Audi A6 2012 - ABS error codes
Souriau
Newry, NI
C?ID=86928
Can anyone help me with the error codes on the ABS?
There is low tyre pressure warning light on the dash display but I can't seem to reset it.
Thursday,16,January,2020,14:44:26:46973
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
Workshop Code: 000 18261 018261
VIN: WAUZZZ4GXCN154910   License Plate:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ4GXCN154910   Mileage: 181076km-112515miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LA    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H24 9977
   Revision: 45H24---
   Coding: 0A194012242401080000
   Shop #: WSC 41215 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018LA 003011
   ROD: EV_ECM20TDI01103L906018GT.rod
   VCID: F4A4958D5F0CD2EF33-80A0
          U1113 00 [039] - -
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:36
                    Engine speed: 830.50 /min
                    Normed load value: 27.5 %
                    Coolant temperature: 53 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 14.660 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
          U1113 00 [039] - -
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:36
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 00000000000000000000
   Shop #: WSC 02391 785 00200
   VCID: B6206F8509F080FFCD-80E2
0058 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_Getriebe_01_Timeout]
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:33
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: BE
                    Uz: BC
0060 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_Getriebe_03_Timeout]
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:33
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C1
                    Uz: BC
0061 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_Getriebe_04_Timeout]
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:34
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: CB
                    Uz: BC
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0333
   Coding: 03B83006000000000000
   VCID: F6A0AF854170C0FF0D-80A2
   Serial number: 2312000054271013
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
   Component: KLIMA 2 ZONEN H10 0064
   Serial number: 21031200040666
   Coding: 34210008A0
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   VCID: A306A6D1AA6205571A-80F6
0267 - Sensor for Refrigerant Pressure and Temperature
          B10C2 21 [009] - Signal Amplitude Too Low
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:34
                    Compressor current: actual value: 0 mA
                    Outside air temperature: 11.5 °C
                    Temperature after evaporator: 14.61 °C
                    Engine speed: 829 /min
   Part No SW: 4H0 907 063 BM    HW: 4H0 907 063 E
   Component: BCM1 2.0      H12 0111
   Revision: 19012002    Serial number: 00000001249799
   Coding: 2600201040349F600481008000001D0C0F9D830827090101000004602100
   VCID: F4A4958D570CD2EF33-80A0
   Component: WWS57X 120214  H35 0080
   Serial number:         120305184049
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20112220
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 16 03 2012  00001561
   Serial number: 21180E16000000000001
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901207903874
   Coding: 080206
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: BD3270A92CC653A70C-80E8
   Revision: --------    Serial number: 003JG007PJDG
   Coding: 30323436313230303235554A305234473053
   Serial number: 3575HRB406317UE4AP4B
   Serial number: 3585HRB405D177543GT+
   Serial number: 3515JRB40184UHGCA1AC
   Serial number: 3525JRB401I4UHGCEQ32
   Serial number: 3554VRB40084UH6IP91-
   Serial number: 3564VRB40084UH6INA7%
   Revision: 00000000    Serial number: 20120324000386
   Coding: 000014
   VCID: B02C599DE394AECF97-80E4
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H08 0009
   Part No SW: 4G8 920 950 K    HW: 4G8 920 950 K
   Component: MDieGb        H34 0209
   Revision: 26450208    Serial number: 658060312592041
   Coding: 33A408000B012600010000
   ASAM Dataset: EV_RBC7KMID 004045
   ROD: EV_RBC7KMID.rod
   VCID: B73E62810EFA79F7D6-80E2
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:34
   Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002372128
   Coding: 00CD074410
   Shop #: WSC 54484 001 1048576
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: B83C61BD03E4768FDF-80EC
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790556910
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 16121100000000000044
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0009
   Revision: --------    Serial number: EJ1BPA3201TNCL0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: EB968EF102320D17E2-80BE
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011C16204001620002080002
