2007 passat no start no crank
   #21
coryr55
C?ID=392327
Ok, so I pulled the steering column and removed the steering wheel lock and it was stuck in locked position (cause of a safety mechanism my guess or, an anti tamper system)but now car cranks and everything comes on haven't cleared codes yet doing that next
Friday,17,January,2020,16:22:19:34027
VIN: WVWAK73C47P165189   License Plate:
Mileage: 327910km-203753mi   Repair Order: 0120
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
          72
VIN: WVWAK73C47P165189   Mileage: 327910km-203753miles
1C-Position Sensing -- Status: Malfunction 1010
   Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 22232 444 85704
   VCID: 303916C6362B1D37797-8064
012555 - Low Pressure Fuel regulation
               P310B - 004 - Fuel Pressure Outside Specification - Intermittent
                    Fault Status: 00110100
                    Mileage: 327905 km
                    Date: 2018.11.27
                    Time: 15:40:50
                    RPM: 4396 /min
                    Load: 90.9 %
                    Speed: 57.0 km/h
                    Temperature: 66.0°C
                    Temperature: 44.0°C
                    Absolute Pres.: 950.0 mbar
                    Voltage: 13.589 V
001299 - Incorrect Immobilizer Key
               P0513 - 008 -  - Intermittent
                    Mileage: 327914 km
                    RPM: 73 /min
                    Load: 69.4 %
                    Temperature: 15.0°C
                    Temperature: 17.0°C
                    Voltage: 11.303 V
001669 - ECM Power Relay Control Circuit
               P0685 - 004 - Open Circuit - Intermittent
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:28:50
                    Temperature: 14.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 0.000 V
050197 - Implausible Data Received from ABS Control Module
               U0415 - 008 -  - Intermittent
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:00:30
                    Temperature: 14.0°C
                    Temperature: 17.0°C
                    Voltage: 0.000 V
Readiness: 0110 0101
   Part No SW: 09G 927 750 HJ    HW: 09G 927 750 FP
   Component: AQ 250 6F           1068
   Revision: 00H69000    Serial number:
   Coding: 0000072
   VCID: 00598606C60B4DB7C97-8054
                    Fault Frequency: 13
                    Reset counter: 0
                    Mileage: 95885 km
                    Date: 2009.08.27
                    Time: 18:53:55
                    Fault Frequency: 13
                    Reset counter: 0
                    Mileage: 95885 km
                    Date: 2009.08.27
                    Time: 18:53:55
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 109 A    HW: 3C0 614 109 A
   Component: ESP 440 C4     H018 0001
   Revision:  H018       Serial number: 0775408135
   Coding: 0013755
   VCID: 1C61D2764AA3895735F-8048
                    Fault Status: 00101101
                    Fault Frequency: 9
                    Reset counter: 93
                    Mileage: 325615 km
                    Date: 2018.03.03
                    Time: 00:00:33
02840 - Wake-Up Line from Central Convenience Module
                    Fault Frequency: 11
                    Reset counter: 93
                    Mileage: 327919 km
                    Date: 2018.12.07
                    Time: 00:12:17
                    Reset counter: 93
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 09:41:55
                    Fault Frequency: 9
                    Reset counter: 93
                    Mileage: 325615 km
                    Date: 2018.03.03
                    Time: 00:00:33
                    Reset counter: 93
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 09:41:55
   Part No SW: 1K0 820 047 GG    HW: 1K0 820 047 GG
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 6FBBD5BAEB9542CF20D-803A
00532 - Supply Voltage B+
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004901723
   Coding: 15848F0340041A00470000000F00000000285D435C0001
   Shop #: WSC 00028 028 00001
   VCID: 6C81C2B6DA83B9D705F-8038
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 120407 003  0205
   Coding: 00046997
   Shop #: WSC 00028
10 Faults Found:
                    Fault Frequency: 12
                    Reset counter: 94
                    Mileage: 325619 km
                    Date: 2018.03.10
                    Time: 01:12:00
                    Voltage: 13.80 V
00906 - Horn (H1)
                    Fault Status: 00101001
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.07
                    Time: 00:18:00
                    Voltage: 11.25 V
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.06
                    Time: 00:11:00
                    Voltage: 9.45 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.09
                    Time: 22:12:00
                    Voltage: 8.95 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 94
