Results 1 to 10 of 15
Thread: Passat 3B and replacing the ECU problem
    Feb 2017
    Oulu, Finland
    Hey!
    The problem car at the moment is the Volkswagen Passat model 2001.
    The original Ecu will have to be replaced because the engine is fitted with more powerful nozzles than the original one, which has been disassembled from a crashed car. The same crashed car takes an ECU optimized for these most powerful nozzles.
    We followed the instructions for this link http://wiki.ross-tech.com/wiki/index....28USED_ECU.29, but right from the start it will stop the error message. "SKC code incorrect"
    I was looking at the SKC code before switching to VagTacho and we know the code, but VagTacho claims that the old and new used ECUs would have the same code. Can this be true? and what should we try next to get the new used ecu to work on that car?
    Preheat and immobilizer lights on instrument cluster blink when engine ecu is replaced with new used
    These codes are read from the new used ECU.
    Friday,17,January,2020,19:03:16:00464
    Dealer/Shop Name: J.P - V3lmu
    VIN: WVWZZZ3BZ2E152041   License Plate: VW PASSAT
    Mileage: 448790km-278865mi   Repair Order: ecu homma
    Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWZZZ3BZ2E152041   Mileage: 448790km-278865miles
    Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
       Part No: 8E0 614 111 A
       Component: ABS/EDS 5.3 QUATTRO D10
       Shop #: BB 24334
       VCID: 1C61D4672FBBDAE735F-51CE
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 H
       Component: CLIMATRONIC B5GP    0006
       Coding: 17000
       Shop #: WSC 05311
       VCID: 2615F68F61F7103793B-5184
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
                30-00 - Open or Short to Plus
       Part No: 1C0 909 605 B
       Component: 0A AIRBAG VW51 04     02
       Coding: 12353
       Shop #: WSC 05311
       VCID: 2313EF9B12C5E51FF45-513C
    Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
       Part No: 3B0 920 826 A
       Component: KOMBI+WEGFAHRSP VDO V01
       Coding: 05115
       Shop #: WSC 00050
       VCID: 211FE59308D9F70FE69-513C
       WVWZZZ3BZ2E152041     VWZ7Z0A4036000
    01177 - Engine Control Unit
                65-10 - Unauthorized - Intermittent
       Part No: 6N0 909 901
       Coding: 00004
       Shop #: WSC 05314
       VCID: 70B9D0D793B30E87397-513C
       Part No: 1C0 959 799 B
       Component: 16 Komfortgerát HLO 0003
       Coding: 00258
       Shop #: WSC 05311
       VCID: 363526CFB15760B723B-4B1E
       Subsystem 1 - Part No: 1C1959801
       Component: 16 Tőrsteuer.FS KLO 0003
       Subsystem 2 - Part No: 1C1959802
       Component: 16 Tőrsteuer.BF KLO 0003
       Subsystem 3 - Part No: 1C0959811
       Component: 16 Tőrsteuer.HL KLO 0002
       Subsystem 4 - Part No: 1C0959812
       Component: 16 Tőrsteuer.HR KLO 0002
    01134 - Alarm Horn (H12)
                49-00 - No Communications
    01141 - Luggage Compartment Unlocking Switch (E165)
                36-00 - Open Circuit
                27-00 - Implausible Signal
    End----(Elapsed Time: 04:34, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
    Quote Originally Posted by V3lmu View Post
    That seems highly unlikely. As in the chances of that are something on the order of 1 in 10,000.
    Your scan doesn't show any ECU at all.
    Feb 2017
    Oulu, Finland
    Does this mean that this car is not immo 3 but immo 2?
    I only noticed this now. Is this because of that DTC (1 Fault Found: 01177 - Engine Control Unit 65-10 - Unauthorized - Intermittent)
    No, since the instrument cluster knows the car's VIN, I think it's pretty safe to conclude that this car is Immo-3.
    I would expect this fault code is there due to you having swapped ECUs at some point.
    Need to establish communication issue with ECU in scan first?
    Does check engine illuminate?
    Does car crank, start and die after 2 seconds?
    Why not just defeat Immobilizer?
    Is Tune code running FOD interference maybe bad xsum?
    Feb 2017
    Oulu, Finland
    If you think the ECU is broken, you're wrong. The ecu has been dismantled from a crashed car, but here the engine worked with these nozzles and the ecu.
    Yes and immo light too.
    Yes, Exactly.
    The owner would like the immobilizer to be a last resort.
    I am researching the subject to remove the immobilizer, but I have not found any program / help how to do this.
    I don't understand this question, sorry
    No it is you who are wrong, that is why you are here!
    Bad Math...........
  9. #8
    Feb 2017
    Oulu, Finland
    The owner said that before disassembling the parts, he had started the car and let it idle and gasified the engine. The engine had run smoothly at all revs.
    The problems started when the crash car parts were put in the current car.
    Bad Math...........
    Is this somehow related to the ecu/tuning program?
  10. #9
    Ja Ja Ah huh!
    Depends but It can be............
    Tuners protect their shit with MATH or sometimes HASH!
    https://www.theatlantic.com/technolo...-count/466242/
    Hash function
    https://en.wikipedia.org/wiki/Hash_function
  11. #10
    Feb 2017
    Oulu, Finland
    Ja Ja Ah huh!
    This amazes me and even a little pissed off..
    How do parts in a crash car rotate the engine nicely but not rotate another same engine?
