Results 1 to 10 of 13
Thread: VCDS Help
    Jan 2020
    Spain
    VCDS Help
    have been trying to activate high beam assist today and traffic signs. In doing so I have unfortunately created an error saying “Audi adaptive light fault - see owners manual.
    I have changed back all the settings that I can remember but am really stuck, can anyone help?
    I have an Audi TT 8S 2015 2.0 TFSI, as far as I’m aware I do not have cornering lights.
    Thanks in advanced.
    Moving to New User Forum from General VW/Audi Repair.
    Please post an Auto-Scan so people can see how your car is equipped and configured.
    Jan 2020
    Spain
    Friday,17,January,2020,21:43:09:30289
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: TRUZZZFV3F1009952   License Plate:
    Chassis Type: FV-AU37 (8S0)
    Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A5 A9
    VIN: TRUZZZFV3F1009952   Mileage: 94444km-58684miles
    A9-Struct. Borne Sound -- Status: Malfunction 0010
    Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
      Part No SW: 8S0 906 259     HW: 06K 907 425 B
      Component: 2.0l R4 TFSI  H13 0004
      Revision: --H13---
      Coding: 0A1900322424050B3002
      Shop #: WSC 06385 790 00016
      ASAM Dataset: EV_ECM20TFS0208S0906259 001005
      ROD: EV_ECM20TFS0208S0906259.rod
      VCID: 7AAEFB5F1C583CC7873-802F
    6 Faults Found:
    16452 - Implausible Data Received from ESP Control Module
             U0416 00 [032] - -
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 11:18:47
                       Coolant temperature: 77 °C
                       Intake air temperature: 52 °C
                       Voltage terminal 30: 14.296 V
                       Unlearning counter according OBD: 32
                       PV: 0.00 %
                       Engine: operating status: ES
                       T_IGK: 2.90 s
    17178 - Databus
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 11:18:45
                       Intake air temperature: 51 °C
                       Voltage terminal 30: 14.257 V
                       Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                       Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                       Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                       Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                       Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                       Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                       Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                       Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                       Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                       Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    21322 - Implausible Data Received from ABS Control Module
             U0415 00 [040] - -
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       Engine speed: 3028.75 /min
                       Normed load value: 22.4 %
                       Vehicle speed: 53 km/h
                       Coolant temperature: 82 °C
                       Intake air temperature: 42 °C
                       Voltage terminal 30: 12.792 V
                       Engine: operating status: PL
                       ECU_STATE: SYN_ENG_IGK_ON
                       Engine oil temperature: 75.0 °C
                       Time since engine start: 71.6 s
                       T_ES: 0 min
                       Cruise control switch actuation-Main switch hardware: operated
                       Cruise control switch actuation-Main switch CAN: operated
                       STATE_ERR_ABC_PRED: 0
    21323 - Implausible Data Received from ABS Control Module
             U0415 00 [040] - -
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       T_ES: 0 min
    23130 - Implausible Data Received from ABS Control Module
             U0415 00 [040] - -
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       Engine speed: 3002.00 /min
                       Voltage terminal 30: 12.578 V
                       T_ES: 0 min
    23131 - Implausible Data Received from ABS Control Module
             U0415 00 [040] - -
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       T_ES: 0 min
    Readiness: 0010 0001
      Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
      Component: ESC           H31 0504
      Revision: 00000000    Serial number: 63474000000378
      Coding: 32AA108D1A9915B2409A0069C2939306444C0858A8020043C96022
      ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
      ROD: EV_Brake1UDSContiMK100IPB_052.rod
      VCID: 40DA49B73A04A617897-8015
    18 Faults Found:
    0070 - Rear Left Wheel Speed Sensor
             C101C 29 [008] - Signal Implausible
                       Reset counter: 193
                       Mileage: 92354 km
                       Date: 2020.01.14
                       Time: 11:41:46
    0075 - Rear Left Wheel Speed Sensor
             C101C 07 [008] - Mechanical Failure
                       Reset counter: 193
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
    0091 - Rear Right Wheel Speed Sensor
             C101D 07 [008] - Mechanical Failure
                       Reset counter: 193
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
    8246 - Databus
             [FCAN: Motor_Code_01 message is not received]
                       Reset counter: 198
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:45
    8250 - Databus
             [FCAN: Motor_07 message is not received]
                       Fault Frequency: 143
                       Reset counter: 201
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:45
    8252 - Databus
             [FCAN: Motor_11 message is not received]
                       Fault Frequency: 201
                       Reset counter: 201
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
    8254 - Databus
             [FCAN: Motor_12 message is not received]
                       Reset counter: 201
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
    8256 - Databus
             [FCAN: Motor_14 message is not received]
                       Fault Frequency: 196
                       Reset counter: 201
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    8258 - Databus
             [FCAN: Motor_20 message is not received]
                       Fault Frequency: 200
                       Reset counter: 201
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    8264 - Databus
             [FCAN: Tsk_06 message is not received]
                       Reset counter: 201
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    8351 - Databus
             [FCAN: Motor_17_alt veraltet bit is set]
                       Reset counter: 198
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:42
                       Reset counter: 193
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
    32865 - Databus
             [IPB_BUS: Motor_12 / MO_Drehzahl_01]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    32866 - Databus
             [IPB-BUS: Motor_20 / MO_Solldrehz_Leerlauf invalid]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    32867 - Databus
             [IPB-BUS: Motor_11 / MO_Mom_ist_Summe invalid]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    32872 - Databus
             [IPB-BUS: Motor_20 / MO_Fahrpedalrohwert_01invalid]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    32992 - Control Module for Electric Parking Brake
             C10E2 F0 [008] - RPM Sensor Implausble Signal
                       Reset counter: 193
                       Date: 2015.01.22
                       Time: 22:57:48
    32994 - Control Module for Electric Parking Brake
                       Reset counter: 193
                       Date: 2015.01.22
                       Time: 22:57:48
      Part No SW: 3Q0 959 435     HW: 3Q0 959 435
      Component: VWKESSYMQB    023 0522
      Revision: 00023000    Serial number: 0356563904
      Coding: 000F0F1620
      ASAM Dataset: EV_KessyHellaMQBAB 004027
      VCID: 77A8E26B2F4A21AFF8D-8023
    12716804 - Databus
             [Message Motor_14 missing]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    12718343 - Databus
             [Message Motor_07 missing]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:44
    12718344 - Databus
             [Message Motor_09 missing]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:44
      Part No SW: 8S0 820 047     HW: 8S0 820 047
      Component: AC Manuell el H05 0030
      Revision: 20009000    Serial number: 14190000009000
      Coding: 410040000011100100
      ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
      ROD: EV_AirCondiMAPrehAU33x.rod
      VCID: 70BAD9774A247697397-8025
      Operating and display unit 1 for air conditioning:
      Subsystem 1 - Part No SW: 8S0 820 374 A    HW: 8S0 820 374 A
      Component: E774 BuA_1  H06 0010
      Serial number: 00000000000000000916
      Operating and display unit 2 for air conditioning:
      Subsystem 2 - Part No SW: 8S0 820 360 D    HW: 8S0 820 360 D
      Component: E775 BuA_2  H06 0010
      Operating and display unit 3 for air conditioning:
      Subsystem 3 - Part No SW: 8S0 820 360 C    HW: 8S0 820 360 C
      Component: E776 BuA_3  H06 0010
      Operating and display unit 4 for air conditioning:
      Subsystem 4 - Part No SW: 8S0 820 360 E    HW: 8S0 820 360 E
      Component: E777 BuA_4  H06 0010
      Operating and display unit 5 for air conditioning:
      Subsystem 5 - Part No SW: 8S0 820 374 B    HW: 8S0 820 374 B
      Component: E778 BuA_5  H06 0010
    459023 - Databus
             [Motor_12_Alt - Motorsteuergerät - Datenbus fehlende Botschaft]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
      Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
      Component: BCM MQBAB H   H18 0136
      Serial number: 01011500600635
      Coding: 07054C46C201067D03044004B31807A80080000000000000000000000000
      ROD: EV_BCMBOSCH_013.rod
      VCID: 094C949349BE275F9E9-805D
      Subsystem 1 - Part No SW: 8S2 955 119 A    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
      Component: 43x RL 140703  032 0371
      Serial number: 00000001407010600651
      Coding: 1BC7F7
      Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
      Component: G397_RLS  H06 0002
      Serial number: 20170017
      Coding: 00005D
      Light switch:
      Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
      Serial number: 31 10 2014  00001298
      Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
      Serial number: 000000000ZY143210P5Q
      Serial number: 00000000000031477725
    7 Faults Found:
    534549 - Databus
             [FLA_01 Datenbus fehlende Botschaft]
                       Reset counter: 201
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 18:49:13
    541973 - Databus
             [Motor_04 Datenbus fehlende Botschaft]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
    542229 - Databus
             [Motor_14 Datenbus fehlende Botschaft]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
    542485 - Databus
             [Motor_18 Datenbus fehlende Botschaft]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
    555541 - Databus
             [Motor_12_alt aktiv]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
    559125 - Databus
             [Motor_07 Datenbus fehlende Botschaft]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
    565764 - LED Light Bar
             B1664 31 [008] - No Signal
                       Reset counter: 201
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 18:39:58
      Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
      Component: PARKHILFE 4K  H10 0051
      Revision: --------    Serial number: 39291435205285
      Coding: 0000050001
      VCID: 3B203E5B53E2C5CFDC5-806F
    13637426 - Databus
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
      Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
      Component: AirbagVW20    009 0870
      Serial number: 003M7R008LLN
      Coding: 88CCF0C00C8000005C5000CFC0C800000065
      ROD: EV_AirbaVW20SMEVW37X.rod
      VCID: 4DC46083FD567B7F721-8019
      Subsystem 1 - Part No SW: -----------    HW: 480 000 701 15
      Serial number: 35700000000B4079621C
      Subsystem 2 - Part No SW: -----------    HW: 480 000 701 15
      Serial number: 358000000007D539621J
      Subsystem 3 - Part No SW: -----------    HW: 480 010 712 14
      Component: SideSensor_Dr  004 0108
      Serial number: 351001A014A5F5C2CECQ
      Subsystem 4 - Part No SW: -----------    HW: 480 400 910 14
      Serial number: 3550002A7175A922917%
      Front Sensor Passenger:
      Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
      Serial number: 3560002A5175A924114W
      Pedestrian Protection Center:
      Subsystem 6 - Part No SW: -----------    HW: 480 400 812 14
      Serial number: 23000029F1811B91607X
      Subsystem 7 - Part No SW: -----------    HW: 480 000 612 14
      Serial number: I0M000000007C0CC1211
      Subsystem 8 - Part No SW: -----------    HW: 480 000 612 14
      Serial number: I0N00000000C94CC1218
      Part No SW: 8S0 907 129 AL    HW: 8S0 907 129 AL
      Component: Lenks. Modul  H07 0140
      Revision: --------    Serial number: 91335OA800762
      Coding: 280C
      ASAM Dataset: EV_SMLSKLOMQB 019002
      ROD: EV_SMLSKLOMQB_010_VW37.rod
      VCID: 045285A76E9C7A37EDF-8051
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
      Part No SW: 8S0 920 790     HW: 8S0 920 790
      Component: FBenRDW       H32 0221
      Coding: 24250110698406000120F8809000800000000000
      ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
      ROD: EV_DashBoardBOSCHAU33X.rod
      VCID: 76B6EF6F284058A7E3B-8023
    16776971 - Databus
             [Motor_04 communication error can_error_timeout]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
      Part No SW: 8S0 907 468 A    HW: 8S0 907 468
      Component: GW MQB TT3    012 0203
      Revision: --------    Serial number: 10121410802670
