Retrofit mk60ec1 into 2.5 Tiguan.
Zachmac
Prince Edward Island, Canada
Hi guys. I recently swapped a 2.5 into my Tiguan and had to match abs with the ecm. I'm wondering if someone can generate some long coding for me to finish the basic settings. Seeing as I never had a mk60ec1 I have no original coding to base it off of.
Zachmac
. Sunday,15,September,2019,20:32:57:39498
VCDS Version: 19.6.1.0 (x64)
VIN: WVGBV75N79W526364   License Plate:
Mileage: 151800km-94324mi   Repair Order:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 4F 52 53
          55 56 62 69 72
VIN: WVGBV75N79W526364   Mileage: 151800km-94324miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 M    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H02---    Serial number: VWX7Z0H824L0Z9
   Coding: 0000075
   Shop #: WSC 08091 444 103284
   VCID: 3874F1454BC9C18F61-806C
10 Faults Found:
001152 - Coolant Fan Control Circuit 1
               P0480 - 000 - Electrical Malfunction
                    Mileage: 151631 km
                    Time: 08:55:10
                    RPM: 788 /min
                    Load: 23.5 %
                    Temperature: 81.0°C
                    Temperature: -40.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
001112 - Evap System Purge Control Valve (N80)
               P0458 - 000 - Short to Ground - MIL ON
                    Fault Status: 11100000
                    Mileage: 151637 km
                    Time: 10:47:43
                    RPM: 250 /min
                    Load: 72.9 %
                    Temperature: 84.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.049 V
008328 - Bank 1 Camshaft A (Intake) Position Actuator
               P2088 - 000 - Short to Ground - MIL ON
                    Mileage: 151637 km
                    Time: 10:47:43
                    RPM: 250 /min
                    Load: 72.9 %
                    Temperature: 84.0°C
                    Voltage: 11.049 V
000066 - Oxygen (Lambda) Sensor B1 S3: Heating Circuit
               P0042 - 000 - Malfunction /Open Circuit - MIL ON
                    Mileage: 151631 km
                    Time: 08:55:10
                    RPM: 788 /min
                    Load: 23.5 %
                    Temperature: 81.0°C
                    Voltage: 13.970 V
009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
               P2432 - 000 - Short to Ground - MIL ON
                    Mileage: 151631 km
                    Time: 08:55:10
                    RPM: 788 /min
                    Load: 23.5 %
                    Temperature: 81.0°C
                    Voltage: 13.970 V
005171 - Secondary Air Pump Relay (J299)
               P1433 - 000 - Open Circuit - MIL ON
                    Mileage: 151631 km
                    Time: 08:55:10
                    RPM: 788 /min
                    Load: 23.5 %
                    Temperature: 81.0°C
                    Voltage: 13.970 V
005170 - Secondary Air Injection Solenoid Valve (N112)
               P1432 - 000 - Open Circuit - MIL ON
                    Mileage: 151631 km
                    Time: 08:55:10
                    RPM: 788 /min
                    Load: 23.5 %
                    Temperature: 81.0°C
                    Voltage: 13.970 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 000 - Signal too High - MIL ON
                    Mileage: 151631 km
                    Time: 08:55:14
                    RPM: 764 /min
                    Load: 22.3 %
                    Temperature: 81.0°C
                    Voltage: 14.097 V
001384 - Cruise Control Switch (E45)
               P0568 - 000 - Implausible Signal
                    Fault Frequency: 21
                    Mileage: 151631 km
                    Time: 09:44:55
                    RPM: 691 /min
                    Load: 28.2 %
                    Temperature: 86.0°C
                    Voltage: 12.700 V
001393 - Brake Switch (F)
               P0571 - 000 - Implausible Signal - MIL ON
