Results 1 to 10 of 10
Thread: How to remove item fom "Installed" tab if it's not showed in Gateway list?
    Aug 2019
    Question How to remove item fom "Installed" tab if it's not showed in Gateway list?
    Hello! Is there any way to remove an item from the "Installed" tab if it's not showed in the Installation List?
    I have a problem with 0B-Sec. Air Heating
    In my Installation list there is no 0B:
    BCM: 7E0 937 090 C
    Gateway: 7E0 909 901
  2. Likes iichel liked this post
  3. #2
    Is this a an actual car or some modules on a test bench?
    Please do an Auto-Scan using Auto-Detect and post the results so we can see what VCDS actually finds.
    Aug 2019
    yes, it's a test bench, full autoscan:
    Tuesday,21,January,2020,02:06:08:45480
    Dealer/Shop Name: CNK
    VIN: WVWZZZ6RZC0000000   License Plate: CNK-TEST
    Mileage: 43370km-26948mi   Repair Order: 01
    Chassis Type: 6R-VW25 (7E0)
    Scan: 09 17 19 25
    VIN: WVWZZZ6RZC0000000   Mileage: 43370km-26948miles
       Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
       Component: BCM PQ25 Max4 H82 0752
       Revision: B9082001    Serial number: 4000 354171304
       Coding: 3CB02FB848FB2C00933807E0FFEB9FF9F09060EF608D78D0B00400030820
       Shop #: WSC 00046 123 12345
       VCID: 2B030594830E2ADF4C5-807E
    20 Faults Found:
    00967 - Left Turn Signals
                        Fault Status: 01101011
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:47
    00968 - Right Turn Signals
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:47
    00886 - Turn Signal Switch (E2)
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:48
    01758 - Bulbs for Brake Lamps
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:47
    00329 - Control Circuit for Unlocking Rear Lid
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:48
    00975 - Heated Rear Window (Z1)
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:50
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:50
    00077 - Windshield Wiper Stop Switch (F229)
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:47
    01134 - Alarm Horn (H12)
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:51
    03156 - Sensor for Anti-Theft System (G578)
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:51
    01326 - Control Module for Multi-Function Steering Wheel (J453)
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:51
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:51
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:51
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:51
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:51
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:51
    03591 - Control Circuit for Horn
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:49
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:48
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:48
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:34:48
       Part No SW: 6R0 920 860 H    HW: 6R0 920 860 H
       Component: KOMBI         H03 0505
       Coding: 140800
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 392F2FDC79D2884FCE9-806C
    9453074 - Fuel Level Sensor 1
              B103E 1B [009] - Resistance Too High
                        Reset counter: 0
                        Mileage: 43375 km
                        Date: 2020.01.21
                        Time: 00:33:45
       Part No SW: 7E0 909 901     HW: 7E0 937 090 C
       Component: GW-K-CAN TP20 H82 0752
       Revision: B9082001
       Coding: 002004
       VCID: 6889BA985278C1C7617-803C
       Component: IMMO          H03 0505
       VCID: 6A8DC0904CF4F3D7773-803E
    End----(Elapsed Time: 00:12, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
  5. Likes Uwe liked this post
    OK, that is somewhat puzzling. I have a half-baked theory, but I need to discuss it with Eric in the office tomorrow before I make myself look dumb by posting it here.
  7. Likes NZDubNurd liked this post
  8. #5
    Aug 2016
    The Hague, NL
    My suspicion is that 0B is always shown on a 7E0 gateway, I'm having the same in my car.
  9. Likes PetrolDave liked this post
  10. #6
    Aug 2019
    Hello iichel, I didn't want to bully you on WhatsApp
    I confirm that, I checked my old BCM 087 (6R0 937 087) with older gateway from Polo 6R - there 0B doesn't appear, so there are probably no errors on my part.
    Gateway from old BCM 087:
    SW 6N0 909 901
    HW: 6R0 937 087
  11. #7
    Even if that's the case, it's still a bit strange that it shows up in the list of buttons, but not here:
  12. #8
    Quote Originally Posted by CNK View Post
    With the Gateway that does exhibit the 0B in the button list, in VCDS, please go to [Options], set Debug Level to 1024, click [Apply] and then go to the Auto-Scan screen and click [Gateway Installation List] button. When after you see the list, go back from the Auto-Scan screen and click [Select] to bring up the button list. When it appears, exit VCDS gracefully. Next, look in your Debug sub-folder. ZIP up any files with current date/time stamps and send them to Support@RT along with a link to this thread.
  13. #9
    The VCDS source is peppered with little nuggets in the comments, such as this almost ten year old one
    20100412 on Uwe's insistance: tentative add of 0x0B for 7E/7F
    The T5 (which uses the same gateway as a lot of the Polotariat) has a very dumb arrangement where 0x0B exists but on K and not present in the GVL. With VCDS having no way of knowing in advance if that control module is going to be installed along with one of those gateways, we also scan for 0x0B (on the very slow K line) and present it in the installed modules list.
    However when VCDS starts an autoscan, the first thing it does is get a VIN, and from that there's a couple easy things we can do to exclude the presence of 0x0B, such as being a 6R , 6J, AA, AT chassis code. That explains why it's not in the autoscan results and scanning list. Santos prompted that tweak when he mentionned how annoying it was that 0x0B was getting scanned for every time on his LOW-NAR Jetta.
    When we get the installed modules tab, however, the waiting time for the GVL to populate is already borderline acceptable, and I don't want to lengthen it even further by connecting to the engine (which takes a long time to setup on legacy interfaces) to query a VIN just so the Polotariat can benefit from what would be a cosmetic fix
  14. Likes Santos, Uwe, NEtech, PetrolDave liked this post
  15. #10
    Hah! I totally forgot about that!
  16. Likes Eric, PetrolDave liked this post