      Coding: 030100042F025A004B000268080000000000000000000000000000000001
      ASAM Dataset: EV_GatewContiAU33X 011002
      ROD: EV_GatewContiAU33X_011.rod
      VCID: 3E26374F40F0D0E7FBB-806B
      Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
      Component: J453 MFL  H06 0001
      Serial number: 20141127192416 RD508
      Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
      Serial number: 1322795203
    131702 - No Communication with Engine Control Module (SAE ECM/PCM)
             U0100 00 [008] - -
             [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:43
                       Supply voltage: Terminal 30: 14.1 V
                       Terminal 15: On
      Serial number: 14000306508006
      Coding: 0100000000000000
      ROD: EV_ELVMarquMQBB.rod
      VCID: 71BCDC73412E7F9F369-8025
    12666369 - Databus
             [Timeout Message Motor_14]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
                       Result lock conditions: invalid
                       ESCL locked: No
                       ESCL unlocked: Yes
                       Lock sensor: not activated
                       Unlock sensor: operated
                       Error mode 1: not active
                       Error mode 2: not active
                       Clamp S: On
                       Clamp 15: On
                       Clamp 15 Status: valid
                       Remote Start: not active
                       Driver door: Open
                       Central locking locked external: unlocked
                       Central locking safed external: Vehicle not secured
                       Clamp Request: No
                       Request highside lock: No
                       HW highside lock: OFF
                       Highside unlock: No
                       Motor break: not active
                       Activation lowside unlock: OFF
                       Activation lowside lock: OFF
                       I2C overflow: No
                       I2C error pathflags: No
                       I2C resetinfo: No
                       I2C error cpu: No
                       I2C error rom: No
                       I2C error ram: No
                       I2C length failure: No
                       I2C error sda: No
                       I2C communication failure: i2c no comm failure
                       I2C state esp 10: i2c cnd true
                       I2C cnd haco message: valid
                       Coco reset: No
                       Coco supply: On
                       Password IMS OK: Yes
                       Signature IMS OK: Yes
                       IMS responded: Yes
                       Positive authentification in current KL15 cycle: No
                       Lifestate: Immobilizer download obtained
                       Authentication valid (T1): No
                       State of authentication state machine: WFS_AUTH_INIT_e
                       Vehicle speed: 0.00 km/h
                       UBat internal: 13.6 V
                       UMotorBridge: 7.4 V
                       Lock condition engine speed: Condition met
                       Lock condition clamp S: Condition not met
                       Lock condition clamp 15: Condition not met
                       Lock condition E2E clamp status: Condition not met
                       Lock condition timeout clamp status: Condition met
                       Lock condition vehicle speed: Condition met
                       Lock condition E2E vehicle speed: Condition met
                       Lock condition timeout vehicle speed: Condition met
                       Lock condition Mode1: Condition met
                       Lock condition drive readiness: Condition met
                       Lock condition selector lever position parking: Condition met
                       Clamp enable ESCL: not enabled
                       Lock condition timeout distance pulse: Condition met
                       Lock condition E2E distance pulse: Condition met
                       Lock condition difference distance pulse: Condition met
    13637378 - Databus
             [Errorvalue ESP_Wegimpulse]
                       Reset counter: 193
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:11
                       ESCL locked: No
                       ESCL unlocked: Yes
                       Clamp S: On
                       Clamp 15: On
                       Driver door: closed
                       Clamp Request: No
                       Highside unlock: No
                       I2C overflow: No
                       I2C resetinfo: No
                       I2C error cpu: No
                       I2C error rom: No