                    Mileage: 151635 km
                    Time: 10:24:19
                    RPM: 1152 /min
                    Load: 19.2 %
                    Speed: 29.0 km/h
                    Temperature: 86.0°C
                    Voltage: 13.589 V
Readiness: 0010 1101
   Part No SW: 09G 927 750 KM    HW: 09G 927 750 KM
   Component: AQ 250 6F           1703
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 13293 002 1048576
   VCID: 06084FBD71BD677FA3-8052
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
   Component: J104    C2 450 V2   0008
   Revision: --H13---    Serial number: 00000001608030
   Coding: 0010524
   VCID: 3972F44170C3D8879E-806C
                    Fault Frequency: 22
                    Reset counter: 74
                    Mileage: 151631 km
                    Time: 09:58:53
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
03366 - Vacuum Sensor
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 21
                    Reset counter: 74
                    Hex Value: 0x0000
                    Voltage: 0.00 V
                    Bin. Bits: 00011111
                    Count: 132
                    Hex Value: 0x0000
                    Reset counter: 76
                    Mileage: 151804 km
                    Time: 20:08:10
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 165
                    Hex Value: 0x0000
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6DDA1011740BB42742-8038
00898 - Control Circuit A/C compressor
            010 - Open or Short to Plus
   Revision: 00H54000    Serial number: 00000009127866
   Coding: F78C8FA340041C004719000014000000002AF7475C400125420000000000
   VCID: 336EC66952AF22D754-8066
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 171108  012 0203
   Coding: 00038805
   Shop #: WSC 01357
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     140808 046  0204
   Coding: 00208933
   Shop #: WSC 01357
01117 - Generator Terminal DF Load Signal
                    Reset counter: 114
                    Mileage: 151631 km
                    Voltage: 11.85 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0440834
   Coding: 0000102
                    Reset counter: 74
                    Mileage: 151631 km
                    Time: 09:59:05
   Part No SW: 5N0 959 655 B    HW: 5N0 959 655 B
   Component: J234__200 VW10 HI   1815
   Revision: 19013000    Serial number: 0039EPN4LBAY
   Coding: 0012336
   VCID: 3C7CED557FF1EDAF85-8068
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 000000000028RH
   Subsystem 3 - Serial number: 0024.10.080000100000660032ÿ† 63
   Subsystem 4 - Serial number: 660032ÿ† 6333FTS632352828 ÿ† 63
   Subsystem 5 - Serial number: 52828 ÿ† 6343FTS681242818 ÿ† 63
   Subsystem 6 - Serial number: 42818 ÿ† 6353ETS6618DVVNJ ÿ† 63
   Subsystem 7 - Serial number: DVVNJ ÿ† 6363ETS6A57QVVNR ÿ† 63
   Subsystem 8 - Serial number: QVVNR ÿ† 6373JTS6A51006KJ ÿ† 63
   Subsystem 9 - Serial number: 006KJ ÿ† 6383JTS6NHHDV5KR ÿ
   Subsystem 10 - Serial number: DV5KR ÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Fault Frequency: 19
                    Reset counter: 116
                    Mileage: 151631 km
                    Time: 09:59:12
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           055 0111
   Coding: 0001132
   VCID: 7AF02B4D3545139FD7-802E
   Component: E0221           002 0030
   Part No SW: 5N0 920 870 E    HW: 5N0 920 870 E
   Component: KOMBIINSTRUMENT VDD 2422
   Revision: V0005000    Serial number: VWX7Z0HN3NH0WE
   Coding: 0007304
   VCID: 3260C36DADB52BDF5F-8066
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 011108F2000915
   Coding: FD83FF46001303006002
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T4J8H03
   VCID: 7DFA2051246B24A7F2-8028
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4B9EBE892A5F5A173C-801E
00448 - Haldex Clutch Pump (V181)
                    Fault Status: 00101011
                    Reset counter: 38
