Results 1 to 2 of 2
Thread: VW Crafter 2009 CEBB 2.5
    Please see attached scan
    Hi All
    A crafter this time with multiple faults after wiring (engine Loom) cut through behind air filter assembly all wiring repaired and tested back to to componants and ecu multiplug
    The two codes for turbo postion sensor and heater circuit of nox sensor im am not intereseted in at the moment unless they are connected, the heater circuit fault is in the ecu and i suspect from tresting that the position sensor will be there to however the van runs perfectly over 200 miles a day
    the problem that needs fixing first is that after driving approximatley 60 miles the speedo display suddenly stop working along with the wipers and indicators
    the only way to overcome it is to turn the ignition off and on again and it resets itself after 60 miles this fault with then repeat itself about six times during the jouney on short runs it never happens
    i have swapped out the instrument cluster with a know good unit and it still occurs, also on the scan it refers to different terminals on the ignition swithed ie 15 15R 54 61 also on the central electics on the first line there is a refence to earth deceased ive checked and cleaned earths behind headlights and both inner a panels
    all help appreciated thanks PhillW
    Saturday,17,January,2015,16:26:02:27229
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    VIN: WV1ZZZ2EZA6012215   License Plate:
    Chassis Type: 2E (2E - VW Crafter (LT3 / 2006 >))
              B0 B1 B2 B3 B4 B5 B6 C1
    Address 01: Engine (CEB)       Labels: None
       Part No SW: 076 906 022 N    HW: 076 906 022 G
       Component: R5 2,5L EDC A020SG  7731
       Revision: 24H31---    Serial number: VWXDZ0I1023466
       Coding: 0003032
       Shop #: WSC 00379 210 94948
       VCID: 1E384CD4CADD88D17D7-50C8
    9 Faults Found:
    009571 - Turbocharger Boost Control Position Sensor Circuit
                   P2563 - 000 - Implausible Signal - Intermittent
                        RPM: 777 /min
                        Speed: 4.0 km/h
                        Voltage: 13.68 V
                        Temperature: 132.0C
                        Lambda: -13.4 %
                        Bin. Bits: 00001110
                        Voltage: 1.672 V
    008871 - NOx Sensor 2 Bank 1; Heating Circuit
                   P22A7 - 000 - Implausible Signal - MIL ON
                        Fault Status: 11100000
                        RPM: 2541 /min
                        Speed: 78.0 km/h
                        Voltage: 13.07 V
                            1020 ppm
                        (no units): 1.0
                        Voltage: 12.70 V
                        Temperature: 2.7C
    006457 - Powertrain Databus
                   P1939 - 000 - Missing Message from Controller for Access & Start Auth. - Intermittent
                        Fault Frequency: 59
                        Load: 25.1 %
                        Voltage: 11.70 V
                        Voltage: 11.70 V
                        Voltage: 11.70 V
                        Voltage: 11.70 V
                        Fault Frequency: 59
                        Load: 25.5 %
                        Voltage: 11.70 V
                        Torque: 615.0 Nm
                        Temperature: 50.4C
                        Bin. Bits: 00010000
    049493 - No Communication with Instrument Cluster
                   U0155 - 000 -  - Intermittent
                        Fault Frequency: 58
                        Load: 29.4 %
                        Voltage: 11.70 V
                        Torque: 615.0 Nm
                        Temperature: 50.4C
                        Bin. Bits: 00010000
                        Fault Frequency: 58
                        Load: 29.4 %
                        Voltage: 11.70 V
                        Torque: 615.0 Nm
                        Temperature: 50.4C
                        Bin. Bits: 00010000
                        Fault Frequency: 50
                        RPM: 2457 /min
                        Speed: 113.0 km/h
                        Load: 21.2 %
                        Voltage: 13.83 V
                        Torque: 15.0 Nm
                        Temperature: 90.9C
                        Bin. Bits: 00010000
    005762 - Powertrain Data Bus
                   P1682 - 000 - Implausible Message from ABS Controller - Intermittent
                        RPM: 735 /min
                        Voltage: 13.30 V
                        Torque: 0.0 Nm
                        Temperature: 63.0C
                        Bin. Bits: 00010000
    001299 - Incorrect Immobilizer Key
                   P0513 - 000 -  - Intermittent
                        RPM: 903 /min
                        Voltage: 11.25 V
                        Absolute Pres.: 989.4 mbar
                        Absolute Pres.: 969.0 mbar
                        Temperature: 4.5C
                        Temperature: 14.4C
    Readiness: 1 4 0 0 1
    Address 91: LT3 Engine        Labels: None
       Coding: 0003032
