment if needed.
    On the other hand, I'm at least learning a few things here, getting practice with VCDS, and familiarizing myself with a new-to-me engine.
  9. #19
    Isn't practically anything that would cause an MIL under such a warranty now that would make a vehicle fail SMOG?
    If the Flap can't operate than EGR would suffer function, don't you just love the vicarious nature of all this?
    Did you know your time spent and purchase of VCDS is reimbursable under useful life warranty?
    Did you read the entire JPPSG yet, the whole thread?
  10. #20
    Jan 2020
    Richardson, TX, USA
    Perhaps, but whats the harm in trying to clean it out if its a potential easy fix?
    Not sure how it is "vicarious"
    "useful life warranty". First time I heard that term.
    Yup
