Hi Group,
I have a problem with the convertible top and suspect the rear latch motor. MVB 1,4 (convertible top switches II) value is 000011 when the top stops while opening (top all the way open, flaps up). VCDS has activation and basic settings greyed out. Is there a way to activate any of the components thru VCDS (maybe there is a login needed)?
Thanks for any help or info.
Wednesday,02,October,2019,14:10:47:57829
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
Chassis Type: 1Y - VW New Beetle Cab (2003 > 2010)
Address 01: Engine Labels: 06A-906-032-AWV.lbl
Part No: 06A 906 032 PS
Component: 1.8l 5VT NBC AG6G 5107
Coding: 00004
Shop #: WSC 00066
VCID: FEB0A491F81610BF6B-513C
3VWCD31Y84M316494 VWZ5Z0C7137175
16825 - EVAP Emission Control Sys
P0441 - 35-10 - Incorrect Flow - Intermittent
Part No: 09G 927 750 P
Component: AQ 250 6F 0387
Coding: 0000008
VCID: BE306491E896D0BF2B-513C
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00066 000 00000
VCID: B42446B9D6DA0AEFCD-5160
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 AF
Component: 05 AIRBAG VW71 0509
Coding: 0012341
VCID: FBB6AD85BB0405974C-513C
Subsystem 1 - Part No: 1C0 959 339
Component: BF-Gewichtsens. 004 0004
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00006
Shop #: WSC 00066
VCID: F0AC8AA9B24276CFE9-4B00
Address 26: Auto Roof Labels: 1Y0-959-255-HYD.lbl
Part No: 1Y0 959 255
Component: VSG NBC ь
VCID: FDB2A39DA5100BA772-513C
02000 - Switch Position
02460 - Position Sensor for Left Linkage Flap Position Sensor (G442)
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 G
Component: 6J Komfortgerбt HLO 0004
Coding: 00256
Shop #: WSC 00066
VCID: BB366D85AB84C5970C-4B00
Subsystem 1 - Part No: 1Y1959801
Component: 6J Tхrsteuer.FS KLO 0001
Subsystem 2 - Part No: 1Y1959802A
Component: 6J Tхrsteuer.BF KLO 0001
Subsystem 3 - Part No: 1Y0959811
Component: Tхrsteuer.HL KLO 0005
Subsystem 4 - Part No: 1Y0959812
Component: 6J Tхrsteuer.HR KLO 0001
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 157 D
Component: Radio DE2 0006
Coding: 06031
Shop #: WSC 00066
VCID: 9D72831D1550ABA712-51CE
End----------(Elapsed Time: 03:55, VBatt start/end: 14.1V/14.1V)-----------
