Results 1 to 7 of 7
Thread: Audi A6 2012 - ABS error codes
    Aug 2016
    Newry, NI
    Can anyone help me with the error codes on the ABS?
    There is low tyre pressure warning light on the dash display but I can't seem to reset it.
    Thursday,16,January,2020,14:44:26:46973
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    Workshop Code: 000 18261 018261
    VIN: WAUZZZ4GXCN154910   License Plate:
    Chassis Type: 4G-AU57 (4G5)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 72
    VIN: WAUZZZ4GXCN154910   Mileage: 181076km-112515miles
    Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 LA    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H24 9977
       Revision: 45H24---
       Coding: 0A194012242401080000
       Shop #: WSC 41215 002 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018LA 003011
       ROD: EV_ECM20TDI01103L906018GT.rod
       VCID: F4A4958D5F0CD2EF33-80A0
              U1113 00 [039] - -
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:36
                        Engine speed: 830.50 /min
                        Normed load value: 27.5 %
                        Coolant temperature: 53 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 14.660 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 40
                        Cruise control switch-off: irreversible-Bits 0-7: 255
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
              U1113 00 [039] - -
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:36
       Coding: 00000000000000000000
       VCID: B6206F8509F080FFCD-80E2
    0058 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_01_Timeout]
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:33
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 43
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BE
                        Uz: BC
    0060 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_03_Timeout]
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:33
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 43
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: C1
                        Uz: BC
    0061 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_04_Timeout]
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:34
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 43
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: CB
                        Uz: BC
       Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
       Coding: 03B83006000000000000
       VCID: F6A0AF854170C0FF0D-80A2
       Serial number: 2312000054271013
       Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
       Component: KLIMA 2 ZONEN H10 0064
       Serial number: 21031200040666
       Coding: 34210008A0
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       VCID: A306A6D1AA6205571A-80F6
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:34
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 11.5 °C
                        Temperature after evaporator: 14.61 °C
                        Engine speed: 829 /min
       Part No SW: 4H0 907 063 BM    HW: 4H0 907 063 E
       Component: BCM1 2.0      H12 0111
       Revision: 19012002    Serial number: 00000001249799
       Coding: 2600201040349F600481008000001D0C0F9D830827090101000004602100
       VCID: F4A4958D570CD2EF33-80A0
       Component: WWS57X 120214  H35 0080
       Serial number:         120305184049
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 20112220
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 16 03 2012  00001561
       Serial number: 21180E16000000000001
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901207903874
       Coding: 080206
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: BD3270A92CC653A70C-80E8
       Revision: --------    Serial number: 003JG007PJDG
       Coding: 30323436313230303235554A305234473053
       Serial number: 3575HRB406317UE4AP4B
       Serial number: 3585HRB405D177543GT+
       Serial number: 3515JRB40184UHGCA1AC
       Serial number: 3525JRB401I4UHGCEQ32
       Serial number: 3554VRB40084UH6IP91-
       Serial number: 3564VRB40084UH6INA7%
       Revision: 00000000    Serial number: 20120324000386
       Coding: 000014
       VCID: B02C599DE394AECF97-80E4
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Component: E221 - MFL  H08 0009
       Part No SW: 4G8 920 950 K    HW: 4G8 920 950 K
       Component: MDieGb        H34 0209
       Revision: 26450208    Serial number: 658060312592041
       Coding: 33A408000B012600010000
       ASAM Dataset: EV_RBC7KMID 004045
       ROD: EV_RBC7KMID.rod
       VCID: B73E62810EFA79F7D6-80E2
    1048578 - No Basic Setting
              B2010 00 [009] - -
              [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:34
       Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
       Component: J533--Gateway H14 0083
       Revision: --------    Serial number: 00000002372128
       Coding: 00CD074410
       Shop #: WSC 54484 001 1048576
       ASAM Dataset: EV_GatewPkoUDS 001028
       VCID: B83C61BD03E4768FDF-80EC
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790556910
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Serial number: 16121100000000000044
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0009
       Revision: --------    Serial number: EJ1BPA3201TNCL0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: EB968EF102320D17E2-80BE
