Results 1 to 10 of 13
Thread: 2003 VW Beetle Conv - 01179 - Incorrect Key Programming
    Feb 2017
    I'm original owner of this car and everything worked perfectly until this keyless issue. Looking for guidance to resolve.
    Beetle is exercised regularly but had sat resting in garage for a few weeks over the holidays.
    When tried to start it after long rest discovered the 5 year old DieHard battery had died.
    Replaced the battery and everything works _except_ keyless entry!?
    Have original key fobs and car does not respond to either remote.
    Tried re-programing keyless procedure in owners manual few times but no work.
    Got out the trusty VCDS and tried reprogramming keyless using VCDS video: https://www.youtube.com/watch?v=qiYPmebh0fg
    still no work!
    found fault 01179 - Incorrect Key Programming and cleared it then retried VCDS method again but no response from car to remote.
    and fault 01179 came back!
    clear fault, retry VCDS method, no response 01179 is back
    repeat a few more times carefully checking the steps, still no response 01179 comes back
    is there some different VCDS procedure that works for these older cars after replacing a dead car battery?
    here's my scan
    Friday,10,January,2020,18:07:52:24453
    VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
    VIN: 3VWCK21Y53M3xxxxx   License Plate:
    Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
    VIN: 3VWCK21Y53M3xxxxx   Mileage: 250120km-155417miles
    Address 01: Engine        Labels: None
       Part No: 06A 906 032 KC
       Component: 2l ULEV NB-C A6 G   4795
       Coding: 00003
       Shop #: WSC 00066
       VCID: 698CB718106C1A1F7E9-513C
       3VWCK21Y53M301580     VWZ5Z0B9228194
       Part No: 09G 927 750 N
       Component: AQ 250 6F           0302
       Coding: 0000008
       VCID: 3C223E4C2A7E5FB7D5F-513C
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0004097
       Shop #: WSC 00066 000 00000
       VCID: 33301570072090CF045-513C
       Part No: 6Q0 909 605 E
       Component: 08 AIRBAG VW7       0418
       Coding: 0012344
       VCID: 392C2758254C6A9FCE9-513C
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 1C0-920-x4x.lbl
       Part No: 1C0 920 941 L
       Component: KOMBI+WEGFAHRS. M73 V03
       Coding: 03234
       VCID: 290CF718D0ECDA1FBE9-4B00
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V032
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70BADA7C33B6EBD7397-4B00
    Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
       Part No: 1Y0 959 255
       Component:  VSG  NBC       ?
       VCID: 7DA4F34871E496BFA21-513C
       Part No: 1C0 959 799 G
       Component: 6J Komfortger?t HLO 0004
       Coding: 00256
       Shop #: WSC 00066
       VCID: 3B203D502A70588FDC5-4B00
       Subsystem 1 - Part No: 1Y1959801
       Component: 6J T?rsteuer.FS KLO 0001
       Subsystem 2 - Part No: 1Y1959802A
       Component: 6J T?rsteuer.BF KLO 0001
       Subsystem 3 - Part No: 1Y0959811
       Component: 6J T?rsteuer.HL KLO 0001
       Subsystem 4 - Part No: 1Y0959812
       Component: 6J T?rsteuer.HR KLO 0001
                35-00 - -
       Part No: 1C0 035 180 E
       Component:  RADIO 3CP         0002
       Coding: 06401
       Shop #: WSC 00066
       VCID: 1A6ED8D4858A4187273-4B00
    End----------(Elapsed Time: 03:51, VBatt start/end: 12.5V/12.4V)-----------
    Did you mean to post a link to this video?
    https://www.youtube.com/watch?v=6ODt94_d6Cw
    Are the batteries in the remotes good?
    Feb 2017
    Arggh, yes d6Cw is indeed the video I was following to try and rematch the remotes.
    In my search for a solution I was updating everything and must have pasted in wrong you tube link.
    Already replaced batteries in both remotes.
    Checked old and new remote batteries with voltmeter just to be sure.
  5. Likes Uwe, Jack@European_Parts liked this post
    Dallas (McKinney) ,TX ,USA
    Does it your car lock/unlock all doors and make beep when you insert key in door lock?
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #5
    Feb 2017
    Yes.
    manual lock using key in drivers dorr locks all doors, lights flash and car beeps.
  9. #6
    Did you try recoding CCM and than a default of CCM to clear keys and battery reboot of everything?
    Did you verify clicker is seen by antenna in VCDS blocks?
    Are you sure batteries are not installed wrong in remotes?
  10. Likes Uwe liked this post
  11. #7
    Feb 2017
    yes, remote batteries are oriented correctly, LED blinks when push button
    I disconnected the car battery, touched + and - cables for a bit and reconnected no luck
    how do I verify clicker is seen by antenna in VCDS blocks?
    I dont know what you mean by recoding CCM and than a default of CCM to clear keys
  12. #8
    Quote Originally Posted by rntrary View Post
    Look at MVBs 014 and 015 with VCDS while pressing buttons on the remotes to see if any of the fields change at all.
  13. Likes Jack@European_Parts, Jetta ,97 liked this post
  14. #9
    Also are you setting the remote count in adaption & to be freshly attempted to be adapted after clearing and saving the new remote count after saving to zero?
  15. #10
    Feb 2017
    I got it to work with following variation in video d6Cw.
    After select 46, 10 adatp, goto chan 01 (skip chan 00)
    click on the displayed chan 01 and read becomes highlighted
    click on highlighted read
    enter new value (2)
    test, save and are you sure
    then click lock button on each remote
    tadah it works !
    perhaps the d6Cw video needs to be updated
  16. Likes Jack@European_Parts, Uwe liked this post
