Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 2007 passat no start no crank
  1. #21
    Jan 2020
    Ok, so I pulled the steering column and removed the steering wheel lock and it was stuck in locked position (cause of a safety mechanism my guess or, an anti tamper system)but now car cranks and everything comes on haven't cleared codes yet doing that next
    Friday,17,January,2020,16:22:19:34027
    VIN: WVWAK73C47P165189   License Plate:
    Mileage: 327910km-203753mi   Repair Order: 0120
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
              72
    VIN: WVWAK73C47P165189   Mileage: 327910km-203753miles
    16-Steering wheel -- Status: Malfunction 1010
    1C-Position Sensing -- Status: Malfunction 1010
       Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 22232 444 85704
       VCID: 303916C6362B1D37797-8064
    012555 - Low Pressure Fuel regulation
                   P310B - 004 - Fuel Pressure Outside Specification - Intermittent
                        Fault Status: 00110100
                        Mileage: 327905 km
                        Date: 2018.11.27
                        Time: 15:40:50
                        RPM: 4396 /min
                        Load: 90.9 %
                        Speed: 57.0 km/h
                        Temperature: 66.0C
                        Temperature: 44.0C
                        Absolute Pres.: 950.0 mbar
                        Voltage: 13.589 V
    001299 - Incorrect Immobilizer Key
                   P0513 - 008 -  - Intermittent
                        Mileage: 327914 km
                        RPM: 73 /min
                        Load: 69.4 %
                        Temperature: 15.0C
                        Temperature: 17.0C
                        Voltage: 11.303 V
    001669 - ECM Power Relay Control Circuit
                   P0685 - 004 - Open Circuit - Intermittent
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:28:50
                        Load: 0.0 %
                        Temperature: 14.0C
                        Temperature: 17.0C
                        Absolute Pres.: 960.0 mbar
                        Voltage: 0.000 V
    050197 - Implausible Data Received from ABS Control Module
                   U0415 - 008 -  - Intermittent
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:00:30
                        Load: 0.0 %
                        Temperature: 14.0C
                        Temperature: 17.0C
                        Voltage: 0.000 V
    Readiness: 0110 0101
       Part No SW: 09G 927 750 HJ    HW: 09G 927 750 FP
       Component: AQ 250 6F           1068
       Revision: 00H69000    Serial number:
       Coding: 0000072
       VCID: 00598606C60B4DB7C97-8054
                        Fault Frequency: 13
                        Reset counter: 0
                        Mileage: 95885 km
                        Date: 2009.08.27
                        Time: 18:53:55
                        Fault Frequency: 13
                        Reset counter: 0
                        Mileage: 95885 km
                        Date: 2009.08.27
                        Time: 18:53:55
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 109 A    HW: 3C0 614 109 A
       Component: ESP 440 C4     H018 0001
       Revision:  H018       Serial number: 0775408135
       Coding: 0013755
       VCID: 1C61D2764AA3895735F-8048
                        Fault Status: 00101101
                        Fault Frequency: 9
                        Reset counter: 93
                        Mileage: 325615 km
                        Date: 2018.03.03
                        Time: 00:00:33
    02840 - Wake-Up Line from Central Convenience Module
                        Fault Frequency: 11
                        Reset counter: 93
                        Mileage: 327919 km
                        Date: 2018.12.07
                        Time: 00:12:17
                        Reset counter: 93
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:41:55
                        Fault Frequency: 9
                        Reset counter: 93
                        Mileage: 325615 km
                        Date: 2018.03.03
                        Time: 00:00:33
                        Reset counter: 93
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:41:55
       Part No SW: 1K0 820 047 GG    HW: 1K0 820 047 GG
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       VCID: 6FBBD5BAEB9542CF20D-803A
    00532 - Supply Voltage B+
       Revision: 00H52000    Serial number: 00000004901723
       Coding: 15848F0340041A00470000000F00000000285D435C0001
       Shop #: WSC 00028 028 00001
       VCID: 6C81C2B6DA83B9D705F-8038
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 120407 003  0205
       Coding: 00046997
       Shop #: WSC 00028
    10 Faults Found:
                        Fault Status: 01101100
                        Fault Frequency: 12
                        Reset counter: 94