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16204001620002080002
       VCID: C2C803555D382C5F71-8096
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0026403518
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: B2285395E5989CDFE1-80E6
       Revision: 00002001    Serial number: 0173462617
       Coding: 011B062200B9044083200804000103000000000000000000000000000000
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: C1CA0C59583E374768-8094
       Revision: --------    Serial number: 00000000289125
       ROD: EV_ParkiBrake_VW51.rod
       VCID: AA184BF5CD48D41F59-80FE
       Serial number: 120322-0002-107
       Coding: 112196101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: AC144DEDC7BCCA2FAB-80F8
       Part No SW: 4G0 035 193 E    HW: 4G0 035 193 D
       Component: RMC Cnct Nav  H52 0775
       Coding: 0101000101415B47002B060301010000010000
       VCID: A502B8C9AC56FB6774-80F0
       Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9464C-0C2517377
       Subsystem 2 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
       Serial number: 90349LCJ00039
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:38
                        Bin. Bits: 00000000 10000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: C4C4054D472C226F43-8090
       Component: TSG HR        H04 0212
    End----------(Elapsed Time: 01:33, VBatt start/end: 14.7V/14.7V)-----------
    ABS is looking for messages from the Auto-Trans. But Gateway doesn't think it has an automatic trans. That's a bit confusing. What's the back-story here? What parts have been changed?
  3. Likes Jack@European_Parts, Souriau liked this post
    Vehicle Identification No. WAUZZZ4GXCN154910
    Model Audi A6 2,0 TDI
    A6
    Date of production 30.03.2012
    Model year 2012
    Sales type 4G20TC
    Engine Code CGLC
    Transmission Code NEJ
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PD Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 7JV Vehicle class differentiation -4G0/4G8-
    tail pipe 0P0 Rear exhaust tailpipe (standard)
    Emission standard 7MG Emission standard EU5
    Trailer hitch 1D8 Trailer hitch preparation
    airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated carbon canister
    Label for central electric 0W2 Label for central electric system English-speaking countries
    Storage compartment package QE0 Without storage compartment package/box
    Exterior mirror setting 6XD Exterior mirrors, power-adjustable/ heated
    Follow-on warranty EA0 Without subsequent warranty
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 6TS Right exterior mirror, aspherical, large viewing field
    Alternative drive system 0K0 Without alternative drive system
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment levels A8S Standard equipment
    Brake type in rear 1KW Disc brakes in rear
    batteries J0B Battery 520 A (92 Ah)
    Brake type, front 1LA Disc brakes in front
    Components with special surface 6FA Components without special surface appearance
    Handset (telephone) QF0 Without receiver (car phone)
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0N Component parts set, complying with vehicle type for Great Britain, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AS Electronic stability control (ESC)
    Front passenger seat control 4V0 Without front passenger seat control
    Owner's manuals 0VF Information kit in English
    Operating voltage 9Z0 Operating voltage 12 V
    CD changer/CD player 7A7 without CD changer
    General operating permit, alterations C07 Operating permit, alteration
    CO2 variant 0C0 Standard
    Cd enhancing underbody panel 2D0 Without cd enhancing underbody panel
    Shock absorption/suspension, chassis 1BE Sports suspension/shock absorption
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Double DIN/dual-view display 2T5 Without dual-view display
    Roof insert/convertible top 3FA Without roof insert (standard roof)
    Decorative films / emblems 6F1 Emblems
    Load-through hatch/ski bag 3X0 without load through system
    ECO function for driving profiles and Drive select EF1 ECO function
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 5TG Decorative inserts, brushed, matte aluminum
    Scuff plates 7M8 Scuff plates in door apertures
    Input medium for multimedia UJ0 Input medium for multimedia
    Park distance control 7X2 Park distance control in front and rear
    Extended safety system 7W0 Without extended safety system
    Electric interface for external use UF0 Without electric interface
    Power-operated door (power latching) GZ0 Manually operated doors
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    Color of dashboard/door and side trim panel 6RA Dashboard and door trim panel one-piece, single color
    Headlight activation 8K4 Separate daytime running light -- NAR --
    Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with combination filter
    Parking brake UH2 Parking brake
    Vehicle tracing system 7G0 Without preparation for VTS (Vehicle Tracing System)
    Night vision 9R0 without night-vision system
    Alternators 9G3 Alternator 120-180 A
    Transmission types/gearshift mechanisms 0G1 Gearshift lever
    Weight category rear axle 0YH Weight range 8 installation control only, no requirement forecast
