Results 1 to 10 of 14
Thread: Disable Speaker Monitoring while keeping Fader in Sound Settings
    Apr 2019
    I recently installed aftermarket amp + speakers with factory radio. Factory radios have build in speaker monitoring which perform basic speaker check on bootup.
    My J794 output is now going to high-to-low converter which triggers errors
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    853 0890
       Coding: 02730602BE00000051220001001808001F0500E401200405C6
       Shop #: WSC 00066 790 00326
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 33331CCC0BB105CF045-8066
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  252 8130
       Serial number: VWZ6ZMV2535287
       Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
    0512 - Rear Right Bass Speaker
              B1067 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
                        Reset counter: 206
                        Mileage: 12584 km
                        Date: 2020.01.11
                        Time: 00:00:04
                        Voltage terminal 30: 12.3 V
    0517 - Front Right Bass Speaker
              B1062 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
                        Reset counter: 206
                        Mileage: 12584 km
                        Date: 2020.01.11
                        Time: 00:00:04
    0522 - Front Left Bass Speaker
              B105F 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
                        Reset counter: 206
                        Mileage: 12584 km
                        Date: 2020.01.11
                        Time: 00:00:04
    0527 - Rear Left Bass Speaker
              B1065 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                        Reset counter: 206
                        Mileage: 12584 km
                        Date: 2020.01.11
                        Time: 00:00:04
    One way to disable that is to change byte4 to "Sounds System Installed"
    However this disables fader menu in radio settings. I would really like to keep the fader.
    Anyone know how to disable speaker monitoring without loosing radio sound settings, like the fader?
    I looked over Adaptations but there was nothing explicit. I tried changing IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic ,49 to "manual"
    but that did not do anything.
    ;SW:3Q0-035-844-B   HW:3Q0-035-844-B ---  Information Electr.
    ;Component:MU-S-S-US     724 0890, Coding:02140600FF00000051220001001808001F0500C40120050002
    ;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
    ;Monday,09,December,2019,19:36:41:18133
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
    ;VCID: 2E050DB8E09328276BB-807A
    IDE00346-Summertime-automatic,manual ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
    IDE02502-Confirmation of installation change,36 2D ,2
    IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
    IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
    IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
    IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
    IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
    IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_NAR ,30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
    IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
    IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
    IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
    IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
    IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
    IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
    IDE10604-Menu entries for mobile online services,not activated ,1
    IDE11122-Country identification: country of sale HMI,US ,2
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,blocked ,21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11,blocked ,21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12,blocked ,21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2,blocked ,21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3,blocked ,21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7,blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,blocked ,21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,blocked ,21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,blocked ,21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,blocked ,21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,blocked ,21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,blocked ,21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,blocked ,21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,blocked ,21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,blocked ,21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,blocked ,21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,blocked ,21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10,blocked ,21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11,blocked ,21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12,blocked ,21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13,blocked ,21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20,blocked ,21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22,blocked ,21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44,blocked ,21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45,blocked ,21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46,blocked ,21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47,blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9,blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,blocked ,21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21,blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4,blocked ,21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6,blocked ,21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9,blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,blocked ,21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,blocked ,21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,blocked ,21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,blocked ,21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,blocked ,21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,blocked ,21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,blocked ,21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,blocked ,21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,blocked ,21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,blocked ,21
    IDE11503-Satellite radio tuner: pre-activated subscription,05 ,1
    IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57,not activated ,192
    IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus,not activated ,192
    IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
    IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
    IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
    IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
    IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C,not activated ,192
    IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus,not activated ,192
    IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
    IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
    IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
    IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
    IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
    IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192
    IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
    IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
    IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
    IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
    IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
    IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
    IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65,not activated ,192
    IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus,not activated ,192
    IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64,not activated ,192
    IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus,not activated ,192
    IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
    IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192
    IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
    IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
    IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
    IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
    IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
    IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
    IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
    IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
    IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
    IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
    IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
    IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
    IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
    IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
    IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
    IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
    IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
    MAS00951-Bluetooth,On ,1
    MAS01968-Fan,normal ,1
    MAS03782-WLAN,On ,1
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
    ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
    ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
    ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
    ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
    ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
    ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
    ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
    ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
    ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
    ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
    ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
    ENG117808-p_HMI_Display,13 %,1
    ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
    Elapsed Time: 00:32
    Thanks !
    Jun 2017
    Try different permutations in Byte 11...
    Apr 2019
    There are only two options for long coding for byte 11.
    Internal Sound System active
    External Sound System active
    If I make the external sound system active that completely kills the signal on speaker outputs. Expected, as you are pretty much telling the J794 that there is external amplifier and the unit sends sound over Optic port. This would be applicable if I was retrofitting Fender or Dynaudio factory amp.
    Perhaps, I can play with experimental long coding...
    Quote Originally Posted by OEMplusCC View Post
    The most promising value (at least to me) seems like: 05 - Sound_System - Sound_System_external_BOOSTER
    Jun 2017
    With "permutations" I mean counting binary
    0001
    0010
    0011
    0100
    Apr 2018
    ITALY
    check my autoscan in the non-broken section, I also installed a non-OEM amp and got rid of the fault. it's been a while
    so I don't remember out of the blue.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
    Apr 2019
    Thanks for all the inputs.
    I tried playing with byte11 experimental settings. But did not find anything that would work
    Here are my results. Before each settings, I cleared codes, applied settings(with soft reset) and checked Codes again
    "Sound_System_External_Booster"
    Monday,20,January,2020,19:02:37:18133
    VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
                    Address 5F: Information Electr.       Labels: 5G0-035-MIB-STD2.clb
    Control Module Part Number: 3Q0 035 876 B    HW: 3Q0 035 876 B
      Component and/or Version: MU-S-NS-US    853 0890
               Software Coding: 02730602BE00000051220005001808001F0500E401200405C6
                Work Shop Code: WSC 00066 790 00326
                  ASAM Dataset: EV_MUStd4CDELP 001001 (VW37)
                           ROD: EV_MUStd4CDELP_VW37.rod
                          VCID: 33331CCC0A3105CF045-8066
    7 Faults Found:
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:00:43
                        Voltage terminal 30: 12.1 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: OK
    0512 - Rear Right Bass Speaker
              B1067 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:00:49
    0517 - Front Right Bass Speaker
              B1062 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:00:49
              B1064 13 [009] - Open Circuit
              [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:00:49
    0522 - Front Left Bass Speaker
              B105F 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:00:49
              B1061 13 [009] - Open Circuit
              [Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:00:49
    0527 - Rear Left Bass Speaker
              B1065 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:00:49
    System_internal_individual
               Software Coding: 02730602BE00000051220004001808001F0500E401200405C6
                          VCID: 33331CCC0BB105CF045-8066
    7 Faults Found:
              U1014 00 [009] - -
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:09:28
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:09:33
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:09:33
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:09:34
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:09:33
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:09:34
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:09:33
    "Sound_System_No_Allocation"
               Software Coding: 02730602BE00000051220000001808001F0500E401200405C6
    6 Faults Found:
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:11:55
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:11:55
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:11:56
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:11:55
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:11:56
                        Reset counter: 215
                        Mileage: 12743 km
                        Date: 2020.01.20
                        Time: 19:11:55
    Rest of available options behaved the same way, I dont want to spam this post with errors.
    It looks like I only have three options:
    1. Keep the coding as from factory and live with the VCDS errors (my OCD does not like it)
    2. Change byte4 to "Sound System Installed" this will remove errors but I loose fader settings in infotainment. I'm still able to vary sound left and right but not front to rear
    3. Aftermarket hardware change. Either get a high-to-low converter which has "speaker load build in". I know audiocontrol is working on a converter like that, its still in beta. Or get an aftermarket EQ for sound balancing
  9. #8
    Apr 2019
    Thanks for the suggestions. I found your scan here but nothing stood out. I tried changing byte 1 2 and 11 but no difference
    Here is breakdown of your long coding, at least the things that would be applicable for this situation
    02140600FF00000051220001001808001F0500C40120050002
    021406 - Atlas [CA]
    00 - Navigation Not Active
    FF000000 - 4 Channel / 8 Speakers
    51 - Microphone, Aux active/not active etc
    22 - Country related radio frequencies
    00 - Tuner stuff
    01 - Internal Sound System
    00 - Antenna Stuff
    When it comes to sound settings your code is very similar to mine. I'm surprised you are not getting speaker errors like me.
    I did try chaning my coding to "Atlas" with "4 channel/8 speakers" but that did nothing. Just got 8 errors instead of 6
    Just curious, why do you have your radio set to Atlas if you have golf? Different sound processing?
  10. #9
    Apr 2019
    One more quick idea.
    What about if I adjusted following adaptations to 0Hz and 0 volume? Would that be silly?
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
  11. #10
    Apr 2018
    ITALY
    02730000FF0000005111000100080A001F0206C40120010003
    I am confused. this above is my coding when the car was stock. the 5F is a Composition Media, no navigation. I had no sound system, just the four passive WF+TW.
    I installed a dsp/amp with high level inputs, and that gave me the speaker errors like you have. I don't remember if it said OPEN CIRCUIT or what, but it surely complained about speakers.
    I was almost on the verge of removing the amplifier, because I also don't want errors in my autoscan. then I somehow changed the coding and I got rid of the errors. again, I didn't keep a log so I can't remember. I am almost positive I used the experimental coding as a helper.
    my actual coding is:
    02730000AA0000005111000100080A031F0206D40120010003
    I hope it helps you. as to why the car type is set to Atlas, I have to idea.
    EDIT: hold on a second, I just realized that the coding you cited as mine, is not the correct one. maybe you copied&pasted wrong.
