Results 1 to 6 of 6
Thread: ABS sensor
    Apr 2018
    Norway
    ABS sensor
    Hi now I have another problem that I can't get completely resolved. So now I almost have to ask here on the world's best forum
    again. Has replaced ABS sensor without help on the rear right side. Should buy a new abs sensor and try and see if it helps. However, the System Function Test has tried part of and sometimes the esp lamp stops glowing. But it comes back on right away and I don't get that error code.
    Thanks for all the help I can get now
                003 - Mechanical Failure
    01487 - System Function Test
    Wednesday,15,January,2020,22:13:30:36574
    Dealer/Shop Name: F526727B
    VIN: WAUZZZ8P75B008365   License Plate: AUDI A3
    Mileage: 94450km-58688mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
    VIN: WAUZZZ8P75B008365   Mileage: 94450km-58688miles
    42-Door Elect, Driver -- Status: Malfunction 1010
    Address 01: Engine        Labels: 06A-906-033-BGU.lbl
       Part No: 06A 906 033 DS
       Component: SIMOS71 1.6l 2V     6206
       Revision: --H04---    Serial number: AUX7Z0DNFNU0FJ
       Coding: 0000071
       Shop #: WSC 00046 412 00000
       VCID: 73B3221A77BDC57FC45-8026
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0019077
       VCID: 3A2DCF3E10577437C73-806E
       Part No SW: 8P0 820 043 J    HW: 8P0 820 043 J
       Component: KlimavollautomatH14 0180
       Revision: 040457      Serial number: 8P0820043J
       Shop #: WSC 00046 412 1310720
       VCID: 3333E21A373D857F045-8066
                        Reset counter: 99
                        Mileage: 93831 km
                        Date: 2020.01.02
                        Time: 12:20:04
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 C    HW: 8P0 907 279 C
       Component: Bordnetz-SG     H34 0301
       Revision: 00H34000    Serial number: 00000001344434
       Coding: 0D8E4F068014100000000000000000000000FE0F5C
       Shop #: WSC 00046 000 704512
       VCID: 3D27C4220179430FE21-8068
       Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 00046
                009 - Open or Short to Ground
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
       Component: Airbag 8.4ED    H00 0140
       Coding: 0010603
       VCID: 43D3B2DA679D35FF945-8016
       Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
       Component: Lenksäulenmodul 021 0050
       Coding: 0000012
       VCID: 3537DC0239499B4F2A1-8060
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
       Part No SW: 8P0 920 930 N    HW: 8P0 920 930 N
       Component: KOMBIINSTR. VDO H73 0300
       Revision: D04         Serial number: 224NDD04005162
       Coding: 0004113
       Shop #: WSC 40410 222 179579
    16346 - Control Module - ROM Error
                014 - Defective
                        Fault Status: 00000011
                        Mileage: 61975 km
                        Date: 2014.12.03
                        Time: 14:55:39
       Part No SW: 1K0 907 530 D    HW: 1K0 907 951
       Component: Gateway         H08 0100
       Revision: 08          Serial number: 2500104B230BC4
       Coding: 3D0F0342070100
       Shop #: WSC 00046 000 696320
       VCID: 28090576FEFBF6A7A17-807C
    01304 - Radio
                        Reset counter: 71
                        Mileage: 87750 km
                        Date: 2019.08.24
                        Time: 19:12:38
                        Reset counter: 99
                        Mileage: 93831 km
                        Date: 2020.01.02
                        Time: 12:16:14
       Revision: D04         Serial number: AUX7Z0DNFNU0FJ
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
       Part No: 8P0 959 801 E
       Component: Tuersteuerger.  H10 0030
       Coding: 0000120
    00120 - Outside Warning Light/Door exit Light Driver Side
       Part No: 1K1 909 144 H
       Component: EPS_ZFLS Kl.7       1502
       VCID: 3039ED16C62BBE67797-8064
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 E
       Component:    KSG          H04 0050
       Coding: 008000186D288505488A016300
       VCID: 3E25C32E0C7F5817FBB-806A
       Part No SW: 8P3 035 382     HW: 8P3 035 382
       Component: AB2 SUBWOOFERBOXH25 0160
       Revision: 00003       Serial number: 10000001178738
       VCID: 70B92D1606ABFE67397-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
       Part No: 8P0 959 802 E
       Coding: 0000120
    Address 56: Radio
    End----------(Elapsed Time: 00:53, VBatt start/end: 14.3V/14.2V)-----------
    You will need to fix whatever is causing the Wheel Speed Sensor fault first, since it's highly unlikely that the System Function Test will "pass" while the wheel speed sensor is playing up.
  3. Likes cleo liked this post
    Mar 2019
    Hi, driving straight (to 20 kilometers) in abs take a graphic measurement of the speed of the rear wheels and see if there are no peaks in the speed of the right wheel if they are to replace the wheel hub with a wheel rotation transmitter.
    "Wheel speed sensor ABS; Rear right (G44)
    003 - Mechanical failure "
  5. Likes cleo liked this post
    Apr 2018
    Norway
    Then I'll have to look at it. Have ordered new ABS sensor coming over the weekend. See if it helps
    Apr 2018
    Norway
    Quote Originally Posted by Jacek View Post
    Yes you are into something there so maybe there is the wheel bearing that makes curl. Can order one and also exchange it with the new ABS senor.
    Apr 2018
    Norway
    Then I changed wheel bearings. And ran new tests and finally all the lights went out.
    Looks like everything is fine now has no wrong codes.
    So thank you for your help.
  9. Likes Uwe, Jacek liked this post
