Results 1 to 4 of 4
Thread: New user with a question on VCDS lite
    New User
    Jan 2020
    NE Ohio, USA
    Hi guys, just joined. Have a 2008 Beetle with some issues, bought it as-is. Pulled some codes using a 3rd party interface cable I bought for my '01 TDI Beetle that I could never get to work, seems to work fine with VCDS shareware and a newer laptop. Was wondering if I could do a throttle body alignment and check the transmission temperature with VCDS lite? I see there is limited functionality with the shareware and more function with the registered version but unclear which functions I wouldn't get between VCDS lite either registered or unregistered and the regular VCDS? I found a chart comparing the 3 but can't tell if I can to things like a TBA and trans temp with VCDS lite. Thanks in advance for your help!
    Yes, you can do a TBA on that car with VCDS-Lite, but only if it's registered.
    Transmission temperature can probably be read with the free shareware version, but I don't know off the top of my head what transmission/TCU an 08 Beetle likely has, so I'm not certain.
    FWIW, the NB was the only VAG in the NAR market that still did full diagnostics via K-Line in MY 2008.
    New User
    Jan 2020
    NE Ohio, USA
    Thanks Uwe, I thought I read that somewhere, maybe even here, that's why I decided to try it. And as far as transmission goes, I believe it's the infamous 09g.
    Quote Originally Posted by hogluvr View Post
    If so, the fluid temperature should be in MVB 006.1 and you should be able to see it with the free shareware version.