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:00:00
                    Voltage: 9.85 V
                    Reset counter: 94
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:00:00
                    Voltage: 9.85 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:00:00
                    Voltage: 9.60 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.07
                    Time: 21:01:00
                    Voltage: 11.35 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.06
                    Time: 01:02:00
                    Voltage: 13.00 V
00927 - Terminal 30 (Right)
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.06
                    Time: 00:11:00
                    Voltage: 9.45 V
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0119987
   VCID: 2E0508BE2C1F0BC76BB-807A
                    Fault Status: 00100001
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 09:44:13
                    Voltage: 15.60 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.03
                    Time: 02:28:19
                    Voltage: 8.10 V
                    Fault Frequency: 7
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.03
                    Time: 02:28:19
                    Voltage: 8.10 V
                    Fault Frequency: 11
                    Reset counter: 94
                    Mileage: 327919 km
                    Date: 2018.12.20
                    Time: 00:00:25
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 17 AIRBAG VW8R  032 2522
   Revision: 13032000    Serial number: 003B2P72YHAP
   Coding: 0012599
   VCID: 313F13C23D21143F769-8064
   Subsystem 1 - Part No: 3C0 959 339 B
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 0000000003LVW8
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME170E457DMÿ†63
   Subsystem 5 - Serial number: E457DMÿ†6342MSME17150016-ÿ†63
   Subsystem 6 - Serial number: 50016-ÿ†6351HTS6LNF43J37Iÿ†63
   Subsystem 7 - Serial number: 43J37Iÿ†6361HTS6LNFCERQ6Pÿ†63
   Subsystem 8 - Serial number: CERQ6Pÿ†63727TS6S4CGI8L6Tÿ†63
   Subsystem 9 - Serial number: GI8L6Tÿ†63827TS6S4CKMLK67ÿ
   Subsystem 10 - Serial number: KMLK67ÿ
   Part No SW: 3C0 953 549 K    HW: 3C0 953 549 K
   Revision: 00006000    Serial number: 3C5953507AE
   Coding: 0002111
   VCID: 34311AD6C23321171DF-8060
   Component: E0221           007 0080
02768 - Activation Steering Column Lock
   Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: V0007000    Serial number: 00000000000000
   Coding: 0007205
   VCID: 2313E98A77DDB6AFF45-8076
8 Faults Found:
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.09
                    Time: 20:41:18
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 325930 km
                    Date: 2018.04.15
                    Time: 17:42:10
                    Fault Frequency: 7
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.10
                    Time: 03:28:48
00447 - Function Limitation due to Over-Voltage
                    Fault Frequency: 10
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 09:44:45
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 09:45:07
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 09:45:07
                    Fault Frequency: 7
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.10
                    Time: 03:28:48
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:28:31
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C074210CF3
   Coding: 3FFD0E04D31002
   VCID: 211FE3826DC1A4BFE69-8074
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.07
                    Time: 21:01:24
02638 - Enabling Steering Column Lock
                    Fault Status: 00101100
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.07
                    Time: 21:12:23
                    Reset counter: 94
                    Time Indication: 15
00484 - Vehicle Position Recognition Control Module (J603)
                    Reset counter: 134
                    Time Indication: 15
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:00:31
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1166279TRDWA06
   VCID: 6D87CFB2E199B0DF121-8038
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 09:56:21
   Part No SW: 3C0 959 433 Q    HW: 3C0 959 433 Q
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 22232 444 90278
   VCID: 38292EE6DE5BC577317-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
02861 - Electronic Steering Column Lock Check Sum Error
                    Fault Status: 00111110
                    Reset counter: 134
                    Mileage: 327919 km
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:00:23
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000001478503
   Coding: 0001205
   VCID: 3B2331EAEF6DEE6FDC5-806E
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.09
                    Time: 22:12:00
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 13:00:32
01034 - Electric Window Thermal Protection Active; Driver
