Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Retrofit mk60ec1 into 2.5 Tiguan.
    New User
    Jan 2020
    Prince Edward Island, Canada
    Hi guys. I recently swapped a 2.5 into my Tiguan and had to match abs with the ecm. I'm wondering if someone can generate some long coding for me to finish the basic settings. Seeing as I never had a mk60ec1 I have no original coding to base it off of.
    Did the Tiguan ever use MK60EC1?
    New User
    Jan 2020
    . Sunday,15,September,2019,20:32:57:39498
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVGBV75N79W526364   License Plate:
    Mileage: 151800km-94324mi   Repair Order:
    Chassis Type: 5N (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 4F 52 53
              55 56 62 69 72
    VIN: WVGBV75N79W526364   Mileage: 151800km-94324miles
    Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 M    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   9970
       Revision: G6H02---    Serial number: VWX7Z0H824L0Z9
       Coding: 0000075
       Shop #: WSC 08091 444 103284
       VCID: 3874F1454BC9C18F61-806C
    10 Faults Found:
    001152 - Coolant Fan Control Circuit 1
                   P0480 - 000 - Electrical Malfunction
                        Mileage: 151631 km
                        Time: 08:55:10
                        RPM: 788 /min
                        Load: 23.5 %
                        Temperature: 81.0C
                        Temperature: -40.0C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 13.970 V
    001112 - Evap System Purge Control Valve (N80)
                   P0458 - 000 - Short to Ground - MIL ON
                        Fault Status: 11100000
                        Mileage: 151637 km
                        Time: 10:47:43
                        RPM: 250 /min
                        Load: 72.9 %
                        Temperature: 84.0C
                        Temperature: -40.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 11.049 V
    008328 - Bank 1 Camshaft A (Intake) Position Actuator
                   P2088 - 000 - Short to Ground - MIL ON
                        Mileage: 151637 km
                        Time: 10:47:43
                        RPM: 250 /min
                        Load: 72.9 %
                        Temperature: 84.0C
                        Temperature: -40.0C
                        Voltage: 11.049 V
    000066 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
                   P0042 - 000 - Malfunction /Open Circuit - MIL ON
                        Mileage: 151631 km
                        Time: 08:55:10
                        RPM: 788 /min
                        Load: 23.5 %
                        Temperature: 81.0C
                        Temperature: -40.0C
                        Voltage: 13.970 V
    009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
                   P2432 - 000 - Short to Ground - MIL ON
                        Mileage: 151631 km
                        Time: 08:55:10
                        RPM: 788 /min
                        Load: 23.5 %
                        Temperature: 81.0C
                        Temperature: -40.0C
                        Voltage: 13.970 V
    005171 - Secondary Air Pump Relay (J299)
                   P1433 - 000 - Open Circuit - MIL ON
                        Mileage: 151631 km
                        Time: 08:55:10
                        RPM: 788 /min
                        Load: 23.5 %
                        Temperature: 81.0C
                        Temperature: -40.0C
                        Voltage: 13.970 V
    005170 - Secondary Air Injection Solenoid Valve (N112)
                   P1432 - 000 - Open Circuit - MIL ON
                        Mileage: 151631 km
                        Time: 08:55:10
                        RPM: 788 /min
                        Load: 23.5 %
                        Temperature: 81.0C
                        Temperature: -40.0C
                        Voltage: 13.970 V
    000275 - Intake Air Temp. Sensor (G42)
                   P0113 - 000 - Signal too High - MIL ON
                        Mileage: 151631 km
                        Time: 08:55:14
                        RPM: 764 /min
                        Load: 22.3 %
                        Temperature: 81.0C
                        Temperature: -40.0C
                        Voltage: 14.097 V
    001384 - Cruise Control Switch (E45)
                   P0568 - 000 - Implausible Signal
                        Fault Frequency: 21
                        Mileage: 151631 km
                        Time: 09:44:55
                        RPM: 691 /min