                    Mileage: 151631 km
                    Time: 09:58:53
   Component: IMMO            VDD 2422
   Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
   Component: MEM-FS        H04 0032
   Revision: AA000000    Serial number: 00001001187156
   Coding: 20581300000044440011
   VCID: 3874F1458BC9C18F61-806C
   Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
   Component: Tuer-SG         008 2005
   Coding: 0005567
   VCID: 356AF8715CDB3CE77A-8060
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.0   1101
   Revision: 1AH02255    Serial number: 00082610188202
   Coding: 0000258
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Component:    KSG PQ35 G2  020 0205
   Coding: 9380078852832C1B1B04058FB0888F0C88FCA0
   VCID: 71E20C61683350C766-8024
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 66C86F3D91FD877F03-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
   Coding: 0005566
   VCID: 3668FF7D41DD37FF73-8062
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
   Component: J540 EPB3  VW-09384 0005
   Revision:   H09       Serial number: 00000000160486
   Coding: 0000057
   VCID: 2E58D71DB98D0F3F3B-807A
            000 - - - MIL ON
                    Fault Status: 11110000
                    Reset counter: 40
                    Mileage: 150777 km
                    Voltage: 11.10 V
                    Count: 103
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: AFS-Steuergeraet    0136
   Coding: 1352902
   Shop #: WSC 94777 999 04893
   VCID: 346CC57557A125EF4D-8060
   Component: AFS-Lst.-Modul l    S004
   Coding: 00000020
   Component: AFS-Lst.-Modul r    S004
   Coding: 00000020
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio PM6       135 0037
   Revision: 00135000    Serial number: VWZ5Z7H2287454
   Coding: 0040401
   VCID: 2952240180636807EE-807C
                    Fault Status: 01101011
                    Reset counter: 74
                    Mileage: 151637 km
                    Time: 10:27:22
00856 - Radio Antenna
                    Reset counter: 75
                    Mileage: 151631 km
                    Time: 09:59:03
   Part No SW: 5N0 959 703 C    HW: 5N0 959 703 C
   Component: Tuer-SG         007 2001
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 3776F27946D7CEF768-8062
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0050
   Revision: 3A002002    Serial number: 00000115737722
   Coding: 4200000100000000
   VCID: 2F66CA197E87063730-807A
   Part No SW: 5N0 959 704 C    HW: 5N0 959 704 C
   Coding: 0001168
End-------------------------(Elapsed Time: 02:46)--------------------------
Here is one from September. Everything is the same aside from the abs which is a 1k0 907 379 an. It currently reads 0's.
Edit* the Tiguan never had a mk60ec1 before. Not that I could find
I don't have a whole lot of confidence that anyone will be able to build a proper coding for an MK60EC1 that's installed in a vehicle in which such an ABS was never original equipment.
Zachmac
The only reason I would think that this would be doable would be the similarities between the Tiguan and golf. I know the coding uses brake size, hill hold and some other specifics. I also know the VIN is somehow integrated into it. I tried to search for a code generating program but no luck. Just hoping someone can begin. For the time being. I'll try codes found on scans online. See if I can get one to stick.
Without integrating the VIN, chances of some random code working are nil.
But even getting one to "stick" does not mean it's proper.
Do the VINs in the ECU and the cluster match?
Please post a current Auto-Scan.
Zachmac
I'm almost certain the instrument isn't matched to the ecm. Although the "labels" in the scan are the same as a Jetta or rabbit I don't know that they are referring to. I'll grab another scan here today. I have no issues with the instrument cluster and coding.
Zachmac
Here is the most recent scan. Let me know if there is anymore that's needed. Thanks.
