Results 1 to 5 of 5
Thread: Fuel pressure sensor (g247) help please
    Jun 2019
    Birmingham, UK
    hi guys, iv been on this car for 3 months now and cant seem to find a solution to it.
    the car is driving in limp with no power, iv changed the fuel pressure sensor and clear codes, it comes back with the same code on engine.
    any thoughts please
    thanks
    Saturday,18,January,2020,18:25:05:58999
    VIN: VSSZZZ1PZCR061000   License Plate:
    Mileage: 207060km-128661mi   Repair Order:
    Chassis Type: 1P-SE35 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 61 62 72
    VIN: VSSZZZ1PZCR061000   Mileage: 207060km-128661miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 LG    HW: 03L 906 023 KL
       Component: 1,6l R4 CR td H43 8832
       Revision: --H43---    Serial number:
       Coding: 00114036032501080000
       Shop #: WSC 06402 785 00200
       ASAM Dataset: EV_ECM16TDI02103L906023LG 003005
       ROD: GV_ECM16TDI021PQ36_003_SK34.rod
       VCID: 76B5E74348495AC7E3B-8022
    10131 - Fuel Pressure Sensor (G247)
              P0193 00 [165] - Short to Plus
                        Mileage: 208030 km
                        Date: 2020.01.18
                        Time: 01:36:28
                        Engine speed: 763.25 /min
                        Normed load value: 34.1 %
                        Coolant temperature: 70 C
                        Intake air temperature: 25 C
                        Voltage terminal 30: 14.682 V
                        Supply voltage of analog output 1-VCC_1: 5.00 V
                        Fuel high pressure sensor: unconditioned voltage-VP_PFU: 4.9936 V
                        Fuel pressure: 200000 kPa rel
                        Fuel high pressure: actual value-FUP_FIL: 199.997 MPa
                        Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 0.000 kPa
                        ECM system status-Binary 16 Bit: 00000000 00000000
    Readiness: 0110 1000
       Revision: 00H31001
       Coding: 133B2012092800FBC80B04E490190091350800
       Shop #: WSC 04941 000 00000
       VCID: 7BA3F67773EB07AF9C5-802E
    02214 - Tire Pressure Warning
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 189
                        Mileage: 207057 km
                        Date: 2014.06.07
                        Time: 00:35:37
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 397
                        Count: 53248
       Part No SW: 5P0 907 044 R    HW: 5P0 907 044 R
       Component: Climatronic   H18 0804
       Revision: 00001001
       Coding: 0000000003
       ROD: EV_ClimaAutoBasis_SE35.rod
       VCID: 3FDB426727F3DB8FF0D-806A
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0064
       Revision: BC021001
       Coding: 46180A3E8025B0C04288008095008104425100A8427D81605C80C7000041
       VCID: 3E253F632079D287FBB-806A
       Subsystem 1 - Part No: 1P0 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 12031  26  0611
       Coding: 00DB90
       Subsystem 2 - Part No SW: 1P0 955 559 A    HW: 1P0 955 559 A  Labels: 1P0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 02542E
       Subsystem 3 - Part No: 1P0 951 171
       Component: Innenraumuebe  010 4971
    01134 - Alarm Horn (H12)
                        Reset counter: 190
                        Mileage: 207057 km
                        Date: 2014.06.07
                        Time: 00:35:48
                            Term 15 On
                        Voltage: 14.85 V
    Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
       Part No SW: 5P0 919 475 B    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H08 0008
       Revision: --------    Serial number: 36861205603656
       VCID: 3A2D33733C51FEA7C73-806E
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__A0E VW10 HI   2118
       Revision: 24017000    Serial number: 003L7P2Q3YF7
       Coding: 0012357
       VCID: 7CA1F56B7AE5009795F-8028
       Subsystem 1 - Serial number: 6332MTS603760442
       Subsystem 2 - Serial number: 00000000000000000
       Subsystem 3 - Serial number: 6351HTS653LJ0AKR
       Subsystem 4 - Serial number: 6361HTS6914K0AKR
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                007 - Short to Ground - MIL ON
                        Fault Status: 11100111
                        Mileage: 207057 km
                        Date: 2014.06.07
                        Time: 00:35:51
       Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
       Revision: FF010040    Serial number: 20120315200846
       Coding: 108A140002
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 79AFEC7F795735BF8E9-802C
       Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H02 0102
       Coding: E20000
       Part No SW: 1P0 920 953 D    HW: 1P0 920 953 D
       Component: KOMBI         H05 0607
       Coding: 410B01
       VCID: 313F145FE1A73DFF769-8064
       Part No SW: 7N0 907 530 N    HW: 1K0 907 951
       Component: J533  Gateway H43 1623
       Revision:   H43       Serial number: 270212F2000199
       Coding: 350203
       VCID: 3B233677336BC7AFDC5-806E
       Component: IMMO          H05 0607
       VCID: 6A8DC3330CF18E27773-803E
       Revision: A1001003    Serial number: 7662065057
       VCID: 290FFC3FC9F7453FBE9-807C
       Part No SW: 5P0 035 191 G    HW: 5P0 035 191 G
       Component: RNS315-EU   H36 0263
       Serial number: SEZAZ2M9168011
       Coding: 040004010402000000000002
       ASAM Dataset: EV_RNS315EUV2UDS A01004
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2F3B1227F7932B0F60D-807A
       Component: EUR_W_0038  0038
    1048629 - Aux IN Socket
              B1104 13 [008] - Open Circuit
                        Reset counter: 230
                        Mileage: 207057 km
                        Date: 2020.01.15
                        Time: 00:22:07
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0508
       Revision: 12110009    Serial number: 0004058472
       Coding: 0212B0
       VCID: 6D87C82F3D1F991F121-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704 E    HW: 3C0 959 794 E  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  008 1501
       Serial number: 00000006525934
       Coding: 000290
              B11EC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 230
                        Mileage: 207057 km
                        Date: 2020.01.15
                        Time: 00:35:56
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 65     3305
       Revision: 00H22000
       VCID: 372B2A470343E3CF38D-8062
       Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1130
       Revision: 31008001    Serial number: 00000550478217
       Coding: 0000688
       Shop #: WSC 04941 785 00200
       VCID: 3C21356B3A65C097D5F-8068
                        Fault Status: 00100101
                        Reset counter: 230
                        Mileage: 207057 km
       Component: Batt.regelung H43 1623
       Coding: 030F185A
       VCID: 71BFD45F21A77DFF369-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900311923
    End----(Elapsed Time: 01:23, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Couldn't you maybe test wiring harness and before changing controller & did you consider unplugging engine side connector at ECU checking codes & after cleared too to check status of DTC and running tests with decade box to qualify stack of ECU using VCDS?
    How many wires to this sensor and where do they go?
    "Short to Plus" may mean a missing (or poor) ground connection.
  4. Likes Jack@European_Parts liked this post
    It can also mean that something else on that chain within controller is faulty too.
    Jun 2019
    Birmingham, UK
    Solved!
    This car has been sitting in the corner for the last 3 months in my garage. Its been to a few indies but nothing
    Today i rememberd the customer saying a while back, a few days after servicing the problem started.
    Long story short, in the end it was the 2 pipes on the fuel filter connected wrong way.
    The pipes that go towards rail and fuel temp
  7. Likes PetrolDave, Uwe, NZDubNurd liked this post