   VCID: C2C803555D382C5F71-8096
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0026403518
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: B2285395E5989CDFE1-80E6
   Revision: 00002001    Serial number: 0173462617
   Coding: 011B062200B9044083200804000103000000000000000000000000000000
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: C1CA0C59583E374768-8094
   Revision: --------    Serial number: 00000000289125
   ROD: EV_ParkiBrake_VW51.rod
   VCID: AA184BF5CD48D41F59-80FE
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Serial number: 120322-0002-107
   Coding: 112196101000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: AC144DEDC7BCCA2FAB-80F8
   Part No SW: 4G0 035 193 E    HW: 4G0 035 193 D
   Component: RMC Cnct Nav  H52 0775
   Coding: 0101000101415B47002B060301010000010000
   VCID: A502B8C9AC56FB6774-80F0
   Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9464C-0C2517377
   Subsystem 2 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
   Serial number: 90349LCJ00039
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:38
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010814204001620002080002
   VCID: C4C4054D472C226F43-8090
   Component: TSG HR        H04 0212
End----------(Elapsed Time: 01:33, VBatt start/end: 14.7V/14.7V)-----------
ABS is looking for messages from the Auto-Trans. But Gateway doesn't think it has an automatic trans. That's a bit confusing. What's the back-story here? What parts have been changed?
Vehicle Identification No.WAUZZZ4GXCN154910
ModelAudi A6 2,0 TDI
A6
Date of production30.03.2012
Model year2012
Sales type4G20TC
Engine CodeCGLC
Transmission CodeNEJ
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PDWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components7JVVehicle class differentiation -4G0/4G8-
tail pipe0P0Rear exhaust tailpipe (standard)
Emission standard7MGEmission standard EU5
Trailer hitch1D8Trailer hitch preparation
airbag4UFAirbag for driver and front passenger with front passenger airbag deactivation
Aktivkohlebehälter / Ottopartikelfilter1E0Without activated carbon canister
Label for central electric0W2Label for central electric system English-speaking countries
Storage compartment packageQE0Without storage compartment package/box
Exterior mirror setting6XDExterior mirrors, power-adjustable/ heated
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror6TSRight exterior mirror, aspherical, large viewing field
Alternative drive system0K0Without alternative drive system
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8SStandard equipment
Brake type in rear1KWDisc brakes in rear
batteriesJ0BBattery 520 A (92 Ah)
Brake type, front1LADisc brakes in front
Components with special surface6FAComponents without special surface appearance
Handset (telephone)QF0Without receiver (car phone)
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0NComponent parts set, complying with vehicle type for Great Britain, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ASElectronic stability control (ESC)
Front passenger seat control4V0Without front passenger seat control
Owner's manuals0VFInformation kit in English
Operating voltage9Z0Operating voltage 12 V
CD changer/CD player7A7without CD changer
General operating permit, alterationsC07Operating permit, alteration
CO2 variant0C0Standard
Cd enhancing underbody panel2D0Without cd enhancing underbody panel
Shock absorption/suspension, chassis1BESports suspension/shock absorption
Roof rails/roof load rack3S0Without roof rails/roof load rack
Double DIN/dual-view display2T5Without dual-view display
Roof insert/convertible top3FAWithout roof insert (standard roof)
Decorative films / emblems6F1Emblems
Load-through hatch/ski bag3X0without load through system
ECO function for driving profiles and Drive selectEF1ECO function
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Inserts5TGDecorative inserts, brushed, matte aluminum
Scuff plates7M8Scuff plates in door apertures
Input medium for multimediaUJ0Input medium for multimedia
Park distance control7X2Park distance control in front and rear
Extended safety system7W0Without extended safety system
Electric interface for external use UF0Without electric interface
Power-operated door (power latching)GZ0Manually operated doors
Manufacturing sequence differentiation0FAStandard manufacturing sequence
Color of dashboard/door and side trim panel6RADashboard and door trim panel one-piece, single color
Headlight activation8K4Separate daytime running light -- NAR --
Fresh air intake for passenger compartment (with particulate filter)2V5Fresh air intake system with combination filter
Parking brakeUH2Parking brake
Vehicle tracing system7G0Without preparation for VTS (Vehicle Tracing System)
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Night vision9R0without night-vision system
