Results 1 to 10 of 10
Thread: RS3 ACC issue (yellow exclamation mark)
    New User
    Nov 2017
    Australia
    Hey guys,
    Sorry to post this topic again... I read through the other thread but it was hijacked by someone else. So I think it will be easier to post a new thread.
    unfortunately i didn’t have time to upload the whole scan to my cloud to be able to most it here (I’ll do it tomorrow).
    Anyhow long story short - heavily modified RS3 2017. I have had my sensor for the ACC moved so it doesn’t work...
    After reading the other thread last night I thought I maybe able to reset it to see if it came good (was out of range as I didn’t have a wall) anyhow...
    Long story short whiles trying the 3 or 4 options in VCDS - the error never went away
    And instead I inherited a new yellow exclamation mark!
    The below is a Full autoscan prior to playing
    Thursday,16,January,2020,10:42:10:38378
    VIN: WUAZZZ8V8H19xxxxx   License Plate: xxxxx
    Mileage: 30693km-19071mi   Repair Order:
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 3C 42 44 47
              52 55 5F 65 6C A5 BB BC CF D6 D7
    VIN: WUAZZZ8V8Hxxxxxxx   Mileage: 30693km-19071miles
    Address 01: Engine (------DAZA)       Labels: None
       Part No SW: 8V0 907 404 A    HW: 07K 907 309 E
       Component: 2.5l R5/4V TF X22 0004
       Revision: 53X22000
       Coding: 0A250032246601033620
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM25TFS0118V0907404A 001005
       ROD: EV_ECM25TFS0118V0907404A.rod
       VCID: 373EE58C8ED86EF756-8062
    2967 - Intake Manifold Flap Position Sensor (Bank 1)
              P2015 00 [096] - Implausible Signal
                        Mileage: 30647 km
                        Date: 2020.01.09
                        Time: 06:41:16
                        Engine speed: 977.50 /min
                        Normed load value: 53.3 %
                        Coolant temperature: 54 °C
                        Intake air temperature: 31 °C
                        Voltage terminal 30: 14.240 V
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    22858 - Bank 1; System Too Lean off Idle
              P2177 00 [096] - -
                        Mileage: 30686 km
                        Date: 2020.01.15
                        Time: 15:06:10
                        Engine speed: 1885.00 /min
                        Normed load value: 11.4 %
                        Vehicle speed: 69 km/h
                        Coolant temperature: 92 °C
                        Intake air temperature: 48 °C
                        Voltage terminal 30: 13.860 V
    Readiness: 0010 0001
       Part No SW: 0DL 300 012 E    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2012
       Revision: 00H06V07
       VCID: 2B16C9FC4290DA1722-807E
       Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
       Component: ESC           H25 0621
       Revision: 00000000    Serial number: 60457000000313
       Coding: 2E9C938DD49913A98B930B6741966974C92BC8D1D08296771841500402A812
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
       VCID: 393AE3B4B8CC7887A0-806C
       Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
       Revision: 00021000    Serial number: 0434627613
       Coding: 030C0C
       VCID: 3B36F9BCB2F04A97B2-806E
       Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
       Component: AC Automat    H03 0130
       Revision: 20002000    Serial number: 00000001178693
       Coding: 03100005110000001000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
       VCID: 40CC8E50DB16294FE7-8014
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: DE39839800PAG0MUFU03
       Serial number: 02001707000536
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EB030A8E1629FBFD5-802A
       Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS371 170104  043 0585
       Serial number:         170120134015
       Coding: 0A47F7
       Serial number: 62682398
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 19 12 2016  00000110
       Serial number: 000000000ZY170233FEK
       Serial number: 00000000000068854348
    262936 - Sensor for anti-theft alarm system
              B1330 29 [008] - Signal Implausible
                        Reset counter: 14
                        Mileage: 30679 km
                        Date: 2020.01.14
                        Time: 14:50:26
    558100 - Databus
              [Airbag_02 Datenbus empfangener Fehlerwert]
                        Reset counter: 14
                        Mileage: 28030 km
                        Date: 2019.10.29
                        Time: 10:13:27
       Part No SW: 5QA 919 294 A    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0038
       Serial number: 000308418617056
       Coding: 0470155011
       ASAM Dataset: EV_EPHVA18AU3700000 009031
       VCID: 4AD8AC78ED2AE31F39-801E
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: 3500E7C219FFC42474988055000026
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: EV_ACCBOSCHVW416_001_VW37.rod
    0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_MISALIGNMENT_HORIZONTAL]
                        Reset counter: 170
                        Mileage: 28030 km
                        Date: 2019.10.29
                        Time: 10:13:22
                        Control Module temperature: 26 °C
                        Voltage terminal 15: 13.3 V
    0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_MISALIGNMENT_VERTICAL]
                        Reset counter: 170
                        Mileage: 28030 km
                        Date: 2019.10.29
                        Time: 10:13:22
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0317
       Serial number: 003TDR2R8B3.
       Coding: 98CCC000008000005C54000000C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 106C7E10CBF699CF37-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 000 203 17
       Serial number: 35700000000D4A400227
       Subsystem 2 - Part No SW: -----------    HW: 480 000 203 17
       Serial number: 3580000000085918522D
       Subsystem 3 - Part No SW: -----------    HW: 480 402 502 17
       Serial number: 3510001B5249E3B205F5
       Subsystem 4 - Part No SW: -----------    HW: 480 402 502 17
       Serial number: 3520001B3249E3B5F6CK
       Subsystem 5 - Part No SW: -----------    HW: 480 401 601 17
       Serial number: 3550002BF23A3F821379
    9440027 - Driver's side; side-airbag igniter
              B100B 1B [136] - Resistance Too High
                        Mileage: 28030 km
                        Date: 2019.10.29
                        Time: 10:13:22
    9439771 - Front Passenger's Side Airbag Igniter
              B100A 1B [136] - Resistance Too High
                        Mileage: 28030 km
                        Date: 2019.10.29
                        Time: 10:13:22
    9447189 - Seat Occupied Sensor; Passenger's Side
              B1027 15 [136] - Open or Short to Plus
                        Mileage: 28030 km
                        Date: 2019.10.29
                        Time: 10:13:23
       Part No SW: 8V0 953 521 KT    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 04031704400169
       Coding: E818
       VCID: 16600808E91277FF6D-8042
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 790     HW: 8V0 920 790
       Component: FBenRDW       H14 0046
       Coding: 240D18D26E8800080184EC041000001000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001023
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 79BA23B4F84CB887E0-802C
       Component: GW MQB High   515 5286
       Serial number: 07031710802273
       Coding: 030100043F0860005B008278380B00000001010000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 2F2EDDEC7688A6370E-807A
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20170221190108 22085
       Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
       Serial number: 3062813204
    8521278 - Battery terminal recognition
              U1411 00 [008] - Open circuit
              [Spannung Fahrbatterie mechanischer Fehler]
                        Reset counter: 13
                        Mileage: 29996 km
                        Date: 2019.11.22
                        Time: 16:59:09
                        Supply voltage: Terminal 30: 13.9 V
                        Terminal 15: On
       Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7756
       Serial number: HA1-00013.07.16
       Coding: 0601
       VCID: 45C29F44C4340C67D4-8010
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H06 0017
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42C88458D51A3B5FF1-8016
       Revision: 00000000    Serial number: 17000610044004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3424D2809FAE85EF73-8060
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0410
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
       Serial number: 210217EBK25374
       Coding: 005D1A205C01040000001003
       VCID: 43C6815CCA003257FA-8016
       Coding: 9107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A38FCB8BDCA739FA9-806E
       Part No SW: 81A 035 466 A    HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0420
       Revision: 00000001    Serial number: AUZ8ZAG5F006UB$
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 230621DC2A4012579A-8076
       Serial number: 280217EBS17044
       Coding: 005D12205E01040000001003
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0EEE00102B200200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E30F0A8A1E25FBF95-806A
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8V1 035 041 A    HW: 8V1 035 041
       Component: MU-P-LND-RW   053 0875
       Serial number: A838B0HS004349
       Coding: 017361080000000011511102000A00102F0028E6017001045E
       VCID: 2D12C7E47C84D4273C-8078
       Subsystem 1 - Part No SW: V03 959 802 DH    HW: -----------
       Component: ROW 2019  --- 0076
       Component: DU High  H49 0014
       Serial number: AUZ8Z9H1Y01TRL
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL120021700010736
       Component: Gracenote2  --- 4011
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 8S0 907 273     HW: 4M0 907 273 B
       Component: RDKHUFAU736   H04 0002
       Serial number: 40000000001877
       ASAM Dataset: EV_RDKHUFAU736 002007
       ROD: EV_RDKHUFAU736_AU37.rod
       VCID: 77BE258CCE58AEF796-8022
    10 Faults Found:
    8398082 - Tire Pressure Sensor(s)
              C111A 31 [009] - No Signal
                        Reset counter: 222
                        Mileage: 30167 km
                        Date: 2019.11.23
                        Time: 17:44:34
                        Expanded ambient data 6-Vehicle speed: 123.57 km/h
                        Expanded ambient data 6-Outside air temperature: 23.50 °C
                        Tire pressure sensor 01-Manufacturer code: 0
                        Tire pressure sensor 01-Sensor identification number (sensor ID): 557572758
                        Tire pressure sensor 01-Wheel position: Unknown
                        Tire pressure sensor 01-CURRENT pressure: 0.00 bar
                        Tire pressure sensor 01-CURRENT temperature: -40 °C
                        Tire pressure sensor 01-SPECIFIED pressure: 0.00 bar
                        Tire pressure sensor 01-Warning pressure: 0.00 bar
    8397058 - Front Left TPMS Sensor
              C1050 31 [008] - No Signal
                        Reset counter: 3
                        Mileage: 29792 km
                        Date: 2019.11.22
                        Time: 08:33:25
                        Expanded ambient data 6-Vehicle speed: 16.19 km/h
                        Expanded ambient data 6-Outside air temperature: 25.50 °C
                        Left front tire pressure sensor: remaining oper. life: 127 m
                        Left front tire pressure sensor: identification-Manufacturer code: numerical value: no text
                        Left front tire pressure sensor: identification-Sensor identification number (sensor ID): 623977457
    8397314 - Front Right TPMS Sensor
              C1051 31 [008] - No Signal
                        Reset counter: 3
                        Mileage: 29792 km
                        Date: 2019.11.22
                        Time: 08:33:25
                        Right front tire pressure sensor: remaining oper. life: 127 m
                        Right front tire pressure sensor: identification-Manufacturer code: numerical value: no text
                        Right front tire pressure sensor: identification-Sensor identification number (sensor ID): 623978501
    8397570 - Rear Left TPMS Sensor
              C1052 31 [008] - No Signal
                        Reset counter: 3
                        Mileage: 29792 km
                        Date: 2019.11.22
                        Time: 08:33:25
                        Left rear tire pressure sensor: remaining oper. life: 127 m
                        Left rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
                        Left rear tire pressure sensor: identification-Sensor identification number (sensor ID): 623977334
    8397826 - Rear Right TPMS Sensor
              C1053 31 [008] - No Signal
                        Reset counter: 3
                        Mileage: 29792 km
                        Date: 2019.11.22
                        Time: 08:33:25
                        Right rear tire pressure sensor: remaining oper. life: 127 m
                        Right rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
                        Right rear tire pressure sensor: identification-Sensor identification number (sensor ID): 623977284
    8389634 - TPMS Display
              C1239 F0 [009] - Position Determination Not Possible
                        Reset counter: 218
                        Mileage: 30120 km
                        Date: 2019.11.23
                        Time: 13:47:00
                        Expanded ambient data 1-Left front tire pressure sensor: identification: Not available
                        Expanded ambient data 1-Right front tire pressure sensor: identification: Not available
                        Expanded ambient data 1-Left rear tire pressure sensor: identification: Not available
                        Expanded ambient data 1-Right rear tire pressure sensor: identification: Not available
    8389633 - Adapatation Not Possible
              C112C 00 [009] - Tire Pressure Sensor(s) Defective or No Signal
                        Reset counter: 220
                        Mileage: 30095 km
                        Date: 2019.11.23
                        Time: 10:29:49
                        Radio interference levels: 37
    8390147 - Tire Pressure Monitoring
              C10DC 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 3
                        Mileage: 30110 km
                        Date: 2019.11.23
                        Time: 13:36:54
    8400898 - Tires 01: Tire  Pressure Warning
              C111B 00 [008] - Pressure too Low