                        Mileage: 325619 km
                        Date: 2018.03.10
                        Time: 01:12:00
                        Voltage: 13.80 V
    00906 - Horn (H1)
                        Fault Status: 00101001
                        Fault Frequency: 6
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.07
                        Time: 00:18:00
                        Voltage: 11.25 V
    01516 - Terminal 30; Left
                        Fault Status: 00101011
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.06
                        Time: 00:11:00
                        Voltage: 9.45 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.09
                        Time: 22:12:00
                        Voltage: 8.95 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 94
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:00:00
                        Voltage: 9.85 V
                        Reset counter: 94
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:00:00
                        Voltage: 9.85 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:00:00
                        Voltage: 9.60 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.07
                        Time: 21:01:00
                        Voltage: 11.35 V
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.06
                        Time: 01:02:00
                        Voltage: 13.00 V
    00927 - Terminal 30 (Right)
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.06
                        Time: 00:11:00
                        Voltage: 9.45 V
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7G0119987
       VCID: 2E0508BE2C1F0BC76BB-807A
                        Fault Status: 00100001
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:44:13
                        Voltage: 15.60 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.03
                        Time: 02:28:19
                        Voltage: 8.10 V
                        Fault Frequency: 7
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.03
                        Time: 02:28:19
                        Voltage: 8.10 V
                        Fault Frequency: 11
                        Reset counter: 94
                        Mileage: 327919 km
                        Date: 2018.12.20
                        Time: 00:00:25
       Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
       Component: 17 AIRBAG VW8R  032 2522
       Revision: 13032000    Serial number: 003B2P72YHAP
       Coding: 0012599
       VCID: 313F13C23D21143F769-8064
       Subsystem 1 - Part No: 3C0 959 339 B
       Component: BF-Gewichtsens. 007 0003
       Subsystem 2 - Serial number: 0000000003LVW8
       Subsystem 3 - Serial number: 0001.01.00000070000000000063
       Subsystem 4 - Serial number: 0000006332MSME170E457DM63
       Subsystem 5 - Serial number: E457DM6342MSME17150016-63
       Subsystem 6 - Serial number: 50016-6351HTS6LNF43J37I63
       Subsystem 7 - Serial number: 43J37I6361HTS6LNFCERQ6P63
       Subsystem 8 - Serial number: CERQ6P63727TS6S4CGI8L6T63
       Subsystem 9 - Serial number: GI8L6T63827TS6S4CKMLK67
       Subsystem 10 - Serial number: KMLK67
    01316 - ABS Control Module
       Part No SW: 3C0 953 549 K    HW: 3C0 953 549 K
       Component: J0527               0015
       Revision: 00006000    Serial number: 3C5953507AE
       Coding: 0002111
       VCID: 34311AD6C23321171DF-8060
       Component: E0221           007 0080
    02768 - Activation Steering Column Lock
       Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: V0007000    Serial number: 00000000000000
       Coding: 0007205
       VCID: 2313E98A77DDB6AFF45-8076
    8 Faults Found:
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.09
                        Time: 20:41:18
    00771 - Fuel Level Sensor (G)
                        Fault Status: 00101010
                        Fault Frequency: 9
                        Reset counter: 134
                        Mileage: 325930 km
                        Date: 2018.04.15
                        Time: 17:42:10
                        Fault Frequency: 7
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.10
                        Time: 03:28:48
                        Fault Frequency: 10
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:44:45
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:45:07
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:45:07
                        Fault Frequency: 7
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.10
                        Time: 03:28:48
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:28:31
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C074210CF3
       Coding: 3FFD0E04D31002
       VCID: 211FE3826DC1A4BFE69-8074
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.07
                        Time: 21:01:24
    02638 - Enabling Steering Column Lock
