Results 1 to 4 of 4
Thread: 2003 Jetta GLI Project - First Auto Scan
    Jan 2020
    Puerto Rico, USA
    Hi all;
    I just installed VCDS and performed an Auto Scan to my Jetta. I replaced the steering angle sensor and I'm rying to set it up correctly. Need some tips on how to do it. Also found several DTCs on the engine module. Your help is highly appreciated.
    German
    Friday,17,January,2020,17:43:47:07067
    VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
    VIN: 3VWVH69MX3M060650   License Plate:
    Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
              75 76
    VIN: 3VWVH69MX3M060650   Mileage: 314400km-195359miles
    Address 01: Engine        Labels: 022-906-032-BDF.lbl
       Part No: 022 906 032 CS
       Component: MOTRONIC ME7.1.1G   0004
       Coding: 00032
       Shop #: WSC 00066
       VCID: 5EE5999759262C479BB-5160
       3VWVH69MX3M060650     VWZ7Z0B5783956
    16804 - Catalyst System; Bank 1
                P0420 - 35-10 - Efficiency Below Threshold - Intermittent
    17880 - EVAP Leak Detection Pump
                P1472 - 35-10 - Short to Ground - Intermittent
    17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
                P1117 - 35-10 - Short to Ground - Intermittent
    17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2
                P1198 - 35-10 - Electrical Malfunction - Intermittent
       Part No: 1C0 907 379 M
       Coding: 0019970
       Shop #: WSC 00028 000 00000
       VCID: 34311B3F822AD6171DF-5184
       Part No: 1C0 909 605 F
       Component: 04 AIRBAG VW61 0202 0001
       Coding: 12340
       Shop #: WSC 00066
       VCID: 270BFC7346FCAD8FA8D-513C
       Part No: 1J0 920 906 J
       Component: KOMBI+WEGFAHRSP VDO V11
       Coding: 07234
       VCID: 2F3B14536E0CF5CF60D-513C
    01304 - Radio
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00028
       VCID: 70B9D72FB3B2AA37397-513C
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 1H Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 00028
       VCID: 372B2C33965C3D0F38D-4B1E
       Component: 1H Tőrsteuer.FS KLO 0004
       Component: 1H Tőrsteuer.BF KLO 0004
       Component: 1H Tőrsteuer.HL KLO 0004
       Component: 1H Tőrsteuer.HR KLO 0004
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180
       Component:    Radio ZSW        0012
       Coding: 00401
       Shop #: WSC 00028
       VCID: 5DE79E9B5420375F821-513C
    00856 - Radio Antenna
                36-10 - Open Circuit - Intermittent
    End----------(Elapsed Time: 05:18, VBatt start/end: 12.5V/12.5V)-----------
  3. Likes Jetta ,97 liked this post
    Dallas (McKinney) ,TX ,USA
    It is VR6 ,possible need software update for CAT.
    JACK we need you here
    Immobilizer/ECU
    email : marinmm2001@gmail.com
    Jan 2020
    Puerto Rico, USA
    Thanks Uwe;
    The steering angle sensor was set up as per the instructions. Need to replace the oxygen sensors for the engine issues. I’m glad to adquire the VCDS.
