Results 1 to 5 of 5
Thread: Fabia 2 FL Longcoding ESP8.2i help please
    Jan 2020
    Berlin, Germany
    SOLVED: Fabia 2 FL Longcoding ESP8.2i help please
    hi everyone
    after testing another speedometer in my fabia my esp is now completely zero.
    I don't have a scan of this before.
    i tried to calculate the esp coding with espcalculator but with every result the error 22.
    I don't know what to do, can someone help me here?
    thank you danny
     Friday,17,January,2020,15:30:30:39104
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
    VCDS Version 19.6.2.0  HEX-V2 CB: 0.4508.4
    VIN: TMBEA25J2C3024139   License Plate:
    Chassis Type: 5J-SK25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: TMBEA25J2C3024139   Mileage: 108940km-67692miles
    Address 01: Engine (CHF)       Labels: Redir Fail!
       Part No SW: 03D 906 023 M    HW: 03D 906 023 M
       Component: SIMOS91 1.2l 2V     1718
       Revision: --H05---    Serial number:
       Coding: 0000071
       Shop #: WSC 13765 790 00051
       VCID: 280802755EEA9747A17-5185
    Readiness: 0010 0001
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AA    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0003
       Revision: --------
       VCID: 7DA60321EDB8E2EFA21-8029
    03306 - Coding Not Valid
                        Fault Frequency: 27
                        Reset counter: 130
                        Mileage: 108873 km
                        Date: 2014.06.06
                        Time: 17:46:31
                        Hex Value: 0x0007
                        Hex Value: 0x0000
                        Hex Value: 0x3209
                        Hex Value: 0x1494
                        Hex Value: 0x007F
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
                        Fault Frequency: 83
                        Reset counter: 130
                        Mileage: 108738 km
                        Date: 2014.05.27
                        Time: 20:43:39
                        Hex Value: 0x0007
                        Hex Value: 0x0002
                        Hex Value: 0x3211
                        Hex Value: 0x1498
                        Hex Value: 0x007F
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 5J0 820 045 C    HW: 5J0 820 045 C
       Component: Man AC         02 0101
       Revision: 0003S 02
       VCID: 25160B4125E88A2F9A1-8071
       Part No SW: 6R7 937 086 H    HW: 6R7 937 086 H
       Component: PQ25 BCM      H12 0022
       Revision: -3------    Serial number: 1002480501
       Coding: 64980B380801000000200EC03E6B18840000400F600000000000
       VCID: 48C8A2F5F2BA7747417-801D
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3211
       Coding: 020000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3211
       Coding: 020000
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagT23 H09 0020
       Revision: --------    Serial number: 003GX00PPFC0
       Coding: 003233
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4ACC98FDEC368557573-801F
       Serial number: 3495RRB405T0KEOINHB-
       Serial number: 3505RRB404V0KSEG3P7F
       Part No SW: 5J0 920 801 H    HW: 5J0 920 801 H
       Component: KOMBI         H04 0206
       Serial number: 00000007146755
       Coding: 110800
       Shop #: WSC 13765 031 00051
       ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
       ROD: EV_DashBoardUDSJCIPQ25_A01.rod
       VCID: 2B02FD79438CBC5F4C5-807F
       Part No SW: 6N0 909 901     HW: 6R7 937 086 H
       Component: GW-K-CAN TP20 0022
       Revision: -3------
       Coding: 032200
       VCID: 70B82A15AAAA9F87397-8025
    Address 25: Immobilizer (J285)       Labels: 5J0-920-xxx-25.clb
       Component: IMMO          H04 0014
       ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
       ROD: EV_ImmobUDSJCIPQ25.rod
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11240
       Shop #: WSC 13765
       VCID: 2F3AE9697E54C07F60D-807B
    Address 56: Radio
    End----------(Elapsed Time: 00:55, VBatt start/end: 13.4V/13.4V)-----------
    Jan 2020
    Berlin, Germany
    good morning
    nobody can help me by coding?
    vin: TMBEA25J2C3024139
    1.2 engine chf
    LHD
    front disk: 256 mm
    back drums: 200 mm
    no tmp, no hill hold, no xds
    Jan 2020
    Berlin, Germany
    nobody wants or can help me to code the abs new here?
    To few Autoscan with this engine.
    Maybe try this:
    410124DB216F00B6822624E584DA00401000
  5. Likes Uwe liked this post
    Jan 2020
    Berlin, Germany
    thank you, thank you, thank you very much.
    you coding is perfect working.
  7. Likes Uwe liked this post