                        Fault Status: 00101100
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.07
                        Time: 21:12:23
    00381 - Databus Instrument Cluster
                        Reset counter: 94
                        Time Indication: 15
    00484 - Vehicle Position Recognition Control Module (J603)
                        Reset counter: 134
                        Time Indication: 15
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:00:31
       Part No SW: 3C0 919 965     HW: 3C0 919 965
       Component: Kompass         005 0003
       Revision: 00005000    Serial number: 1166279TRDWA06
       VCID: 6D87CFB2E199B0DF121-8038
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:56:21
       Part No SW: 3C0 959 433 Q    HW: 3C0 959 433 Q
       Component:    IMMO         051 0383
       Revision: 00051000    Serial number: VWZCZ000000000
       Shop #: WSC 22232 444 90278
       VCID: 38292EE6DE5BC577317-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    02861 - Electronic Steering Column Lock Check Sum Error
                        Fault Status: 00111110
                        Reset counter: 134
                        Mileage: 327919 km
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:00:23
       Component: J386  TUER-SG FT    1131
       Revision: 32008001    Serial number: 00000001478503
       Coding: 0001205
       VCID: 3B2331EAEF6DEE6FDC5-806E
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.09
                        Time: 22:12:00
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 13:00:32
    01034 - Electric Window Thermal Protection Active; Driver
                        Reset counter: 134
                        Mileage: 324746 km
                        Date: 2017.11.30
                        Time: 08:34:28
                        Fault Status: 00111000
                        Fault Frequency: 6
                        Reset counter: 127
                        Mileage: 326390 km
                        Date: 2018.08.13
                        Time: 17:53:23
                        Fault Frequency: 173
                        Reset counter: 134
                        Mileage: 325935 km
                        Date: 2018.08.04
                        Time: 02:40:22
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.135 H07 1806
                        Mileage: 327900 km
                        Temperature: 14.0C
                        Voltage: 12.30 V
                        Voltage: 12.10 V
                        Mileage: 327900 km
                        Temperature: 14.0C
                        Voltage: 7.20 V
                        Voltage: 7.00 V
                        Mileage: 327900 km
                        Temperature: 15.0C
                        Voltage: 6.20 V
                        Voltage: 6.00 V
       Component:    KSG PQ46 RDK 051 0218
       Coding: 13910F8001862E521004141FF08A0F0E085800
                        Fault Frequency: 19
                        Reset counter: 127
                        Mileage: 326678 km
                        Date: 2018.10.13
                        Time: 18:00:04
                        Fault Frequency: 15
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.07
                        Time: 21:01:25
                        Fault Frequency: 16
                        Reset counter: 134
                        Reset counter: 134
       Component: J387  TUER-SG BT    1131
       Revision: 32008001    Serial number: 00000003478504
       Coding: 0001204
       VCID: 3C2132F6EA63E957D5F-8068
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.09
                        Time: 22:12:00
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 13:00:32
    01035 - Electric Window Thermal Protection Active; Passenger
                        Reset counter: 134
                        Mileage: 324746 km
                        Date: 2017.11.30
                        Time: 09:00:43
       Part No SW: 3C0 907 801 E    HW: 3C0 907 801 E
       Component: EPB  VC8HC003   013 0003
       Revision:   013
       Coding: 0000013
       VCID: 2411EA9672D3B1978DF-8070
                        Reset counter: 134
                        Mileage: 327912 km
                        Date: 2019.01.07
                        Time: 00:01:32
                        Voltage: 7.45 V
                        Count: 202
                        Fault Status: 11101101
                        Reset counter: 94
                        Mileage: 327912 km
                        Date: 2019.01.07
                        Time: 00:01:46
                        Voltage: 10.77 V
                        Count: 224
                        Reset counter: 134
                        Mileage: 327912 km
                        Date: 2019.01.07
                        Time: 00:00:31
                        Voltage: 9.73 V
                        Count: 241
