Results 1 to 4 of 4
Thread: Set Automatic Transmission Start Mode to D or B?
    Dec 2019
    Sweden
    I have a Passat GTE 2020 and would like to "swap places" of D (Drive) and B (Recuperation). Found below to swap D and S. Is it possible to swap D and B?
    Set Automatic Transmission Start Mode to D or S
    [09 - Cent. Elect.] [Security Access - 10]
    [Adaptation 10] -> Channel 64 - Stored Value = 218 = Starting mode is always D
    Channel 64 - New Value = 00; Starting mode is determined by ADS selection at engine shutdown (Comfort and Auto=D, Dynamic=S, Individual=whatever you pick)
    Channel 64 - New Value = 03; Starting mode is always S regardless of ADS selection at engine shutdown (opposite of stock)
    Channel 64 - New Value = 11; Starting mode is S with all ADS settings at shutdown except Comfort where it's D
    Channel 64 - New Value = 19; Starting mode is S with all ADS settings at shutdown except Auto where it's D
    Tuesday,17,December,2019,10:35:31:38248
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ3CZLE0XXXXX   License Plate:
    Chassis Type: 3C-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 17 18 19 23 2B 36 3C 42 44 47
              4B 51 52 5F 69 6C 6D 75 8C A5 A9 BB BC C6 D6 D7
    VIN: WVWZZZ3CZLE0XXXXX   Mileage: 5276km-3278miles
    4B-Multifunc. Module -- Status: Malfunction 0010
    C6-Batt. Chrg. -- Status: OK 0000
    Address 01: Engine (J623-DGEB)       Labels: None
       Part No SW: 04E 906 024 G    HW: 04E 907 309 CG
       Component: 1.4 TFSI hy   H20 9819
       Revision: DCH20000
       Coding: 011D401A647405083008
       Shop #: WSC 05311 115 00291
       ASAM Dataset: EV_ECM14TFS01104E906024G 002006
       ROD: EV_ECM14TFS01104E906024AE.rod
       VCID: 2517F604156850AF9A1-8071
    38484 - Exhaust Gas Temp Bank 1 Sensor 2
              P2084 00 [096] - Implausible Signal
    38482 - Exhaust Gas Temp Bank 1 Sensor 1 (G235)
              P2080 00 [096] - Implausible Signal
    25358 - Fuel Tank Door
              P04B6 00 [096] - Stuck Closed
                        Mileage: 3311 km
                        Date: 2019.12.02
                        Time: 08:11:13
                        Normed load value: 29.4 %
                        Coolant temperature: 69 °C
                        Intake air temperature: 1 °C
                        Voltage terminal 30: 12.920 V
                        Unlearning counter according OBD: 3
                        Gasoline tank pressure sensor: offset corrected: -20.75 hPa
                        Ambient air pressure: 100 kPa abs
                        Outside air temperature: -6 °C
                        Fuel pump: specified value: 3.999 %
                        High fuel pressure: control deviation: -2.2580 MPa
                        Fuel: tank fill level: 7.8 l
                        State of shut-off valve to the gasoline pressure tank: false
                        State of shut-off valve to the gasoline pressure tank-Test_Program_B TRUE UBYTE: 0
       Part No SW: 0DD 300 046 E    HW: 0DD 927 770 C
       Component: GSG DQ400E    H32 2201
       Revision: 00032056    Serial number: TFK01908190302
       Shop #: WSC 05311 115 00093
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021_VW37.rod
       VCID: 2A0D05387C767FD7B73-807F
       Part No SW: 5QM 614 517 C    HW: 5QM 614 517
       Component: ESC           H26 0208
       Revision: 00000000    Serial number: 62309000000759
       Coding: 4FEC728F33233B734779060968C849F24ECCDCE26016927138A1F0F8D2A24A0B0003000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 048010
       ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
       VCID: 4EC569A8205E73F70BB-801B
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0526366241
       Coding: 1F20000723
       ASAM Dataset: EV_KessyHellaMQBAB 004052
       VCID: 45D75684F528B0AFBA1-8011
       Part No SW: 5GE 907 044 BB    HW: 5GE 907 044 BB
       Component: Climatronic   H10 2301
       Coding: 12021004200111010915100C8010D832
       ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001039
       ROD: EV_AirCondiBHTCMQB3rTranc_VW37.rod
       VCID: 7DA7FE64DD78386FA21-8029
       Subsystem 1 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
       Component: J848 HV-PTC  200 0204
       Serial number: -00103.8W.2B20370309
       Subsystem 4 - Part No SW: 5QE 816 803 H    HW: 5QE 816 803 H
       Component: J842 eKK  H03 0009
       Subsystem 5 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
       Component: E265KlimaHeck  H02 0201
       Serial number:       04031501850571
    1048836 - Blower Output Reduction due to Energy Management
              B10CE 00 [008] - -