    Noise cancellation EP0 No noise cancellation
    Weight category front axle 0JF Weight category front axle weight range 6
    Base engine TM4 4-cylinder diesel engine 2.0 l unit 03L.M
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T1 Cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Transmission specifications G0K 6-speed manual transmission
    rear axle differential GH0 Without rear axle differential
    Rear trim panel 6V1 Rear trim panel (ECE)
    Manufacturer A51 Audi AG
    Rear spoiler 5J0 Without rear spoiler
    Molded headliner 6NQ Standard molded headliner
    Rear seats 3NZ Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8BP Bi-functional headlamp with gas discharge lamp
    Head-up display KS0 Without head-up display
    Customized installation FC1 Customized installation
    Instrument clusters U1B Instrument cluster with mph speedometer, clock, tachometer and trip odometer
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Body style K8B Notchback
    Camera/distance sensor QK0 Without camera without distance sensor (driver assistance system)
    Luggage compartment floor covering 6SS Luggage compartment floor covering
    Fuel tank capacity 0M0 Fuel tank
    Climatic zones 0Y1 Standard climatic zones
    Compass/road sign display QR8 without road sign recognition
    Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
    Fuel quantity for initial filling 1Z5 Increase in initial standard fuel filling
    Fuel quality 0U2 Fuel quality < 50 ppm
    Fuel systems 0F3 Fuel system for diesel engine
    Body measures 5C0 Without special body measures
    Child seat anchors in front 3G1 Child seat anchors, front left (ISOFIX)
    Camera systems/accident sensors KA0 without camera systems/environment sensors
    Front license plate carrier 6W6 Front license plate carrier
    Paint preservative/transit coating 5K5 Transport protection film with additional transport protection measures
    Rear cargo area 3GA Without luggage compartment floor
    Light package (lighting) QQ0 Without add. lights (interior lighting)
    Steering system arrangement L0R Right-hand drive
    steering QZ7 Power steering
    Lumbar support 7P1 Power-adjustable lumbar support in front seats
    steering wheels 1XW Leather-wrapped multi-function sports steering wheel
    Driving on the left/on the right AV0 Driving on the left
    Speaker installation 9VD active loudspeakers
    Steering column systems 2C5 Axial and vertical adjustable steering column
    Leather scope 7HA Without leather trim
    Headlight range control 8Q3 Dynamic headlight range control (self-adjusting while driving)
    Center armrest 6E3 Center armrest in front
    Versions FM0 Basic equipment variant
    Multi-function display/trip computer 9Q7 Multi-function display/trip computer
    Center console 3D1 Center console
    Engine cooling 8Z5 not hot country
    Engine specifications DE2 4-cyl. turbo dies. eng. 2.0 l/130 kW 4V TDI common rail base engine is TR1,TD1,TM4/TL4/TP4
    Navigation device 7T2 Navigation system (LOW)
    Platform group class 7PA Platform group class 1
    Audi Sport/ Quattro GmbH FQ1 Wheels of Audi Sport/ Quattro GmbH
    Quality class AQ0 Standard-production quality
    Wheels C9T Alloy wheels 8J x 18
    Radios 8DP Radio "LOW II"
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K6 Tire pressure monitoring system
    tire H2E Tires 245/45 R18 100Y xl
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G5 Space-saving spare wheel, same size (same rolling circumference) as original equipment tires
    Type of tire VG6 Type of tire: design 2
    PQ1 Audi exclusive cast aluminium alloy wheels, 5 twin-spoke design, size 8J x 18, with 245/45 R 18 tyres
    PQD PACK_SPORT_DESIGN
    PX4 XENON PLUS
    WQR
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 7F9 Gearshift knob/handle in plastic/leather
    Self-collection / special control A00 No self-collection
    Special labels/plates 2KR Labels in English and German
    Tail lamp assemblies 8SK Taillight assemblies with diodes (LED)
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Bumper systems 2K7 bumper reinforced
    Seat belt check 9P6 Seat belt reminder, electric contact in buckle
    seat covers N1V Seat trim covers in leather
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Safety certificate 0LL With special labels safety certificates for England
    Start-stop system/regenerative braking 7L8 Start-stop system with regenerative braking
    Lane change assist/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    Handling production and pre-production FA0 Control of series production
    Headlamp washer system 8X1 Headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N6 Windshield wiper intermittent control with light/rain sensor
    Special approval measures 3M3 Passenger car design
    Nameplate set 0NB Nameplate set in basic style
    Thermal insulation insert (cup holder) KT0 Without thermal insulation insert (cup holder)
    Door and lid locking system 4K4 Central locking w/ radio remote control
    Type approval countries/countries with special requirements B09 Type approval country GB/Northern Ireland
    Carrier frequency for remote control 5D7 Carrier frequency 868 MHz without panic button
    Transit coating NT1 Transit coating (type 2)