 Friday,17,January,2020,02:58:05:39498
VCDS Version: 19.6.2.0 (x64)
Mileage: 154390km-95933mi   Repair Order:
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 4F 52 55
          56 62 69 72
VIN: WVGBV75N79W526364   Mileage: 154390km-95933miles
03-ABS Brakes -- Status: Not registered 0011
   Coding: 0000075
   VCID: 3874F1454BC9C18F5F-806C
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
               P2185 - 000 - Signal too High
                    Mileage: 154399 km
                    Time: 00:02:54
                    Load: 0.0 %
                    Temperature: 2.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.684 V
                    Mileage: 154399 km
                    Time: 00:02:54
                    Load: 0.0 %
                    Temperature: 2.0°C
                    Voltage: 11.684 V
                    Mileage: 154399 km
                    Time: 00:02:59
                    Load: 0.0 %
                    Temperature: 2.0°C
                    Voltage: 11.684 V
Readiness: 0110 1101
   Part No SW: 09G 927 750 HG    HW: 09G 927 750 HG
   Component: AQ 250 6F           1631
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 7DFA2051246B24A7CC-8028
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   VCID: 7EF8275DE96D3FBFD5-802A
                    Fault Status: 01100101
                    Reset counter: 190
                    Mileage: 154399 km
                    Count: 16387
                    Count: 12
                    Count: 12288
                    Count: 279
                    Count: 42752
                    Reset counter: 190
                    Mileage: 154399 km
                    Count: 16387
                    Count: 12
                    Count: 12288
                    Count: 295
                    Count: 42752
                    Reset counter: 190
                    Mileage: 154399 km
                    Count: 16387
                    Count: 12
                    Count: 12288
                    Count: 270
                    Count: 42752
                    Reset counter: 190
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 195
                    Count: 42752
   VCID: 6DDA1011740BB4277C-8038
   VCID: 336EC66952AF22D76A-8066
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 00208933
   Shop #: WSC 01357
                    Fault Status: 01101000
                    Reset counter: 190
                    Mileage: 154399 km
                    Voltage: 11.85 V
02604 - Low Vehicle Voltage from Power Steering Control Module
                    Reset counter: 230
                    Voltage: 12.55 V
   Coding: 0000102
02617 - Satellite Antenna (R170)
                    Reset counter: 190
                    Mileage: 154399 km
                    Time: 00:12:18
                    Reset counter: 190
                    Mileage: 154399 km
                    Time: 00:12:18
   Coding: 0012336
   VCID: 3C7CED557FF1EDAFBB-8068
   Subsystem 7 - Serial number: DVVNJ ÿ† 6363ETS6A57QVVNR ÿ† 00
   Subsystem 8 - Serial number: QVVNR ÿ† 00000000000000000ÿ† 63
   Subsystem 9 - Serial number: 000000ÿ† 6383JTS6NHHDV5KR ÿ
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
                    Fault Status: 11101010
                    Reset counter: 190
                    Mileage: 154399 km
                    Time: 00:12:10
   Coding: 0001132
   VCID: 7AF02B4D3545139FE9-802E
   Coding: 0007304
   VCID: 3260C36DADB52BDF61-8066
   Coding: E583FF46001303001002
                    Mileage: 154399 km
                    Time: 00:14:18
   Coding: 0000005
   VCID: 4B9EBE892A5F5A1702-801E
   VCID: 3874F1458BC9C18F5F-806C
   Coding: 0005567
   VCID: 356AF8715CDB3CE744-8060
   Coding: 0000258
   VCID: 3972F44170C3D887A0-806C
                    Fault Status: 11100101
                    Reset counter: 190
                    Mileage: 154399 km
                    Time: 00:01:37
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 14
   VCID: 71E20C61683350C758-8024
   Coding: 050B0500
   VCID: 66C86F3D91FD877F3D-8032
   Coding: 0005566
   VCID: 3668FF7D41DD37FF4D-8062
   Coding: 1352902
   VCID: 346CC57557A125EF73-8060
   Coding: 00000020
   Coding: 00000020
   Coding: 0040401
   VCID: 2952240180636807D0-807C
   Coding: 0001168
   VCID: 3776F27946D7CEF756-8062
   VCID: 2F66CA197E8706370E-807A
   Coding: 0001168
End-------------------------(Elapsed Time: 02:29)--------------------------
Dana
Western PA, USA
I agree with Uwe on this. The Tiguan never used MK60EC1 and that 2.5L Gas wasn't installed in a Tiguan either. Golf/Jetta 2.5Ls weren't AWD so even if we were to try to build it that way the configuration wouldn't exist.
