Results 1 to 6 of 6
Thread: Audi P8 Is Particle Filter Carbon Mass = Diesel Particle Filter Ash Volume ?
    Jun 2015
    Ireland
    Attached is my autoscan for a DPF engine light I've been getting for the last few days.
    Monday,13,January,2020,20:21:45:40377
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8P18A150608   License Plate:
    Mileage: 405740km-252115mi   Repair Order: 13Jan2020
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8P18A150608   Mileage: 405740km-252115miles
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 RG    HW: 03G 906 021 AB
       Component: R4 1,9L EDC  000SG  1957
       Revision: --H07---    Serial number: AUX7Z0H1FN50NE
       Coding: 0000071
       Shop #: WSC 15937 159 999999
       VCID: 75CF03891C5C8FE784-8020
    001137 - Exhaust Pressure Sensor 1
                   P0471 - 000 - Implausible Signal
                        Fault Status: 01110000
                        Mileage: 405471 km
                        Date: 2020.01.11
                        Time: 11:56:18
                        (no units): 66.30
                        (no units): 71.40
                        (no units): 0.0
                        Temperature: 84.0C
                        Temperature: 7.2C
    009299 - Diesel Particle Filter; Differential Pressure Sensor
                   P2453 - 000 - Implausible Signal
                        Mileage: 405546 km
                        Date: 2020.01.11
                        Time: 13:36:03
                        (no units): 81.60
                        (no units): 76.50
                        (no units): 0.0
                        Temperature: 384.0C
                        Temperature: 7.2C
    005659 - Glowplug for Cylinder 2 (Q11)
                   P161B - 000 - Open Circuit
                        Mileage: 405594 km
                        Date: 2020.01.12
                        Time: 08:20:08
                        RPM: 882 /min
                        Voltage: 13.15 V
                        Bin. Bits: 00000100
                        Temperature: 4.5C
                        Bin. Bits: 10110000
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 000 - Open Circuit - Intermittent
                        Mileage: 405594 km
                        Date: 2020.01.12
                        Time: 08:20:08
                        RPM: 882 /min
                        Voltage: 13.15 V
                        Bin. Bits: 00000100
                        Temperature: 4.5C
                        Bin. Bits: 10110000
    Readiness: 1 1 0 0 0
       Revision: 00H11001
       Coding: 0021121
       Shop #: WSC 06314 000 00000
       VCID: 73CB3D91122891D7AA-8026
       Part No: 8P0 820 047
       Component: J255  Klima Man H07 0030
       VCID: 6DFF2BE9740C47277C-8038
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-B.lbl
       Part No SW: 8P0 907 279 J    HW: 8P0 907 279 J
       Component: Bordnetz-SG     H54 2501
       Revision: 00H54000    Serial number: 00000008037223
       Coding: 00880F01B01410004F1600001600000000085A175C010000000000000000
       Shop #: WSC 06314 000 08192
       VCID: 44A9AE4D0706666FC3-8010
       Subsystem 1 - Part No: 8P2 955 119 E  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H01 0130
       Coding: 00062736
       Shop #: WSC 06314
                        Fault Status: 00111010
                        Reset counter: 19
                        Mileage: 403301 km
                        Date: 2019.12.03
                        Time: 07:55:00
                        Voltage: 14.10 V
    01598 - Drive Battery Voltage
                        Reset counter: 17
                        Mileage: 405133 km
                        Date: 2019.12.16
                        Time: 08:31:00
                        Voltage: 13.85 V
    Address 15: Airbags        Labels: 8P0-959-655-94.lbl
       Part No SW: 8P0 959 655 L    HW: 8P0 959 655 L
       Component:    Airbag 9.41  H01 4220
       Revision: 91H01422    Serial number: 003CP002PSAJ
       Coding: 0071612
       VCID: 4BBB85712A58A91702-801E
       Subsystem 1 - Serial number: 6332DRB40E69872A$
       Subsystem 2 - Serial number: 6342DRB406AC9231R
       Subsystem 3 - Serial number: 63528RB40385DBF0Z
       Subsystem 4 - Serial number: 63628RB403843960E
       Subsystem 5 - Serial number: 63747RB40369EEE22
       Subsystem 6 - Serial number: 63847RB40369ED9E9
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           036 0070
       VCID: 78D10ABD0B4EF28F9F-802C
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 981 K    HW: 8P0 920 981 K
       Component: KOMBIINSTR. VDO H22 0660
       Revision: D0H22003    Serial number: 2241H003108478
       Coding: 0006423
       VCID: 40A1A25D131E7A4FE7-8014
       Part No SW: 1K0 907 530 P    HW: 1K0 907 951