                       I2C error ram: No
                       I2C error sda: No
                       I2C state esp 10: i2c cnd false
                       Coco reset: No
                       Coco supply: On
                       IMS responded: Yes
                       Vehicle speed: 63.38 km/h
                       UBat internal: 12.3 V
                       UMotorBridge: 6.6 V
                       Lock condition engine speed: Condition not met
                       Lock condition vehicle speed: Condition not met
                       Lock condition E2E vehicle speed: Condition not met
                       Lock condition difference distance pulse: Condition not met
      Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
      Serial number: 060115BLN04479
      Coding: 001146225C01040100001402
      VCID: 42DE43BF3408B4079F3-8017
    458803 - Databus
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
      Coding: 9103
      VCID: 3728226B6FCAE1AF38D-8063
    7 Faults Found:
    20228 - Databus
             [ESP_19 Botschaft - SNA-Check]
                       Reset counter: 193
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       Motor status: 01
                       System status: Driving mode
                       Supply voltage: 12.75 V
                       Temperature: 31.0 °C
                       KFC: 4F
                       KFA: 00 04
                       Environmental conditions: 21
                       uioUdNotFilt_xdu16: 12.83 V
                       uAdSensI_SwitchedKl30_xdu16: 12.81 V
    23040 - Databus
             [MOTOR_20 Botschaft - CAN-Timeout]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
                       Motor status: 03
                       Supply voltage: 14.00 V
                       KFC: 5A
                       KFA: 00 00
                       Environmental conditions: 20
                       uioUdNotFilt_xdu16: 14.09 V
                       uAdSensI_SwitchedKl30_xdu16: 14.08 V
    22784 - Databus
             [MOTOR_14-Botschaft - CAN-Timeout]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
                       Motor status: 03
                       Supply voltage: 14.25 V
                       KFC: 59
                       KFA: 00 00
                       uioUdNotFilt_xdu16: 14.36 V
                       uAdSensI_SwitchedKl30_xdu16: 14.36 V
    19460 - Databus
             [ESP_05 Botschaft - SNA-Check]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:42
                       Motor status: 03
                       KFC: 4C
                       KFA: 00 04
                       uioUdNotFilt_xdu16: 14.16 V
                       uAdSensI_SwitchedKl30_xdu16: 14.16 V
    23296 - Databus
             [MOTOR_CODE_01 Botschaft - CAN-Timeout]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:45
                       Motor status: 03
                       KFC: 5B
                       KFA: 00 00
                       uioUdNotFilt_xdu16: 14.25 V
                       uAdSensI_SwitchedKl30_xdu16: 14.26 V
    21762 - Databus
             [HCA_01 Botschaft - MC-Check]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 11:09:11
                       Motor status: 03
                       Temperature: 33.0 °C
                       KFC: 55
                       KFA: 00 02
                       uioUdNotFilt_xdu16: 14.52 V
                       uAdSensI_SwitchedKl30_xdu16: 14.51 V
    19716 - Databus
             [ESP_10 Botschaft - SNA-Check]
                       Reset counter: 193
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       Motor status: 01
                       KFC: 4D
                       KFA: 00 04
                       uioUdNotFilt_xdu16: 13.02 V
                       uAdSensI_SwitchedKl30_xdu16: 13.01 V
      Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
      Serial number: 100115BA91780A
      Coding: 001146225E01040100001402
      VCID: 41DC4CB3310EAF1F869-8015
    65541 - Dimming for Switch Illumination
             B132B 01 [008] - Electrical Failure
                       Reset counter: 201
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 18:07:29
    458803 - Databus
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
      Coding: 03DE00102B100200
      ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
      VCID: 343215677EBC0AB71DF-8061
      Coding: E01800
      Coding: E01800
      Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
      Component: LeiMo links  H02 S002
      Coding: E01800
      Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
      Component: LeiMo rechts  H02 S002
      Coding: E01800
      Matrix Headlamp Powermodule 1 Left:
      Component: MxB LeiMo li.
      Matrix Headlamp Powermodule 1 Right:
      Component: MxB LeiMo re.
    6 Faults Found:
    13705479 - Databus
             U1121 00 [137] - Missing Message
             [Kamera_FDD_Obj01 Datenbus fehlende Botschaft]
                       Reset counter: 161
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 19:55:59
    5334065 - Output Stage for Left Matrix Headlamp
             C1164 31 [137] - No Signal
                       Reset counter: 161
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 19:56:00
    5334321 - Output Stage for Right Matrix Headlamp
             C1165 31 [137] - No Signal
                       Reset counter: 161
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 19:56:00
    5275220 - Headlight
                       Reset counter: 161
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 19:56:00
    5350720 - Left Matrix High Beam
             C1175 54 [137] - Missing Calibration / Basic Setting
                       Reset counter: 161
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 19:56:00
    5350976 - Right Matrix High Beam
             C1176 54 [137] - Missing Calibration / Basic Setting
                       Reset counter: 161
                       Mileage: 94440 km
                       Date: 2020.01.17
                       Time: 19:56:00
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
      Part No SW: 8S0 035 072 A    HW: 8S0 035 072
      Component: MU-H-ND-ER    041 0139
      Serial number: A587A0FB000508
      Coding: 013304013C00000011111101000800002F0000E3000000001E
      ASAM Dataset: EV_MUHig4CGen2HBAS 001115
      ROD: EV_MUHig4CGen2HBAS_AU37.rod
      VCID: 2D0400039D965B7F521-8079
      Subsystem 1 - Part No SW: V03 959 801 ET    HW: -----------
      Component: ECE 2015  --- 0105
      Multimedia Operating Unit:
      Subsystem 2 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
      Component: ControlUnit_H  H21 0129
      Serial number: C1000015111400010114
      Component: Gracenote2  --- 1008
    6708 - Databus
             [Engine: no communication]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:40
                       Voltage terminal 30: 14.4 V
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
      Part No SW: 8S0 980 653     HW: 5Q0 980 653
      Component: MQB_MFK       H06 0002
      Serial number: 00000268359
      Coding: 0101000001010300000501000000010100
      ROD: EV_MFKBoschAU370.rod
    0291 - Steering
             C10AC F3 [008] - Lane-Holding Assistance Not Available
             [suHcaBlockedSteeringErrorFailure]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 11:19:01
                       Control Module temperature: 40 °C
                       Outside air temperature: 14.5 °C
                       Voltage terminal 15: 14.1 V
                       Terminal 15 on: 8.1 s
      Part No SW: 8S0 907 159     HW: 4H0 907 159 A
      Component: SAS-GEN 2     H07 0004
      Serial number: 141203200313
    0010 - Databus
             [Keine Funktion durch CAN FehlerMotorsteuergerätebotschaft fehlt--> keine Klangerzeugung]
                       Reset counter: 193
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 10:53:41
    End----------(Elapsed Time: 01:34, VBatt start/end: 14.6V/14.6V)-----------
    Kind Regards
    Glenn - HGB Motors
    Glenn@hgbmotors.co.uk
    On 17 Jan 2020, at 21:34, Andy Smith <support@ross-tech.com> wrote:
    Please email a COMPLETE AutoScan, not just the faults in 01-Engine.
    Regards,
    Andy
    On 1/17/2020 3:16 PM, Glenn - HGB Motors wrote:
    Hi Andy, thanks for your quick response.
