Results 1 to 3 of 3
Thread: ABS probelm
    Jan 2020
    Israel
    ABS probelm
    hello all
    i have this car with this autoscan code below
    steering light and abs is on
    i dont know what to do
    i did basic settings for G85 and nothing happened
    also when trying dpf regeneration, it says "Aborted - Safety reasons | cancellation due to p/n not selected"
    thnx
    Monday,24,February,2020,15:01:50:04619
    VIN: TMBAG7NE9D0019598   License Plate:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: TMBAG7NE9D0019598   Mileage: 336306km-208970miles
    Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 N    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 4946
       Revision: 84H22---
       Coding: 01250012032401090000
       Shop #: WSC 73430 031 00207
       ASAM Dataset: EV_ECM16TDI01104L906021N 002007
       ROD: EV_ECM16TDI01104L906021N_002.rod
       VCID: 303916FB1AA27337795-8064
    5188 - Diesel Particle Filter
              P2463 00 [175] - Excessive Soot Accumulation
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:35:22
                        Engine speed: 772.00 /min
                        Normed load value: 25.9 %
                        Coolant temperature: 87 C
                        Intake air temperature: 74 C
                        Voltage terminal 30: 13.160 V
                        Counter for regeneration time of diesel particle filter: 0.00 s
                        Particle filter: kilometers since last regeneration: 3340317 m
                        Particle filter: soot mass measured: 11.54 g
                        Particle filter: soot mass calculated: 50.00 g
                        Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 2 hPa
    17287 - Ignition Switch; Run/Start Position Circuit
              P2535 00 [036] - Short to Plus
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:56:39
                        Engine speed: 770.00 /min
                        Normed load value: 23.5 %
                        Coolant temperature: 96 C
                        Intake air temperature: 82 C
                        Limitation: torque: 102.1 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 0
                        Accelerator pedal travel: raw value: 0.00 %
                        Engine torque: 24.4 Nm
                        Generator: load signal: 45.12 %
    5250 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:35:22
                        Engine speed: 773.50 /min
                        Longitudinal acceleration: raw value: 32.767 m/s
                        Vehicle inclination acceleration angle: raw value: 0.000 m/s
                        Status: incline angle-Bits 0-7: 1
                        Longitudinal acceleration: 0.000 m/s
                        Longitudinal acceleration sensor: status-Bits 0-7: 1
                        Vehicle lateral acceleration: raw value: -0.02 g
                        Vehicle lateral acceleration: -0.02 g
    20557 - Heater support pump
              P16C7 00 [039] - locked
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:35:28
                        Engine speed: 770.50 /min
                        Normed load value: 26.7 %
                        Voltage terminal 30: 13.180 V
                        Heater support pump 1 bank 1 second.circuit: activat.: 95.00 %
                        Extern.temp.sens.1 bank 1: raw value: 26.0 C
                        Shut-off timer: last engine shut-off time: 169 s
              U0428 00 [039] - -
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:35:22
    17158 - Databus
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:35:22
                        Engine speed: 769.00 /min
                        Normed load value: 26.3 %
                        Voltage terminal 30: 13.100 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 4
                        Acceleration: 0.000 m/s
    Readiness: 1 1 0 0 1
       Part No SW: 0CW 300 047 R    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5210
       Revision: 00043014    Serial number: CU501411085892
       Shop #: WSC 04940 001 00001
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 4ACD64139C3E29E7571-801E
       Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
       Component: ESC           H75 0333
       Coding: 1A07629120210A75007C060901CB245846045000608024F00048000040
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
       ROD: EV_Brake1UDSContiMK100ESP_008_SK37.rod
       VCID: 3A2D34D3CCDEB967C71-806E
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 34
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 01:19:11
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 34
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 01:19:11
    8277 - Databus
              [FCAN: EPS_DSR_Status signal is invalid]
                        Reset counter: 34
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 01:19:11
    8299 - Databus
              [FCAN: Anhaenger_01_alt veraltet bit is set]
                        Reset counter: 34