       Component: J533__Gateway   H16 0192
       Revision:   H16       Serial number: 2500K0820401C4
       Coding: E9807F061002022103
       VCID: 3449FE8D57A6D6EF73-8060
       Revision: D0H22003    Serial number: AUX7Z0H1FN50NE
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
       Component: Tuer-SG         H03 0050
       Coding: 0000688
       VCID: 43ABAD5102086157FA-8016
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.078 H08 1901
       VCID: 364DC48541DAC4FF4D-8062
       Part No: 8P0 959 433 J
       Component:    KSG          H11 0080
       Coding: 1980202002186D0985054C9FC637
       Shop #: WSC 80093 222 69422
       Component: Neigungssensor  005 0003
       Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
       Component: AB2 SUBWOOFERBOXH06 0180
       Revision: 00005       Serial number: 30674752816328
       VCID: 354FC3895CDCCFE744-8060
    00422 - Rear Right DSP Midrange Speaker (R106)
                        Fault Status: 00101011
                        Reset counter: 6
                        Mileage: 398935 km
                        Date: 2019.10.31
                        Time: 17:17:35
                        Temperature: 11.0C
       Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
       Coding: 0000688
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
       Part No SW: 8P0 035 186 P    HW: 8P0 035 186 P
       Component: R Concert2+     H02 0270
       Revision: 00H02000    Serial number: AUZ1Z3H8880884
       Coding: 0110211
       VCID: 3FA3A1A16EE005B79E-806A
                        Reset counter: 28
                        Mileage: 368890 km
                        Date: 2019.01.19
                        Time: 11:04:58
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
       Component: Tuer-SG         H04 0040
       Coding: 0000144
       Shop #: WSC 06314 000 1012544
       VCID: 41A7A75918147347E8-8014
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
       Coding: 0000144
       VCID: 42A5A8551D12685FF1-8016
    End-------------------------(Elapsed Time: 01:16)--------------------------
    I'm trying to see if the regen is taking place but I'm not sure if the measurements are the correct ones or what the ranges should be
    In http://wiki.ross-tech.com/wiki/index...5/P2453/009299 it talks about the Diesel Particle Filter Ash volume but I'm not seeing that entry in the measurements but I do see a particle filter carbon mass value. My value is staying at 255 but is that very bad - good - very good?
    Below are some other measurements I thought might help after taking the car for a short spin (5-10mins) at motorway speeds over 2k revs
      285.0 mg/str   Exhaust Gas Recirculat. (spec.)
      430.0 mg/str   Exhaust Gas Recirculat. (actual)
      100.6 %   Exhaust Gas Recirc. Duty Cycle
      0.0 %   Exhaust Gas Recirc. Duty Cycle
             0   Exhaust Gas Recirc. Cooler
      81.60   Press. Difference Particle Filter
      255.0   Particle Filter Carbon Mass
      150.0C   Temperature bef. Particle Filter
      6.7 %   Particle Filter Load Coefficient
      216.0C   Temperature after Particle Filter
    Background
    The car is just back having had a coolant leak, the car is idling under 1000 revs now. It does more motorway commuting than town/stop starts. I cleared the codes but they came back after about a day.
    With Pressure Sensor faults, it's mostly likely not doing any active regeneration. Fix those first.
    Does the DPF in this car really have 252,000 miles on it?
    Jun 2015
    Ireland
    Well I've never changed the dpf so I'm guessing it's the original.
    Is this warning just coincidence after I've just gotten it back from fixing (yet) another problem?
    Also are my measurement values tje correct ones to be monitoring and do their values make sense or cause concern?
    Nov 2018
    Ireland
    As Uwe says, those pressure sensor faults aren't good.. check the pressure values with ignition on and if anything other than 0 there's something up.. sensors do go faulty.. you could also test with a test pump.. There is no units for the pressure and soot mass values but presuming they are millibars and grammes, those figures are bad.. looks like its blocked up but again you would need to verify pressure sensor before jumping to conclusions.. also I have seen glow plug faults preventing regeneration so you might need to sort those as well.
    Owen.
    Jun 2015
    Ireland
    Had the pressure sensor replaced and the issue seems to have gone away
  8. Likes Jack@European_Parts liked this post
  9. #6
    Did you know some guys install inline traps to protect sensors for PSI or even a diaphragm so contaminants can't ever reach the sensors?
    Thank you for report of the situation being resolved.