                        Load: 28.2 %
                        Temperature: 86.0C
                        Temperature: -40.0C
                        Voltage: 12.700 V
    001393 - Brake Switch (F)
                   P0571 - 000 - Implausible Signal - MIL ON
                        Mileage: 151635 km
                        Time: 10:24:19
                        RPM: 1152 /min
                        Load: 19.2 %
                        Speed: 29.0 km/h
                        Temperature: 86.0C
                        Temperature: -40.0C
                        Voltage: 13.589 V
    Readiness: 0010 1101
       Part No SW: 09G 927 750 KM    HW: 09G 927 750 KM
       Component: AQ 250 6F           1703
       Revision: 00H76000    Serial number:
       Coding: 0000840
       Shop #: WSC 13293 002 1048576
       VCID: 06084FBD71BD677FA3-8052
    Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
       Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
       Component: J104    C2 450 V2   0008
       Revision: --H13---    Serial number: 00000001608030
       Coding: 0010524
       VCID: 3972F44170C3D8879E-806C
                        Fault Frequency: 22
                        Reset counter: 74
                        Mileage: 151631 km
                        Time: 09:58:53
                        Hex Value: 0x0000
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 215
                        Hex Value: 0x0000
    03366 - Vacuum Sensor
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 21
                        Reset counter: 74
                        Hex Value: 0x0000
                        Voltage: 0.00 V
                        Bin. Bits: 00011111
                        Count: 132
                        Hex Value: 0x0000
                        Reset counter: 76
                        Mileage: 151804 km
                        Time: 20:08:10
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 165
                        Hex Value: 0x0000
       Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: 6DDA1011740BB42742-8038
    00898 - Control Circuit A/C compressor
                010 - Open or Short to Plus
       Revision: 00H54000    Serial number: 00000009127866
       Coding: F78C8FA340041C004719000014000000002AF7475C400125420000000000
       VCID: 336EC66952AF22D754-8066
       Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 171108  012 0203
       Coding: 00038805
       Shop #: WSC 01357
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     140808 046  0204
       Coding: 00208933
       Shop #: WSC 01357
    01117 - Generator Terminal DF Load Signal
                        Reset counter: 114
                        Mileage: 151631 km
                        Voltage: 11.85 V
       Revision: 00000000    Serial number: AUZ4Z7H0440834
       Coding: 0000102
                        Reset counter: 74
                        Mileage: 151631 km
                        Time: 09:59:05
       Part No SW: 5N0 959 655 B    HW: 5N0 959 655 B
       Component: J234__200 VW10 HI   1815
       Revision: 19013000    Serial number: 0039EPN4LBAY
       Coding: 0012336
       VCID: 3C7CED557FF1EDAF85-8068
       Subsystem 1 - Part No: 5N0 959 339 A
       Component: BF-Gewichtsens. 001 0004
       Subsystem 2 - Serial number: 000000000028RH
       Subsystem 3 - Serial number: 0024.10.080000100000660032† 63
       Subsystem 4 - Serial number: 660032† 6333FTS632352828 † 63
       Subsystem 5 - Serial number: 52828 † 6343FTS681242818 † 63
       Subsystem 6 - Serial number: 42818 † 6353ETS6618DVVNJ † 63
       Subsystem 7 - Serial number: DVVNJ † 6363ETS6A57QVVNR † 63
       Subsystem 8 - Serial number: QVVNR † 6373JTS6A51006KJ † 63
       Subsystem 9 - Serial number: 006KJ † 6383JTS6NHHDV5KR
       Subsystem 10 - Serial number: DV5KR
    03551 - Functional Restriction of Seat Occupied Recognition
                000 - - - MIL ON
                        Fault Frequency: 19
                        Reset counter: 116
                        Mileage: 151631 km
                        Time: 09:59:12
       Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
       Coding: 0001132
       VCID: 7AF02B4D3545139FD7-802E
       Component: E0221           002 0030
       Part No SW: 5N0 920 870 E    HW: 5N0 920 870 E
       Component: KOMBIINSTRUMENT VDD 2422
       Revision: V0005000    Serial number: VWX7Z0HN3NH0WE
       Coding: 0007304
       VCID: 3260C36DADB52BDF5F-8066
       Part No SW: 1K0 907 530 T    HW: 1K0 907 951
       Component: J533  Gateway   H06 0071
       Revision:   H06 01    Serial number: 011108F2000915
