Results 1 to 2 of 2
Thread: 2014 VW Touran steering angle sensor not calibrating, reading 0 all time
    Jan 2016
    Steering wheel clockspring unit has been renewd and coded with the original coding but
    now having trouble with Touran not letting to do basic settings for the G85. Tried many times in 03, 44 & 16 (sensor zeroing), all with login 40168.
    Also checked graph of abs wheel sensor and they looked all good, sometimes there is fault code under 10 (Park/Steer Assist) of a front radar.
    The angle reading keeps 0 in most places, the rate (acceleration) reading works. Under 16 - Steering wheel (J527) I can see some hexadecimals changing while turning the wheel and under 44: Steering Assist there's a reading from 0-360 that goes over and over about 10 times with just one full turn of the steering wheel, don't know what that is.
    Any suggestions?
    Thursday,16,January,2020,17:16:03:34924
    VCDS Version: 17.1.2.0 (x64)
    Data version: 20170107 DS267.0
    VIN: WVGZZZ1TZFW012144   License Plate: TOURAN_3
    Mileage: 162580km-101022mi   Repair Order:
    Chassis Type: 1T (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 37 42 44 46 4F 52 55
              56 61 62 69 72
    VIN: WVGZZZ1TZFW012144   Mileage: 162580km-101022miles
    Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 NR    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9978
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00254036032401080000
       ASAM Dataset: EV_ECM16TDI02103L906023NR 003011
       ROD: EV_ECM16TDI02103L906023NR.rod
       VCID: 830E26B30A9DF4597E-80D6
       Part No SW: 0AM 300 064 B    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 5201
       Revision: 00043014    Serial number: CU501406135401
       VCID: AD5AA00B3499D229F8-80F8
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: 323B401609230EFC4C0C02E8901D7051A1015021
       VCID: FEF85747697F99B111-80AA
                        Reset counter: 180
                        Mileage: 162584 km
                        Date: 2020.01.16
                        Time: 15:53:29
                        Count: 16387
                        Count: 12800
                        Count: 16390
                        Count: 48384
                        Count: 9728
                        Reset counter: 180
                        Mileage: 162584 km
                        Date: 2020.01.16
                        Time: 15:53:29
       Part No SW: 3AA 907 044 BS    HW: 3AA 907 044 BS
       Component: Climatronic   H05 0607
       Revision: 00001K02
       Coding: 001000C003
       VCID: 820023B71587FD5175-80D6
       Part No SW: 5K0 937 087 AB    HW: 5K0 937 087 AB
       Component: BCM PQ35 H    122 0174
       Revision: BE122001
       Coding: 60180A3B80251AE4408800C0540011604BD59008626DA520E480C7000049
       VCID: F5EA486B5C49DAE940-80A0
       Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 18061  26  0512
       Coding: 009795
       Component: RLS 020714 05  54  0403
       Coding: 0230ED
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0043
       Revision: --------    Serial number: 56201416701018
       Coding: 148301
       ASAM Dataset: EV_EPHVA2C000000000 002014
       ROD: EV_EPHVA2C000000000_VW41.rod
       VCID: CB9ECE93624DFC19C6-809E
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No SW: 1T0 909 605 E    HW: 1T0 909 605 E
       Component: 02 AIRBAG VW8   022 0100
       Revision: 02022000    Serial number: 003K4D0CVW8.
       Coding: 0012338
       VCID: B7768263C6C568F992-80E2
       Subsystem 1 - Serial number: 6332QSME6E463E72V
       Subsystem 2 - Serial number: 6342QSME6E463252I
       Subsystem 3 - Serial number: 6352QSME36453E40G
       Subsystem 4 - Serial number: 6362QSME34451F60G
       Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
       Revision: --X01---    Serial number: 20191029100200
       Coding: 1982140000
       Shop #: WSC 01286 386 08256
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0571575
       Coding: 820000
    1140738 - Steering angle sensor
                        Reset counter: 180
                        Mileage: 162584 km
                        Date: 2020.01.16
                        Time: 15:50:58
                        UBat: 12.40 V
                        MC1 interner Fehlercode: 0
                        MC2 interner Fehlercode: 0
       Part No SW: 1T0 920 885 N    HW: 1T0 920 885 N
       Component: KOMBI         H03 0705
       Coding: 180F01
       VCID: C38EE6B34A1D34593E-8096
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 7N0 963 272 C
       Component: Standheizer     044 4840
       Revision: 00044000    Serial number: 09024302000000
       Coding: 0031012
       Shop #: WSC 35110 377 00163
       VCID: B56A886BDCC99AE980-80E0
       Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1653
       Revision:   H55       Serial number: 230614F1001106
       Coding: 358002
       VCID: 800429BF138BEF4163-80D4
       Component: IMMO          H03 0705
       VCID: EAD06B170DF70511DD-80BE
       Revision: A1001003    Serial number: 7666349754
       Coding: 020100
       VCID: AB5EAE13CA8DDC19E6-80FE
       Part No SW: 3C8 035 279 R    HW: 3C8 035 279 R
       Component: RNS315-EU   H80 0500
       Serial number: VWZAZ2P0357542
       Coding: 040004110400090000029002
       ROD: EV_RNS315EUV2UDS.rod
       VCID: BA709B573DD775916D-80EE
       Component: EUR_W_V6  0062
       Part No SW: 1T0 959 701 AE    HW: 1T0 959 701 AE
       Component: Tuer-SG         009 2121
       Coding: 0165045
       VCID: FAF05B57B557B5912D-80AE
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.294 1401
       Revision: 1BH04739    Serial number: 00141780051501
       Coding: 0000258
       VCID: C182ECBB980126492C-8094
    02546 - Steering Limit Stop
                        Fault Status: 11100101
                        Reset counter: 180
                        (no units): 4.0
                        Voltage: 12.70 V
    00566 - Steering Assistance Operation
                        Reset counter: 180
                        Reset counter: 180
                        Mileage: 162584 km
                        Date: 2020.01.16
                        Time: 15:56:15
                        (no units): 4.0
                        Steering Angle: 0.00
                            Not OK
                        (no units): 5
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1653
       Coding: 050B0500
       VCID: EFE67A033E15E0398A-80BA
       Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H03 0090
       Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H03 0090
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0165045
       VCID: C796F2A3B6251879E2-8092
    Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
       Component: AFS-ECU       H04 0111
       Coding: 038200000B000200
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       VCID: B77682630EC568F992-80E2
       Subsystem 1 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0007
       Coding: 320000
       Subsystem 2 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0007
       Coding: 320000
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
       Component: Batt.regelung H55 1653
       Coding: 030F1859
       VCID: F1E27C7B2821F6C99C-80A4
       Component: J367-BDM  H07 0180
       Serial number: 31171523261491440508
       Part No SW: 5K0 959 703 B    HW: 5K0 959 703 B
       Component: Tuer-SG         007 2102
       Coding: 0165008
       Shop #: WSC 01357 011 1012552
       VCID: B36EB673D2BD84D9AE-80E6
    00937 - Switch for Electric Window; Rear Left (E52)
    Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
       Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
       Component: Towbar module H10 0110
       Revision: 3A001001    Serial number: 006789XXXXXX
       Coding: 0100000100000000
       VCID: B162BC7BE8A1B6C9DC-80E4
       Part No SW: 5K0 959 704 B    HW: 5K0 959 704 B
       Coding: 0165008
       VCID: B46CB56FD7B383E1B7-80E0
    End-------------------------(Elapsed Time: 03:12)--------------------------
    Is the TPMS fault running interference?
    Are all correct parts installed?
    Are all mechanical operations correct & set to neutral basic setting center-line?
