Fuel pressure sensor (g247) help please
Shuhel
Birmingham, UK
C?ID=368132
hi guys, iv been on this car for 3 months now and cant seem to find a solution to it.
the car is driving in limp with no power, iv changed the fuel pressure sensor and clear codes, it comes back with the same code on engine.
any thoughts please
thanks
Saturday,18,January,2020,18:25:05:58999
VIN: VSSZZZ1PZCR061000   License Plate:
Mileage: 207060km-128661mi   Repair Order:
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 61 62 72
VIN: VSSZZZ1PZCR061000   Mileage: 207060km-128661miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LG    HW: 03L 906 023 KL
   Component: 1,6l R4 CR td H43 8832
   Revision: --H43---    Serial number:
   Coding: 00114036032501080000
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_ECM16TDI02103L906023LG 003005
   ROD: GV_ECM16TDI021PQ36_003_SK34.rod
   VCID: 76B5E74348495AC7E3B-8022
10131 - Fuel Pressure Sensor (G247)
          P0193 00 [165] - Short to Plus
                    Mileage: 208030 km
                    Date: 2020.01.18
                    Time: 01:36:28
                    Engine speed: 763.25 /min
                    Normed load value: 34.1 %
                    Coolant temperature: 70 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 14.682 V
                    Supply voltage of analog output 1-VCC_1: 5.00 V
                    Fuel high pressure sensor: unconditioned voltage-VP_PFU: 4.9936 V
                    Fuel pressure: 200000 kPa rel
                    Fuel high pressure: actual value-FUP_FIL: 199.997 MPa
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 0.000 kPa
                    ECM system status-Binary 16 Bit: 00000000 00000000
Readiness: 0110 1000
   Revision: 00H31001
   Coding: 133B2012092800FBC80B04E490190091350800
   Shop #: WSC 04941 000 00000
   VCID: 7BA3F67773EB07AF9C5-802E
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 189
                    Mileage: 207057 km
                    Date: 2014.06.07
                    Time: 00:35:37
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 397
                    Count: 53248
   Part No SW: 5P0 907 044 R    HW: 5P0 907 044 R
   Component: Climatronic   H18 0804
   Revision: 00001001
   Coding: 0000000003
   ROD: EV_ClimaAutoBasis_SE35.rod
   VCID: 3FDB426727F3DB8FF0D-806A
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0064
   Revision: BC021001
   Coding: 46180A3E8025B0C04288008095008104425100A8427D81605C80C7000041
   VCID: 3E253F632079D287FBB-806A
   Subsystem 1 - Part No: 1P0 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 12031  26  0611
   Coding: 00DB90
   Subsystem 2 - Part No SW: 1P0 955 559 A    HW: 1P0 955 559 A  Labels: 1P0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 02542E
   Subsystem 3 - Part No: 1P0 951 171
   Component: Innenraumuebe  010 4971
01134 - Alarm Horn (H12)
                    Reset counter: 190
                    Mileage: 207057 km
                    Date: 2014.06.07
                    Time: 00:35:48
                    Voltage: 14.85 V
   Part No SW: 5P0 919 475 B    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H08 0008
   Revision: --------    Serial number: 36861205603656
   Coding: 000001
   VCID: 3A2D33733C51FEA7C73-806E
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__A0E VW10 HI   2118
   Revision: 24017000    Serial number: 003L7P2Q3YF7
   Coding: 0012357
   VCID: 7CA1F56B7AE5009795F-8028
   Subsystem 1 - Serial number: 6332MTS603760442
   Subsystem 2 - Serial number: 00000000000000000
   Subsystem 3 - Serial number: 6351HTS653LJ0AKR
   Subsystem 4 - Serial number: 6361HTS6914K0AKR
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
            007 - Short to Ground - MIL ON
                    Fault Status: 11100111
                    Mileage: 207057 km
                    Date: 2014.06.07
                    Time: 00:35:51
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20120315200846
   Coding: 108A140002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AFEC7F795735BF8E9-802C
   Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0102
   Coding: E20000
   Part No SW: 1P0 920 953 D    HW: 1P0 920 953 D
   Component: KOMBI         H05 0607
   Coding: 410B01
   VCID: 313F145FE1A73DFF769-8064
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 270212F2000199
   Coding: 350203
   VCID: 3B233677336BC7AFDC5-806E
   Component: IMMO          H05 0607
   VCID: 6A8DC3330CF18E27773-803E
   Revision: A1001003    Serial number: 7662065057
   VCID: 290FFC3FC9F7453FBE9-807C
   Part No SW: 5P0 035 191 G    HW: 5P0 035 191 G
   Component: RNS315-EU   H36 0263
   Serial number: SEZAZ2M9168011
   Coding: 040004010402000000000002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2F3B1227F7932B0F60D-807A
   Component: EUR_W_0038  0038
1048629 - Aux IN Socket
          B1104 13 [008] - Open Circuit
                    Reset counter: 230
                    Mileage: 207057 km
                    Date: 2020.01.15
                    Time: 00:22:07
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0508
   Revision: 12110009    Serial number: 0004058472
   Coding: 0212B0
   VCID: 6D87C82F3D1F991F121-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 E    HW: 3C0 959 794 E  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1501
   Serial number: 00000006525934
   Coding: 000290
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 230
                    Mileage: 207057 km
                    Date: 2020.01.15
                    Time: 00:35:56
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 65     3305
   Revision: 00H22000
   VCID: 372B2A470343E3CF38D-8062
   Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1130
   Revision: 31008001    Serial number: 00000550478217
   Coding: 0000688
   Shop #: WSC 04941 785 00200
   VCID: 3C21356B3A65C097D5F-8068
                    Fault Status: 00100101
                    Reset counter: 230
                    Mileage: 207057 km
   Component: Batt.regelung H43 1623
   Coding: 030F185A
   VCID: 71BFD45F21A77DFF369-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900311923
End----(Elapsed Time: 01:23, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Couldn't you maybe test wiring harness and before changing controller & did you consider unplugging engine side connector at ECU checking codes & after cleared too to check status of DTC and running tests with decade box to qualify stack of ECU using VCDS?
How many wires to this sensor and where do they go?
"Short to Plus" may mean a missing (or poor) ground connection.
It can also mean that something else on that chain within controller is faulty too.
Shuhel
Birmingham, UK
C?ID=368132
Solved!
This car has been sitting in the corner for the last 3 months in my garage. Its been to a few indies but nothing
Today i rememberd the customer saying a while back, a few days after servicing the problem started.
Long story short, in the end it was the 2 pipes on the fuel filter connected wrong way.
The pipes that go towards rail and fuel temp