    Please see the error codes below, look forward to hearing from you;
    Friday,17,January,2020,20:09:47:30289
    VCDS Version Release 19.6.2 (x64) Running on Windows 7 x64(Parallels)
    www.Ross-Tech.com <http://www.ross-tech.com/>
                   Address 01: Engine       Labels: 06K-907-425-V1.clb
    Control Module Part Number: 8S0 906 259     HW: 06K 907 425 B
     Component and/or Version: 2.0l R4 TFSI  H13 0004
              Software Coding: 0A1900322424050B3002
               Work Shop Code: WSC 06385 790 00016 <tel:06385%20790%2000016>
                 ASAM Dataset: EV_ECM20TFS0208S0906259 001005 (AU37)
    6 Faults Found:
             U0416 00 [032] - -
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 11:18:47
                       PV: 0.00 %
                       T_IGK: 2.90 s
    17178 - Databus
                       Mileage: 92339 km
                       Date: 2020.01.14
                       Time: 11:18:45
             U0415 00 [040] - -
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       T_ES: 0 min
             U0415 00 [040] - -
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       T_ES: 0 min
             U0415 00 [040] - -
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       T_ES: 0 min
             U0415 00 [040] - -
                       Mileage: 92340 km
                       Date: 2020.01.14
                       Time: 11:24:09
                       T_ES: 0 min
    Good lord, that car is so full of fault codes that the signal-to-noise ratio is just about nil.
    What exactly did you do to make such a mess?
    Please look at your CodingLog and AdpLog files and put everything back to stock, then clear all fault codes and post a new scan.
  5. Likes PetrolDave, Dana liked this post
    Jan 2020
    Spain
    I was trying to activate high beam assist and traffic sign recognition. Traffic signs were successful and I have reverted the changes I made for high beam assist unless I have missed anything.
    I am new to this how can I go back to standard?
    I have had sat nav activated as a retrofit and also a remap so I am worried about wiping these.
    Thanks for your help.
    United States
    We received the e-mail sent to support but it contains the same Auto-Scan. I would recommend posting a handful of logs so we can try to help you get this resolved as a group:
    1) Open the CodingLog and AdpLog files using Notepad and paste the contents within code tags here.
    2) The VCDS Auto-Scan prior to any modifications would be extremely helpful. You may want to look in both C:\Ross-Tech\VCDS\Logs -and- C:\Ross-Tech\VCDS\Scans to locate the oldest one you have from this VIN.
    3) The scan you posted includes 59 fault codes which are flagged Intermittent. Many of those should clear so please do so and include another scan in that condition. That will make it significantly to determine what's what.
  8. Likes Hbuk24 liked this post
    Jan 2020
    Spain
    I have had some help with this from someone using team viewer and he manages to sort everything out apart from the headlights which was great, I have attached the latest autoscan. Please ignore the door warning as I had the door card off at the time to install puddle lights. Any help regarding this would be really appreciated as I can't seem to find any information on how to fix the lights. It looks like they need to be calibrated? The message that comes up on the dash is "Audi adaptive light: fault. See owners manual. Thanks
    Wednesday,22,January,2020,17:38:50:30289
    VIN: TRUZZZFV3F1009952   Mileage: 94535km-58741miles
       Revision: --H13---
       Coding: 000F0F1620
       Coding: 1BC7F7
       Coding: 00005D
       Light switch:
       Coding: 0000050001
       Coding: 280C
       Coding: 9103
    65592 - Interior Switch for Central Locking
              B1230 29 [008] - Signal Implausible
                        Reset counter: 214
                        Mileage: 94535 km
                        Date: 2020.01.22
                        Time: 17:32:26
       Coding: E01800
       Coding: E01800
       Coding: E01800
       Coding: E01800
    6 Faults Found:
    13705479 - Databus
                        Reset counter: 172
                        Mileage: 94509 km
                        Date: 2020.01.21
                        Time: 23:27:26
                        Reset counter: 172
                        Mileage: 94509 km
                        Date: 2020.01.21
                        Time: 23:27:26
                        Reset counter: 172
                        Mileage: 94509 km
                        Date: 2020.01.21
                        Time: 23:27:26
    5275220 - Headlight
                        Reset counter: 172
                        Mileage: 94509 km
                        Date: 2020.01.21
                        Time: 23:27:26
                        Reset counter: 172
                        Mileage: 94509 km
                        Date: 2020.01.21
                        Time: 23:27:26
                        Reset counter: 172
                        Mileage: 94509 km
                        Date: 2020.01.21
                        Time: 23:27:26
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.2V)-----------
    It looks like it thinks i have Matrix headlights when I don't think i do.