Alternators9G3Alternator 120-180 A
Transmission types/gearshift mechanisms0G1Gearshift lever
Weight category rear axle0YHWeight range 8 installation control only, no requirement forecast
Noise cancellationEP0No noise cancellation
Weight category front axle0JFWeight category front axle weight range 6
Base engineTM44-cylinder diesel engine 2.0 l unit 03L.M
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T1Cruise control system (CCS)
Garage door openerVC0without Garage door opener
Transmission specificationsG0K6-speed manual transmission
rear axle differentialGH0Without rear axle differential
Rear trim panel6V1Rear trim panel (ECE)
ManufacturerA51Audi AG
Rear spoiler5J0Without rear spoiler
Molded headliner6NQStandard molded headliner
Rear seats3NZRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8BPBi-functional headlamp with gas discharge lamp
Head-up displayKS0Without head-up display
Customized installationFC1Customized installation
Instrument clustersU1BInstrument cluster with mph speedometer, clock, tachometer and trip odometer
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Body styleK8BNotchback
Camera/distance sensorQK0Without camera without distance sensor (driver assistance system)
Luggage compartment floor covering6SSLuggage compartment floor covering
Fuel tank capacity0M0Fuel tank
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR8without road sign recognition
Seat ventilation/massage seat4D0Without seat ventilation/massage seat
Fuel quantity for initial filling1Z5Increase in initial standard fuel filling
Fuel quality0U2Fuel quality < 50 ppm
Fuel systems0F3Fuel system for diesel engine
Body measures5C0Without special body measures
Child seat anchors in front3G1Child seat anchors, front left (ISOFIX)
Camera systems/accident sensorsKA0without camera systems/environment sensors
Front license plate carrier6W6Front license plate carrier
Paint preservative/transit coating5K5Transport protection film with additional transport protection measures
Rear cargo area3GAWithout luggage compartment floor
Light package (lighting)QQ0Without add. lights (interior lighting)
Steering system arrangementL0RRight-hand drive
steeringQZ7Power steering
Lumbar support7P1Power-adjustable lumbar support in front seats
steering wheels1XWLeather-wrapped multi-function sports steering wheel
Driving on the left/on the rightAV0Driving on the left
Speaker installation9VDactive loudspeakers
Steering column systems2C5Axial and vertical adjustable steering column
Leather scope7HAWithout leather trim
Headlight range control8Q3Dynamic headlight range control (self-adjusting while driving)
Center armrest6E3Center armrest in front
VersionsFM0Basic equipment variant
Multi-function display/trip computer9Q7Multi-function display/trip computer
Center console3D1Center console
Engine cooling8Z5not hot country
Engine specificationsDE24-cyl. turbo dies. eng. 2.0 l/130 kW 4V TDI common rail base engine is TR1,TD1,TM4/TL4/TP4
Navigation device7T2Navigation system (LOW)
Platform group class7PAPlatform group class 1
Audi Sport/ Quattro GmbHFQ1Wheels of Audi Sport/ Quattro GmbH
Quality classAQ0Standard-production quality
WheelsC9TAlloy wheels 8J x 18
Radios8DPRadio "LOW II"
Smoker's/non-smoker's package9JANon smoker version
Tire pressure monitoring system7K6Tire pressure monitoring system
tireH2ETires 245/45 R18 100Y xl
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G5Space-saving spare wheel, same size (same rolling circumference) as original equipment tires
Type of tireVG6Type of tire: design 2
PQ1Audi exclusive cast aluminium alloy wheels, 5 twin-spoke design, size 8J x 18, with 245/45 R 18 tyres
PQDPACK_SPORT_DESIGN
PX4XENON PLUS
WQR
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle7F9Gearshift knob/handle in plastic/leather
Self-collection / special controlA00No self-collection
Special labels/plates2KRLabels in English and German
Tail lamp assemblies8SKTaillight assemblies with diodes (LED)
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Bumper systems2K7bumper reinforced
Seat belt check9P6Seat belt reminder, electric contact in buckle
seat coversN1VSeat trim covers in leather
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Safety certificate0LLWith special labels safety certificates for England
Start-stop system/regenerative braking7L8Start-stop system with regenerative braking
Lane change assist/lane keeping system7Y0no lane change assistant
Side and rear windows4KCSide and rear windows in heat-insulating glass
Sunroof roller blind for rear/side windows3Y0without roller blind
Handling production and pre-productionFA0Control of series production
Headlamp washer system8X1Headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N6Windshield wiper intermittent control with light/rain sensor
Special approval measures3M3Passenger car design
Nameplate set0NBNameplate set in basic style