    TV reception/digital radio reception QV0 Without TV reception/digital radio reception
    Assembly parts for engine (drive bearing) 1VG Installation parts for four-cylinder engine
    Identification plates 1EX Special identification label for EC for M1 passenger vehicles
    Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
    First aid kit / warning triangle 1T3 First aid kit with warning triangle
    Front seats Q1D Sports front seats
    Telephone / telematics 9ZX Telephone preparation for cellphone
    Maintenance contract EW0 Without maintenance contract
    Heat accumulator system/auxiliary heater 7E6 Electric auxiliary air heater
    Windshield Glass 4GQ Windshield in heat-insulating glass
    Central display and control unit QW1 Central control unit in front
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional body panels, side 6EA Without additional side body covers (stone guard)
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung 0RC Starter switch locking system
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  5. Likes Souriau liked this post
  6. #4
    Wow, a 4G chassis car that came from the factory with a 6-speed manual transmission! I didn't know such a thing existed.
    Something tells me the ABS coding of all zeros ain't right.
  7. Likes Souriau, Jack@European_Parts liked this post
  8. #5
    Aug 2016
    Newry, NI
    The customer bought this car in an auction and have no details of past service history or repair work.
    Do you have the correct ABS coding for this vehicle?
    I will try and see if there is a long coding helper.
    There is no LC helper for this
    I rescanned the car this morning.
    Friday,17,January,2020,11:08:30:46973
       Revision: 45H24---
              U1113 00 [039] - -
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:36
              U1113 00 [039] - -
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:36
              U1111 00 [009] - -
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:33
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 43
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BE
                        Uz: BC
              U1111 00 [009] - -
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:33
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 43
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: C1
                        Uz: BC
              U1111 00 [009] - -
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:34
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 43
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: CB
                        Uz: BC
    0500 - Control Module
              C104A F0 [129] - Incorrect VIN
    0505 - Control Module Incorrectly Coded
              U1014 00 [137] - -
              [VarECUuncoded]
                        Reset counter: 99
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: 83
                        Uz: 00
       Coding: 34210008A0
    0131 - Motor for Left Footwell Flap
              B10B9 07 [009] - Mechanical Failure
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:57:47
                        Voltage terminal 30: 12.29 V
                        Outside air temperature: 10.5 °C
                        Interior temperature: 24.24 °C
                        Left footwell temperature flap motor-Act.val.: 12619
                        Left footwell temperature flap motor-Specified value: 11100
                        Left footwell temperature flap motor-Stop open: 15502
                        Left footwell temperature flap motor-Stop closed: 10000
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:34
       Coding: 0045F7
       Coding: 02512B
       Coding: 080206
       Coding: 000014
       Coding: 33A408000A012600010000
       Shop #: WSC 18261 000 18261
              B2010 00 [009] - -
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 16:32:37
              U1014 00 [009] - -
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 16:32:37
       Coding: 00CD074410
       Voltage stabilizer:
    12290 - Quiescent Current
              U1406 00 [008] - Too High
                        Reset counter: 139
                        Mileage: 181076 km
                        Date: 2020.01.17
                        Time: 00:02:23
                        Voltage terminal 30: 12.1 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 9 °C
                        System status: LIN_active
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
              [Powermanagement active]
                        Reset counter: 139
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 23:05:40
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 1
                        Reset counter: 99
                        Mileage: 181076 km
                        Date: 2020.01.16
                        Time: 14:42:38
    End----------(Elapsed Time: 01:52, VBatt start/end: 14.8V/14.7V)-----------
    TIA
    Seamus
  9. #6
    Quote Originally Posted by Souriau View Post
              U1014 00 [137] - -
              [VarECUuncoded]
                        Reset counter: 99
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 00
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: 83
                        Uz: 00
    It's not just a case of coding, there is also a VIN mismatch...
