Results 1 to 7 of 7
Thread: Car wont start after changing clutch, immobilizer key lost com, any help please
    Jun 2019
    Birmingham, UK
    helo all, my colleague changed the clutch on this vehicle, and the car starts for only about 2 seconds cuts off.
    on the dash it says ''SAFE''
    cleared all codes, comes back with same on immo
    anyone come across this before?
    any thought please, thanks again
     Saturday,18,January,2020,16:38:59:58999
    VIN: VSSZZZ5PZ9R010587   License Plate:
    Mileage: 279310km-173555mi   Repair Order:
    Chassis Type: 5P (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: VSSZZZ5PZ9R010587   Mileage: 279310km-173555miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 021 SK    HW: 03G 906 021 AN
       Component: R4 1,9L EDC G000SG  1444
       Revision: --H08---    Serial number: SEX7Z0H631M0EF
       Coding: 0050071
       Shop #: WSC 06402 785 00200
       VCID: 7AADF37370D13EA7873-802E
    005488 - Engine Start Blocked by Immobilizer
                   P1570 - 000 -  - MIL ON
                        Fault Status: 11110000
                        Mileage: 279315 km
                        Time: 00:03:05
                        RPM: 1071 /min
                        Voltage: 12.84 V
                        Bin. Bits: 00001100
                        Bin. Bits: 11000000
                        Bin. Bits: 00100001
    005659 - Glowplug for Cylinder 2 (Q11)
                   P161B - 000 - Open Circuit
                        Mileage: 279315 km
                        Time: 00:00:48
                        Voltage: 12.31 V
                        Bin. Bits: 00001100
                        Temperature: 20.7C
                        Bin. Bits: 00110000
    005661 - Glowplug for Cylinder 4 (Q13)
                   P161D - 000 - Open Circuit
                        Mileage: 279315 km
                        Time: 00:00:48
                        Voltage: 12.31 V
                        Bin. Bits: 00001100
                        Temperature: 20.7C
                        Bin. Bits: 00110000
    Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
       Component: MABS MK70M          0104
       Revision: 00H32001
       Coding: 0016641
       VCID: 76B5E74344C95AC7E3B-8022
       Part No: 5P0 907 044 K
       Component: ClimatronicPQ35 011 0702
       VCID: 3829297B0E5DECB7317-806C
       Revision: 00H54000    Serial number: 00000005852089
       Coding: E1880F2F00041000431800000000000000007F075C400000000000000000
       Shop #: WSC 00137 211 56823
       VCID: 33331E57173B0FEF045-8066
       Subsystem 1 - Part No: 5P0 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 160608 022  0601
       Coding: 00056208
       Shop #: WSC 00137
       Subsystem 2 - Part No: 1P0 955 559   Labels: 1P0-955-559.CLB
       Component: REGENLICHTSENSORH04 0090
       Coding: 00152622
       Shop #: WSC 00137
                        Reset counter: 98
                        Mileage: 279315 km
                        Voltage: 12.40 V
                        Reset counter: 98
                        Mileage: 279315 km
                        Voltage: 12.40 V
    Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
       Part No SW: 1K0 919 475 E    HW: 1K0 919 475 E
       Component: PARKHILFE     005 1406
       Revision: 00005000    Serial number: 0 263 004 292
       Coding: 000001
       Shop #: WSC 04941 000 00000
       VCID: 34311D4B1E3508D71DF-8060
       Component: S9 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD248KGD
       Coding: 0021305
       VCID: 3D27386F217FC99FE21-8068
       Subsystem 1 - Serial number: 6332MSME290475389
       Subsystem 2 - Serial number: 6342MSME2B560C22C
       Subsystem 3 - Serial number: 6351HSME174957718
       Subsystem 4 - Serial number: 6361HSME173E33548
       Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
       Component: J0527           752 0101
       Coding: 0002042
       VCID: 04518D8B02157857EDF-8050
       Component: E0221           001 0010
       Part No: 5P0 920 927 B
       Component: KOMBIINSTRUMENT VO3 0450
       Coding: 0002401
       Shop #: WSC 00011 067 57207
       VCID: 34311D4B123508D71DF-8060
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K0860482D3
       Coding: E9A07F060002022203
       VCID: 3537204F194F11DF2A1-8060
       Component: IMMO            VO3 0450
    01176 - Key
       Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1520
       Revision: 71009005    Serial number: 00000364288508
       Coding: 0004784
       VCID: 40D9419B568DA477897-8014
                        Fault Status: 01100101
                        Reset counter: 98
                        Mileage: 279315 km
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 77     2301
       Revision: 00H15000
       VCID: 2A0D0333C0F14E27B73-807E
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.4 V
                            PD
                        Temperature: 9.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
       Coding: 988000005183CC7F0006850560085F86107C80
       VCID: 03538E97071B7F6FD45-8056
       Subsystem 5 - Part No: 5P0 951 171 C
       Component: Innenraumueberw.009 4865
       Coding: 00000000
       Shop #: WSC 06402
       Subsystem 6 - Part No: 1K0 951 605 C
       Subsystem 7 - Component:       NGS n.mounted
                        Reset counter: 138
                        Mileage: 279315 km
       Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1520
       Revision: 71009005    Serial number: 00000563688513
       Coding: 0004784
       VCID: 41DF449F5D87AD7F869-8014
                        Reset counter: 98
                        Mileage: 279315 km
                        Fault Status: 00101100
                        Reset counter: 138
                        Mileage: 279315 km
       Part No: 5P2 035 186 A
       Component: Radio BVX           0007
       Coding: 0040464
       VCID: 2F3B1227FB132B0F60D-807A
    No Faults Found
       Part No SW: 1K0 959 703 AE    HW: 1K0 959 795 R
       Revision: 11006001    Serial number: 00000003248988
       Coding: 0000144
       VCID: 73B3DE5757BB4FEFC45-8026
       Part No SW: 1K0 959 704 AE    HW: 1K0 959 794 R
       Revision: 11006001    Serial number: 00000003305626
       Coding: 0000144
       VCID: 74B1DD4B52B548D7DDF-8020
    End----(Elapsed Time: 01:30, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
    Did you check key is proper and D2 coil excites transponder to be seen in Immobilizer measured blocks in VCDS?
    Fuses all good?
    JPPSG
    Quote Originally Posted by Shuhel View Post
    01176 - Key
    I don't understand how a clutch job could have caused this, but I've seen stranger coincidences.
    http://wiki.ross-tech.com/wiki/index.php/01176
    Jun 2019
    Birmingham, UK
    Now sorted
    I read on a forum maybe here, hold positive and negative battery term together for 30secs and then connect battery, leave jump leads on for 5mins with ignition on if the batterys weak.
    Car started, all working fine now.
    I still dont get why it happened in the first place
    Thanks guys
    Now sorted
    Nice. That's not the first time we've heard of a procedure we irreverently refer to as a "BJ" (short for "Battery Jesus") has exorcised immobilizer problems that came out of nowhere.
  8. Likes Jack@European_Parts liked this post
  9. #6
    Did you leave the battery connected while trying to take a trans out and removing the chassis ground or half the hots or short it on body?
    Ever notice how a loud fart for odor may go unnoticed but a small one could insult yourself or even the family dog?
  10. #7
    Jul 2014
    Tallinn, Estonia
    On a VW PQ platform vehicle, removing the battery is pretty much inevitable when the trans has to come out - the battery tray is sitting on the trans side mount.