Thermal insulation insert (cup holder)KT0Without thermal insulation insert (cup holder)
Door and lid locking system4K4Central locking w/ radio remote control
Type approval countries/countries with special requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D7Carrier frequency 868 MHz without panic button
Transit coatingNT1Transit coating (type 2)
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Assembly parts for engine (drive bearing)1VGInstallation parts for four-cylinder engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification label for EC for M1 passenger vehicles
Type sign2Z1Type sign at rear and "Quattro" nameplates respectively
First aid kit / warning triangle1T3First aid kit with warning triangle
Front seatsQ1DSports front seats
Telephone / telematics9ZXTelephone preparation for cellphone
Maintenance contractEW0Without maintenance contract
Heat accumulator system/auxiliary heater7E6Electric auxiliary air heater
Windshield Glass4GQWindshield in heat-insulating glass
Central display and control unitQW1Central control unit in front
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZBBright decorative trims
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung0RCStarter switch locking system
Auxiliary heating system9M0Without auxiliary heater/parking heater
Wow, a 4G chassis car that came from the factory with a 6-speed manual transmission! I didn't know such a thing existed.
Something tells me the ABS coding of all zeros ain't right. ;)
Souriau
Newry, NI
C?ID=86928
The customer bought this car in an auction and have no details of past service history or repair work.
Do you have the correct ABS coding for this vehicle?
I will try and see if there is a long coding helper.
There is no LC helper for this
I rescanned the car this morning.
Friday,17,January,2020,11:08:30:46973
   Revision: 45H24---
          U1113 00 [039] - -
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:36
          U1113 00 [039] - -
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:36
          U1111 00 [009] - -
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:33
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: BE
                    Uz: BC
          U1111 00 [009] - -
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:33
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C1
                    Uz: BC
          U1111 00 [009] - -
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:34
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 43
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: CB
                    Uz: BC
0500 - Control Module
          C104A F0 [129] - Incorrect VIN
0505 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [VarECUuncoded]
                    Reset counter: 99
                    Time: 00:00:00
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 83
                    Uz: 00
   Coding: 34210008A0
0131 - Motor for Left Footwell Flap
          B10B9 07 [009] - Mechanical Failure
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:57:47
                    Voltage terminal 30: 12.29 V
                    Outside air temperature: 10.5 °C
                    Interior temperature: 24.24 °C
                    Left footwell temperature flap motor-Act.val.: 12619
                    Left footwell temperature flap motor-Specified value: 11100
                    Left footwell temperature flap motor-Stop open: 15502
                    Left footwell temperature flap motor-Stop closed: 10000
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:34
   Coding: 0045F7
   Coding: 02512B
   Coding: 080206
   Coding: 000014
   Coding: 33A408000A012600010000
   Shop #: WSC 18261 000 18261
          B2010 00 [009] - -
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 16:32:37
          U1014 00 [009] - -
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 16:32:37
   Coding: 00CD074410
   Voltage stabilizer:
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 139
                    Mileage: 181076 km
                    Date: 2020.01.17
                    Time: 00:02:23
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 9 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 139
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 23:05:40
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
                    Reset counter: 99
                    Mileage: 181076 km
                    Date: 2020.01.16
                    Time: 14:42:38
End----------(Elapsed Time: 01:52, VBatt start/end: 14.8V/14.7V)-----------
TIA
Seamus
          U1014 00 [137] - -
          [VarECUuncoded]
                    Reset counter: 99
                    Time: 00:00:00
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 83
                    Uz: 00
It's not just a case of coding, there is also a VIN mismatch...
Souriau
Newry, NI
C?ID=86928
ADVANCE ID scan:
I think I will sent this to a garage in Belfast to be connect to Factory link Odis to get this correctly code
Saturday,18,January,2020,11:02:09:46973
                Address 01: Engine
Control Module Part Number: 03L 906 018 LA
  Component and/or Version: R4 2.0l TDI   H24 9977
           Software Coding: 0A194012242401080000
            Work Shop Code: WSC 41215
Advanced Identification/FAZIT
     Identification: RB8-658
     Revision: 45H24---
     Date: 13.03.12
     Manufacturer number: 1415
     Test stand number: 1087
Flash Status
     Programming Attempts(application): 0/1/1/1
     Successful Attempts(application): 0/1/1/1
     Flash Date: 00.00.00
Misc.
     Hardware number: 03L 906 018 JL
     Workshop System Name: J623
     ASAM Dataset Revision: 003011
Car Info
     Chassis Number: WAUZZZ4GXCN154910
     Engine code: CGLC
VCDS Info:
       Labels: 03L-906-018-CGL.clb
       Readiness: No script available
Control Module Part Number: 4G0 907 379 H
  Component and/or Version: ESP PREMIUM   H09 0361
           Software Coding: 00000000000000000000
            Work Shop Code: WSC 02391
     Identification: BPA-085
     Revision: --------
     Date: 13.03.12
     Manufacturer number: 0035
     Test stand number: 4065
Flash Status
     Programming Attempts(application): 0/0/0
     Successful Attempts(application): 0/0/0
     Programming Attempts(data): 0
     Successful Attempts(data): 0
     Programming Status: 00000000
     Flash Tool Code(data): 00000 000 00000
Software
     BAP: 01.04.03
     Unknown: 01.03.00
     Generic Net Mgt: 02.07.00
     FlexRay Net Mgt: 02.05.00
     FlexRay Trsp: 02.07.26
     Unknown: 03.00.01
     Prot Data Unit Router: 02.06.03
     FlexRay Interf: 02.06.23
     FlexRay Drv: 02.06.80
     Unknown: 01.00.19
     Unknown: 02.07.01
Misc.
     Hardware number: 4G0 907 379 H
     Workshop System Name: J104
     Equipment/PR Code: 0000000000000000
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: 004028
VCDS Info:
       Labels: 4G0-907-379-V1.clb
Control Module Part Number: 4H0 907 064 BN
  Component and/or Version: BCM2 2.0      H31 0333
           Software Coding: 03B83006000000000000
     Identification: HLH-W41
     Date: 20.03.12
     Manufacturer number: 1002
     Test stand number: 0975
Flash Status
     Programming Attempts(data): 1
     Successful Attempts(data): 1
     Flash Tool Code(data): 00200 785 02391
Software
     Theft prot.: 02.02.00
     KWP2000: 02.30.00
Misc.
     Hardware number: 4H0 907 064 BN
     Workshop System Name: J393
     Equipment/PR Code: 0000000000002CAB
     Dataset Number: 4G0909517D
     Dataset Version: 0016
     End of Line Equipment Level: --------------------
Car Info
Immobilizer
     Transponder ID 1: B7184D99
     Transponder ID 2: ED184D99
VCDS Info:
       Labels: 8K0-907-064-05.clb
Control Module Part Number: 4G0 820 043 G
  Component and/or Version: KLIMA 2 ZONEN H10 0064
           Software Coding: 34210008A0
     Identification: KMM-KMM
     Date: 21.03.12
     Manufacturer number: 0004
     Test stand number: 0666
Flash Status
     Flash Date: 00.01.01
Misc.
     Hardware number: 4G0 820 043 G
     Workshop System Name: J255
     Equipment/PR Code: 4230303030303030
     ASAM Dataset Revision: 002040
VCDS Info:
       Labels: 4G0-820-043-2Z.clb
Control Module Part Number: 4H0 907 063 BM
  Component and/or Version: BCM1 2.0      H12 0111
           Software Coding: 2600201040349F600481008000001D0C0F9D830827090101000004602100
     Revision: 19012002
     Date: 02.03.12
     Manufacturer number: H059
     Test stand number: 1106
Flash Status
     Flash Date: 0000.00.00
     Flash Tool Code: 00000 000 00000
Software
     Theft prot.: 03.02.03
     BAP: 01.04.01
     CAN: 02.04.06
     TP 2.0: 03.05.00
     KWP2000: 00.30.00
     OSEK-OS: 00.10.00
     HiSpd Net: 01.12.01
     LIN 2.0: 00.01.53
Misc.
     Hardware number: 4H0 907 063 E
     Workshop System Name: J519
     Equipment/PR Code: 04563A7C13893C53
     Dataset Number: 4G0909514C
     Dataset Version: 0047
VCDS Info:
       Labels: 4H0-907-063-V1.clb
Control Module Part Number: 4H0 919 475 N
  Component and/or Version: PARKHILFE ACC H07 0050
           Software Coding: 080206
     Identification: ATW-001
     Revision: 11001001
     Date: 22.03.12
     Manufacturer number: EJGQ
     Test stand number: 0014
Flash Status
     Programming Attempts(application): 1/1/1/1
     Successful Attempts(application): 1/1/1/1
Misc.
     Hardware number: 4H0 919 475 C
     Workshop System Name: J446
     ASAM Dataset Revision: 002005
VCDS Info:
       Labels: 4H0-919-475-7X2.clb
                Address 15: Airbags
Control Module Part Number: 4H0 959 655 C
  Component and/or Version: Airbag10.43   H43 0040
           Software Coding: 30323436313230303235554A305234473053
     Identification: BPA-00A
     Revision: --------
     Date: 20.03.12
     Manufacturer number: 15JG
     Test stand number: 7PJD
Flash Status
Software
     Unknown: 05.01.00
     Bootloader/Flasher: 01.00.08
Misc.
     Hardware number: 4H0 959 655 C
     Workshop System Name: J234
     Equipment/PR Code: 0000000000005FC8
     Dataset Number: 4G0909602G
     Dataset Version: 0013
     End of Line Equipment Level: 00000000000000----
     ASAM Dataset Revision: 001014
Car Info
VCDS Info:
       Labels: 4H0-959-655.clb
Control Module Part Number: 4G8 920 950 K
  Component and/or Version: MDieGb        H34 0209
           Software Coding: 33A408000A012600010000
            Work Shop Code: WSC 18261
     Revision: 26450208
     Date: 06.03.12
     Manufacturer number: 3592
     Test stand number: 0413
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0
     Successful Attempts(application): 0/0/0/0/0/0
     Programming Attempts(data): 0/0/0/0/0
     Successful Attempts(data): 0/0/0/0/0
Software
     Unknown: 05.02.01
     BAP: 01.05.00
     UDS: 01.02.14
     Diag: 01.03.00
     CAN: 01.37.00
     TP 2.0: 03.05.00
     ISO15765: 01.02.15
     OSEK-OS: 03.07.00
     OSEK-Com: 03.07.00
     UDS Std Diag: 01.01.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 4G8 920 950 K
     Workshop System Name: J285
     Equipment/PR Code: 000000000000000000000000
     ASAM Dataset Revision: 004045
VCDS Info:
       Labels: 4H0-920-xxx-17.clb-SRI1
Control Module Part Number: 4G5 907 468 F
  Component and/or Version: J533--Gateway H14 0083
           Software Coding: 00CD074410
            Work Shop Code: WSC 54484
     Identification: LAK-000
     Revision: --------
     Date: 15.09.16
     Manufacturer number: 2009
     Test stand number: 2128
Flash Status
     Flash Date: 0001.01.00
     Flash Tool Code(data): 1048576 001 54484
Software
     FlexRay Drv: 02.06.75
     FlexRay Interf: 02.06.22
     Prot Data Unit Router: 02.06.02
     Diag: 01.03.00
     UDS: 01.02.14
     TP 2.0: 03.05.02
     ISO15765: 01.02.15
     AUTOSAR-ISO TP: 00.01.08
     HiSpd Net: 01.12.01
     MOST Net: 02.01.07
     MOST Firmware: 01.10.07
     INIC Config Str: 02.00.00
Misc.