This is going to be a challenge and the VINs in 01 and 17/25 need to match or MK60EC1 ABS coding will zero. Please post the Advanced ID - 1A info from those addresses. [Save] will allow you to add all of the info from 01, 17 and 25 to a single text log.
Zachmac
Here are the 3 requested. I know they won't match. I had the immobilizer defeated by a Volkswagen shop nearby. If that's the case. What's needed to make it work
. Friday,17,January,2020,11:39:27:39498
VIN: 3VWRZ71KX9M053902   License Plate:
                Address 01: Engine
Control Module Part Number: 07K 906 055 M
  Component and/or Version: 2,5l R5/4V      G   9970
           Software Coding: 0000075
            Work Shop Code: WSC 08091
Advanced Identification
     Identification: BPG-864
     Revision: G6H02---
     Date: 26.08.08
     Test stand number: 7825
     Manufacturer number: 0260
Flash Status
     Programming Attempts: 2
     Successful Attempts: 2
     Programming Status: 00000000
     Required Conditions: 00000000
     Flash Tool Code: 160852 444 08091
     Flash Date: 00.00.00
Software
     P0101
     M10M30
Misc.
     Hardware number: 07K 906 055 M
Car Info
     Chassis Number: 3VWRZ71KX9M053902
     Engine code: CBU
VCDS Info:
       Readiness: 06A-906-032-BGP.crd
Friday,17,January,2020,11:41:15:39498
Control Module Part Number: 5N0 920 870 E
  Component and/or Version: KOMBIINSTRUMENT VDD 2422
           Software Coding: 0007304
            Work Shop Code: WSC 01357
     Identification: VDD-024
     Revision: V0005000
     Date: 17.11.08
     Test stand number: 7701
     Manufacturer number: 1166
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Flash Tool Code: 00000 000 00000
     Flash Date: --.--.--
Software
     DKBI339
     Y024
     Z0022
Misc.
     Hardware number: 5N0 920 870 E
     Lot Number: 000
     Type Lock: 0000
Car Info
     Chassis Number: WVGBV75N79W526364
VCDS Info:
  Component and/or Version: IMMO            VDD 2422
           Software Coding:
            Work Shop Code: WSC 00000
     Revision: V0005000
     Date: 17.11.08
Flash Status
Software
     DKBI339
     Y024
     Z0022
Misc.
     Lot Number: 000
     Type Lock: 0000
Car Info
VCDS Info:
           Software Coding:
     Revision: V0005000
     Date: 17.11.08
Flash Status
Software
     DKBI339
     Y024
     Z0022
Misc.
     Lot Number: 000
     Type Lock: 0000
Car Info
VCDS Info:
Friday,17,January,2020,11:42:04:39498
           Software Coding:
     Revision: V0005000
     Date: 17.11.08
Flash Status
Software
     DKBI339
     Y024
     Z0022
Misc.
     Lot Number: 000
     Type Lock: 0000
Car Info
VCDS Info:
Dana
Western PA, USA
Ouch, you do have both VINs stored diagnostically.
Address 01: Engine
Serial number: VWX7Z0H824L0Z9​
Address 17: Instruments/Address 25: Immobilizer
Serial number: VWX7Z0HN3NH0WE​
What this means; Even if someone can build you coding that could be accepted (even if it isn't correct for the configuration) by the 03-ABS module it will be rejected -or- zero immediately after you cycle the ignition due to the VIN discrepancy.​
Because the Immo still has the proper VIN and I'm ASSumign all of the vehicle keys are original to the Tiguan all hope is not lost in regards to the diagnostic VIN discrepancy but I don't know if you can simply match that Jetta engine controller to this Tiggy cluster using ODIS at the dealer. If that's possible, the Immo defeat would need to be un-done and then someone with ODIS could run a Engine controller replacement test plan which should transfer the Tiguan VIN into the Jetta engine controller.
However, as I type this I realized we've never attempted to encrypt Tiguan VIN digits into a MK60EC1 ABS coding string. So, if that isn't possible - the above is entirely off track and it needs to go the other way making all diagnostic VINs match the Jetta instead. Because you cannot match used keys or clusters dealer level that direction would require someone with specialized tools or a complete transplant (lock cylinders, keys, cluster, etc) of the used Jetta components in which case you may or may not have remote compatibility issue but the VIN discrepancy could be resolved.
I would wait for additional feedback before making any changes. This thread would receive far more views in the Retrofits section however you aren't a Verified user. Did you purchase that VCDS interface used?
Zachmac
The vcds I am using is a friend's. I believe he also got it from someone originally. I'll look into getting verified. As it seems it would help. Any idea what vin's need to match as far as modules. I figure I can source a cluster to match. Or even find a parts car and take everything out. Ie. Ecm cluster abs and whatever would be needed
Zachmac
Hey guys change of plans. Looking into it further I decided to opt for a full parts car module swap. My friends at the junkyard were able to get me a matching key, cluster, abs, and ecm. By doing this I should be able to generate a code with my mk60ec1. The cluster in a Tiguan and similar cars is the the module that determines the VIN on a scan. I should be able to use the new Vin from my ecm to make coding work. The Tiguan will think it's a Jetta now.
Zachmac
Bump.
I have swapped the cluster, ecm,abs and key. The immobilizer is not reading the new key transponder. The only thing that's different is the new key has immo4c (circuit board chip) as opposed to the immo4a? Tiguan(pill chip) I can't physically insert the new key because the blade is different and the new key doesn't come apart easily or really at all. I do however hold the key as close to the ignition as humanly possible If I was to get it apart would it be as easy as swapping the blades or will the new transponder be looking for something that I don't have in my car. I'll attach the newest scan (notice the new Vin and mileage)
 Monday,27,January,2020,16:55:04:39498
VIN: 3VWJX7AJ0AM076099   License Plate:
Mileage: 211260km-131270mi   Repair Order:
Chassis Type: AJ-VW36 (1K0)
          56 62 69 72
VIN: 3VWJX7AJ0AM076099   Mileage: 211260km-131270miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 AH    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9206
   Revision: G6H03---    Serial number:
   Coding: 0000075
   Shop #: WSC 95245 999 87902
   VCID: 74EC0575172165EFB3-8020
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:05:09
                    Load: 0.0 %
                    Temperature: 3.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.557 V
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:05:14
                    Load: 0.0 %
                    Temperature: 3.0°C
                    Voltage: 11.557 V
Readiness: 1110 0101
   Coding: 0000840
   Revision: 00H45001
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:15
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 279
                    Count: 42496
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:15
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 295
                    Count: 42496
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:15
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 270
                    Count: 42496
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:15
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 195
                    Count: 42496
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 00208933
   Shop #: WSC 01357
   Coding: 0000102
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:24
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:24
   Coding: 0012336
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:15
   Coding: 0001132
   Part No SW: 5M0 920 860 D    HW: 5M0 920 860 D
   Component: KOMBI         H05 0308
   Coding: 370F00
   Shop #: WSC 00066 123 00149
   VCID: 2F66CA19768706370E-807A
9453074 - Fuel Level Sensor 1
          B103E 1B [009] - Resistance Too High
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2020.01.27
                    Time: 00:07:13
9459739 - Fuel Level Sensor 2
          B1058 1B [009] - Resistance Too High
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2020.01.27
                    Time: 00:07:13
   Coding: ED83FF46001303001002
   Coding: 0000005
   Component: IMMO          H05 0308
   VCID: 6AD01B0D8DE5A31F19-803E
9456433 - Key
          B104B 31 [009] - No Signal
                    Reset counter: 190
   Coding: 0005567
   Coding: 0000258
02546 - Steering Limit Stop
                    Reset counter: 190
                        Term 15 On
                    (no units): 4.0
                    Voltage: 11.90 V
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:08:14
                    (no units): 4.0
                        Not OK
                    (no units): 14
   Coding: 050B0500
   Coding: 0005566
   Coding: 1352902
   Coding: 00000020
   Coding: 00000020
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7J3047209
   Coding: 2500040004
   VCID: 61C27C2178D3E047C8-8034
02788 - Internal Communications Error
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:13
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:13
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:13
02633 - Antenna for Satellite Tuner
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:07:13
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:08:24
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.19
                    Time: 00:08:24
   Coding: 0001168
   Coding: 0001168
End-------------------------(Elapsed Time: 02:41)--------------------------
While holding the transponder as close to the position it would be in if the key were inserted in the lock, check the following measuring values in 25-Immobilzer:
ENG109100-ENG102540 -- Status of immobilizer - Ist-Schluessel
ENG109101-ENG151582 -- Status of immobilizer slaves - Schluessel angelernt
ENG109101-ENG151514 -- Status of immobilizer slaves - Schluessel authentifizierbar
ENG109101-ENG151476 -- Status of immobilizer slaves - Schluessel gelockt
Zachmac
I'll give that a go when I get home. Thanks for the input Uwe.
Zachmac
Well. After talking with a buddy from digital kaos. I was able to generate some coding for my mk60ec1. And after getting the new key close to the ignition barrel I was able to get the car to start again! So some steps in the right direction. I wasn't able to do any adaptations for the mk60 because my brake lines are not completely done. I'll see if the coding will actually stick (the coding is accepted and the fault goes away) I'll attach the newest scan. Hoping to have it on all fours by the weekend.
  Tuesday,28,January,2020,17:12:52:39498
          56 62 69 72
   Coding: 0000075
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:28:05
                    Load: 0.0 %
                    Temperature: 2.0°C
                    Voltage: 12.192 V
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:28:10
                    Load: 0.0 %
                    Temperature: 2.0°C
                    Voltage: 12.192 V
   Coding: 0000840
   Revision: 00H45001
   Shop #: WSC 00066 123 12345
8 Faults Found:
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:38:07
                    Count: 16387
                    Count: 12288
                    Count: 8223
                    Count: 45824
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:38:07
                    Count: 16387
                    Count: 12288
                    Count: 8212
                    Count: 45824
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:36:02
                    Count: 16387
                    Count: 12288
                    Count: 279
                    Count: 45824
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:36:02
                    Count: 16387
                    Count: 12288
                    Count: 270
                    Count: 45824
                    Reset counter: 190
                    Date: 2014.06.20
                    Time: 00:39:47
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 212
                    Count: 46080
                    Fault Status: 01101100
                    Reset counter: 190
                    Date: 2014.06.20
                    Time: 00:39:47
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 211
                    Count: 46080
02085 - Incorrect Control Module Installed
                    Reset counter: 190
                    Date: 2014.06.20
                    Time: 00:39:47
                    Count: 16391
                    Count: 12
                    Count: 12288
                    Count: 204
                    Count: 46080
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:36:02
                    Count: 16387
                    Count: 12288
                    Count: 291
                    Count: 45824
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 00208933
   Shop #: WSC 01357
                    Reset counter: 190
                    Mileage: 211265 km
                    Voltage: 12.45 V
   Coding: 0000102
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:25:37
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:25:37
   Coding: 0012336
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:25:28
   Coding: 0001132
   Coding: 370F00
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2020.01.28
                    Time: 00:25:25
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2020.01.28
                    Time: 00:25:25
   Coding: 0000005
   Coding: 000002
   Shop #: WSC 12345 123 12345
   Coding: 0005567
   Coding: 0000258
                    Reset counter: 190
                        Term 15 On
                    (no units): 4.0
                    Voltage: 13.10 V
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:34:53
                    (no units): 4.0
                        Not OK
                    (no units): 14
   Coding: 050B0500
   Coding: 0005566
   Coding: 1352902
   Coding: 00000020
   Coding: 00000020
   Coding: 2500040004
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:25:26
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:25:26
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:25:26
                    Reset counter: 190
                    Mileage: 211265 km
                    Date: 2014.06.20
                    Time: 00:28:32
   Coding: 0001168
   Coding: 0001168
End-------------------------(Elapsed Time: 02:39)--------------------------
Zachmac
Hi guys looking for your help again. I managed to get the coding to stick. I'm having an issue with the g251 sensor. It comes up in the mk60ec1 fault code although I have the park brake module coded out and not even showing anymore. That is where the sensor is at. Could it be getting this signal from somewhere else. Any input would be appreciated. Here is the newest scan
  Friday,07,February,2020,09:58:22:39498
          56 62 69 72
   Coding: 0000075
   Coding: 0000840
   Revision: 00H45001
   Coding: 114B600C49290000880B06ED922200413500
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:09:31
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 8223
                    Count: 46080
                    Reset counter: 191
                    Date: 2014.06.30
                    Time: 00:09:48
                    Count: 3
                    Count: 12
                    Count: 4608
                    Count: 212
                    Count: 46080
                    Reset counter: 191
                    Date: 2014.06.30
                    Time: 00:09:48
                    Count: 3
                    Count: 12
                    Count: 4608
                    Count: 211
                    Count: 46080
                    Reset counter: 191
                    Date: 2014.06.30
                    Time: 00:09:48
                    Count: 3
                    Count: 12
                    Count: 4608
                    Count: 204
                    Count: 46080
   Coding: F78C8FA340041C004719000014000000002AF7075C400125420000000000
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 00208933
   Shop #: WSC 01357
                    Reset counter: 191
                    Mileage: 211265 km
                    Voltage: 12.80 V
   Coding: 0000102
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:08:47
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:08:47
   Coding: 0012336
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:08:37
   Coding: 0001132
   Coding: 370F00
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2020.02.07
                    Time: 00:08:34
   Coding: ED83FF46001303006002
   Coding: 0000005
   Coding: 000002
   Coding: 0005567
   Coding: 0000258
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:10:04
                        Term 15 On
                    (no units): 4.0
                    Voltage: 12.80 V
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:10:04
                    (no units): 4.0
                        Not OK
                    (no units): 2
   Coding: 9B80078852836C1F3F00058FB0888F0C88FC80
   Coding: 050B0500
   Coding: 0005566
   Coding: 1352902
   Coding: 00000020
   Coding: 00000020
   Coding: 2500040004
8 Faults Found:
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:08:35
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:08:35
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:08:35
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:08:35
00874 - Treble Speaker Front Left (R20)
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:13:58
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:13:58
00876 - Treble Speaker Rear Left (R14)
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:13:58
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 191
                    Mileage: 211265 km
                    Date: 2014.06.30
                    Time: 00:13:58
   Coding: 0001168
   Coding: 0001168
End-------------------------(Elapsed Time: 02:40)--------------------------
Dana
Western PA, USA
As far as MK60EC1 Golf/Jetta models go; The Longitudinal Acceleration Sensor (G251) is only present cars with All Wheel Drive (AWD) and/or Hill Hold Control (HHC). This VIN (3VWJX7AJ0AM076099) used PR-Code UG0 Without hill start assist/hill descent control/comfort driving assist so I don't think it should be enabled in the coding. You might want to disable that via 16/0 in the long coding helper.
On a side note, Jef created this video and FAQ entry recently: https://forums.ross-tech.com/showthread.php?20619-MK60EC1-ABS-FAQ
He mentions AWD/HHC equipment ... but that video isn't coding chart specific so PR-codes / coding bits aren't explained in that area.
Zachmac
That's where the issue was. I can't find an appropriate car similar to mine that would work. I found out even with the epb disabled. The car still looks for g251. That's because the awd module looks for it as well. I temporarily disconnected the awd module. No more fault for g251. But now I'm stuck because I doubt that I can create a successful code that incorporates awd. Are there other options for running awd? Standalone controller?