                    Reset counter: 134
                    Mileage: 324746 km
                    Date: 2017.11.30
                    Time: 08:34:28
                    Fault Status: 00111000
                    Reset counter: 127
                    Mileage: 326390 km
                    Date: 2018.08.13
                    Time: 17:53:23
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Fault Frequency: 173
                    Reset counter: 134
                    Mileage: 325935 km
                    Date: 2018.08.04
                    Time: 02:40:22
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.135 H07 1806
                    Mileage: 327900 km
                    Temperature: 14.0°C
                    Voltage: 12.30 V
                    Voltage: 12.10 V
                    Mileage: 327900 km
                    Temperature: 14.0°C
                    Voltage: 7.20 V
                    Voltage: 7.00 V
                    Mileage: 327900 km
                    Temperature: 15.0°C
                    Voltage: 6.20 V
                    Voltage: 6.00 V
   Component:    KSG PQ46 RDK 051 0218
   Coding: 13910F8001862E521004141FF08A0F0E085800
                    Fault Frequency: 19
                    Reset counter: 127
                    Mileage: 326678 km
                    Date: 2018.10.13
                    Time: 18:00:04
                    Fault Frequency: 15
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.07
                    Time: 21:01:25
                    Fault Frequency: 16
                    Reset counter: 134
                    Reset counter: 134
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000003478504
   Coding: 0001204
   VCID: 3C2132F6EA63E957D5F-8068
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.09
                    Time: 22:12:00
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 13:00:32
01035 - Electric Window Thermal Protection Active; Passenger
                    Reset counter: 134
                    Mileage: 324746 km
                    Date: 2017.11.30
                    Time: 09:00:43
   Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
   Component: EPB  VC8HC003   013 0003
   Revision:   013
   Coding: 0000013
   VCID: 2411EA9672D3B1978DF-8070
                    Reset counter: 134
                    Mileage: 327912 km
                    Date: 2019.01.07
                    Time: 00:01:32
                    Voltage: 7.45 V
                    Count: 202
                    Fault Status: 11101101
                    Reset counter: 94
                    Mileage: 327912 km
                    Date: 2019.01.07
                    Time: 00:01:46
                    Voltage: 10.77 V
                    Count: 224
                    Reset counter: 134
                    Mileage: 327912 km
                    Date: 2019.01.07
                    Time: 00:00:31
                    Voltage: 9.73 V
                    Count: 241
   Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
   Component: Radio PM6       017 0023
   Revision: 00017000    Serial number: VWZ5Z7G2148758
   Coding: 0040401
                    Fault Frequency: 10
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.09
                    Time: 18:40:49
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1118
   Revision: 12006001    Serial number: 00000001660411
   Coding: 0001168
   VCID: 3E2538FEFC7FFB47FBB-806A
01036 - Electric Window Thermal Protection Active; Rear Left
                    Reset counter: 134
                    Mileage: 324746 km
                    Date: 2017.11.30
                    Time: 08:19:31
   Component:    RDK              0420
   Coding: 0100100
00625 - Vehicle Speed Signal
                    Fault Frequency: 255
                    Reset counter: 134
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1118
   Revision: 12006001    Serial number: 00000001629663
   Coding: 0001168
   VCID: 3FDB45FAFB75F24FF0D-806A
01037 - Electric Window Thermal Protection Active; Rear Right
                    Reset counter: 134
                    Mileage: 324746 km
                    Date: 2017.11.30
                    Time: 08:19:31
End----------(Elapsed Time: 01:37, VBatt start/end: 13.9V/13.5V)-----------
   #22
coryr55
C?ID=392327
This is what I now have to work with. Now it cranks but does not try to fire tell i lot go of the key. So do I change the post to (crank no start). And yes I know I need to change the steering column lock before I drive it.
Friday,17,January,2020,16:35:06:34027
Gateway Installation List: 3C0 907 530 C
By all means, clear fault codes and see what comes back.
coryr55
C?ID=392327
It said relearn process my bad for confussing i am using the VW Workshop Manual
Passat 2006 ➤
Passat Variant 2006 ➤
Electrical system
Edition 10.201
   #25
coryr55
C?ID=392327
The second auto scan is after I cleared codes 3 times it did not change after.
   #26
coryr55
C?ID=392327
I didn't notice the codes were not on their sorry.
after reading the codes it starts but the engine is chugging
Friday,17,January,2020,16:51:50:34027
          72
                    Mileage: 327905 km
                    Date: 2018.11.27
                    Time: 15:40:50
                    RPM: 4396 /min
                    Load: 90.9 %
                    Speed: 57.0 km/h
                    Temperature: 66.0°C
                    Temperature: 44.0°C
                    Voltage: 13.589 V
                    Mileage: 327914 km
                    RPM: 73 /min
                    Load: 69.4 %
                    Temperature: 15.0°C
                    Temperature: 17.0°C
                    Voltage: 11.303 V
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:28:50
                    Temperature: 14.0°C
                    Temperature: 17.0°C
                    Voltage: 0.000 V
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:00:30
                    Temperature: 14.0°C
                    Temperature: 17.0°C
                    Voltage: 0.000 V
   Coding: 0000072
                    Fault Frequency: 14
                    Reset counter: 0
                    Mileage: 95885 km
                    Date: 2009.08.27
                    Time: 18:53:55
   Coding: 0013755
00576 - Terminal 15
                    Reset counter: 93
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:16:14
                    Reset counter: 93
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:17:01
                    Reset counter: 93
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:17:01
   Coding: 00046997
   Shop #: WSC 00028
9 Faults Found:
00156 - Control Circuit for Windshield Washer Pump
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:16:00
                    Voltage: 12.75 V
00834 - Signal for Activation of Heated Rear Window
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:16:00
                    Voltage: 12.75 V
                    Reset counter: 94
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:13:00
                    Voltage: 10.45 V
                    Reset counter: 94
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:13:00
                    Voltage: 10.60 V
02403 - Terminal 15 for Interior
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:16:00
                    Voltage: 13.35 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:16:00
                    Voltage: 13.35 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:17:00
                    Voltage: 13.15 V
00059 - Terminal 30 for Interior Lighting
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:16:00
                    Voltage: 13.05 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:13:00
                    Voltage: 13.00 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2018.12.18
                    Time: 09:44:13
                    Voltage: 15.60 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.03
                    Time: 02:28:19
                    Voltage: 8.10 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:27:49
                    Voltage: 8.10 V
                    Fault Frequency: 11
                    Reset counter: 94
                    Mileage: 327919 km
                    Date: 2018.12.20
                    Time: 00:00:25
   Coding: 0012599
   Coding: 0002111
   Coding: 0007205
                    Ign. Timing: 4.7 °BTDC
                    Raw, Form. N/A: 000 000 000
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:27:50
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:18:38
02828 - Enabling Steering Column Lock from Diagnostic Interface
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:16:11
   Coding: 0001205
                    Mileage: 327900 km
                    Temperature: 17.0°C
                    Voltage: 13.10 V
                    Voltage: 12.90 V
                    Reset counter: 134
                    Mileage: 327919 km
                    Date: 2019.01.07
                    Time: 00:13:12
   Coding: 0001204
   Revision:   013
   Coding: 0000013
                    Reset counter: 134
                    Mileage: 327912 km
                    Date: 2019.01.07
                    Time: 00:17:01
                    Voltage: 12.63 V
                    Count: 241
00576 - Terminal 15
                    Reset counter: 134
                    Mileage: 327912 km
                    Date: 2019.01.07
                    Time: 00:16:12
                    Voltage: 13.66 V
                    Count: 41
                    Reset counter: 134
                    Mileage: 327912 km
                    Date: 2019.01.07
                    Time: 00:16:12
                    Voltage: 13.87 V
                    Count: 244
   Coding: 0040401
   Coding: 0001168
   Component:    RDK              0420
   Coding: 0100100
   Coding: 0001168
End----------(Elapsed Time: 01:29, VBatt start/end: 13.0V/12.9V)-----------
DV52
C?ID=194404
coryr55: I'm not sure how far you took Jeff's suggestion, but all of your observations as you describe in this thread point to a problem with the T15 voltage rail in the car (I think).
I understand that you have checked the operation of J329 , but have you made sure that the wiring loom and the contact points for the relay socket are kosher?
Here's a very unofficial version of how J329 is normally wired (don't look at the wire colors- they may not be correct for your car):
Pull the J329 relay from the board
  1. Make sure that the socket for the earth pin is OK (continuity check)
  2. Check that volts appear on the socket for the "hard" +12V pin with the ignition off (if not - this supply point is normally protected at #1 fuse position)
  3. Turn-on the ignition and check that +12V appears on the J519 pin (this is the coil pin on the relay - as is shown)
  4. Plug-in the relay and with ignition turned-on, check that +12V appears on the T15 pin (at the rear of the socket)
If all of these tests are OK - I apologize for taking you down the wrong path!!:facepalm:
coryr55
C?ID=392327
I will check the relay tomorrow. I did see his reply, and I was going to check it after I checked the steering wheel lock every thing has power now but it has a relay code still.
   #29
He's getting warmer!
Doesn't the ignition switch control the relay for terminal 15 too and why do you think when you operate it in X, 50 & car still doesn't fire but upon release of crank it tries to fire?
Welcome to the VAG club spicy sandwich with "whine"........... :popcorn:
   #30
coryr55
C?ID=392327
it is now running
