Results 1 to 9 of 9
Thread: Audi a3 2016 P00B7
    Jan 2020
    Las Vegas, USA
    Audi a3 2016 P00B7
    insufficient coolant flow
    Saturday,18,January,2020,16:37:27:18491
    VIN: WAUA7GFF8G1062994   License Plate:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F 6C BB BC
    VIN: WAUA7GFF8G1062994   Mileage: 89978km-55909miles
    Address 01: Engine (J623-CNSB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 0A1D00122424000F3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
       ROD: EV_ECM18TFS0208V0906264F.rod
       VCID: 3FDBBE0E27F93F4FF0D-806A
    15470 - Insufficient Engine Cooling / Coolant Flow
              P00B7 00 [036] - -
                        Mileage: 89978 km
                        Date: 2020.01.18
                        Time: 16:14:34
                        Engine speed: 704.50 /min
                        Normed load value: 22.7 %
                        Coolant temperature: 107 °C
                        Intake air temperature: 48 °C
                        Ambient air pressure: 930 mbar
                        Voltage terminal 30: 14.082 V
                        Engine: operating status: IS
                        Engine temp. management actuator: raw value: 249
                        Engine temperature management actuator: stop open: 135
                        Engine temperature management actuator: after-run stop: 3956
                        RVC_SP: 4.00 °
                        RVC_AV: 7.61 °
                        RVCPWM: 26.306 %
    16986 - Insufficient Engine Cooling / Coolant Flow
              P00B7 00 [096] - -
                        Mileage: 89859 km
                        Date: 2020.01.16
                        Time: 22:41:38
                        Engine speed: 950.25 /min
                        Normed load value: 21.6 %
                        Coolant temperature: 77 °C
                        Intake air temperature: 56 °C
                        Ambient air pressure: 950 mbar
                        Voltage terminal 30: 14.003 V
                        Engine temp. management actuator: raw value: 2136
                        Engine temperature management actuator: stop open: 145
                        Engine temperature management actuator: after-run stop: 3948
                        RVC_SP: 129.25 °
                        RVC_AV: 133.48 °
                        RVCPWM: 28.870 %
    16987 - Insufficient Engine Cooling / Coolant Flow
              P00B7 00 [032] - -
                        Mileage: 89858 km
                        Date: 2020.01.16
                        Time: 18:13:19
                        Vehicle speed: 255 km/h
                        Coolant temperature: 105 °C
                        Intake air temperature: 41 °C
                        Voltage terminal 30: 12.714 V
                        Engine: operating status: ES
                        Engine temp. management actuator: raw value: 3563
                        RVC_SP: 233.50 °
                        RVC_AV: 229.17 °
                        RVCPWM: -28.900 %
    Readiness: 0000 0100
       Part No SW: 0D9 300 042 C    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4907
       Revision: 06253104    Serial number: TFK01510272167
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 196F3096991D317F2E9-804C
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 63075000000066
       Coding: 13FF6A9234260A6E0180020981C729C8562C5080408194B4024100548208
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 79AF1016795DD17F8E9-802C
       Revision: 00021000    Serial number: 0386846065
       Coding: 030C0C
       VCID: 3A2DCF1A3CDB1A67C73-806E
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Component: AC Automat    H14 0060
       Revision: 20028000    Serial number: 00000000791174
       Coding: 03000014010000000000000000001400
       VCID: 323DE73AE4ABE2270F3-8066
       Serial number: 5248C9D7000000000001
       Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
       Component: BCM MQBAB MNA H24 0175
       Serial number: 01061530700821
       Coding: 04151A42C04122F541C04004511007000800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7F5BFE0E6779FF4FB0D-802A
       Component: WWS371 150808  042 0585
       Serial number:         151102185255
       Coding: 0A47F7
       Serial number: 60930759
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 07 09 2015  00000897
       Serial number: 00000000000064307183
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST000NEEVA00000
       Coding: 101F00
    204546 - Remote key 2
                        Reset counter: 252
                        Mileage: 89899 km
                        Date: 2020.01.17
                        Time: 12:28:55
       Revision: --------    Serial number: 39391531520154
       Coding: 0010150011
       VCID: 43D3B2FE4B115BAF945-8016
       Serial number: 003GCR03YLC%
       Coding: 9DCCFCC0000000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CBA6EE7F29778F48D-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34230167A13111551025
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34230168A13111541210
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001ENJXN
       Coding: 303332
       Subsystem 4 - Part No SW: -----------    HW: 480 003 010 15
       Serial number: 35700000000809E4671L
       Subsystem 5 - Part No SW: -----------    HW: 480 003 010 15
       Serial number: 35800000000749E4671P
       Subsystem 6 - Part No SW: -----------    HW: 480 400 611 15
       Serial number: 3510002C51D73C64412
       Subsystem 7 - Part No SW: -----------    HW: 480 400 911 15
       Serial number: 3520002A11DBD62241C2
       Subsystem 8 - Part No SW: -----------    HW: 480 401 708 15
       Serial number: 3550002A31CB0C0622D1
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 401 708 15
       Serial number: 3560002A31CB0C03335-
       Part No SW: 8V0 953 521 FH    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 12111508490351
       Coding: A018
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 05576CE605A5A59FFA1-8050
       Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
       Component: KOMBI         H03 6423
       Coding: 0BE419192B80D7050200A8001800000000000000
       VCID: 45D7ACE64525659FBA1-8010
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 08111510803777
       Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
       ROD: EV_GatewConti_013.rod
       Serial number: 06 11 2015  C0015703
       Revision: 00000000    Serial number: 15000244876007
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E1221EBFEC171DF-8060
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 031015BJ216644
       Coding: 00101B204000048000000002
       VCID: 41DFB8F6510D49BF869-8014
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0102
       VCID: 44D1B1E24E1F5C97ADF-8010
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 300815BHT08779
       Coding: 001013204000048000000002
       VCID: 40D9BDF25A0740B7897-8014
       Coding: 011A000101000000
       VCID: 75B71C265545B51FEA1-8020
       Part No SW: 8V0 035 844 C    HW: 8V0 035 844
       Component: MU-S-S-US     014 0660
       Serial number: A7A01211151261
       Coding: 01730100FF0A000011220001001A00002F0001440100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 392FD01639DD117FCE9-806C
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9FY30EBL2
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
       Serial number: C1000026091500030025
              B11CF 53 [009] - Deactivated
                        Reset counter: 248
                        Mileage: 89845 km
                        Date: 2020.01.12
                        Time: 12:52:19
                        Voltage terminal 30: 14.2 V
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_2CamSysRearPASE.rod
       VCID: 3039ED32EAA7D037797-8064
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 151015BJE1256B
       Coding: 000013204000048000000002
       Serial number: 151015BJE12574
    End----------(Elapsed Time: 01:33, VBatt start/end: 12.2V/12.3V)-----------
    Isn't this under campaign recall for safety or under warranty?