  10. #8
    United States
    I agree, it is looking for Matrix lights and a camera ([Kamera_FDD_Obj01 Datenbus fehlende Botschaft]) that isn't on the databus. The CodingLog and AdpLog in addition to any prior VCDS Auto-Scans may allow us to determine the cause.
    In the meanwhile, it might not hurt to see if 55 will accept: 03DE00102B200200 If that's accepted I would clear faults so see how many return. With any luck you will be down to one for Basic Settings rather than 6.
    Edit, I can move this to the Car Repair Support section now that you are Verified. It will receive more views there.
  11. Likes Hbuk24, Uwe liked this post
  12. #9
    Jan 2020
    Spain
    Yes, I have just read the original scan file from when i bought the car and it has them down as normal LED headlamps. I do hoverer have a camera in the can as is currently active for picking up the traffic signs. I have attached the original log file below;
    Sunday,12,January,2020,16:42:30:30289
    VIN: TRUZZZFV3F1009952   Mileage: 91851km-57073miles
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       ASAM Dataset: EV_ECM20TFS0208S0906259 001004
    20277 - Terminal 15 Voltage
              P151B 00 [036] - Implausible
                        Mileage: 91851 km
                        Date: 2020.01.12
                        Time: 15:43:43
                        Engine speed: 798.00 /min
                        Normed load value: 3.1 %
                        Coolant temperature: 90 ∞C
                        Intake air temperature: 34 ∞C
                        Voltage terminal 30: 12.050 V
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 27 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.987 V
                        FAC_TPS_1_SAE: 11.718750 %
                        FUP_H_SAE: 11000.0 kPa
    15057 - Fuel Rail/System Pressure
              P0088 00 [096] - Too High
       Coding: 000F0F1620
       Coding: 1BC7F7
       Coding: 00005D
       Light switch:
    204546 - Remote key 2
                        Reset counter: 144
                        Mileage: 91818 km
                        Date: 2019.12.17
                        Time: 09:38:45
    262912 - Sensor for Anti-Theft Alarm System
              B1330 F5 [008] - Alert Emergency Activation Stage 1
                        Reset counter: 184
                        Mileage: 91818 km
                        Date: 2019.12.17
                        Time: 09:38:46
       Coding: 0000050001
       Coding: 280C
       Coding: 24250110698006000120A8809000800000000000
       Coding: 9103
    Address 52: Door Elect, Pass.
       Coding: 03DE00102B200200
       Coding: E01800
       Coding: E01800
       Coding: E01800
       Coding: E01800
       Coding: 013304013C00000011111101000800002F0000E3000000001A
       Subsystem 1 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
       Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
       Coding: 0100000001010300000501000000010100
    End----------(Elapsed Time: 01:24, VBatt start/end: 13.2V/13.2V)-----------
  13. Likes Dana, Uwe liked this post
  14. #10
    United States
    OK, that original scan sheds a lot of light and confirms 55 was coded to 03DE00102B200200. Providing there weren't any ADP function modifications the modules with remaining modifications are:
    * Including a new 5F slave
    The scan snippets above, with the exception of the new slave, are your old/original values. Due to the extremely high number of fault codes in your initial scan I would code 55 back to 03DE00102B200200 for now and run Basic settings (Basic headlamp setting followed by Acknowledge basic setting) to get this vehicle back to a relativity fully functional/DTC free condition.
    After doing so you can start a new thread containing the factory condition scan and the newest cleaned up post-camera retrofit scan in the Retrofits section. Someone there may be able to help you work out the needed modifications without causing so many codes.
  15. Likes Hbuk24, Uwe liked this post
