Results 1 to 5 of 5
Thread: How perform test by VCDS Lite EGR, MAF, Block 032 Fuel trim
    Verified VCDS-Lite User
    Oct 2015
    Exclamation How perform test by VCDS Lite EGR, MAF, Block 032 Fuel trim
    I am currently buy VCDS Lite :-
    Please need information :-
    My Car has black smoke when i Accelerator. (VW GOLF TDI 1.9 2002 diesel (MK4)
    i have USB Cable KKL VAG-COM.
    1) how i perform test EGR value in Lite version
    2) how i perform MAF test Lite
    3) Perform test GROUP block 032 Lite
    4) fuel trim
    Post an Auto-Scan please so we can see exactly what ECU you have.
    Oct 2015
    VCDS-Lite Version: Release 1.2
    Wednesday, 14 October 2015, 20:13:38:48752
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
    Address 01: Engine       Labels: 038-906-019-AJM.LBL
       Controller: 038 906 019 HJ
       Component: 1,9l R4 EDC G000SG  1490
       Coding: 00002
       Shop #: WSC 00046
       VCID: 66BF8BEB117F
       WVWZZZ1JZ2B134987     VWZ6Z0B0058310
    Readiness: N/A
    Address 03: ABS Brakes       Labels: 1C0-907-37x-ASR.LBL
       Controller: 1C0 907 379 K
       Component: ASR FRONT MK60      0103
       Coding: 0021505
       Shop #: WSC 00046
       VCID: 321727BBED37
    00287 -  ABS Wheel Speed Sensor; Rear Right (G44)
                012 -  Electrical Fault in Circuit
    Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
       Controller: 3B1 907 044 C
       Component: CLIMATRONIC     C 2.0.0
       Coding: 11000
       Shop #: WSC 00046
       VCID: 2135D8F7B8D1
    Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
       Controller: 1C0 909 605 A
       Component: 27 AIRBAG VW51 01   0004
       Coding: 12855
       Shop #: WSC 00046
       VCID: 2237D7FBBDD7
    00532 -  Supply Voltage B+
                07-10 -  Signal too Low - Intermittent
    Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
       Controller: 1J0 920 926 CX
       Component: KOMBI+WEGFAHRSP VDO V20
       Coding: 00414
       Shop #: WSC 00098
       VCID: 8277377B9D17
    Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
       Controller: 6N0 909 901
       Coding: 00006
       VCID: F0936DB3A3BB
    Address 46: Central Conv.       Labels: 1C0-959-799.LBL
       Controller: 1C0 959 799 B
       Component: 1X KomfortgerŠt HLO 0003
       Coding: 00258
       Shop #: WSC 00046
       VCID: 361F1BAB015F
    01336 -  Data Bus for Comfort System
                80-00 -  Single-Wire Operation
    00932 -  Electric Window Motor; Drivers Side (V147)
                62-00 -  No or Incorrect Adjustment
    End   --------------------------------------------------------------------------------------------------
  4. Likes Uwe liked this post
    Quote Originally Posted by nadir khan View Post
    Compare specified and actual MAF readings in MVB 003. If specified and actual MAF readings do not diverge much, then EGR is working as designed. If they do diverge substantially, then there is a problem with your EGR system.
    Log the actual MAF reading during a full-throttle run through second gear, from as low an RPM and you can to the engine's redline.
    4) fuel trim
    It seems to me that you are trying to apply information/procedures that are specific to petrol-fueled engines to your diesel. Your diesel engine management system does not use the concept of fuel trim, and your ECU does have fuel trim data in MVB 032.
    Oct 2015
    need help
    My car generate smocks and change some sound when car temperature going normal after driving 20 min, i change MAF, same condition, what test i will do like boost leak?
    Regards