     Hardware number: 4G0 907 468 AC
     Workshop System Name: J533
     Equipment/PR Code: 000002FAD47D11EC17944CF3
     Dataset Number: 4G0909515VA
     Dataset Version: 0001
     ASAM Dataset Revision: 001028
Car Info
     Engine code: ----
VCDS Info:
       Labels: None
Control Module Part Number: 4G0 907 637
  Component and/or Version: SARA 3D       H02 0009
           Software Coding:
            Work Shop Code: WSC 00000
     Revision: --------
     Date: 20.03.12
     Manufacturer number: 0060
     Test stand number: 0078
Flash Status
     Flash Date: 12.03.20
Misc.
     Hardware number: 4G0 907 637
     Workshop System Name: J849
     ASAM Dataset Revision: 009017
Car Info
VCDS Info:
Control Module Part Number: 4G8 959 793 E
  Component and/or Version: TSG FA        H05 0212
           Software Coding: 011C16204001620002080002
     Identification: KO1-MAL
     Revision: --------
     Date: 16.03.12
     Manufacturer number: 0006
     Test stand number: 1573
Flash Status
Software
     Diag: 01.03.00
     CAN: 01.26.02
     TP 2.0: 03.05.00
     KWP2000: 03.00.00
     HiSpd Net: 02.00.02
     LIN 2.0: 03.81.26
Misc.
     Hardware number: 4G8 959 793 A
     Workshop System Name: J386
     Equipment/PR Code: 00000000000608B0
     Dataset Number: 4G0909872C
     Dataset Version: 0026
VCDS Info:
       Labels: 4H0-959-793.clb
Control Module Part Number: 4G0 909 144 L
  Component and/or Version: RCEPS         H35 0010
           Software Coding: 101000010000
     Identification: TT1-000
     Revision: 00001000
     Date: 26.02.12
     Manufacturer number: 0002
     Test stand number: 1718
Flash Status
     Programming Attempts(application): 4/4/4/4/4/0
     Programming Attempts(data): 4
     Successful Attempts(data): 4
     Programming Status: 01010001
     Flash Date: 15.11.09
Misc.
     Hardware number: 4G0 909 144 G
     Workshop System Name: J500
     Equipment/PR Code: 0000000000000000000013D1
     Dataset Number: 4G0909852H
     Dataset Version: 0027
     End of Line Equipment Level: ------------------#
     ASAM Dataset Revision: 009008
Car Info
     Engine code: ----
VCDS Info:
       Labels: 4G0-909-144.clb
           Software Coding: 011B062200B9044083200804000103000000000000000000000000000000
     Date: 20.03.12
Flash Status
     Flash Date: ----.--.--
Software
     BAP: 01.03.00
     CAN: 01.26.01
     TP 2.0: 03.05.00
     KWP2000: 02.30.00
     OSEK-OS: 04.02.00
     HiSpd Net: 01.12.01
     LIN 2.0: 00.01.26
     EEProm lib.: 01.08.02
Misc.