       Coding: FD83FF46001303006002
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T4J8H03
       VCID: 7DFA2051246B24A7F2-8028
       Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
       Component: Haldex 4Motion      0041
       Coding: 0000005
       VCID: 4B9EBE892A5F5A173C-801E
    00448 - Haldex Clutch Pump (V181)
                        Fault Status: 00101011
                        Reset counter: 38
                        Mileage: 151631 km
                        Time: 09:58:53
       Component: IMMO            VDD 2422
       Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
       Component: MEM-FS        H04 0032
       Revision: AA000000    Serial number: 00001001187156
       Coding: 20581300000044440011
       VCID: 3874F1458BC9C18F61-806C
       Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
       Component: Tuer-SG         008 2005
       Coding: 0005567
       VCID: 356AF8715CDB3CE77A-8060
       Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.0   1101
       Revision: 1AH02255    Serial number: 00082610188202
       Coding: 0000258
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Component:    KSG PQ35 G2  020 0205
       Coding: 9380078852832C1B1B04058FB0888F0C88FCA0
       VCID: 71E20C61683350C766-8024
    Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
       Part No SW: 1K0 907 532     HW: 1K0 907 951
       Coding: 050B0500
       VCID: 66C86F3D91FD877F03-8032
       Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
       Component: J245EE16SKB10  H01 0180
       Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
       Component: J394EE16SKB10  H01 0180
       Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
       Coding: 0005566
       VCID: 3668FF7D41DD37FF73-8062
       Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
       Component: J540 EPB3  VW-09384 0005
       Revision:   H09       Serial number: 00000000160486
       Coding: 0000057
       VCID: 2E58D71DB98D0F3F3B-807A
                000 - - - MIL ON
                        Fault Status: 11110000
                        Reset counter: 40
                        Mileage: 150777 km
                        Voltage: 11.10 V
                        Count: 103
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Component: AFS-Steuergeraet    0136
       Coding: 1352902
       Shop #: WSC 94777 999 04893
       VCID: 346CC57557A125EF4D-8060
       Component: AFS-Lst.-Modul l    S004
       Coding: 00000020
       Component: AFS-Lst.-Modul r    S004
       Coding: 00000020
       Component: Radio PM6       135 0037
       Revision: 00135000    Serial number: VWZ5Z7H2287454
       Coding: 0040401
       VCID: 2952240180636807EE-807C
                        Reset counter: 74
                        Mileage: 151637 km
                        Time: 10:27:22
    00856 - Radio Antenna
                        Reset counter: 75
                        Mileage: 151631 km
                        Time: 09:59:03
       Part No SW: 5N0 959 703 C    HW: 5N0 959 703 C
       Component: Tuer-SG         007 2001
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 3776F27946D7CEF768-8062
       Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
       Component: Anhaenger     H07 0050
       Revision: 3A002002    Serial number: 00000115737722
       Coding: 4200000100000000
       VCID: 2F66CA197E87063730-807A
       Part No SW: 5N0 959 704 C    HW: 5N0 959 704 C
       Coding: 0001168
    End-------------------------(Elapsed Time: 02:46)--------------------------
    Here is one from September. Everything is the same aside from the abs which is a 1k0 907 379 an. It currently reads 0's.
    Edit* the Tiguan never had a mk60ec1 before. Not that I could find
    I don't have a whole lot of confidence that anyone will be able to build a proper coding for an MK60EC1 that's installed in a vehicle in which such an ABS was never original equipment.
    New User
    Jan 2020
    The only reason I would think that this would be doable would be the similarities between the Tiguan and golf. I know the coding uses brake size, hill hold and some other specifics. I also know the VIN is somehow integrated into it. I tried to search for a code generating program but no luck. Just hoping someone can begin. For the time being. I'll try codes found on scans online. See if I can get one to stick.
    Without integrating the VIN, chances of some random code working are nil.
    But even getting one to "stick" does not mean it's proper.
    Do the VINs in the ECU and the cluster match?
    Please post a current Auto-Scan.
  7. Likes Dana, NitrousOxide liked this post
    New User
    Jan 2020
    I'm almost certain the instrument isn't matched to the ecm. Although the "labels" in the scan are the same as a Jetta or rabbit I don't know that they are referring to. I'll grab another scan here today. I have no issues with the instrument cluster and coding.
  9. #8
    New User
    Jan 2020
    Here is the most recent scan. Let me know if there is anymore that's needed. Thanks.
     Friday,17,January,2020,02:58:05:39498
    VCDS Version: 19.6.2.0 (x64)
    Mileage: 154390km-95933mi   Repair Order:
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 4F 52 55
              56 62 69 72
    VIN: WVGBV75N79W526364   Mileage: 154390km-95933miles
    03-ABS Brakes -- Status: Not registered 0011
       Coding: 0000075
       VCID: 3874F1454BC9C18F5F-806C
    008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2185 - 000 - Signal too High
                        Mileage: 154399 km
                        Time: 00:02:54
                        Temperature: 2.0C
                        Temperature: -40.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 11.684 V
                        Mileage: 154399 km
                        Time: 00:02:54
                        Temperature: 2.0C
                        Temperature: -40.0C
                        Voltage: 11.684 V
                        Mileage: 154399 km
                        Time: 00:02:59
                        Temperature: 2.0C
                        Temperature: -40.0C
                        Voltage: 11.684 V
    Readiness: 0110 1101
       Part No SW: 09G 927 750 HG    HW: 09G 927 750 HG
       Component: AQ 250 6F           1631
       Coding: 0000840
       VCID: 7DFA2051246B24A7CC-8028
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Revision: 00H45001
       VCID: 7EF8275DE96D3FBFD5-802A
                        Fault Status: 01100101
                        Reset counter: 190
                        Mileage: 154399 km
                        Count: 16387
                        Count: 12
                        Count: 12288
                        Count: 279
                        Count: 42752
                        Reset counter: 190
                        Mileage: 154399 km
                        Count: 16387
                        Count: 12
                        Count: 12288
                        Count: 295
                        Count: 42752
                        Reset counter: 190
                        Mileage: 154399 km
                        Count: 16387
                        Count: 12
                        Count: 12288
                        Count: 270
                        Count: 42752
                        Reset counter: 190
                        Count: 16391
                        Count: 12
                        Count: 12288
                        Count: 195
                        Count: 42752
       VCID: 6DDA1011740BB4277C-8038
       VCID: 336EC66952AF22D76A-8066
       Coding: 00038805
       Shop #: WSC 01357
       Coding: 00208933
       Shop #: WSC 01357
                        Reset counter: 190
                        Mileage: 154399 km
                        Voltage: 11.85 V
    02604 - Low Vehicle Voltage from Power Steering Control Module
                        Reset counter: 230
                        Voltage: 12.55 V
       Coding: 0000102
    02617 - Satellite Antenna (R170)
                        Reset counter: 190
                        Mileage: 154399 km
                        Time: 00:12:18
                        Reset counter: 190
                        Mileage: 154399 km
                        Time: 00:12:18
       Coding: 0012336
       VCID: 3C7CED557FF1EDAFBB-8068
       Subsystem 7 - Serial number: DVVNJ † 6363ETS6A57QVVNR † 00
       Subsystem 8 - Serial number: QVVNR † 00000000000000000† 63
       Subsystem 9 - Serial number: 000000† 6383JTS6NHHDV5KR
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
                        Fault Status: 11101010
                        Reset counter: 190
                        Mileage: 154399 km
                        Time: 00:12:10
       Coding: 0001132
       VCID: 7AF02B4D3545139FE9-802E
       Coding: 0007304
       VCID: 3260C36DADB52BDF61-8066
       Coding: E583FF46001303001002
                        Mileage: 154399 km
                        Time: 00:14:18
       Coding: 0000005
       VCID: 4B9EBE892A5F5A1702-801E
       VCID: 3874F1458BC9C18F5F-806C
       Coding: 0005567
       VCID: 356AF8715CDB3CE744-8060
       Coding: 0000258
       VCID: 3972F44170C3D887A0-806C
                        Fault Status: 11100101
                        Reset counter: 190
                        Mileage: 154399 km
                        Time: 00:01:37
                        (no units): 4.0
                        Steering Angle: 0.00
                            Not OK
                        (no units): 14
       VCID: 71E20C61683350C758-8024
       Coding: 050B0500
       VCID: 66C86F3D91FD877F3D-8032
       Coding: 0005566
       VCID: 3668FF7D41DD37FF4D-8062
       Coding: 1352902
       VCID: 346CC57557A125EF73-8060
       Coding: 00000020
       Coding: 00000020
       Coding: 0040401
       VCID: 2952240180636807D0-807C
       Coding: 0001168
       VCID: 3776F27946D7CEF756-8062
       VCID: 2F66CA197E8706370E-807A
       Coding: 0001168
    End-------------------------(Elapsed Time: 02:29)--------------------------
  10. #9
    United States
    I agree with Uwe on this. The Tiguan never used MK60EC1 and that 2.5L Gas wasn't installed in a Tiguan either. Golf/Jetta 2.5Ls weren't AWD so even if we were to try to build it that way the configuration wouldn't exist.
    This is going to be a challenge and the VINs in 01 and 17/25 need to match or MK60EC1 ABS coding will zero. Please post the Advanced ID - 1A info from those addresses. [Save] will allow you to add all of the info from 01, 17 and 25 to a single text log.
  11. Likes Uwe, NitrousOxide liked this post
  12. #10
    New User
    Jan 2020
    Here are the 3 requested. I know they won't match. I had the immobilizer defeated by a Volkswagen shop nearby. If that's the case. What's needed to make it work
    . Friday,17,January,2020,11:39:27:39498
    VIN: 3VWRZ71KX9M053902   License Plate:
                    Address 01: Engine
    Control Module Part Number: 07K 906 055 M
      Component and/or Version: 2,5l R5/4V      G   9970
               Software Coding: 0000075
                Work Shop Code: WSC 08091
    Advanced Identification
         Identification: BPG-864
         Revision: G6H02---
         Date: 26.08.08
         Test stand number: 7825
         Manufacturer number: 0260
    Flash Status
         Programming Attempts: 2
         Successful Attempts: 2
         Programming Status: 00000000
         Required Conditions: 00000000
         Flash Tool Code: 160852 444 08091
         Flash Date: 00.00.00
    Software
         P0101
         M10M30
    Misc.
         Hardware number: 07K 906 055 M
    Car Info
         Chassis Number: 3VWRZ71KX9M053902
         Engine code: CBU
    VCDS Info:
           Readiness: 06A-906-032-BGP.crd
    Friday,17,January,2020,11:41:15:39498
    Control Module Part Number: 5N0 920 870 E
      Component and/or Version: KOMBIINSTRUMENT VDD 2422
               Software Coding: 0007304
                Work Shop Code: WSC 01357
         Identification: VDD-024
         Revision: V0005000
         Date: 17.11.08
         Test stand number: 7701
         Manufacturer number: 1166
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Flash Tool Code: 00000 000 00000
         Flash Date: --.--.--
    Software
         DKBI339
         Y024
         Z0022
    Misc.
         Hardware number: 5N0 920 870 E
         Lot Number: 000
         Type Lock: 0000
    Car Info
         Chassis Number: WVGBV75N79W526364
    VCDS Info:
      Component and/or Version: IMMO            VDD 2422
               Software Coding:
                Work Shop Code: WSC 00000
         Revision: V0005000
         Date: 17.11.08
    Flash Status
    Software
         DKBI339
         Y024
         Z0022
    Misc.
         Lot Number: 000
         Type Lock: 0000
    Car Info
    VCDS Info:
               Software Coding:
         Revision: V0005000
         Date: 17.11.08
    Flash Status
    Software
         DKBI339
         Y024
         Z0022
    Misc.
         Lot Number: 000
         Type Lock: 0000
    Car Info
    VCDS Info:
    Friday,17,January,2020,11:42:04:39498
               Software Coding:
         Revision: V0005000
         Date: 17.11.08
    Flash Status
    Software
         DKBI339
         Y024
         Z0022
    Misc.
         Lot Number: 000
         Type Lock: 0000
    Car Info
    VCDS Info:
