Results 1 to 3 of 3
Thread: How to change dome light behaviour and activate cornering lights in C8/4K A6?
    Nov 2019
    is it possible to change dome light behaviour when opening doors? By default only the corresponding dome to the opening door is turned on, but is there any known coding or adaption change to get them all activated at the same time?
    Another question is concerning cornering lights with low level leds? Is it possible to active cornering fuction By coding?
    Saturday,18,January,2020,18:51:24:43746
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(VMWare)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WAUZZZF20KN12xxxx   License Plate: xxx-xxx
    Mileage: 36855km-22900mi   Repair Order:
    Chassis Type: F2-AU58 (4N1)
    Scan: 01 02 03 09 15 16 17 19 42 44 46 52 5F 80 81 A5 AC BB BC D6
              D7
    VIN: WAUZZZF20KN12xxxx   Mileage: 36855km-22900miles
    80-Batt. reg. aux. accum. -- Status: OK 0000
    Address 01: Engine (J623-DEZD)       Labels: None
       Part No SW: 05L 906 027 D    HW: 05L 907 309
       Component: R4 2.0l TDI   H22 6901
       Revision: E1H22---
       Coding: 0A2540322324050C34002000000000000000000000000000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM20TDI01105L906027D 005007
       ROD: EV_ECM20TDI01105L906027BB.rod
       VCID: 2D070970CD9B904F521-8079
    Address 02: Auto Trans (J217)       Labels:| 0CJ-927-156.clb
       Part No SW: 4K0 927 153 D    HW: 0HK 927 156 B
       Component: 0CK 20TDI RdW H01 0002
       Revision: --H01---    Serial number: 0000001102
       ASAM Dataset: EV_TCMDL382021 002031
       ROD: EV_TCMDL382021_AU58.rod
       VCID: 2E050E7CC09DEB576BB-807B
       Manual Transmission Fluid Pump:
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041190128001650
       Part No SW: 4K0 907 379 P    HW: 4K0 907 379 A
       Component: ESP9 Plus     H06 0854
       Coding: 0CAA499714A40A9711A0489A008552D2F5B9C0309228508812004A4BAF9D03
       ROD: EV_ESP9BOSCHCMP_004_AU65.rod
       VCID: 42DD4ACC64057F379F3-8017
       Part No SW: 4N0 907 063 GG    HW: 4N0 907 063 AG
       Component: BCM1 MLBevo   H10 0653
       Coding: 07000943E11800CD074C070818AD8068130B3310000600970100080039321A010840083242560108000001000001001A0000000000010100000000000000000000
       ASAM Dataset: EV_BCM1BOSCHAU651 014010
       ROD: EV_BCM1BOSCHAU651_014.rod
       VCID: 79AFED204953FCEF8E9-802D
       Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
       Component: J400FRWISCH  063 0740
       Serial number: 00000001904120402652
       Coding: 7DC727
       Serial number: 23021672X81A955555A0
       Coding: 02006E
       Subsystem 3 - Part No SW: 4K1 941 501     HW: 4K1 941 501
       Component: E1 - LTM  H05 0053
       Serial number: 16S17.05.1900300853
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE111121823311833
       Interior Light Module:
       Subsystem 5 - Part No SW: 4K0 947 135 AE    HW: 4K0 947 135 AE
       Component: Dachmodul  H42 0415
       Serial number: C00272757
       Coding: 0D0104
       Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
       Component: AirbagVW31    H09 2720
       Serial number: 003YZM053WAF
       Coding: AACCF0C00CC00000985400FFF00D40AC00C5
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
       ROD: EV_AirbaVW31SMEAU65x_VW53.rod
       VCID: 4ACD62EC5C35A777573-801F
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
       Component: BeltPretRevFL  H10 0115
       Serial number: 00AI2019131725400000
       Coding: 04F001
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
       Component: BeltPretRevFR  H10 0115
       Serial number: 00AI2019115110700000
       Coding: 04F001
       Subsystem 3 - Part No SW: -----------    HW: 480 002 305 19
       Serial number: 357000000000F7605B3J
       Subsystem 4 - Part No SW: -----------    HW: 480 002 305 19
       Serial number: 358000000007F9605B3T
       Subsystem 5 - Part No SW: -----------    HW: 480 031 805 19
       Serial number: 351001C20004E4B0FD54
       Subsystem 6 - Part No SW: -----------    HW: 480 031 805 19
       Serial number: 352001C2000C21713E4Q
       Subsystem 7 - Part No SW: -----------    HW: 480 032 205 19
       Component: FrontSensor_D  002 0149
       Serial number: 355001C20CED50C08E1L
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 480 032 205 19
       Component: FrontSensor_P  002 0149
       Serial number: 356001C20CED15103D16
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 480 031 105 19
       Component: PedP_Sensor_C  002 0149
       Serial number: 230001C201EB6190396.