       VCID: 1E384CD4C9DD88D17D7-804B
    9 Faults Found:
                        RPM: 777 /min
                        Speed: 4.0 km/h
                        Voltage: 13.68 V
                        Temperature: 132.0C
                        Lambda: -13.4 %
                        Bin. Bits: 00001110
                        Voltage: 1.672 V
                        RPM: 2541 /min
                        Speed: 78.0 km/h
                        Voltage: 13.07 V
                            1020 ppm
                        (no units): 1.0
                        Voltage: 12.70 V
                        Temperature: 2.7C
                        Fault Frequency: 59
                        Load: 25.1 %
                        Voltage: 11.70 V
                        Voltage: 11.70 V
                        Voltage: 11.70 V
                        Voltage: 11.70 V
                        Fault Frequency: 59
                        Load: 25.5 %
                        Voltage: 11.70 V
                        Torque: 615.0 Nm
                        Temperature: 50.4C
                        Bin. Bits: 00010000
                        Fault Frequency: 58
                        Load: 29.4 %
                        Voltage: 11.70 V
                        Torque: 615.0 Nm
                        Temperature: 50.4C
                        Bin. Bits: 00010000
                        Fault Frequency: 58
                        Load: 29.4 %
                        Voltage: 11.70 V
                        Torque: 615.0 Nm
                        Temperature: 50.4C
                        Bin. Bits: 00010000
                        Fault Frequency: 50
                        RPM: 2457 /min
                        Speed: 113.0 km/h
                        Load: 21.2 %
                        Voltage: 13.83 V
                        Torque: 15.0 Nm
                        Temperature: 90.9C
                        Bin. Bits: 00010000
                        RPM: 735 /min
                        Voltage: 13.30 V
                        Torque: 0.0 Nm
                        Temperature: 63.0C
                        Bin. Bits: 00010000
                        RPM: 903 /min
                        Voltage: 11.25 V
                        Temperature: 4.5C
                        Temperature: 14.4C
    Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
       Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
       Component: IMMO          0805  0815
       Revision: 00805000    Serial number: VWXDZ0I1023466
       VCID: 6DDA5B1874FBA349B4D-8038
    Address 94: LT3 Airbag        Labels: None
       Part No HW: 9064461442
       Shop #: WSC 00117 555 00000
       ASAM Dataset: 3 3332
       ROD: CRFT_AB_3_3332.rod (*)
       VCID: 55AA13F8346B0B896CD-8000
    Address 95: LT3 ESP        Labels: None
       Part No SW: 9069022800    HW: 0004460153
       ASAM Dataset: 3 4101
       ROD: CRFT_ESP_3_4101.rod (*)
       VCID: 040C1EBC8F7142014B3-8051
    6 Faults Found:
    4283 - Voltage supply: Lower limit not reached
                MIL ON - Test Complete - Stored
    475C - CAN message ID240h Electronic Ignition Switch (D9): failed
    472D - CAN message ID408h Instrument Cluster Control Module (J285): failed
    5401 - SCN coding: Invalid
    4804 - Transmitted variant value: outside permissible range
    7352 - CAN Electronic Ignition Lock (D9): Message periodically not received
    Address 96: LT3 Instruments        Labels: None
       Part No SW: 9069024700    HW: 9069012000
       ASAM Dataset: 32 786
       ROD: CRFT_KOMBI_32_786.rod (*)
       VCID: 050A03B8844B7B095CD-8050
    Address 99: LT3 Ign. Switch        Labels: None
       Part No HW: 9065455808
       ASAM Dataset: 67 257
       ROD: CRFT_EZS_67_257.rod (*)
    9009 - Terminal 15C: Implausible signal
    9007 - Terminal 15: Implausible signal
    Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
       Component: HF-FFB        0805  0815
       Revision: 00805000    Serial number: 12345678901234
    Address 9B: LT3 Driver Door        Labels: None
       Part No HW: 9068204126
       ASAM Dataset: 33 773
       ROD: CRFT_FTUHR_33_773.rod (*)
    Address B1: LT3 Upper Console        Labels: None
       Part No HW: 9065454107
       ASAM Dataset: 67 3
       ROD: CRFT1_OBF_67_3.rod (*)
    Address B4: LT3 Central Elec.        Labels: None
       Part No SW: 9064420700    HW: 9065453801
       ASAM Dataset: 33 772
       ROD: CRFT_EZE_33_772.rod (*)
    9094 - Supply GND decrease Vehicle Electrical System Module: Lower limit not reached
    9090 - Terminal 15R; monitoring: Implausible signal
    9091 - Terminal 15; monitoring: Implausible signal
    9099 - Terminal 54; brake pedal monitoring: Implausible signal
    90AC - Terminal 61: Implausible signal
    Address B6: LT3 Steering Wheel        Labels: None
       Part No SW: 9065402345    HW: 9065402345
       ASAM Dataset: 72 257
       ROD: CRFT_SML_72_257.rod (*)
       VCID: 060804B4B94D7011557-8053
    End-------------------------(Elapsed Time: 02:50)--------------------------
    Dec 2019
    any updates ?
