- Jan 16, 2019
- 23
- 11
- Cornwall, UK
- C?ID=358455
Hi All,
Hoping someone can help with a fault on my wife's Golf as can't find much on the net (that makes sense to me anyway). She was complaining that the heater wasn't hot and only luke warm air blowing out (outside temp is around -2 at the moment). I reset the flaps which seemed to resolve the issue.
I then ran a scan and found codes in the HVAC area however when cleared they just come back straight away. Any help would be gratefully received.
Many Thanks
Many Thanks
Sunday,19,January,2020,18:28:20:44739
VCDS Version: 19.6.2.0
Dealer/Shop Name: DOODY CARS
VIN: WVWZZZAUZEP007042 License Plate: PY13CFL
Mileage: 115394km-71702mi Repair Order: 19-01-2020
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEP007042 Mileage: 115394km-71702miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5517
Revision: 84H22---
Coding: 01110012034505092000
Shop #: WSC 00028 028 00072
ASAM Dataset: EV_ECM16TDI01104L906021M 002009
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F6DC09D76B38F370E-807A
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 615030000005DF
Coding: 01FA8AA1242009730377060441C52580512490C06082A4F3F440F074C002
Shop #: WSC 00028 028 00025
VCID: 7BF524CDF24BA397F2-802E
Part No SW: 5G0 907 426 M HW: 5G0 907 426 M
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00120104202100001000000000000000
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 3561F2F594EFB5E744-8060
1048834 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 102
Mileage: 115277 km
Date: 2020.01.18
Time: 09:06:15
Voltage terminal 30: 11.5 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: No enabling
Auxiliary heater: in stages-Act.val.: 1
Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
Fault Frequency: 13
Reset counter: 102
Mileage: 115248 km
Date: 2020.01.18
Time: 08:42:30
Voltage terminal 30: 14.0 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011314701031
Coding: 03000842C24102730BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 489F8B01F31D380F2F-801C
Component: WWS 130514 042 0551
Serial number: 130523132915
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y13M06D06H06M21S51S4
Coding: 00A8DD
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131001SXL
Serial number: 00000000000056818445
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [008] - Electrical Failure
Reset counter: 102
Mileage: 115238 km
Date: 2020.01.17
Time: 20:51:31
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H03 0141
Serial number: 01061376510301
Coding: 00000300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001013
Part No SW: 5Q0 959 655 M HW: 5Q0 959 655 M
Serial number: 003M1R036D0W
Shop #: WSC 00028 028 00053
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4A9BB109ED11CA1F39-801E
Belt Pretensioner left:
Component: BeltPretRevFL H35 0340
Serial number: 34169677B29051340192
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0340
Serial number: 34169676B31051340410
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 805 13
Serial number: 357670000009A2102D0M
Subsystem 4 - Part No SW: ----------- HW: 480 002 805 13
Serial number: 35867000000089402D0M
Subsystem 5 - Part No SW: ----------- HW: 480 403 105 13
Serial number: 3516502AF105EDD2708O
Subsystem 6 - Part No SW: ----------- HW: 480 403 105 13
Serial number: 3526502AF105EDD402CQ
Subsystem 7 - Part No SW: ----------- HW: 480 402 705 13
Serial number: 3556502BB1050661C21$
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AG HW: 5Q0 953 549 A
Revision: -------- Serial number: 06061304220974
Coding: 0D00
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_009_VW37.rod
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
Part No SW: 5G0 920 961 A HW: 5G0 920 961 A
Component: KOMBI 252 2210
Coding: 27A41A002780260001882A01040000
VCID: 285F2B81535DD80FCF-807C
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
Component: GW MQB High 212 2147
Revision: -------- Serial number: 31051310800412
Coding: 030100040B087300EF00005C080F00010001000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti_009.rod
VCID: 3B75E4CDB2CB6397B2-806E
Component: E221__MFL-DC1 H14 0035
Serial number: 27130000599140053192
Coding: 2C0000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 7784760603
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000062852575
Coding: 003002208001028000001000
VCID: 55A1527534AF95E7A4-8000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001586000
Coding: 0D0000
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D71EAD5ACDF6DA78C-8068
Part No SW: 5Q4 959 392 HW: 5Q4 959 392
Component: TSG BFS 007 0006
Serial number: 0000062597701
Coding: 003000208001028000801000
VCID: 7F0DD0DDE653BFB7DE-802A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001591646
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 040 0421
Serial number: V5C00306130506
Coding: 02730000FF00000021111201002800001F0100060100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F4D305D06131FB7BE-804A
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9N24035BG
End-------------------------(Elapsed Time: 03:35)--------------------------