  10. Likes Uwe, Souriau liked this post
  11. #7
    Aug 2016
    Newry, NI
    ADVANCE ID scan:
    I think I will sent this to a garage in Belfast to be connect to Factory link Odis to get this correctly code
    Saturday,18,January,2020,11:02:09:46973
                    Address 01: Engine
    Control Module Part Number: 03L 906 018 LA
      Component and/or Version: R4 2.0l TDI   H24 9977
               Software Coding: 0A194012242401080000
                Work Shop Code: WSC 41215
    Advanced Identification/FAZIT
         Identification: RB8-658
         Revision: 45H24---
         Date: 13.03.12
         Manufacturer number: 1415
         Test stand number: 1087
    Flash Status
         Programming Attempts(application): 0/1/1/1
         Successful Attempts(application): 0/1/1/1
         Flash Date: 00.00.00
    Misc.
         Hardware number: 03L 906 018 JL
         Workshop System Name: J623
         ASAM Dataset Revision: 003011
    Car Info
         Chassis Number: WAUZZZ4GXCN154910
         Engine code: CGLC
    VCDS Info:
           Labels: 03L-906-018-CGL.clb
           Readiness: No script available
    Control Module Part Number: 4G0 907 379 H
      Component and/or Version: ESP PREMIUM   H09 0361
               Software Coding: 00000000000000000000
                Work Shop Code: WSC 02391
         Identification: BPA-085
         Revision: --------
         Date: 13.03.12
         Manufacturer number: 0035
         Test stand number: 4065
    Flash Status
         Programming Attempts(application): 0/0/0
         Successful Attempts(application): 0/0/0
         Programming Attempts(data): 0
         Successful Attempts(data): 0
         Programming Status: 00000000
         Flash Tool Code(data): 00000 000 00000
    Software
         BAP: 01.04.03
         Unknown: 01.03.00
         Generic Net Mgt: 02.07.00
         FlexRay Net Mgt: 02.05.00
         FlexRay Trsp: 02.07.26
         Unknown: 03.00.01
         Prot Data Unit Router: 02.06.03
         FlexRay Interf: 02.06.23
         FlexRay Drv: 02.06.80
         Unknown: 01.00.19
         Unknown: 02.07.01
    Misc.
         Hardware number: 4G0 907 379 H
         Workshop System Name: J104
         Equipment/PR Code: 0000000000000000
         Dataset Number: -----------
         Dataset Version: ----
         End of Line Equipment Level: ------------------
         ASAM Dataset Revision: 004028
    VCDS Info:
           Labels: 4G0-907-379-V1.clb
    Control Module Part Number: 4H0 907 064 BN
      Component and/or Version: BCM2 2.0      H31 0333
               Software Coding: 03B83006000000000000
         Identification: HLH-W41
         Date: 20.03.12
         Manufacturer number: 1002
         Test stand number: 0975
    Flash Status
         Programming Attempts(data): 1
         Successful Attempts(data): 1
         Flash Tool Code(data): 00200 785 02391
    Software
         Theft prot.: 02.02.00
         KWP2000: 02.30.00
    Misc.