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio PM6       017 0023
       Revision: 00017000    Serial number: VWZ5Z7G2148758
       Coding: 0040401
                        Fault Frequency: 10
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.09
                        Time: 18:40:49
       Component: J388   TUER-SG HL   1118
       Revision: 12006001    Serial number: 00000001660411
       Coding: 0001168
       VCID: 3E2538FEFC7FFB47FBB-806A
    01036 - Electric Window Thermal Protection Active; Rear Left
                        Reset counter: 134
                        Mileage: 324746 km
                        Date: 2017.11.30
                        Time: 08:19:31
       Component:    RDK              0420
       Coding: 0100100
    00625 - Vehicle Speed Signal
                        Fault Frequency: 255
                        Reset counter: 134
       Component: J389   TUER-SG HR   1118
       Revision: 12006001    Serial number: 00000001629663
       Coding: 0001168
       VCID: 3FDB45FAFB75F24FF0D-806A
    01037 - Electric Window Thermal Protection Active; Rear Right
                        Reset counter: 134
                        Mileage: 324746 km
                        Date: 2017.11.30
                        Time: 08:19:31
    End----------(Elapsed Time: 01:37, VBatt start/end: 13.9V/13.5V)-----------
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #22
    Jan 2020
    This is what I now have to work with. Now it cranks but does not try to fire tell i lot go of the key. So do I change the post to (crank no start). And yes I know I need to change the steering column lock before I drive it.
    Friday,17,January,2020,16:35:06:34027
    Gateway Installation List: 3C0 907 530 C
  4. #23
    By all means, clear fault codes and see what comes back.
  5. #24
    Jan 2020
    It said relearn process my bad for confussing i am using the VW Workshop Manual
    Passat 2006 ➤
    Passat Variant 2006 ➤
    Electrical system
    Edition 10.201
  6. #25
    Jan 2020
    The second auto scan is after I cleared codes 3 times it did not change after.
  7. #26
    Jan 2020
    I didn't notice the codes were not on their sorry.
    after reading the codes it starts but the engine is chugging
    Friday,17,January,2020,16:51:50:34027
              72
                        Mileage: 327905 km
                        Date: 2018.11.27
                        Time: 15:40:50
                        RPM: 4396 /min
                        Load: 90.9 %
                        Speed: 57.0 km/h
                        Temperature: 66.0C
                        Temperature: 44.0C
                        Voltage: 13.589 V
                        Mileage: 327914 km
                        RPM: 73 /min
                        Load: 69.4 %
                        Temperature: 15.0C
                        Temperature: 17.0C
                        Voltage: 11.303 V
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:28:50
                        Load: 0.0 %
                        Temperature: 14.0C
                        Temperature: 17.0C
                        Voltage: 0.000 V
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:00:30
                        Load: 0.0 %
                        Temperature: 14.0C
                        Temperature: 17.0C
                        Voltage: 0.000 V
       Coding: 0000072
                        Fault Frequency: 14
                        Reset counter: 0
                        Mileage: 95885 km
                        Date: 2009.08.27
                        Time: 18:53:55
       Coding: 0013755
    00576 - Terminal 15
                        Reset counter: 93
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:16:14
                        Reset counter: 93
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:17:01
                        Reset counter: 93
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:17:01
       Coding: 00046997
       Shop #: WSC 00028
    9 Faults Found:
    00156 - Control Circuit for Windshield Washer Pump
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:16:00
                        Voltage: 12.75 V
    00834 - Signal for Activation of Heated Rear Window
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:16:00
                        Voltage: 12.75 V
                        Reset counter: 94
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:13:00
                        Voltage: 10.45 V
                        Reset counter: 94
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:13:00
                        Voltage: 10.60 V
    02403 - Terminal 15 for Interior
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:16:00
                        Voltage: 13.35 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:16:00
                        Voltage: 13.35 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:17:00