       Subsystem 10 - Part No SW: -----------    HW: 480 002 105 19
       Serial number: I0M00000000EE7D8AAB+
       Subsystem 11 - Part No SW: -----------    HW: 480 002 105 19
       Serial number: I0N00000000BE7D8AAB$
       Part No SW: 4N0 907 129 S    HW: 4N0 907 129 S
       ROD: EV_SMLSKLOAU736_VW53.rod
       VCID: 41DF45C06103642F869-8015
       Part No SW: 4K0 920 701 C    HW: 4K0 920 701 C
       Component: TDieRDW------ H07 0189
       Coding: 81A420C2688000080C40A0609080000008001000
       ROD: EV_DashBoardAU65X_VW53.rod
       VCID: 2517F150956BA80F9A1-8071
       Part No SW: 4N1 907 468 AL    HW: 4N1 907 468 AB
       Component: Gateway       H14 0045
       Revision: AA010003    Serial number: 038AA510719517
       Coding: 02010005002006405A860002005B0132CC1A000710000000097F078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 003170
       ROD: EV_CGateCONTIAU491_003_AU58.rod
       VCID: 025D8ACC2485BF37DF3-8057
       Subsystem 1 - Part No SW: 4N0 951 523 H    HW: 4N0 951 523 H
       Component: E221__MFL  H06 0003
       Serial number: 00000000000000000000
       Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
       Serial number: 74186313001905150632
    8531970 - Quiescent Current
              U1406 00 [009] - Too High
              [Electric_current_Upper_Limit_Value_Exceeded]
                        Reset counter: 222
                        Mileage: 36855 km
                        Date: 2020.01.18
                        Time: 18:49:02
                        Total static current-current total quiescent current: 70 mA
                        Total static current-Total time quiescent current exceeded: 1.0 H
                        EM_vehicle_state: 02 1C
       Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
       Component: TSG FS002 0189
       Serial number: YE007SDK33417
       Coding: 001CDB0040000480A000B000
       VCID: 3E253E3C10FD1BD7FBB-806B
       Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
       Component: EPS_MLBEVO2BS H22 0505
       Coding: 94002101010000
       ASAM Dataset: EV_EPSVWBSAU426 010017
       ROD: EV_EPSVWBSAU426_010.rod
       VCID: 323D1A0CD4A5CFB70F3-8067
       Part No SW: 4N0 907 064 CB    HW: 4N0 907 064 B
       Component: BCM2 MLBevo H14 0164
       Coding: 01340000002000E06301A0000400000203020000804B04502F04000000040030001F0100000011
       ASAM Dataset: EV_BCM2CONTIAU651 009009
       ROD: EV_BCM2CONTIAU651_009_AU58.rod
       VCID: 71BFD5001123B4AF369-8025
       Ignition key:
       Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
       Component: TSG BFS002 0189
       Serial number: YE007SDK2840C
       VCID: 3D2739301DFB00CFE21-8069
       Part No SW: 4K0 035 136 B    HW: 4K0 035 136 A
       Component: MU-H-N-EU     046 9815
       Coding: 01850100FF0A000043110001000800002F0008C40370080002
       ROD: EV_MUHigGen2pALPI_AU27.rod
       VCID: 2313EF489B5F563FF45-8077
       Subsystem 1 - Part No SW: 4K1 919 604 G    HW: 4K1 919 604 F
       Component: DU AU58x Top  H71 0170
       Serial number: BHB00130041903200629
       Subsystem 2 - Part No: V03 959 800 EG
       Component: Gracenote2  1008
       Volume Control 1:
       Subsystem 3 - Part No SW: 4K1 919 616 A    HW: 4K1 919 616 A
       Component: LSR-D5/C8  H33 0108
       Serial number: 00004419000047201027
       Display Unit 5 For Multimedia System:
       Subsystem 4 - Part No SW: 4K1 919 603 G    HW: 4K1 919 603 F
       Component: DU AU58x Bot  H71 0170
       Serial number: BHB00118051903130118
       Media socket:
       Subsystem 5 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
       Component: MediaConnectL  014 0133
       Serial number: 051900210792004
    Address 80: Batt. reg. aux. accum. (A1)       Labels: None
       Part No SW: 4K0 915 101     HW: 4K0 915 101
       Component: MQ-BMS        H20 0127
       Serial number: 18000047306002
       ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
       ROD: EV_BMS12VLiIonSDIAU49X.rod
       VCID: 6099A044CAC90D27A97-8035
       Part No SW: 4K1 713 041 H    HW: 4K1 713 041 H
       Component: GSM-LL H14 0051
       Serial number: 19.136 40269
       ASAM Dataset: EV_GSMKAMAU581 001005
       ROD: EV_GSMKAMAU581.rod
       VCID: 2809F864E279B567A17-807D
    Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
       Part No SW: 4KE 907 107 AA    HW: 4N0 907 107 F
       Component: zFAS Var A    H08 0291
       Coding: 04018200000000000000060000000424189D5600000000000000000000000000001900000000000000000000000000000000000000000000000000000000000000006200008000B000000000000000000080400000B0
       ASAM Dataset: EV_ZFASAU516 001003
       ROD: EV_ZFASAU516_001_AU58.rod
       VCID: 7EA5FE3C507DDBD7BBB-802B
    Address AC: Reductant Control (J880)       Labels: None
       Part No SW: 80A 907 355 F    HW: 80A 907 355 D
       Component: SCR-Stg-G4H08 0004
       ASAM Dataset: EV_RDCMHelbaAU426 003011
       ROD: EV_RDCMHelbaAU426_003.rod
       VCID: 2C010474F681994745F-8079
       Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
       Component: TSG HFS003 0189
       Serial number: YE007SD414558
       Coding: 000CD90000000480A000B000
       VCID: 40D940C46A096D27897-8015
       Component: TSG HBFS003 0189
       Serial number: YE007SD41289A
    Address D6: Light Ctrl Left 2 (A31)       Labels: None
       Part No SW: 4K0 941 572 DC    HW: 4K0 941 572 D
       Component: LMS_MLBevo    H06 0031
       ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
       ROD: EV_LMSLeftHELLAAU58X_AU38.rod
       VCID: 72BDDA0C14258FB7CF3-8027
    Address D7: Light Ctrl Right 2 (A27)       Labels: None
       ASAM Dataset: EV_LMSRightHELLAAU58X 001013
       ROD: EV_LMSRightHELLAAU58X_AU38.rod
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.1V)-----------
    Jun 2017
    First topic: Unit 09, Coding, deactivate Byte 10 Bit 0
    Second topic: Experimental!
    New Coding Unit 09: 07000944E11800CD074C070818AD8068130B3310000600970100080039 321A010842083242560108000001000001001A0000000000010100000000 000000000000
    If that does not work, try: 07000944E11800CD074C070818AD8068130B3310000600970100080039 321A010852083242560108000001000001001A0000000000010100000000 000000000000
    You need to drive to check if its working, not in standstill.
  3. Likes Uwe, santti liked this post
    Nov 2019
    Thanks a lot! Gotta try those in few days.
