Results 1 to 10 of 10
Thread: Security Code Needed for O3/ABS channel IDE03493-Driver door status
    Aug 2019
    NW Florida
    First, I'm trying to deactivate the automatic EPB when the driver's door is opened. I think the subject adaptation channel may do the trick, but I've not been able to find a security code that successfully works. I've tried all listed below without success; most are accepted initially, but not for this specific adaptation channel. There is a chance I made a miss-step along the way that caused one of these security codes, although correct, to fail - but I don't think so. So, if anyone can confirm what security code actually did work in changing O3/ABS channel IDE03493-Driver door status: from "activated" to "not activated", please post...
    Thank you, everyone,
    TW
    10505
    10815
    11966
    15081
    18573
    19249
    20103
    24435
    24990
    25004
    25757
    28183
    31857
    37202
    40168
    40304
    44595
    Wednesday,15,January,2020,12:04:16:27651
    VIN:    License Plate:
    Mileage: 14654km-9105mi   Repair Order:
    Chassis Type: CA-VW41 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 4B 52 5F 69
              6C 6D 75 A5 CA D6 D7
    VIN:    Mileage: 14654km-9105miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (0-32-CDVC)       Labels: None
       Part No SW: 03H 906 026 AA    HW: 03H 907 309 K
       Component: VR6 3.6l FSI  H21 6694
       Revision: 52H21000
       Coding: 012A003244740108B0000000000000000000000000000000
       Shop #: WSC 06050 062 00200
       ASAM Dataset: EV_ECM36FSI01103H906026AA 001005
       ROD: EV_ECM36FSI01103H906026AA.rod
       VCID: 6491AD249EDD7F174DF-8030
       CAN Converter 01:
       Part No SW: 09G 927 158 DR    HW: 09G 927 158
       Component: AISIN AQ8     206 3536
       Coding: 0000000100000000000000000000000000000000
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 065597AC48A1ED07F3B-8052
       Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
       Component: ESC           H25 0524
       Revision: 00000000    Serial number: 53468000000124
       Coding: 44FC6B8D84231A6DC57F0203A2C66922D62158A34045967038415058C2A2420B0023641C12141A1D8DDB45506CC8CF
       ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
       VCID: 77ABEA683F4B848FF8D-8022
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0497749765
       Coding: 1F20000723
       VCID: 43D34EB83B13182F945-8016
       Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11358006
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 3CN 907 044 L    HW: 3CN 907 044 L
       Component: Climatronic   H04 2009
       Revision: 00001K03
       Coding: 1602002620001C001104210C5210142C
       ASAM Dataset: EV_ACClimaBHBVW416 002012
       ROD: EV_ACClimaBHBVW416.rod
       VCID: 48C9599402353B77417-801C
       Fresh Air Blower Back:
       Part No SW: 5Q0 937 085 BT    HW: 5Q0 937 085 BG
       Component: BCM MQBAB HNA H38 0273
       Serial number: 8335010201˙˙˙˙
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 0C41A58456CD9757A5F-8058
       Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
       Component: RLHSS  052 0122
       Serial number: S7Y18M10D30H02M31S58
       Coding: 00382D
       Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H08 0050
       Serial number: 0000009600363Z01QP02
       Coding: 150000
       Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
       Component: GTO BF  H06 0007
       Serial number: 8MW00130091800010032
       Steering Column Switch:
       Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
       Component: Lenks.Modul  H23 0170
       Serial number: 0300091220180C205828
       Serial number: 000137088R18341
       Coding: 0471155111
       VCID: 4CC16584164DD75765F-8018
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Component: ACC BOSCH MQB H11 0682
       Coding: 3200074959FFC728949C810530401600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: 44D14DA43E1D1F17ADF-8010
       Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
       Component: Airbag VW21   006 0713
       Revision: --------    Serial number: 003SUMKVWKQe
       Coding: 8CCCDC00000000005000001A420800000065
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0B43A69853C3906FAC5-805E
       Occupant Detection:
       Component: Occ.Detection  H13 0022
       Serial number: IBH0000J18000ARK0B0D
       Coding: 303030
       Subsystem 2 - Part No SW: -----------    HW: 454 002 910 18
       Serial number: 35700000000424496236
       Subsystem 3 - Part No SW: -----------    HW: 454 001 110 18
       Serial number: 35800000000D0A78623M
       Subsystem 4 - Part No SW: -----------    HW: 454 801 212 18
       Serial number: 3510097AC3F17000000U
       Subsystem 5 - Part No SW: -----------    HW: 454 802 711 18
       Serial number: 35200E3FA1F17000000X
       Subsystem 6 - Part No SW: -----------    HW: 454 802 111 18
       Serial number: 35500096FEC16000000X
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 454 802 111 18
       Component: FrontSensor_P  304 0149
       Serial number: 356009120BA16000000B
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 3CN 920 891 B    HW: 3CN 920 891 B
       Component: KOMBI         403 4191
       Coding: 0BA40F1D6F88CF0502886B0B50010000A0000000
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5344
       Serial number: 26111800842619
       Coding: 0B0100347F087300FA0002581C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 3D2738405DF76EDFE21-8068
       Component: 1-01-0e-01-04
       Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0052
       Serial number: 33180001692630031439
       Coding: 2EFFFF
       Serial number: 1795406200
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