    Is there an MIL?
    Jan 2020
    Las Vegas, USA
    No mil light.
    I think the recall on water pump is only Audi A4. Audi co. Warranty only 50000 k miles or 4 years.
    Thank you very much, for helping me
    Mc
    No mil light.
    Mc
    Did you know your car has much more warranty than you think, were you told otherwise?
    Did you JPPSG yet?
    Well if there is no MIL what's the reason to be concerned, unless of course you are worried about your engine or burning down a nice piece of property you reside your vehicle in or attach your bed too go to sleep at night?
    What kind of a pillow do you use and does it block your ears on sides to muffle noise for a smoke detector, you do have a smoke detector right?
    Is the coolant pump in this engine, the same part number & design type?
    Was that pump also superseded to the same part number as a replacement in both the 1.8 & 2.0 engines, early type Bosch, late type Pierburg?
    Was it the pump used in the recalled vehicles the same & was software already updated, you know like the other cars that caught fire shortly afterward or when the codes were dismissed in a similar fashion?
    https://static.nhtsa.gov/odi/rcl/201...8V229-5195.pdf
    https://www.carcomplaints.com/news/2...-lawsuit.shtml
    All important questions no?
    8V0 906 264 F 0003
    Hey did you know another software update exists?
    Hey according to Audi your car has this below as disseminated by them publicly, did you know that?
    https://literature.vw.com/calibration_lookup.asp
    ECM 8V0906264F 0004 AXAJ 890EA948 GVGAV02.0APA
    Huh I wonder what the conformity application says?
    https://iaspub.epa.gov/otaqpub/displ...d=43249&flag=1
    Vehicle Identification No. WAUA7GFF8G1062994
    Model Audi A3 limousine 1.8
    A3
    Date of production 26.11.2015
    Model year 2016
    Sales type 8VS57X
    Engine Code CNSB
    Transmission Code QYZ
    Emission standard 0GT Emission standard SULEV
    Section 21 Pg. 7 Other Information Engine Code R.CH-No.: Revision Date Test Group GADXV02.0APA all 12-13-2016
    Engine Control Module (ECM) Information 1.8T
    Model Engine Code Software ID CVN CAL ID
    Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264D 0001 EDFAED27 8V0264D 0001 AXAJ
    Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264D 0002 C88FD0EA 8V0264D 0002 AXAJ
    Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264D 0003 20791AD7 8V0264D 0003 AXAJ
    Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264D 0004 EB8B8B0B 8V0264D 0004 AXAJ
    Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264F 0001 A6F22067 8V0264F 0001 AXAJ
    Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264F 0002 33442DB8 8V0264F 0002 AXAJ
    Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264F 0003 C7D2465C 8V0264F 0003 AXAJ
    Audi A3, A3 Cabrio DQ250-6F 125kW CNSB 8V0906264F 0004 890EA948 8V0264F 0004 AXAJ
    I just love asking questions don't you?
    OP,
    Could you post the OBD2 data all modes please?
    Did you at least express your concern to NHTSA yet?
    https://www-odi.nhtsa.dot.gov/VehicleComplaint/
    Jan 2020
    Las Vegas, USA
    Thanks for help me
    My car running about 30 minutes and over heat no acceleration.
    Thank again I'll check with Audi about recall
  7. #7
    Thanks for help me
    Did I say there was a recall or did I ask if it was under recall or possible warranty?
    Please post the requested scan data & do you have an MIL now, that like you said, could you do that please?
  8. #8
    Jun 2019
    Quote Originally Posted by maxium View Post
    Thanks for help me
    Hey Maxium.....See this link...Jack was of great help to me.......If it were me I would go straight to your dealer....https://forums.ross-tech.com/showthr...highlight=2015
  9. #9
    Yeah that thread was a bunch of fun questions too & that brought relevant answers to light, huh?
    Are not all these engines the same crap with a different shovel of EA888 fun?
  10. Likes tclark18 liked this post
