Hi all,
this is my first post here on the forum. I am a vcds user since 2012. Then I bought my first VAG car, a Audi A4 B7. Since one month now I've bought another car, it is a Seat Leon 5F. The autoscan is below:
Currently I am busy finding out what needs to be done to install a factory amplifier (5Q0035456A) in my car with the additional speakers. Currently I am not satisfied with the sound quality, so I want to change the speakers, add an amplifier, and a centre speaker and subwoofer. For that I need to couple the amplifier to the control unit. I think the connections are done through the quad connector and a MOST line. This will be my first project to this car.
greetings from the Netherlands
Saturday,18,January,2020,14:43:25:21183
VCDS Version: 18.9.1.0 (x64)
VIN: VSSZZZ5FZGR026591 License Plate: GV-464-R
Mileage: 155796km-96807mi Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69
VIN: VSSZZZ5FZGR026591 Mileage: 155796km-96807miles
Address 01: Engine (J623-CZEA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HF HW: 04E 907 309 BJ
Component: R4 1.4l TFS H22 2326
Revision: R6H22---
Coding: 01190032242419080000
Shop #: WSC 00049 770 00194
ASAM Dataset: EV_ECM14TFS01104E906027HF 001004
ROD: EV_ECM14TFS01104E906027HF.rod
VCID: 6FED68D7B6CFB33234-803A
CAN Converter 01:
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 61585000003131
Coding: 20EE6A9224222972007C060941C4240456249400608224F200210070C002
Shop #: WSC 00049 770 00199
VCID: 4B95DC47E297AF1278-801E
Part No SW: 5F0 907 044 H HW: 5F0 907 044 H
Component: Climatronic H04 0911
Revision: 00001K09
Coding: 00000004200100011005000000101000
Shop #: WSC 00049 770 00103
ASAM Dataset: EV_ACClimaBHBVW37X 003017
VCID: 2B55BCC742578F1258-807E
Air quality sensor:
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0173
Serial number: 01061516803412
Coding: 08020A42424102FB4BE44000400403281000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 0919264FA86BFD028A-805C
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150508 041 0574
Serial number: 150607064453
Coding: 0BC5FD
Component: RLHS 037 0059
Serial number: S4Y15M06D24H21M51S36
Coding: 00095D
203016 - Unlock Switch in Rear Lid Handle
B140B 29 [008] - Signal Implausible
Fault Frequency: 25
Reset counter: 228
Mileage: 153901 km
Date: 2019.12.24
Time: 12:26:08
Revision: -------- Serial number: 39311518102138
Coding: 0031151101
VCID: 4385F467CAC7675280-8016
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPCUE5DR
Coding: 98CCC000000000005C0000CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F2D0857D60FD33254-805A
Subsystem 1 - Part No SW: ----------- HW: 454 001 006 15
Serial number: 3576U0000006507CA41A
Subsystem 2 - Part No SW: ----------- HW: 454 001 006 15
Serial number: 3586U00000092C01E419
Subsystem 3 - Part No SW: ----------- HW: 454 800 607 15
Serial number: 3516R6F5567070000007
Subsystem 4 - Part No SW: ----------- HW: 454 803 006 15
Serial number: 3526RF8D45407000000D
Subsystem 5 - Part No SW: ----------- HW: 454 800 806 15
Serial number: 3556V7DE42207000000D
Part No SW: 5Q0 953 507 GD HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 22061504400049
Coding: 1400
VCID: 7EF34593E1A5CABAAF-802A
Part No SW: 5F0 920 873 HW: 5F0 920 873
Component: KOMBI 303 6420
Coding: 07A402002980000800086A001000000000000000
VCID: 68DF03CB9321640A75-803C
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003697200
Coding: 030100F42F085700EB0002C8080F00010001050000000000000000000000
ROD: EV_GatewLear_013_VW37.rod
VCID: 75E15ABFD49389E2FE-8020
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A0232040615
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001506161468
Component: TSG FS 010 0031
Serial number: 0000155769737
Coding: 00100320DC00040000001000
VCID: 479DE077FEFF4B725C-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006502431
Coding: 310000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 8103
Component: TSG BFS 010 0031
Serial number: 0000155777673
Coding: 00100320DE00040000001000
VCID: 4683ED73F9F5527AA7-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006446384
Coding: 290000
Component: LWR-ECU 005 0080
Coding: 048A000009000000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 858 HW: 5QA 035 858
Component: MU-S-ND-ER H24 0241
Serial number: SEZAZ2R0262782
Coding: 04730001D70A000011111101008808002F0201D40120010046
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SK25.rod
VCID: 0407377B8F49A06AF9-8050
Subsystem 1 - Part No SW: 5F0 919 604 A HW: 5F0 919 604 A
Component: ABTm_Std2_Nav H43 1028
Serial number: SEZ8Z9RFT005VX
Subsystem 2 - Part No SW: 6P0 919 866 M HW: -----------
Component: ECE1 2017 --- 0730
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 E HW: 5Q0 907 383 B
Component: Anhaenger H14 0137
Revision: 8C001002 Serial number: 0372823052
Coding: 0100000202000000
VCID: 3979968FB80B2D82DA-806C
656138 - Bulb for Right Tail Light on Trailer
C10F4 15 [009] - Open or Short to Plus
Reset counter: 147
Mileage: 153901 km
Time: 00:00:00
End-------------------------(Elapsed Time: 04:14)--------------------------