                        Reset counter: 0
                        Mileage: 28030 km
                        Date: 2019.10.29
                        Time: 10:13:21
                        Expanded ambient data 6-Vehicle speed: 0.00 km/h
                        Expanded ambient data 6-Outside air temperature: 21.00 °C
                        Expanded ambient data 2-Left front tire pressure sensor: nominal pressure: 2.60 bar
                        Expanded ambient data 2-Left front tire pressure sensor: actual pressure: Not available
                        Expanded ambient data 2-Left front tire pressure sensor: temperature: Not available
                        Expanded ambient data 2-Left front tire pressure sensor: identification: 623977457
    8400901 - Tires 02: Tire  Pressure Warning
              C111D 00 [008] - Pressure too Low
                        Reset counter: 0
                        Mileage: 28613 km
                        Date: 2019.11.04
                        Time: 05:47:44
                        Expanded ambient data 6-Vehicle speed: 19.57 km/h
                        Expanded ambient data 6-Outside air temperature: 10.50 °C
                        Expanded ambient data 3-Right front tire pressure sensor: nominal pressure: 2.60 bar
                        Expanded ambient data 3-Right front tire pressure sensor: actual pressure: 2.10 bar
                        Expanded ambient data 3-Right front tire pressure sensor: temperature: 12 °C
                        Expanded ambient data 3-Right front tire pressure sensor: identification: 623978501
       Coding: 0273010102002001400040
       Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0231
       Serial number: 27021711P21885
       Coding: 0403070100000101010223468048A90080000E200020
       ROD: EV_MFKBoschMQBB_VW46.rod
    0665 - Module for Camera
              C110A F0 [008] - Limited Visibility
              [Permanent_blindness_detected]
                        Fault Frequency: 101
                        Reset counter: 0
                        Mileage: 29039 km
                        Date: 2019.11.06
                        Time: 17:14:33
                        Control Module temperature: 45 °C
                        Outside air temperature: 23.0 °C
                        Vehicle speed: 43.23 km/h
                        System run time: 1484.0 s
                        Voltage terminal 15: 14.2 V
                        mid: 01 12
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 1
                        Software_Info_3: 3
                        Software_Info_2: 2
                        Software_Info_1: 0
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 240117EAO07897
       Coding: 000C12204001040000001002
       Serial number: 240117EAO07894
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
       Revision: --------
       Coding: 44C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
       VCID: 3620E88889D297FF4D-8062
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 177E050CEE184EF776-8042
       Component: LED1R         H09 0008
    End----(Elapsed Time: 01:58, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    The below is the scan post playing with ACC (I'll put in below exactly what I did in a minute)
    Saturday,18,January,2020,17:23:11:38378
    VIN: WUAZZZ8V8Hxxxxxxx   License Plate: xxxxx
    Mileage:    Repair Order: Acc2
                    Address 13: Auto Dist. Reg       Labels: 3Q0-907-572.clb
    Control Module Part Number: 5Q0 907 572 G    HW: 5Q0 907 572 G
      Component and/or Version: ACC BOSCH MQB H10 0571
               Software Coding: 3500E7C219FFC42474988055000026
                Work Shop Code: WSC 06385 790 00016
                  ASAM Dataset: EV_ACCBOSCHVW416 001005 (AU37)
    0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_ALIGNMENT_NOT_OK]
                        Reset counter: 237
                        Mileage: 30821 km
                        Date: 2020.01.18
                        Time: 17:18:36
                        Control Module temperature: 51 °C
                        Voltage terminal 15: 11.9 V
                        Status_ACC_System: ACC_irreversible error
              C1103 00 [009] - -
                        Reset counter: 237
                        Mileage: 30821 km
                        Date: 2020.01.18
                        Time: 17:18:36
              C1103 00 [009] - -
                        Reset counter: 237
                        Mileage: 30821 km
                        Date: 2020.01.18
                        Time: 17:18:36
    Hopefully the above worked...
    Anyhow anyone have any idea how I may be able to get rid of the exclamation mark!?
    Note it wasn’t there prior to me dicking around - neither were those errors in the attached above - just the ACC standard error.
    I’ll copy the full prior lot tomorrow and post log
    For bonus points ideas on how to get the ACC to work without a dealer... haha but I might just get the dealer to do it.
    Last edited by Uwe; 01-23-2020 at 09:02 AM. Reason: VIN de-personalized at OP's request
    Please post a complete Auto-Scan for context, not just some pictures of a screen.
    New User
    Nov 2017
    Australia
    Thanks Uwe,
    Sorry I had to post from my mobile - didn't have the log. It's attached now
    New User
    Nov 2017
    Australia
    Saturday,18,January,2020,17:22:35:38378
    VIN: WUAZZZ8V8xxxxxx   License Plate: xx
    Mileage:    Repair Order: ACC
                    Address 01: Engine       Labels: None
    Control Module Part Number: 8V0 907 404 A    HW: 07K 907 309 E
      Component and/or Version: 2.5l R5/4V TF X22 0004
               Software Coding: 0A250032246601033620
                Work Shop Code: WSC 92521 052 00000
                  ASAM Dataset: EV_ECM25TFS0118V0907404A 001005 (AU37)
    17156 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 30821 km
                        Date: 2020.01.18
                        Time: 17:19:47
                        Engine speed: 742.00 /min
                        Normed load value: 15.7 %
                        Coolant temperature: 88 °C
                        Intake air temperature: 69 °C
                        Voltage terminal 30: 13.980 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
    Readiness: 1010 0001
    The above is the new error I see (which has brought up the yellow exclamation mark!
    Compared to the Full auto scan above (as the car is tuned I get the lean issue - but it clears when reset).
    As I said the above is new since Iwas looking at some options in module 13
    New User
    Nov 2017
    Australia
    Edit - While I was playing I also opted to disable Stop/start.Though I kept getting a message on the dash saying it doesn't work, I did it on my A3 (instead of using the option in VCDS) I changed the voltage. Haven't had any issues... (I'll have to change it back on the RS3)
    Engine only is woefully insufficient here.
  7. #7
    New User
    Nov 2017
    Australia
    The main post is updated with the full autoscan before I messed around - then The following two are the remaining faults in the ACC / Engine post trying to reset with the ACC
  8. #8
    New User
    Nov 2017
    Australia
    Looks like it came up when I tried the below;
  9. #9
    New User
    Nov 2017
    Australia
    Any ideas?
    I’d like to try clear it, before taking it into the dealer where they will recalibrate it due to a recall
  10. #10
    Apr 2018
    ITALY
    a misalignment error can only be cleared with a calibration. either go to an Audi deader or to an ADAS calibration centre.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  11. Likes Uwe, PetrolDave liked this post
