Hi now I have another problem that I can't get completely resolved. So now I almost have to ask here on the world's best forum
again. Has replaced ABS sensor without help on the rear right side. Should buy a new abs sensor and try and see if it helps. However, the System Function Test has tried part of and sometimes the esp lamp stops glowing. But it comes back on right away and I don't get that error code.
Thanks for all the help I can get now
003 - Mechanical Failure
01487 - System Function Test
Wednesday,15,January,2020,22:13:30:36574
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: F526727B
VIN: WAUZZZ8P75B008365 License Plate: AUDI A3
Mileage: 94450km-58688mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P75B008365 Mileage: 94450km-58688miles
42-Door Elect, Driver -- Status: Malfunction 1010
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 DS
Component: SIMOS71 1.6l 2V 6206
Revision: --H04--- Serial number: AUX7Z0DNFNU0FJ
Coding: 0000071
Shop #: WSC 00046 412 00000
VCID: 73B3221A77BDC57FC45-8026
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0019077
VCID: 3A2DCF3E10577437C73-806E
Part No SW: 8P0 820 043 J HW: 8P0 820 043 J
Component: KlimavollautomatH14 0180
Revision: 040457 Serial number: 8P0820043J
Shop #: WSC 00046 412 1310720
VCID: 3333E21A373D857F045-8066
Reset counter: 99
Mileage: 93831 km
Date: 2020.01.02
Time: 12:20:04
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001344434
Coding: 0D8E4F068014100000000000000000000000FE0F5C
Shop #: WSC 00046 000 704512
VCID: 3D27C4220179430FE21-8068
Subsystem 1 - Part No: 8P1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 00046
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0010603
VCID: 43D3B2DA679D35FF945-8016
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000012
VCID: 3537DC0239499B4F2A1-8060
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 N HW: 8P0 920 930 N
Component: KOMBIINSTR. VDO H73 0300
Revision: D04 Serial number: 224NDD04005162
Coding: 0004113
Shop #: WSC 40410 222 179579
16346 - Control Module - ROM Error
014 - Defective
Fault Status: 00000011
Mileage: 61975 km
Date: 2014.12.03
Time: 14:55:39
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104B230BC4
Coding: 3D0F0342070100
Shop #: WSC 00046 000 696320
VCID: 28090576FEFBF6A7A17-807C
01304 - Radio
Reset counter: 71
Mileage: 87750 km
Date: 2019.08.24
Time: 19:12:38
Reset counter: 99
Mileage: 93831 km
Date: 2020.01.02
Time: 12:16:14
Revision: D04 Serial number: AUX7Z0DNFNU0FJ
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000120
00943 - Heated Exterior Mirror; Driver Side (Z4)
00120 - Outside Warning Light/Door exit Light Driver Side
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.7 1502
VCID: 3039ED16C62BBE67797-8064
Part No: 8P0 959 433 E
Component: KSG H04 0050
Coding: 008000186D288505488A016300
VCID: 3E25C32E0C7F5817FBB-806A
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001178738
VCID: 70B92D1606ABFE67397-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Coding: 0000120
Address 56: Radio
End----------(Elapsed Time: 00:53, VBatt start/end: 14.3V/14.2V)-----------