         Hardware number: 4H0 907 064 BN
         Workshop System Name: J393
         Equipment/PR Code: 0000000000002CAB
         Dataset Number: 4G0909517D
         Dataset Version: 0016
         End of Line Equipment Level: --------------------
    Car Info
    Immobilizer
         Transponder ID 1: B7184D99
         Transponder ID 2: ED184D99
    VCDS Info:
           Labels: 8K0-907-064-05.clb
    Control Module Part Number: 4G0 820 043 G
      Component and/or Version: KLIMA 2 ZONEN H10 0064
               Software Coding: 34210008A0
         Identification: KMM-KMM
         Date: 21.03.12
         Manufacturer number: 0004
         Test stand number: 0666
    Flash Status
         Flash Date: 00.01.01
    Misc.
         Hardware number: 4G0 820 043 G
         Workshop System Name: J255
         Equipment/PR Code: 4230303030303030
         ASAM Dataset Revision: 002040
    VCDS Info:
           Labels: 4G0-820-043-2Z.clb
    Control Module Part Number: 4H0 907 063 BM
      Component and/or Version: BCM1 2.0      H12 0111
               Software Coding: 2600201040349F600481008000001D0C0F9D830827090101000004602100
         Revision: 19012002
         Date: 02.03.12
         Manufacturer number: H059
         Test stand number: 1106
    Flash Status
         Flash Date: 0000.00.00
         Flash Tool Code: 00000 000 00000
    Software
         Theft prot.: 03.02.03
         BAP: 01.04.01
         CAN: 02.04.06
         TP 2.0: 03.05.00
         KWP2000: 00.30.00
         OSEK-OS: 00.10.00
         HiSpd Net: 01.12.01
         LIN 2.0: 00.01.53
    Misc.
         Hardware number: 4H0 907 063 E
         Workshop System Name: J519
         Equipment/PR Code: 04563A7C13893C53
         Dataset Number: 4G0909514C
         Dataset Version: 0047
    VCDS Info:
           Labels: 4H0-907-063-V1.clb
    Control Module Part Number: 4H0 919 475 N
      Component and/or Version: PARKHILFE ACC H07 0050
               Software Coding: 080206
         Identification: ATW-001
         Revision: 11001001
         Date: 22.03.12
         Manufacturer number: EJGQ
         Test stand number: 0014
    Flash Status
         Programming Attempts(application): 1/1/1/1
         Successful Attempts(application): 1/1/1/1
    Misc.
         Hardware number: 4H0 919 475 C
         Workshop System Name: J446
         ASAM Dataset Revision: 002005
    VCDS Info:
           Labels: 4H0-919-475-7X2.clb
                    Address 15: Airbags
    Control Module Part Number: 4H0 959 655 C
      Component and/or Version: Airbag10.43   H43 0040
               Software Coding: 30323436313230303235554A305234473053
         Identification: BPA-00A
         Revision: --------
         Date: 20.03.12
         Manufacturer number: 15JG
         Test stand number: 7PJD
    Flash Status
    Software
         Unknown: 05.01.00
         Bootloader/Flasher: 01.00.08
    Misc.
         Hardware number: 4H0 959 655 C
         Workshop System Name: J234
         Equipment/PR Code: 0000000000005FC8
         Dataset Number: 4G0909602G
         Dataset Version: 0013
         End of Line Equipment Level: 00000000000000----
         ASAM Dataset Revision: 001014
    Car Info
    VCDS Info:
           Labels: 4H0-959-655.clb
    Control Module Part Number: 4G8 920 950 K
      Component and/or Version: MDieGb        H34 0209
               Software Coding: 33A408000A012600010000
                Work Shop Code: WSC 18261
         Revision: 26450208
         Date: 06.03.12
         Manufacturer number: 3592
         Test stand number: 0413
    Flash Status
         Programming Attempts(application): 0/0/0/0/0/0
         Successful Attempts(application): 0/0/0/0/0/0
         Programming Attempts(data): 0/0/0/0/0
         Successful Attempts(data): 0/0/0/0/0
    Software
         Unknown: 05.02.01
         BAP: 01.05.00
         UDS: 01.02.14
         Diag: 01.03.00
         CAN: 01.37.00
         TP 2.0: 03.05.00
         ISO15765: 01.02.15
         OSEK-OS: 03.07.00
         OSEK-Com: 03.07.00
         UDS Std Diag: 01.01.00
         HiSpd Net: 01.12.01
    Misc.
