Results 1 to 2 of 2
Thread: 2019 Tiguan SEL ignition-active message actuator disable
    Jan 2020
    I've been trying to disable the ignition active door chime and while the changes are accepted by the controller the door chime still sounds. I was able to turn off the seat belt warning but the door chime has defeated me. Is there something else I should try?
    I tried using module 17 - adaptations - ignition - none
    Here is the log file:
    Monday,13,January,2020,16:10:28:03841
    VIN: 3VV2B7AX0KM182761   License Plate:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 22 2B 3C 42 44 52 5F 6C 6D
              75 CA
    VIN: 3VV2B7AX0KM182761   Mileage: 1467km-911miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 83A 907 115     HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H31 0004
       Revision: 1DH31000
       Coding: 012A00122466012FB4000000000000000000000000000000
       Shop #: WSC 00066 790 00184
       ASAM Dataset: EV_ECM20TFS01183A907115 001006
       ROD: EV_ECM20TFS01183A907115.rod
       VCID: 6390A7786BD5480FB45-8036
    Readiness: 0000 0100
       Part No SW: 09G 927 158 DT    HW: 09G 927 158
       Component: AISIN AQ8     206 3549
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00439
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 084A90D4B2B3CB57817-805C
       Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
       Component: ESC           H35 0108
       Revision: 00000000    Serial number: 51529000000683
       Coding: 0BFA6BA450281B6EC57E0306A2C449D0D60AD8A3C045927438415058D28A4A0B00402864121A1C230935351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD: EV_Brake1UDSContiMK100IPB_038.rod
       VCID: 06569EECB8A7DD27F3B-8052
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0516377127
       Coding: 132C0C0723
       VCID: 43D047F8CB15280F945-8016
       Part No SW: 5NN 907 044 M    HW: 5NN 907 044 M
       Component: AC Automat    H35 4601
       Revision: 20K03000    Serial number: 00000D00392872
       Coding: 0002002420011800100501001211140E
       ASAM Dataset: EV_ACClimaPrehVW37X 002025
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 56F68EAC2887ADA7C3B-8002
       Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 98193930
       Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
       Component: BCM PQ37BOSCH 036 0265
       Revision: --------    Serial number: C86424061901Y8
       ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7BA0FF18F36590CF9C5-802E
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 190422  034 0373
       Serial number: 19041721005850
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Serial number: 72470637
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0300260620190C201996
       Serial number: 000137088R19180
       Coding: 0471555811
       VCID: 4CC26CC4E64BE77765F-8018
       Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0342
       Coding: 3200008258FF8728749C810530409700000000000000000000
       ASAM Dataset: EV_ACCMRRCONTIVW376 003015
       ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
       VCID: 42DE42FCD40F21079F3-8016
       Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
       Component: AirbagVW21    005 0403
       Serial number: 003FGM03UPVG
       Coding: 8CCCFC00000000005000001AC20800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 0C42ACC4A6CBA777A5F-8058
       Occupant Detection:
       Serial number: IBH00000000000BOLJOG
       Coding: 303451
       Subsystem 2 - Part No SW: -----------    HW: 480 001 705 19
       Serial number: 35700000000A61ACEB3$
       Subsystem 3 - Part No SW: -----------    HW: 480 002 105 19
       Serial number: 35800000000B0644FB3R
       Subsystem 4 - Part No SW: -----------    HW: 480 401 405 19
       Component: SideSensor_Dr  005 6149
       Serial number: 3510001BAEFE7867D770
       Subsystem 5 - Part No SW: -----------    HW: 480 401 705 19
       Component: SideSensor_Pr  005 6149
       Serial number: 3520001C0EFE7863D41M
       Subsystem 6 - Part No SW: -----------    HW: 480 403 105 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001B6F051DB267DI
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 403 105 19
       Component: FrontSensor_P  005 6149
       Serial number: 3560001B6F051DB215BA
       Part No SW: 5NA 920 890 D    HW: 5NA 920 890 D
       Component: KOMBI         509 1701
       Coding: 08A4041AA788CF050288634950010000A0000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001026
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       VCID: 44D244E4CE1B2F37ADF-8010
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 26061900840915
       Coding: 030500347F085900FB0722581E0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 6E86C64CB017F5672BB-803A
       Component: 0-00-0d-00-04
       Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
       Component: E221__MFL-TAT  H06 0025
       Serial number: 1291901243400151FJ2B
       Coding: 2C0000
       Serial number: 4381976600
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00019.04.19
       Coding: 0101
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 19000136383017
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 333017389BB5988F045-8066
       Component: HRE_Master    H12 0081
       Serial number: 0519375819
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D243100ADF15EFFE21-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0081
       Serial number: 0519315838
       Coding: 020111
       Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
       Component: TSG FS        006 0247
       Serial number: 50038917800463
       Coding: 00301B200000048000000000
       Shop #: WSC 01383 790 50316
       VCID: 4DC461C01D51EE7F721-8018
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000003432455
       Coding: 011000
       Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
       Component: EPS_MQB_ZFLS  173 1081
       Coding: 811F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50FA78B40A63C397197-8004
       Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
       Component: TSG BFS       006 0247
       Serial number: 54038917500071
       Coding: 003013200000048000000000
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000003464323
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    853 0890
       Coding: 02730602BE00000051220001001808001F0500E401200405C6
       ROD: EV_MUStd4CDELP_VW37.rod
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  254 8130
       Serial number: VWZ6ZMW1785634
       Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
       Component: RVC Compact   H18 0231
       Coding: 0123060122002017300040
       VCID: 392C2510B9D962DFCE9-806C
       Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0266
       Revision: --------    Serial number: A2-C758-8680-2
       Coding: 0A08
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       VCID: 45D459E0C521163FBA1-8010
       Component: OCULowMQBUS   009 0570
       Coding: 02230602C2823A017F1E06020000
       ROD: EV_OCULowMQB.rod
       Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
       Component: SAD_STG_1     006 0002
       Coding: 00804073260C
       ASAM Dataset: EV_SunRoofCONTIAU736 009011
       ROD: EV_SunRoofCONTIAU736_009_VW37.rod
       VCID: 75B4E920D541C6BFEA1-8020
    End----------(Elapsed Time: 01:40, VBatt start/end: 14.8V/14.8V)-----------
    Hi and welcome.
    Moving this to the Tweaks section.