     Equipment/PR Code: 00000A6233E0BFC0
     Dataset Number: 4G0909501D
     Dataset Version: 0048
VCDS Info:
       Labels: 4H0-907-064-46.clb
Control Module Part Number: 4G8 959 792 E
  Component and/or Version: TSG BF        H05 0212
     Revision: --------
     Date: 05.03.12
     Test stand number: 0147
Flash Status
Software
     Diag: 01.03.00
     CAN: 01.26.02
     TP 2.0: 03.05.00
     KWP2000: 03.00.00
     HiSpd Net: 02.00.02
     LIN 2.0: 03.81.26
Misc.
     Hardware number: 4G8 959 792 A
     Workshop System Name: J387
     Equipment/PR Code: 0000000000003850
     Dataset Number: 4G0909873C
     Dataset Version: 0025
VCDS Info:
       Labels: 4H0-959-792.clb
Control Module Part Number: 4H0 907 801 E
  Component and/or Version: EPB-4         H03 0012
           Software Coding:
            Work Shop Code:
     Identification: GNO-TSR
     Revision: --------
     Date: 15.03.12
     Manufacturer number: 0001
     Test stand number: 3890
Flash Status
Software
     ISO15765: 01.02.15
     UDS: 01.02.14
     CAN: 01.47.00
     HiSpd Net: 01.12.01
     Bootloader/Flasher: 01.07.00
Misc.
     Hardware number: 4H0 907 801 A
     Workshop System Name: ----
     ASAM Dataset Revision: 001022
Car Info
     Chassis Number: -----------------
VCDS Info:
Control Module Part Number: 4H0 907 357 A
  Component and/or Version: ....LWR12.... H02 0013
           Software Coding: 112196101000A300
     Identification: HLR-0W5
     Date: 22.03.12
     Test stand number: 1076
Flash Status
Software
     ISO15765: 01.02.15
     UDS: 01.02.14
     Diag: 01.03.00
     CAN: 01.26.01
Misc.
     Hardware number: 4H0 907 357 A
     Workshop System Name: J431
     End of Line Equipment Level: XXXXXXXXXXXXXXXXXX
     ASAM Dataset Revision: 005001
VCDS Info:
       Lab
els: 8X0-907-357.clb
Control Module Part Number: 4G0 035 193 E
  Component and/or Version: RMC Cnct Nav  H52 0775
           Software Coding: 0101000101415B47002B060301010000010000
     Identification: DE2-633
     Date: 14.03.12
     Manufacturer number: 0023
     Test stand number: 0126
Flash Status
Software
     MOST Net: 02.01.01
     TP 2.0: 02.04.05
     Unknown: 02.02.03
     BAP: 01.05.00
     Diag: 01.03.00
     KWP2000: 03.00.00
Misc.
     Hardware number: 4G0 035 193 D
     Workshop System Name: J794
     Equipment/PR Code: 863294F1CA624AAF
     Dataset Number: 4G0909545N
     Dataset Version: 0056
Car Info
VCDS Info:
       Labels: None
Control Module Part Number: 4G8 959 795 E
  Component and/or Version: TSG HL        H04 0212
           Software Coding: 010814204001620002080002
     Revision: --------
     Date: 06.03.12
     Test stand number: 1837
Flash Status
Software
     Diag: 01.03.00
     KWP2000: 03.00.00
     LIN 2.0: 03.81.26
Misc.
     Hardware number: 4G8 959 795 A
     Workshop System Name: J388
     Dataset Number: 4G0909875C
VCDS Info:
       Labels: 4H0-959-795.clb
  Component and/or Version: TSG HR        H04 0212
     Revision: --------
     Date: 06.03.12
     Test stand number: 1851
Flash Status
Software
     Diag: 01.03.00
     KWP2000: 03.00.00
     LIN 2.0: 03.81.26
Misc.
     Workshop System Name: J389
     Dataset Number: 4G0909874C
VCDS Info:
