Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: 2007 passat no start no crank
    Jan 2020
    i have a 2007 VW passat wolfs-berg edition 2.0t that wont start and wont crank. When I put the key in the ignition the yellow steering wheel light comes on and the screen says move steering wheel and i can here clicking then about 10 seconds worth of clicking the screen says is steering wheel locked.the seeing wheel controls do nothing the radio does not come on.no other lights in the dash. i can see the odometer and trip time and date but nothing else checked all the fuses with multi-meter. I need help figuring it out.
    Wednesday,15,January,2020,15:56:02:34027
    VIN: WVWAK73C47P165189
    Chassis Type: 3C0
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
              72
       Mileage: 327910km-203753miles
    Address 01: Engine
    Address 02: Auto Trans
    Address 03: ABS Brakes
       Part No SW: 1K0 820 047 GG    HW: 1K0 820 047 GG
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       VCID: 6FBBD5BAEB9542CF20D-803A
    00532 - Supply Voltage B+
                001 - Upper Limit Exceeded
       Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000004901723
       Coding: 15848F0340041A00470000000F00000000285D435C0001
       Shop #: WSC 00028 028 00001
       VCID: 6C81C2B6DA83B9D705F-FFFE
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 120407 003  0205
       Coding: 00046997
       Shop #: WSC 00028
    No Faults Found
    Address 0F: Digital Radio
    Address 15: Airbags
    Address 16: Steering wheel
       Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: V0007000    Serial number: 00000000000000
       Coding: 0007205
       VCID: 2313E98A77DDB6AFF45-8076
    7 Faults Found:
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.09
                        Time: 20:41:18
    00771 - Fuel Level Sensor (G)
                        Fault Status: 00101010
                        Fault Frequency: 9
                        Reset counter: 134
                        Mileage: 325930 km
                        Date: 2018.04.15
                        Time: 17:42:10
                        Fault Frequency: 7
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.10
                        Time: 03:28:48
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Fault Frequency: 10
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:44:45
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:45:07
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:45:07
                        Fault Frequency: 7
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.10
                        Time: 03:28:48
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C074210CF3
       Coding: 3FFD0E04D31002
       VCID: 211FE3826DC1A4BFE69-8074
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.07
                        Time: 21:01:24
    02638 - Enabling Steering Column Lock
                        Fault Status: 00101100
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.07
                        Time: 21:12:23
    Address 1C: Position Sensing
    Address 25: Immobilizer
    Address 44: Steering Assist
    Address 46: Central Conv.
    Address 52: Door Elect, Pass.
    Address 53: Parking Brake
    Address 56: Radio
    Address 62: Door, Rear Left
    Address 65: Tire Pressure
    Address 72: Door, Rear Right
    End----(Elapsed Time: 05:18, VBatt start/end: 13.3V/12.8V. VIgn 0.0V)------
  2. Likes Uwe liked this post
  3. #2
    Many things are not powering up in this car. A failed steering column lock can keep things from powering up, but doesn't strike me like that; IIRC, there are explicit fault codes associated with that failure. So I'm thinking a bad relay or something like that.
  5. #3
    HQ
    The fuse box in the engine bay, there should be a 50A fuse in position SB30 or SB49 (location depends on type of fuse box you have). Is said 50A fuse good? Remove it and look for visual hotspots on it.
    Jef
  6. Likes Uwe liked this post
  7. #4
    Jan 2020
    I will check the 50a fuse and I will get some new relays shall see if that makes any change would it be a relay in the engine bay or inside the car
  8. #5
    Jan 2020
    There is no hot spots on the two 50A fuses, and they look like they are making a good connection
  9. #6
    HQ
    OK, so what I'm thinking is the J329 relay, which is the Terminal 15 relay, is where the issue is. Now be it the relay itself or the control of the relay, I don't know. The J329 is fitted directly to the J519 up under the dash.
    A crappy drawing suddenly appears!
    The J329 may have "460" stamped on the top of it.
    Jef
  10. Likes Jack@European_Parts, Uwe liked this post
  11. #7
    Is ignition switch dead?
  12. #8
    Jan 2020
    I pulled and checked all the relays, they all click when given power and no resistance on the pins that connect. The two#100 and one #167 relays had low resistance over the coils, but they were still functional. Both the 460 relays under the dash had perfect resistance across the coils and made good contact while powered. One thing I did notice was when the key is on no fuses get ignition power. So the only fuses with power are the ones that get constant power(battery power). I know the ignition switch is somewhat working cause it knows the key is in for the steering wheel light.
  13. #9
    Okay you got it covered and running or are you now going to load light or test for actual current, not resistance and not voltage & too simulate terminals to wake stuff up using WD or again do you have it covered?
    Just because some parts of circuit works in ignition switch doesn't mean it's functional!
  14. #10
    Jan 2020
    I was just what basic knowledge I have on relays. How do I figure out what amount off current to simulate. Have not made any progress still non-responsive other than when I open the driver door I hear the fuel pump prime and when I put the fob in the dash the steering wheel message and light.