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 01:19:11
       Part No SW: 5E0 907 044     HW: 5E0 907 044
       Component: Climatronic   H02 0604
       Revision: 00001K06
       Coding: 00010104000100011005000000100000
       ROD: EV_ACClimaBHBVW37X_002_VW37.rod
       VCID: 629DACB304CE91A7BF1-8036
       Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
       Component: BCM MQBAB M   H14 0106
       Serial number: 00011306600594
       Coding: 0C001842424702FB07A04000000407080000000000000000000000000000
       Shop #: WSC 73430 790 00207
       ROD: EV_BCMBOSCH_010.rod
       VCID: 43D34937BB14F8AF947-8016
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 130302  041 0570
       Serial number:         130307002938
       Coding: 065DDD
       Component: RLFS  024 0042
       Serial number: Y13M03D16H21M00S00S4
       Coding: 02805D
    9482 - Statiionary Cornering Lamp Right
              B1222 15 [009] - Open or Short to Plus
                        Reset counter: 34
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:34:49
    10515 - Bulb for Left Tail Light
              B12BE 01 [008] - Electrical Failure
                        Reset counter: 74
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:34:49
    11786 - Bulb for Rear Left Fog Light
              B12C7 15 [009] - Open or Short to Plus
                        Reset counter: 34
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:34:49
    12298 - License Plate Light
              B12CA 15 [009] - Open or Short to Plus
                        Reset counter: 34
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 00:34:49
    12554 - Bulb for Left Back-up Light
              B12CB 15 [009] - Open or Short to Plus
                        Reset counter: 34
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:36:00
    204546 - Remote key 2
                        Reset counter: 34
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:24:13
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
       Component: PARKHILFE 4K  009 0026
       Revision: --------    Serial number: 60831306500776
       Coding: 0001050011
       ASAM Dataset: EV_EPHVA14AU3700000 002015
       VCID: 372B2DE7FFCCA40F38F-8062
    1079060 - Center Rear Left Parking Aid Sensor
              B1077 14 [008] - Open or Short to Ground
                        Reset counter: 34
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:36:01
    1079316 - Center Rear Right Parking Aid Sensor
              B1078 14 [008] - Open or Short to Ground
                        Reset counter: 34
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:36:01
    13637426 - Databus
                        Fault Frequency: 6
                        Reset counter: 34
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:19:15
       Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
       Component: Airbag VW20   011 0188
       Revision: --------    Serial number: 003P3P53SCBT
       Coding: 98CCC0000C0000005C5400CC000800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7EA5F8C390765547BB9-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 403 13
       Serial number: 3576U000000BCBF43C0X
       Subsystem 2 - Part No SW: -----------    HW: 454 000 503 13
       Serial number: 3586U00000030D3DBC0L
       Subsystem 3 - Part No SW: -----------    HW: 454 800 503 13
       Serial number: 3516R15A73201000000S
       Subsystem 4 - Part No SW: -----------    HW: 454 800 603 13
       Serial number: 3526RA7372101000000V
       Subsystem 5 - Part No SW: -----------    HW: 454 800 503 13
       Serial number: 3556V43B20E01000000%
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 454 801 602 13
       Component: PedP_Sensor_D  114 0149
       Serial number: 2286VD822CD00000000D
       Subsystem 7 - Part No SW: -----------    HW: 454 801 502 13
       Component: PedP_Sensor_P  114 0149
       Serial number: 2296VE433CD00000000D
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 454 801 502 13
       Component: PedP_Sensor_C  114 0149
       Serial number: 2306VCD3AF900000000I
    9451547 - Igniter 1 for pedestrian protection
              B1038 1B [137] - Resistance Too High
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:33:19
    9451803 - Igniter 2 for pedestrian protection
              B1039 1B [137] - Resistance Too High
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:33:19
       Part No SW: 5Q0 953 507 AJ    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 18031304221317
       Coding: 1400
       Part No SW: 5E0 920 860 D    HW: 5E0 920 860 D
       Component: KOMBI         227 0555
       Coding: 07A402082180000801082A00040000
       VCID: 270BFDA72F6C348FA8F-8072
    16776973 - Databus
              [RKA_01 keine Kommunikation]
                        Reset counter: 34
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:18:33
       Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
       Component: GW MQB Mid    124 1109
       Revision: --------    Serial number: 0000452288
       Coding: 030100040B087300EF0002481C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 333319F7EBB4482F047-8066
       Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
       Component: E221__MFL-PR6  H04 0100
       Serial number: 000000000A0333270213
       Serial number: 5434670103
       Part No SW: 5Q4 959 393     HW: 5Q4 959 393
       Serial number: 0000055770042
       Coding: 001000208000020000001100
       VCID: 55F7876F4580761FCA3-8000
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_DRV  005 0004
       Serial number: 00000000000000119081
       Coding: 010200
    589833 - Window Regulator Switch; Rear Driver Side
              B1323 29 [009] - Signal Implausible
                        Reset counter: 34
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:18:49
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0002
       Shop #: WSC 73430 790 12345
       VCID: 44D14A2BBE1AFF97ADD-8010
    16130 - Steering Angle Sensor
              B1168 F2 [009] - Not Initialized
                        Reset counter: 34
                        Mileage: 336306 km
                        Date: 2020.02.06
                        Time: 01:23:18
                        Motor status: 00
                        Supply voltage: 12.50 V
                        Temperature: 49.0 C
                        KFC: 3F
                        KFA: 00 02
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 12.50 V
                        uAdSensI_SwitchedKl30_xdu16: 12.49 V
       Part No SW: 5Q4 959 392     HW: 5Q4 959 392
       Serial number: 0000055311973
       VCID: 7F5B05C7977C5C4FB0F-802A
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_PSG  005 0004
       Serial number: 00000000000000133953
       Coding: 190200
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-ENT1.clb
       Part No SW: 5E0 035 875     HW: 5E0 035 875
       Component: MU-E--ER      164 0141
       Revision: --------    Serial number: 000031094114000
       Coding: 03730100FF00000011110001000000002F0000840000010000
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_MUEnt4CCONT 004052
       ROD: EV_MUEnt4CCONT.rod
       VCID: 6695B0A3E8E6ED87539-8032
              U1111 00 [009] - -
                        Reset counter: 34
                        Mileage: 336291 km
                        Date: 2020.02.05
                        Time: 23:19:11
                        Voltage terminal 30: 13.2 V
                        BAP-BAP_Function_ID: 02
    End----------(Elapsed Time: 01:09, VBatt start/end: 12.5V/12.5V)-----------
    16.4905 S, 151.7375 W
    In the [03-ABS brakes] controller there is a Basic Settings [Basic setting of ESP sensor unit] that may help with the two codes for the "Longitudinal Acceleration Sensor" and "Lateral Acceleration Sensor" Missing Calibration/Basic Setting fault codes.
    You will need to use Security Access Code of [40168] for the Basic Setting Enabling. Also some times a short (parking lot) road test is needed before the ABS will perform the Basic Settings.
    Try and clear the fault codes and see what comes back, if the communication faults return, then it maybe necessary to check wiring/connections before replacing any parts. We recommend the Official Factory Repair Information when working on these vehicle.
    Please try the following for the "Diesel Particle Filter Emergency Regeneration while driving".
    Prerequisites:
    - Fuel tank must be at least 1/4 full
    - Vehicle in good mechanical condition
    - No fault codes (other than DPF regen)
    Warning! - Risk of Fire!
    - When performing the Emergency Regeneration, the temperature of the Exhaust System can be as high as 300C/572F for as 30 or minutes, please insure the vehicle is in good condition before continuing and there are no combustible materials near the exhaust.
    [Select]
    [01 - Engine]
    [Security Access - 16]
    - Enter the Code shown by VCDS for Adaptation Enabling
    [Do It!]
    [Adaptation - UDS]
    - Select [Service regeneration of particle filter while driving]
    [Read]
    [Stored value] = [00 00]
    - Enter [00 01] in [New value]
    - Press [Test], [Save]
    - [Done, Go Back]
    - [Close controller]
    - Locate a suitable place to conduct a road test where you can drive at a constant speed of about 60km/h and an engine rpm of about 2,000 rpm.
    - The DPF warning light in the dash should go out once the procedure is complete.
    - Have a look in [Advanced Measuring Values]
    Particle filter; soot mass measured
    - Soot level should be close to 0
    Check for fault codes.
    We have a Ross-Tech wiki page that should help with the "Diesel Particle Filter Emergency Regeneration".
    Note:
    You may have to correct fault codes in the [01-Engine] before the regeneration procedure can be started/competed.
    The fault code P16C7 is typically a concern with the 'Heater Support Pump - V488' (see repair manuals for testing procedures)
    There is a Ross-Tech wiki page for the fault code P2463 - Diesel Particle Filter: Excessive Soot Accumulation
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
    Jan 2020
    Israel
    thanks a lot
    i will do it