         Hardware number: 4G8 920 950 K
         Workshop System Name: J285
         Equipment/PR Code: 000000000000000000000000
         ASAM Dataset Revision: 004045
    VCDS Info:
           Labels: 4H0-920-xxx-17.clb-SRI1
    Control Module Part Number: 4G5 907 468 F
      Component and/or Version: J533--Gateway H14 0083
               Software Coding: 00CD074410
                Work Shop Code: WSC 54484
         Identification: LAK-000
         Revision: --------
         Date: 15.09.16
         Manufacturer number: 2009
         Test stand number: 2128
    Flash Status
         Flash Date: 0001.01.00
         Flash Tool Code(data): 1048576 001 54484
    Software
         FlexRay Drv: 02.06.75
         FlexRay Interf: 02.06.22
         Prot Data Unit Router: 02.06.02
         Diag: 01.03.00
         UDS: 01.02.14
         TP 2.0: 03.05.02
         ISO15765: 01.02.15
         AUTOSAR-ISO TP: 00.01.08
         HiSpd Net: 01.12.01
         MOST Net: 02.01.07
         MOST Firmware: 01.10.07
         INIC Config Str: 02.00.00
    Misc.
         Hardware number: 4G0 907 468 AC
         Workshop System Name: J533
         Equipment/PR Code: 000002FAD47D11EC17944CF3
         Dataset Number: 4G0909515VA
         Dataset Version: 0001
         ASAM Dataset Revision: 001028
    Car Info
         Engine code: ----
    VCDS Info:
           Labels: None
    Control Module Part Number: 4G0 907 637
      Component and/or Version: SARA 3D       H02 0009
               Software Coding:
                Work Shop Code: WSC 00000
         Revision: --------
         Date: 20.03.12
         Manufacturer number: 0060
         Test stand number: 0078
    Flash Status
         Flash Date: 12.03.20
    Misc.
         Hardware number: 4G0 907 637
         Workshop System Name: J849
         ASAM Dataset Revision: 009017
    Car Info
    VCDS Info:
    Control Module Part Number: 4G8 959 793 E
      Component and/or Version: TSG FA        H05 0212
               Software Coding: 011C16204001620002080002
         Identification: KO1-MAL
         Revision: --------
         Date: 16.03.12
         Manufacturer number: 0006
         Test stand number: 1573
    Flash Status
    Software
         Diag: 01.03.00
         CAN: 01.26.02
         TP 2.0: 03.05.00
         KWP2000: 03.00.00
         HiSpd Net: 02.00.02
         LIN 2.0: 03.81.26
    Misc.
         Hardware number: 4G8 959 793 A
         Workshop System Name: J386
         Equipment/PR Code: 00000000000608B0
         Dataset Number: 4G0909872C
         Dataset Version: 0026
    VCDS Info:
           Labels: 4H0-959-793.clb
    Control Module Part Number: 4G0 909 144 L
      Component and/or Version: RCEPS         H35 0010
               Software Coding: 101000010000
         Identification: TT1-000
         Revision: 00001000
         Date: 26.02.12
         Manufacturer number: 0002
         Test stand number: 1718
    Flash Status
         Programming Attempts(application): 4/4/4/4/4/0
         Programming Attempts(data): 4
         Successful Attempts(data): 4
         Programming Status: 01010001
         Flash Date: 15.11.09
    Misc.
         Hardware number: 4G0 909 144 G
         Workshop System Name: J500
         Equipment/PR Code: 0000000000000000000013D1
         Dataset Number: 4G0909852H
         Dataset Version: 0027
         End of Line Equipment Level: ------------------#
         ASAM Dataset Revision: 009008
    Car Info
         Engine code: ----
    VCDS Info:
           Labels: 4G0-909-144.clb
               Software Coding: 011B062200B9044083200804000103000000000000000000000000000000
         Date: 20.03.12
    Flash Status
         Flash Date: ----.--.--
    Software
         BAP: 01.03.00
         CAN: 01.26.01
         TP 2.0: 03.05.00
         KWP2000: 02.30.00
         OSEK-OS: 04.02.00
         HiSpd Net: 01.12.01
         LIN 2.0: 00.01.26
         EEProm lib.: 01.08.02
    Misc.