                        Voltage: 13.15 V
    00059 - Terminal 30 for Interior Lighting
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:16:00
                        Voltage: 13.05 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:13:00
                        Voltage: 13.00 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2018.12.18
                        Time: 09:44:13
                        Voltage: 15.60 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.03
                        Time: 02:28:19
                        Voltage: 8.10 V
                        Fault Frequency: 8
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:27:49
                        Voltage: 8.10 V
                        Fault Frequency: 11
                        Reset counter: 94
                        Mileage: 327919 km
                        Date: 2018.12.20
                        Time: 00:00:25
       Coding: 0012599
       Subsystem 3 - Serial number: 0001.01.000000700000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME170E457DM†63
       Subsystem 5 - Serial number: E457DM†6342MSME17150016-†63
       Subsystem 6 - Serial number: 50016-†6351HTS6LNF43J37I†63
       Subsystem 7 - Serial number: 43J37I†6361HTS6LNFCERQ6P†63
       Subsystem 8 - Serial number: CERQ6P†63727TS6S4CGI8L6T†63
       Subsystem 9 - Serial number: GI8L6T†63827TS6S4CKMLK67
       Coding: 0002111
    01426 - Controls in Steering Wheel (E221)
       Coding: 0007205
                        Ign. Timing: 4.7 BTDC
                        Raw, Form. N/A: 000 000 000
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:27:50
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:18:38
    02828 - Enabling Steering Column Lock from Diagnostic Interface
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:16:11
       Coding: 0001205
                        Mileage: 327900 km
                        Temperature: 17.0C
                        Voltage: 13.10 V
                        Voltage: 12.90 V
                        Reset counter: 134
                        Mileage: 327919 km
                        Date: 2019.01.07
                        Time: 00:13:12
       Coding: 0001204
       Revision:   013
       Coding: 0000013
                        Reset counter: 134
                        Mileage: 327912 km
                        Date: 2019.01.07
                        Time: 00:17:01
                        Voltage: 12.63 V
                        Count: 241
    00576 - Terminal 15
                        Reset counter: 134
                        Mileage: 327912 km
                        Date: 2019.01.07
                        Time: 00:16:12
                        Voltage: 13.66 V
                        Count: 41
                        Reset counter: 134
                        Mileage: 327912 km
                        Date: 2019.01.07
                        Time: 00:16:12
                        Voltage: 13.87 V
                        Count: 244
       Coding: 0040401
       Coding: 0001168
       Component:    RDK              0420
       Coding: 0100100
       Coding: 0001168
    End----------(Elapsed Time: 01:29, VBatt start/end: 13.0V/12.9V)-----------
  8. #27
    May 2014
    coryr55: I'm not sure how far you took Jeff's suggestion, but all of your observations as you describe in this thread point to a problem with the T15 voltage rail in the car (I think).
    I understand that you have checked the operation of J329 , but have you made sure that the wiring loom and the contact points for the relay socket are kosher?
    Here's a very unofficial version of how J329 is normally wired (don't look at the wire colors- they may not be correct for your car):
    Pull the J329 relay from the board
    1. Make sure that the socket for the earth pin is OK (continuity check)
    2. Check that volts appear on the socket for the "hard" +12V pin with the ignition off (if not - this supply point is normally protected at #1 fuse position)
    3. Turn-on the ignition and check that +12V appears on the J519 pin (this is the coil pin on the relay - as is shown)
    4. Plug-in the relay and with ignition turned-on, check that +12V appears on the T15 pin (at the rear of the socket)
    If all of these tests are OK - I apologize for taking you down the wrong path!!
  9. Likes Jack@European_Parts, Uwe liked this post
  10. #28
    Jan 2020
    I will check the relay tomorrow. I did see his reply, and I was going to check it after I checked the steering wheel lock every thing has power now but it has a relay code still.
  11. #29
    He's getting warmer!
    Doesn't the ignition switch control the relay for terminal 15 too and why do you think when you operate it in X, 50 & car still doesn't fire but upon release of crank it tries to fire?
    Welcome to the VAG club spicy sandwich with "whine"...........
  12. #30
    Jan 2020
    it is now running
  13. Likes Uwe, DV52 liked this post