                        Reset counter: 142
                        Mileage: 4738 km
                        Date: 2019.12.12
                        Time: 15:44:09
                        Voltage terminal 30: 12.2 V
                        Blower reduction: Stage 1
              B10CD 00 [008] - -
                        Reset counter: 142
                        Mileage: 4738 km
                        Date: 2019.12.12
                        Time: 15:54:09
                        Voltage terminal 30: 12.0 V
                        CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
                        Blower reduction: Stage 2 and compressor switch-off
       Part No SW: 5Q0 937 086 CF    HW: 5Q0 937 086 BR
       Component: BCM PQ37BOSCH 038 0303
       Revision: --------    Serial number: J53F2108190142
       ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
       ROD: EV_BCMBOSCH_020_VW27.rod
       VCID: 00598790AA8A5587C97-8055
       Component: WWS    190817  042  0607
       Serial number:         190830202706
       Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
       Component: RLHS  051  0206
       Serial number: SAY19M09D03H22M39S27
       Coding: 0008DD
       Light switch:
       Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
       Component: E1 - LDS MQB  H01  0032
       Serial number: 22 05 2019  10001523
       Component: Sensor, DWA  005  0316
       Serial number: 000000000ZY192151Q41
       Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
       Component: Sirene, DWA  004  0007
       Serial number: 00000000000000568667
       Ceiling Light Module:
       Subsystem 6 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
       Component: J528 Dachelek  H08  0009
       Serial number: 19091200010147C
       Coding: F38380
       Steering Column Switch:
       Subsystem 8 - Part No SW: 5Q1 953 521 AC    HW: 5Q1 953 569 B
       Component: Lenks.Modul  H23  0170
       Serial number: 0100190820190C102149
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058319247
       Coding: 1471255911
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       VCID: 50F977D03A6A6507197-8005
    13688835 - Databus
              [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                        Reset counter: 146
                        Mileage: 4983 km
                        Date: 2019.12.13
                        Time: 14:45:29
       Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
       Component: ACC BOSCH MQB H01 0771
       Coding: 52055FFA5DFFC728949C812481400600000000000000000066
       ASAM Dataset: EV_ACCBOSCHVW416 003014
       ROD: EV_ACCBOSCHVW416_003.rod
       VCID: 46D55188C82EBBB7B3B-8013
    1538 - Sensor for Automatic Distance Control
              [FAULT_SENSOR_BLIND]
                        Reset counter: 135
                        Mileage: 3145 km
                        Date: 2019.11.29
                        Time: 12:51:53
                        Control Module temperature: 7 °C
                        Voltage terminal 15-Voltage: 14.7 V
                        Vehicle speed: 7.02 m/s
                        Longitudinal acceleration: 0.03 m/s²
                        Adaptive distance regulation: status: ACC_StandBy
    1396 - Sensor for Automatic Distance Control
              [FAULT_SENSOR_NO_FREE_SIGHT]
                        Reset counter: 134
                        Mileage: 3148 km
                        Date: 2019.11.29
                        Time: 13:17:02
                        Voltage terminal 15-Voltage: 14.5 V
                        Vehicle speed: 0.00 m/s
                        Longitudinal acceleration: 0.00 m/s²
                        Adaptive distance regulation: status: ACC_Init
    1542 - Sensor for Automatic Distance Control
              [FAULT_SYSTEM_BLIND]
                        Reset counter: 135
                        Mileage: 3145 km
                        Date: 2019.11.29
                        Time: 12:51:53
    1397 - Sensor for Automatic Distance Control
              [FAULT_SYSTEM_NO_FREE_SIGHT]
                        Reset counter: 134
                        Mileage: 3148 km
                        Date: 2019.11.29
                        Time: 13:17:02
       Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0130
       Serial number: 02081941350856
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 392F2A7489D0C44FCE9-806D
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    010 0870
       Serial number: 003MFR05RZCH
       Coding: 98CCC0C0002000005C5400CF004800000065
       Shop #: WSC 05311 000 08193
       ROD: EV_AirbaVW20SMEVW37X.rod
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1040
       Serial number: 3G0857705B0247T01628
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1040
       Serial number: 3G0857706B0250T00370
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 708 19
       Serial number: 357000000007A58D9E3+
       Subsystem 4 - Part No SW: -----------    HW: 480 002 708 19
       Serial number: 358000000009472C9F3Y
       Subsystem 5 - Part No SW: -----------    HW: 480 402 408 19
       Component: SideSensor_Dr  005 6149
       Serial number: 3510001C2F2926C1D6BF
       Subsystem 6 - Part No SW: -----------    HW: 480 402 408 19
       Component: SideSensor_Pr  005 6149
       Serial number: 3520001C2F2926C1423
       Subsystem 7 - Part No SW: -----------    HW: 480 402 408 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001C2F2926C1F138
       Part No SW: 3G0 920 324 A    HW: 3G0 920 324 A
       Component: KOMBI         503 4187
       Coding: 01A408187FCC000A0180625B1001002880700300
       ASAM Dataset: EV_DashBoardVDDMQBA0 001041
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       VCID: 1F1BE4EC37348A7FD0D-804B
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_Audio_0x31 keine Kommunikation]
                        Fault Frequency: 11
                        Reset counter: 146
                        Mileage: 935 km
                        Date: 2019.11.08
                        Time: 02:06:44
    16777056 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_SDS_0x46 keine Kommunikation]
                        Reset counter: 131
                        Mileage: 935 km
                        Date: 2019.11.08
                        Time: 02:06:44
    16777030 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
              [BAP_TEL2_0x29 keine Kommunikation]
                        Reset counter: 131
                        Mileage: 935 km
                        Date: 2019.11.08
                        Time: 02:06:44
    16711681 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 146
                        Mileage: 5050 km
                        Date: 2019.12.14
                        Time: 12:38:14
       Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 K
       Component: STH-MQB       008 0080
       Coding: 13C1
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 3E25396890FEE377FBB-806B
       Component: R64 D208L  004 0402
       Serial number: 00000000000000827412
    0036 - Fuel Level too Low
              P1250 00 [008] - -
                        Reset counter: 113
                        Mileage: 3311 km
                        Date: 2019.12.02
                        Time: 08:11:16
                        Operating condition of parking heater: OFF
                        71
                        Coolant temperature of parking heater: 52 °C
                        Engine running status: not recognized
                        Fuel level: 7 l
                        Heater output: 0 W
       Part No SW: 3Q0 907 530 AD    HW: 3Q0 907 530 D
       Component: GW MQB EV     621 6383
       Serial number: 31081911600432
       Coding: 020900172CE21000F90052FED81D00000001070100010000000300000000
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF.rod
       VCID: 71BFD25491204C0F369-8025
       Subsystem 1 - Part No SW: 3G0 959 442 K    HW: 3G0 959 442 K
       Component: E221__MFL-PR6  H06 0110
       Serial number: PR6-0440036247190644
       Coding: 2F0B00
       Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
       Serial number: 2386941805
    131643 - Brake Booster Control Module
              U103E 00 [008] - No communication
              [Timeout Knoten 0x3B / 23 - Steuergerät für Bremskraftverstärkung]
                        Reset counter: 142
                        Mileage: 4738 km
                        Date: 2019.12.12
                        Time: 15:02:42
                        Supply voltage: Terminal 30: 12.5 V
                        Terminal 15: OFF
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
       Component: EBKV          H06 0069
       Serial number: BPA085110919013
       Coding: 0202C504340000C618638C31000049922449920400
       ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
       ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
       VCID: 3B23307C83ECF65FDC5-806F
    107024 - Unknown Error Code
              U14E4 00 [032] - -
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 19000239160017
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 3333185CABBC3E1F045-8067
       Part No SW: 3Q0 959 760 C    HW: 3Q0 959 760 D
       Component: Sitzmemory    H06 0026
       Serial number: Y0007SEO27804
       Coding: 001000020000050081C280808080000000008181000000F440
       ASAM Dataset: EV_SeatMemorDriveSide 002022
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
       Component: HRE3_Kl15_Mst H06 0149
       Serial number: 00000524837895
       Coding: 62954640
       ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
       ROD: EV_HREntryHellaGen3Kl15.rod
    2240558 - Databus
              [databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
                        Reset counter: 36
                        Mileage: 4983 km
                        Date: 2019.12.13
                        Time: 14:45:28
       Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
       Component: TSG FS002 0320
       Serial number: YE007SHG06793
       Coding: 003F1E20D200028000001000
       ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
       VCID: 49CF5AB4D93054CF5E9-801D
    Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
       Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
       Component: MQB_VWBS_GEN2 212 2211
       Serial number: 957019 00
       Coding: 0100001100410110
       Shop #: WSC 00015 115 00291
       ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
       ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
       VCID: 2B03003C738C66DF4C5-807F
       Part No SW: 3G0 035 466     HW: 3G0 035 466
       Component: AMPeth16C     H07 3027
       Serial number: A1130A00004700
       Coding: 24020000000000000000000000000000000000000000000000
       ASAM Dataset: EV_AMPEthMQB 001005
       ROD: EV_AMPEthMQB_VW48.rod
       VCID: 629DAD1844C6E797BF3-8037
       Part No SW: 3Q0 907 338 F    HW: 3Q0 907 338 F
       Component: FCM MQB High  004 0367
       Serial number: 05091911603524
       Coding: 000000070B0004CA06000F11000302040000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 003003
       ROD: EV_MultiModulContiVW48X_003.rod
       VCID: 38292F70B2DADD47317-806D
       Dedicated Short Range Communication Aerial:
       Subsystem 1 - Part No SW: 3G1 959 121     HW: 3G1 959 121
       Component: R350 NFCTGS  701 0509
       Serial number: 0000000000B34AE40005
       Antenna 2 for short-range communication:
       Subsystem 2 - Part No SW: 3G0 980 611     HW: 3G0 980 611
       Component: J524 NFCMIKO  H09 0059
       Serial number: 31900000000002860098
    13706001 - Databus
              [Kamera_FDD_Funktionsstatus_Blind received error value]
                        Reset counter: 111
                        Mileage: 3231 km
                        Date: 2019.11.30
                        Time: 14:47:51
    0034 - Fog mode active
              C118E 00 [008] - -
                        Reset counter: 111
                        Mileage: 3158 km
                        Date: 2019.11.30
                        Time: 09:08:22
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 3G0 907 080 G    HW: 3G0 907 080 G
       Component: LE Gen 3.3H17 0090
       Revision: 00H17000
       Coding: 03090000000000000000
       ASAM Dataset: EV_DMCM08530113G0907080G 001020
       ROD: EV_DMCM08530113G0907080G.rod
       VCID: 290FFA34797074CFBE9-807D
       Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
       Component: TSG BFS002 0320
       Serial number: YE007SHK3172D
       Coding: 003F1020DE00028000001000
       ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
       VCID: 48C95FB0C23AADC7417-801D
       Part No SW: 3G5 035 816     HW: 3G5 035 816
       Component: MU-O-ND-EU    H12 0152
       Serial number: VWZAZ2W1132851
       Coding: 24820000000020000000000000000000000000000000000000
       ASAM Dataset: EV_MUOIMQB 001001
       ROD: EV_MUOIMQB_VW48.rod
       VCID: 6695B108A8EE9BB753B-8033
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0526426026
       Coding: 0100000202000000
       VCID: 42DD4D98E40687979F3-8017
    656138 - Bulb for Right Tail Light on Trailer
              C10F4 15 [009] - Open or Short to Plus
                        Fault Frequency: 32
                        Reset counter: 107
                        Mileage: 2170 km
                        Date: 2019.11.18
                        Time: 19:56:52
    656394 - Bulb for Left Tail Light on Trailer
              C10F5 15 [009] - Open or Short to Plus
                        Fault Frequency: 160
                        Reset counter: 107
                        Mileage: 2170 km
                        Date: 2019.11.18
                        Time: 19:56:52
    656906 - Bulb for Left Turn Signal on Trailer
              C10F7 15 [008] - Open or Short to Plus
                        Reset counter: 148
                        Mileage: 5050 km
                        Date: 2019.12.14
                        Time: 19:53:36
       Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
       Component: Areaview 2    H13 0608
       Serial number: C854707JG060912
       Coding: 01840201E30F200000204014
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0271
       Revision: --------    Serial number: A2-C737-6291-8
       Coding: 0288
    Address 75: Telematics (J949)       Labels:* None
       Part No SW: 5WA 035 284     HW: 5WA 035 284
       Component: OCUGen3High   H20 0083
       Serial number: 0000000908VIKE1
       Coding: 024827001968A8209005460160102E07
       ASAM Dataset: EV_OCUGen3High 002115
       ROD: EV_OCUGen3High_VW37.rod
       VCID: 0353889CBB9C4E9FD45-8057
    1190912 - Ethernet Databus Branch 1
              U122C 00 [008] - No Communication
                        Reset counter: 36
                        Mileage: 5050 km
                        Date: 2019.12.14
                        Time: 12:38:15
                        Ethernet counter checksum error: branch 1: 0
                        Ethernet counter connection interruptions: branch 1: 1
    0081 - Databus
                        Reset counter: 36
                        Mileage: 2257 km
                        Date: 2019.11.19
                        Time: 15:14:31
                        Voltage terminal 30: 12.3 V
    7246 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [RemoteServices (0x4E) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                        Reset counter: 36
                        Mileage: 3148 km
                        Date: 2019.11.29
                        Time: 13:17:55
                        Voltage terminal 30: 14.8 V
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 3Q0 915 183 E    HW: 3Q0 915 183 D
       Component: J840 K8C  BMC 004 0940
       Serial number: 000000290819010
       ASAM Dataset: EV_BMCeVWBSMQB48 001007
       ROD: EV_BMCeVWBSMQB48.rod
       VCID: 34311B40AEB239271DF-8061
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 2Q0 980 653     HW: 2Q0 980 653
       Component: MQB MFK 3.0   H11 1027
       Serial number: E33417008192500
       Coding: 00000888217C4020109E10001030008000410000000000000000000000000000
       ASAM Dataset: EV_MFK3ValeoMQB 005035
       ROD: EV_MFK3ValeoMQB_005_VW38.rod
       VCID: 72BDDD5894267717CF3-8027
       Part No SW: 3G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 190702201060
       VCID: 698FBA34B9F0B4CF7E9-803D
       Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
       Component: TSG HFS004 0320
       Serial number: YE007SHC08953
       Coding: 000E10200100028000001000
       ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
       VCID: 4BC360BCD34C46DF6C5-801F
       Component: TSG HBFS004 0320
       Serial number: YE007SHC0895E
       ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 AK    HW: 5QE 915 682 AK
       Component: OBC KOSTAL    H41 4027
       Revision: --------    Serial number: 0409190I40001D
       Coding: 115069222004
       ASAM Dataset: EV_OBCSinglPhaseKLOMQB15P 001001
       ROD: EV_OBCSinglPhaseKLOMQB15P.rod
       VCID: 1675C1C8D80ECB3703B-8043
    Address D6: Light Ctrl Left 2 (A31)       Labels: None
       Part No SW: 992 941 572 CA    HW: 992 941 572 C
       Component: LED1L         H08 9002
       ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
       ROD: EV_LLPGen3LKEBODPO68X.rod
       VCID: 6491AB005ED2E9A74DF-8031
    Address D7: Light Ctrl Right 2 (A27)       Labels: None
       Component: LED1R         H08 9002
       ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
    End----------(Elapsed Time: 02:16, VBatt start/end: 14.9V/12.9V)-----------
    Dec 2016
    DE
    Unfortunately the guide you found seems to not apply for your car. Looks like it is an Audi guide(?)
    However I don’t have any information about the DQ400E in your car and if it supports a similar tweak. Have you checked the adaption channels (coding looks like the DQ250)? Could you attach an AdpMap of the Auto. Trans. module?
  3. Likes Uwe, Eric liked this post
    Dec 2019
    Sweden
    Not much here...
    02 - Auto Trans
    ;SW:0DD-300-046-E   HW:0DD-927-770-C ---  Auto Trans
    ;Component:GSG DQ400E    H32 2201, Coding:0014
    ;EV_TCMDQ400021,001001,EV_TCMDQ400021_VW37.rod
    ;Wednesday,15,January,2020,09:40:29:38248
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
    ;VCID: 2A0D05387C767FD7B73-807F
    IDE00001-Production mode,not activated ,3
    IDE02332-Deactivate production mode,00 00 00 ,3
    Dec 2016
    DE
    Oh well. Then I don't see how this is tweak is feasible...