         Equipment/PR Code: 00000A6233E0BFC0
         Dataset Number: 4G0909501D
         Dataset Version: 0048
    VCDS Info:
           Labels: 4H0-907-064-46.clb
    Control Module Part Number: 4G8 959 792 E
      Component and/or Version: TSG BF        H05 0212
         Revision: --------
         Date: 05.03.12
         Test stand number: 0147
    Flash Status
    Software
         Diag: 01.03.00
         CAN: 01.26.02
         TP 2.0: 03.05.00
         KWP2000: 03.00.00
         HiSpd Net: 02.00.02
         LIN 2.0: 03.81.26
    Misc.
         Hardware number: 4G8 959 792 A
         Workshop System Name: J387
         Equipment/PR Code: 0000000000003850
         Dataset Number: 4G0909873C
         Dataset Version: 0025
    VCDS Info:
           Labels: 4H0-959-792.clb
    Control Module Part Number: 4H0 907 801 E
      Component and/or Version: EPB-4         H03 0012
               Software Coding:
                Work Shop Code:
         Identification: GNO-TSR
         Revision: --------
         Date: 15.03.12
         Manufacturer number: 0001
         Test stand number: 3890
    Flash Status
    Software
         ISO15765: 01.02.15
         UDS: 01.02.14
         CAN: 01.47.00
         HiSpd Net: 01.12.01
         Bootloader/Flasher: 01.07.00
    Misc.
         Hardware number: 4H0 907 801 A
         Workshop System Name: ----
         ASAM Dataset Revision: 001022
    Car Info
         Chassis Number: -----------------
    VCDS Info:
    Control Module Part Number: 4H0 907 357 A
      Component and/or Version: ....LWR12.... H02 0013
               Software Coding: 112196101000A300
         Identification: HLR-0W5
         Date: 22.03.12
         Test stand number: 1076
    Flash Status
    Software
         ISO15765: 01.02.15
         UDS: 01.02.14
         Diag: 01.03.00
         CAN: 01.26.01
    Misc.
         Hardware number: 4H0 907 357 A
         Workshop System Name: J431
         End of Line Equipment Level: XXXXXXXXXXXXXXXXXX
         ASAM Dataset Revision: 005001
    VCDS Info:
           Lab
    els: 8X0-907-357.clb
    Control Module Part Number: 4G0 035 193 E
      Component and/or Version: RMC Cnct Nav  H52 0775
               Software Coding: 0101000101415B47002B060301010000010000
         Identification: DE2-633
         Date: 14.03.12
         Manufacturer number: 0023
         Test stand number: 0126
    Flash Status
    Software
         MOST Net: 02.01.01
         TP 2.0: 02.04.05
         Unknown: 02.02.03
         BAP: 01.05.00
         Diag: 01.03.00
         KWP2000: 03.00.00
    Misc.
         Hardware number: 4G0 035 193 D
         Workshop System Name: J794
         Equipment/PR Code: 863294F1CA624AAF
         Dataset Number: 4G0909545N
         Dataset Version: 0056
    Car Info
    VCDS Info:
           Labels: None
    Control Module Part Number: 4G8 959 795 E
      Component and/or Version: TSG HL        H04 0212
               Software Coding: 010814204001620002080002
         Revision: --------
         Date: 06.03.12
         Test stand number: 1837
    Flash Status
    Software
         Diag: 01.03.00
         KWP2000: 03.00.00
         LIN 2.0: 03.81.26
    Misc.
         Hardware number: 4G8 959 795 A
         Workshop System Name: J388
         Dataset Number: 4G0909875C
    VCDS Info:
           Labels: 4H0-959-795.clb
      Component and/or Version: TSG HR        H04 0212
         Revision: --------
         Date: 06.03.12
         Test stand number: 1851
    Flash Status
    Software
         Diag: 01.03.00
         KWP2000: 03.00.00
         LIN 2.0: 03.81.26
    Misc.
         Workshop System Name: J389
         Dataset Number: 4G0909874C
    VCDS Info:
