Results 1 to 4 of 4
Thread: SQ7 4M VCDS issue
    New User
    Jan 2020
    SQ7 4M VCDS issue
    I was playing around with VCDS, Central electrics 09 -> Basic settings 04 -> Headlight basic settings
    After this on the ODO: "Audi adaptive light: fault." and "Main beam assist: fault." + lot of fault codes, anyone could help me out?
    Saturday,18,January,2020,17:34:28:08900
    VIN: WAUZZZ4M0HD060084   License Plate: SQ-7
    Mileage: 88370km-54910mi   Repair Order:
    Chassis Type: 4M-AU73 (4M2)
    Scan: 01 02 03 06 08 09 13 15 16 17 18 19 29 32 36 39 3C 42 44 46
              47 52 5F 61 6C 6D 74 81 82 84 8B A5 A9 AC BA BB BC C0 C4 CB
              CF D4 D5 D6 D7
    VIN: WAUZZZ4M0HD060084   Mileage: 88370km-54910miles
    84-Night Vision -- Status: Malfunction 0010
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    BA-Motor Mounts -- Status: OK 0000
    C4-DC/DC Converter -- Status: OK 0000
    CB-Rear Axle Steering -- Status: OK 0000
    D4-Roll Control 1 -- Status: OK 0000
    D5-Roll Control 2 -- Status: OK 0000
    Address 01: Engine (J623-CZAC)       Labels: Redir Fail!
       Part No SW: 4M0 907 409     HW: 057 907 309
       Component: 4.0l V8 TDI   H45 0005
       Revision: D1H45---
       Coding: 2A2A403A056E050334380400000000000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM40TDI0114M0907409 001009
       ROD: EV_ECM40TDI0114M0907409_AU73.rod
       VCID: 6E85323C101529372BB-803A
       Electrical Charger:
       Subsystem 1 - Part No SW: 057 145 601 D    HW: 057 145 601 D
       Component: J1123 - EAV  H06 1003
       Serial number: VS5-2-ESC401-0003770
    Address 02: Auto Trans        Labels:* None
       Part No SW: 4M0 927 158 AD    HW: 0D6 927 156 F
       Component: 0D6  40TDIRdW H05 1007
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 76B51A5C684511F7E3B-8022
    Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
       Part No SW: 4M0 907 379 Q    HW: 4M0 907 379 N
       Component: ESP9 Premium  H09 0657
       Coding: 2C983AB230A80A96919E58995C8156A6E6A6DA345C0C50891A3A6A6567655B
       ASAM Dataset: EV_ESP9BOSCHAU536K 012013
       ROD: EV_ESP9BOSCHAU536K_AU73.rod
       VCID: 45D7AD906523CA6FBA1-8010
    15383808 - Databus
              U1123 00 [040] - Received Error Message
              [HAL_Status_is_"Lenkungsausfall"_and_rear_wheel_steering_angle_is_correct]
                        Mileage: 88365 km
                        Date: 2020.01.18
                        Time: 15:58:46
                        8E 00 80 04 88 24 00 00 00 00
    415488 - TPMS Warning; Front Left Tire
              C1055 00 [040] - Flat
                        Mileage: 88101 km
                        Date: 2020.01.10
                        Time: 16:25:10
                        96 00 80 15 88 24 00 00 D0 60
    419584 - TPMS Warning; Rear Left Tire
              C1059 00 [040] - Flat
                        Mileage: 88101 km
                        Date: 2020.01.10
                        Time: 16:25:10
    419840 - TPMS Warning; Rear Right Tire
              C105B 00 [040] - Flat
                        Mileage: 88101 km
                        Date: 2020.01.10
                        Time: 16:25:10
       Part No SW: 4M1 959 760 E    HW: 4M1 959 760 E
       Component: MEM-BFS       008 0031
       Serial number: 00000257621399
       Coding: 001010000000B0410000010101010000110000313100000000000000000000
       ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
       VCID: 3B23CB6813E78C9FDC5-806E
       Part No SW: 4M0 820 043 R    HW: 4M0 820 043 R
       Component: Klima Zone 2  H52 0093
       Coding: 6818401D5140010900220180020000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 3431E0543EB943E71DF-8060
       Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
       Component: J216 FLuftV  H08 0003
       Serial number: 00000000000001543769
       Subsystem 2 - Part No SW: 4G0 907 658 B    HW: 4G0 907 658 B
       Component: Humidity_Sens  H01 0006
       Serial number: 8A9889A880PAG0FSA002
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Coding: 07501943C13900CD050D8715582F08F9130331009000000000000000620016810A4502AB22B70A
       VCID: 025D768C348D3D57DF3-8056
       Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
       Component: WWS536 170403  044 0893
       Serial number: 90115300401709301098
       Coding: 1BC7F7
       Serial number: 20238430X81A955547A0
       Coding: 0200FF
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AD    HW: 4M0 941 531 AD
       Component: E1 - LDS  H06 0008
       Serial number: 18 04 2017  00908298
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE107021723510168
       Coding: 030000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 BE    HW: 4M0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: Q00285134
       Subsystem 6 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
       Component: SL-Q7NF/AU736  H10 0013
       Serial number: 00000000000000055890
    67735 - Databus
              [MxB not available]
                        Reset counter: 75
                        Mileage: 88370 km
                        Date: 2020.01.18
                        Time: 17:17:15
                        average_Voltage_terminals: 12.10 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 15.00 ∞C
                        interior_temperature: 21.50 ∞C
                        Vehicle speed: 0.00 km/h
    67737 - Databus
              [MXB_error-lamp_requested]
                        Reset counter: 75
                        Mileage: 88370 km
                        Date: 2020.01.18
                        Time: 17:17:13
       Part No SW: 4M0 907 561 E    HW: 4M0 907 561
       Component: LRR4          H10 0220
       Coding: 3477FFF378FFEC06747860A0
       ASAM Dataset: EV_ACCBOSCHAU736 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 323DE64CC4AD4DD70F3-8066
    1389 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [FAULT_VBAT_BUSMON_LOW]
                        Reset counter: 115
                        Mileage: 88365 km
                        Date: 2020.01.18
                        Time: 15:57:37
                        Control Module temperature: 32 ∞C
                        Voltage terminal 15: 9.3 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
       Part No SW: 4M0 959 655 G    HW: 4M0 959 655 G
       Component: Airbag10.44   H06 0106
       Serial number: 003UN0002B5V
       Coding: AACCF0C00CA00000985400F3D00C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006015
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: 3FDBBF7807FF90BFF0D-806A
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 4M0857705D0131R01130
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 4M0857706J0130R02193
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 062 204 17
       Serial number: 3577Y009F234EB2160B5
       Subsystem 4 - Part No SW: -----------    HW: 442 061 104 17
       Serial number: 3587Y00C72246103337L
       Subsystem 5 - Part No SW: -----------    HW: 442 0B2 704 17
       Serial number: 3517700A525CC3720083
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 704 17
       Serial number: 35277009B25E5CE3438S
       Subsystem 7 - Part No SW: -----------    HW: 442 0C0 305 17
       Serial number: 35575009B2225F5372EG
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C0 305 17
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500C122A9DB3143B
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C1 804 17
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500BF223B67571AB
       Subsystem 10 - Part No SW: -----------    HW: 442 421 904 17
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00A12246103D270
       Subsystem 11 - Part No SW: -----------    HW: 442 421 904 17
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00B52246102135Z
       Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 015F7980318B264FC69-8054
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 4M0 920 790 B    HW: 4M0 920 790 B
       Component: FBenRDW       H17 0310
       Coding: 048D08E07CB8000800A3E9601100400000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 2E05F23CD09569376BB-807A
    Address 18: Aux. Heat (J364)       Labels:* None
       Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
       Component: HSG           H11 0090
       Coding: 0D0F01
       ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
       ROD: EV_AuxilParkHeateEBEAU736.rod
       VCID: 290F0120E97B0E0FBE9-807C
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Fault Frequency: 9
                        Reset counter: 105
                        Mileage: 87933 km
                        Date: 2019.12.23
                        Time: 15:11:13
                        Coolant temperature of parking heater: 58 ∞C
                        Coolant temperature of auxiliary heater_Textual: numerical value: no text
                        Engine_coolant_temperature: 60.00 ∞C
                        Engine_coolant_temperature_Textual: numerical value: no text
                        Voltage terminal 30: 11.00 V
                        System status: 144
                        Auxiliary heater operating status: Start
                        Outside_Temperature_Additional_Heating: 4.50 ∞C
                        Engine_Speed: 2498.00 /min
                        Fuel_Level_Input_Heater: 42 l
       Part No SW: 4M2 907 468 D    HW: 4M2 907 468 A
       Component: Gateway       H16 0108
       Revision: 4W020004    Serial number: 0444W000D17411
       Coding: 03010001000806407F0000000059003074130007B40000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002_AU73.rod
       VCID: 392FD16019DBBE8FCE9-806C
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20170512091839 00918
       Serial number: 5150473804
    8519683 - Energy Management Active
              U140B 00 [008] - -
                        Reset counter: 115
                        Mileage: 88365 km
                        Date: 2020.01.18
                        Time: 15:32:17
                        EM_vehicle_state: 02 1C
                        Static current shutdown level: Deactivation stage 0
                        Auxiliary heater activation restriction request-Parking heater: Not permitted
                        Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0024
       VCID: 77AB17586F4F68FFF8D-8022
    Address 32: Differential Locks (J187)       Labels: None
       Part No SW: 8W0 907 163     HW: 8W0 907 163
       Component: QSP QCU Gen2  H07 0040
       Revision: 5WK12700    Serial number: 605718616252007
       Coding: 0300
       ASAM Dataset: EV_TVDCQSP22 001007
       ROD: EV_TVDCQSP22.rod
       VCID: 79AF1160595B7E8F8E9-802C
       Component: MEM-FS        008 0031
       Serial number: 00000257621287
       Coding: 00181B000000B0410000010101010000110000313100000000000000000000
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566 D    HW: 4M0 907 566
       Component: MRR1Rear      H18 0410
       Revision: --------
       Coding: 0EE002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001022
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 3635DA5C28C551F723B-8062
       Part No SW: 4M0 959 793 E    HW: 4M0 959 793 C
       Component: TSG FS        009 0057
       Serial number: 0000256782734
       Coding: 005F9A015E000080000030B2
       VCID: 40D9BC847A01EF47897-8014
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H20 0005
       Serial number: 0000821598
       Coding: B2110101000101
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
       Part No SW: 8W0 907 064 DD    HW: 8W0 907 064 DD
       Component: BCM2 MLBevo   019 0366
       Coding: 01341E000F110060630980000E00180203004000004F02502F0400000504803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 013013
       ROD: EV_BCM2HellaAU736_013_AU49.rod
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY1710202ZA
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000069496239
       Subsystem 3 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
       Component: GEB.F.Heckoef  H16 0816
       Serial number: 94210751
    65907 - Alarm Horn / Siren for Anti-Theft System
              B131D 29 [008] - Signal Implausible
                        Reset counter: 70
                        Mileage: 88184 km
                        Date: 2020.01.13
                        Time: 09:54:25
                        Supply voltages-Supply voltage: Terminal 30: 12.514 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.528 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.555 V
                        general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 ∞C
                        general_additional_freeze_frame-coprocessor_spi_status: 00000000
                        general_additional_freeze_frame-dataflash_status: 00000000
                        general_additional_freeze_frame-interior_temperature: -50.0 ∞C
                        general_additional_freeze_frame-Operating_Status: 00000000 00000000
                        general_additional_freeze_frame-production_mode: not active
                        general_additional_freeze_frame-reset_cause: 00000000
                        general_additional_freeze_frame-Reset_counter: 0
                        general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                        general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                        general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                        general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 02 98
                        general_additional_freeze_frame-Transport_Mode: not active
                        general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                        can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
       Part No SW: 4M0 035 223 C    HW: 4M0 035 223
       Component: MIB2_amp_PD   H03 0440
       Serial number: 00000000027679
       Coding: 01355608008AF53AAF0000010000
       ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
       ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
       VCID: 231313088B57D45FF45-8076
       Part No SW: 4M0 959 792 E    HW: 4M0 959 792 C
       Component: TSG BFS       009 0057
       Serial number: 0000256906770
       Coding: 005F9A015E000080000030B0
       Part No SW: 4M1 035 036     HW: 4M1 035 036
       Component: MU-P-LN-EU    033 0917
       Serial number: A805E0HB010268
       Coding: 013756010000000013110002000A00332F001CE5017001009E
       VCID: 63935308CBD7945FB45-8036
       Subsystem 1 - Part No SW: V03 959 802 DE    HW: -----------
       Component: ECE 2019  --- 0175
       Subsystem 2 - Part No SW: 4M1 919 605     HW: 4M1 919 605
       Component: AU536_DU_HIGH  H44 0008
       Serial number: AUZ8Z9HJM00BTU
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 H    HW: 4M0 919 615 H
       Component: ControlUnit_P  H15 0209
       Serial number: 09051700000000000604
       Component: Gracenote2  --- 1015
    Address 61: Battery Regul. (J1120)       Labels: None
       Part No SW: 4M0 915 105 B    HW: 4M0 915 105 B
    New User
    Jan 2020
       Part No SW: 4M0 907 428 E    HW: 4M0 907 428
       Component: Areaview 2    H13 0315
       Serial number: C854607JG016811
       Coding: 02350601BE0FA10008404000
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
       ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
       Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: 31333085600000
       Coding: 0070
       ROD: EV_DeckLidCONTIAU736_AU73.rod
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 4M0 907 777 J    HW: 4M0 907 777 B
       Component: Fahrwerk-SG   H35 1214
       Serial number: 1705170257
       Coding: 3E607048F8
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
       Component: V66LFKompOLV  H06 0013
       Serial number: 00000000004130143284
       Coding: 303030
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M1 713 041 E    HW: 4M1 713 041 F
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 20170429000678
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 270B0718FF6F387FA8D-8072
       Part No SW: 4M0 919 617 B    HW: 4M0 919 617 B
       Component: HeadUpDisplay H29 1640
       Coding: 5F01C0
       ASAM Dataset: EV_HudNSEIKAU736 001017
       ROD: EV_HudNSEIKAU736.rod
    Address 84: Night Vision (J853)       Labels:* Redir Fail!
       Part No SW: 4M0 907 547 B    HW: 4M0 907 547
       Component: NV-ECU-Gen3   H10 0037
       Serial number: 635868600201719
       Coding: 200111
       ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
       ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
       VCID: 3333E3483BB744DF045-8066
       Camera For Night Vision System:
       Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
       Component: NV-CAM-Gen3  H05 0007
       Serial number: 639589400A1708900444
    16389 - predictive route data
              B1630 02 [008] - Signal Failure
                        Reset counter: 109
                        Mileage: 88140 km
                        Date: 2020.01.11
                        Time: 18:52:57
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 4M0 907 541 E    HW: 4M0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU736 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
       VCID: 3039EC44CAA17FC7797-8064
              U1400 00 [008] - -
                        Reset counter: 115
                        Mileage: 88365 km
                        Date: 2020.01.18
                        Time: 15:57:37
                        Voltage terminal 15: 9.4 V
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
       Component: BVS           H14 0042
       Coding: 0407030600000404032023B6CD0000B4B0F0C020F280
       ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
       VCID: 2F3BEF38D79F603F60D-807A
    1123669 - Left Matrix High Beam
              C1175 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 75
                        Mileage: 88365 km
                        Date: 2020.01.18
                        Time: 15:10:01
                        Control Module temperature: 39 ∞C
                        Voltage terminal 15: 11.40 V
    1123670 - Right Matrix High Beam
              C1176 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 75
                        Mileage: 88365 km
                        Date: 2020.01.18
                        Time: 15:10:01
    1123600 - predictive route data
                        Fault Frequency: 21
                        Reset counter: 115
                        Mileage: 87945 km
                        Date: 2019.12.24
                        Time: 13:06:09
                        Control Module temperature: 14 ∞C
                        Voltage terminal 15: 14.90 V
    1123601 - predictive route data
                        Reset counter: 114
                        Mileage: 88253 km
                        Date: 2020.01.15
                        Time: 09:34:29
                        Control Module temperature: 10 ∞C
                        Voltage terminal 15: 15.00 V
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 4M0 907 159     HW: 4H0 907 159 A
       Serial number: 170407200200
       VCID: 70B92C440A213FC7397-8024
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H04 0005
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736_AU49.rod
    Address BA: Motor Mounts (J931)       Labels: None
       Part No SW: 4M0 907 145 D    HW: 4M0 907 145 B
       Component: AEMevo        H09 0111
       ASAM Dataset: EV_AEMZFAU736 006012
       ROD: EV_AEMZFAU736_006.rod
       Part No SW: 4M0 959 795 E    HW: 4M0 959 795 C
       Component: TSG HFS       009 0057
       Serial number: 0000258027165
       Coding: 004F980000000080000030A0
       VCID: 42DDB68C740DFD579F3-8016
       Component: TSG HBFS      009 0057
       Serial number: 0000258026854
    Address C0: Act. for Ext. Noise (J943)       Labels: None
       Part No SW: 4M0 907 160     HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H10 0001
       Serial number: 170317200556
       VCID: 6889442432F1F707617-803C
    Address C4: DC/DC Converter (J519)       Labels: 4M0-959-663.clb
       Part No SW: 4M0 959 663 B    HW: 4M0 959 663 B
       Component: PCU10         022 0317
       ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
       ROD: EV_DCDC48V210ABOSCHAU736.rod
    Address CB: Rear Axle Steering (J1019)       Labels:* None
       Part No SW: 4M0 909 145 G    HW: 4M0 909 145 E
       Component: HAL_MLBevoH08 0607
       Revision: --------    Serial number: CCC_007_D_07_03
       Coding: 008508
       ASAM Dataset: EV_RearAxleSteerZFAU736 005010
       ROD: EV_RearAxleSteerZFAU736_005_AU73.rod
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 4M0 907 590 D    HW: 4M0 907 590
       Revision: --------
       Coding: 0EE002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001022
       ROD: EV_RearRadarS2BoschAU736.rod
    Address D4: Roll Control 1 (----)       Labels: None
       Part No SW: 971 907 156 K    HW: 971 907 156 K
       Component: EAWSH16 0111
       Serial number: 00120170403069
       ASAM Dataset: EV_EAWSSchaeFront 008001
       ROD: EV_EAWSSchaeFront_AU73.rod
       VCID: 28090424F2713707A17-807C
    Address D5: Roll Control 2 (----)       Labels: None
       Serial number: 00120170411104
       ASAM Dataset: EV_EAWSSchaeRear 008001
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
       Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
       Component: LED1L         H10 2003
       VCID: 1A6D2EECBC1D9597273-804E
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
       Component: LED1R         H10 2003
    End----------(Elapsed Time: 03:00, VBatt start/end: 12.0V/12.0V)-----------
    Moved to New Users section.
    The VCDS product manual specifically warns that:
    You should refer to the Factory Repair Manual for your particular car (or some other documented procedure) before "playing" with the Basic Settings function. Failure to follow the proper procedures can result in serious damage to the vehicle.
    Now I do hope that someone can help you out with this, but my guess is that the path of least resistance is to take it to the dealer and let them recalibrate it.
    New User
    Jan 2020
    Yes, I took the car to the dealer and they recalibratet it. 122€..
  5. Likes Uwe liked this post