       Component: U13DCAC  H23 0890
       Serial number: B007541
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 18000331561015
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW41.rod
       VCID: 33331E786BB3A8AF045-8066
       Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
       Component: Sitzmemory    H09 0024
       Serial number: Y0006RJG33148
       Coding: 0010000000000500018280808080000000008100000000F400
       ASAM Dataset: EV_SeatMemorDriveSide 002022
       Component: HRE_Master    H12 0081
       Serial number: 0500310573
       Coding: 02012103
       ROD: EV_HREntryHella_VW27.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0081
       Serial number: 0501777184
       Coding: 020121
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS001 0287
       Serial number: YA008RKM004U2
       Coding: 00341B200200020000000000
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000001319046
       Coding: 011000
       Part No SW: 3QF 909 144 B    HW: 3QF 909 144 A
       Component: EPS_MQB_ZFLS  570 1582
       Coding: 191F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 47CB5AA80F2B340F48D-8012
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 03121800841225
       Coding: 000000070900134A00010000000000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW41.rod
       VCID: 3537206065C7B69F2A1-8060
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS001 0287
       Serial number: YA008RK500QUA
       Coding: 003413200E00020000000000
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000001321896
       Coding: 091000
       Part No SW: 3QF 035 876 A    HW: 3QF 035 876 A
       Component: MU-S-NS-US    853 0890
       Coding: 02140602FF00000051220001001808001F0506E401200405CE
       ROD: EV_MUStd4CDELP_VW37.rod
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZJV2910251
       Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
       Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
       Component: Anhaenger     H27 0260
       Revision: 8C001004    Serial number: 0497745983
       Coding: 0200000200000000
       VCID: 40D941B42A050337897-8014
       Component: RVC Compact   H15 0231
       Coding: 01140602A3002017300040
       VCID: 392F2C5049DF52FFCE9-806C
       Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0266
       Revision: --------    Serial number: A2-C758-8680-2
       Coding: 0988
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       ROD: EV_DeckLidCONTIAU736_VW41.rod
       VCID: 45D750A03527261FBA1-8010
       Component: OCULowMQBUS   009 0570
       Coding: 02140602C2823A017F1E06000000
       ROD: EV_OCULowMQB.rod
       Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H09 1272
       Serial number: 21011941K22283
       Coding: 0004010600010201002213558150490084000E200100
       Shop #: WSC 56641 001 104857
       ROD: EV_MFKBoschMQBB_001_VW27.rod
       VCID: 0849999442B5FB77817-805C
       Coding: 00804074160C
       Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
       Component: LED1L         H06 0003
       ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
       VCID: 7BA3F6580363A0EF9C5-802E
       Component: LED1R         H06 0003
       ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
    End----------(Elapsed Time: 01:58, VBatt start/end: 12.9V/12.9V)-----------
    2019 Atlas SEL-R FWD
    Dec 2016
    DE
    Did you also try switching the diagnostic session?
    Aug 2019
    NW Florida
    I apologize for my ignorance, but I'm not sure exactly what that means...
    Dec 2016
    DE
    VCDS offers the possibility to change the diagnostic session. You can change from standard diagnostics to engineering/development or end-of-line session for example.
    This is a somewhat hidden feature and I was asked not to post a "how to" publicly, but you can send an E-Mail to Support@Ross-Tech.com and ask for the steps (possibly referencing this thread).
  5. Likes Uwe, Dana liked this post
    Aug 2019
    NW Florida
    Thank you TBAx, I really appreciate the experts help here. I love the Ross-Tech product - it's made car ownership exciting again!
    TW
    << THIS MESSAGE WILL SELF DESTRUCT IN 5 SECONDS >>
  7. Likes Dana, Uwe liked this post
    United States
    Although this is unlikely the problem do make sure Adv measuring value IDE00323 -- Security Access: Number of invalid keys wasn't 3 or more. If it is over 2, perfectly valid SA codes may be rejected.
    Also, Don't got a nice list here: https://forums.ross-tech.com/showthr...rk-in-progress
    Edit, I didn't cross check these (many will be duplicates) but some of these may help: https://forums.ross-tech.com/showthr...ccess-ABS-unit
  9. Likes Uwe liked this post
  10. #7
    Aug 2019
    NW Florida
    Thank you for the guidance Dana. I started with Don's list - none worked. The second list is new to me, I'll give them a try - would a difference in ABS Modules be relevant?
    I should have added that the Number of invalid keys was never more than 1 and than returned to 0 with a new valid entry each time.
    TW
  11. Likes Dana liked this post
  12. #8
    United States
    Quote Originally Posted by TWs/VW View Post
    ... would a difference in ABS Modules be relevant?
    Yes, that is entirely possible. Ideally you look for feedback specific to ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009 (the ASAM dataset followed by the version) however I'd keep it simple and just use as many generalized MQB ABS SA codes you can.
  13. #9
    Aug 2019
    NW Florida
    Will do.
    TW
  14. #10
    Aug 2019
    NW Florida
    Security Access (SA) O3/ABS Brakes - channel IDE03493-Driver door status
    SA 37203
    03-ABS Brakes >channel IDE03493-Driver door status >activated/not activated
    TW
  15. Likes Eric liked this post
