Results 1 to 4 of 4
Thread: 2004 Beetle Convertible Actuation 1Y
    Nov 2015
    Question 2004 Beetle Convertible Actuation 1Y
    Hi Group,
    I have a problem with the convertible top and suspect the rear latch motor. MVB 1,4 (convertible top switches II) value is 000011 when the top stops while opening (top all the way open, flaps up). VCDS has activation and basic settings greyed out. Is there a way to activate any of the components thru VCDS (maybe there is a login needed)?
    Thanks for any help or info.
    Wednesday,02,October,2019,14:10:47:57829
    Chassis Type: 1Y - VW New Beetle Cab (2003 > 2010)
    Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
    Address 01: Engine        Labels: 06A-906-032-AWV.lbl
       Part No: 06A 906 032 PS
       Component: 1.8l 5VT NBC AG6G   5107
       Coding: 00004
       Shop #: WSC 00066
       VCID: FEB0A491F81610BF6B-513C
       3VWCD31Y84M316494     VWZ5Z0C7137175
    16825 - EVAP Emission Control Sys
                P0441 - 35-10 - Incorrect Flow - Intermittent
       Part No: 09G 927 750 P
       Component: AQ 250 6F           0387
       Coding: 0000008
       VCID: BE306491E896D0BF2B-513C
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0019970
       VCID: B42446B9D6DA0AEFCD-5160
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No: 6Q0 909 605 AF
       Component: 05 AIRBAG VW71      0509
       Coding: 0012341
       VCID: FBB6AD85BB0405974C-513C
       Subsystem 1 - Part No: 1C0 959 339
       Component: BF-Gewichtsens. 004 0004
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V022
       Coding: 00006
       Shop #: WSC 00066
       VCID: F0AC8AA9B24276CFE9-4B00
    Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
       Part No: 1Y0 959 255
       Component:  VSG  NBC       ь
       VCID: FDB2A39DA5100BA772-513C
    02000 - Switch Position
    02460 - Position Sensor for Left Linkage Flap Position Sensor (G442)
       Part No: 1C0 959 799 G
       Component: 6J Komfortgerбt HLO 0004
       Coding: 00256
       Shop #: WSC 00066
       VCID: BB366D85AB84C5970C-4B00
       Subsystem 1 - Part No: 1Y1959801
       Component: 6J Tхrsteuer.FS KLO 0001
       Subsystem 2 - Part No: 1Y1959802A
       Component: 6J Tхrsteuer.BF KLO 0001
       Subsystem 3 - Part No: 1Y0959811
       Component: Tхrsteuer.HL KLO 0005
       Subsystem 4 - Part No: 1Y0959812
       Component: 6J Tхrsteuer.HR KLO 0001
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1C0 035 157 D
       Component:  Radio DE2         0006
       Coding: 06031
       Shop #: WSC 00066
       VCID: 9D72831D1550ABA712-51CE
    End----------(Elapsed Time: 03:55, VBatt start/end: 14.1V/14.1V)-----------
    16.4905 S, 151.7375 W
    The [Output tests] is what is typically used to 'activate' certain components and the [26-Auto Roof] of the 2004 NB Convertible does not appear to support the [Output tests].
    Just in case you have not seen this, we have a Ross-Tech wiki page for the VW Beetle (1Y) Roof Electronics and a video that may help as well, when attempting to diagnose these vehicles.
    New Beetle Convertible Top - (video link)
    Hope this helps,
    drpeter
  3. Likes Uwe, Shzeps, Jack@European_Parts liked this post
    HQ
    You've got issues with one of this:
    There is a left and right side versions of these. When you open the top, this is the mech that secures the top once fully opened. Each of these mechs have 2 micro switches to let the Roof Electronics know if said mech is locked/unlocked (closed/open) position.
    With 26-08-001.4 reading 000011, the left side mech, has a sticking switch, so the mech is reporting both open and closed at the same time... not good. Officially, you replace the whole left side unit. Off the record, 99.9% chance it is just needing the microswitches replaced... but they dealer can't purchase those as separate items. I'm sure some one, somewhere, has figured out a Digikey part number replacement.... but I'm not that person.
    Jef
    Nov 2015
    Thanks for the replies. I was also thinking that I had a latch issue however the only way I was going to check the harness and prove there is a latch motor failure was to test at the control unit (located in the RR of the luggage compartment). When I disconnected the harness it was obvious that there was water damage and corrosion. I found my problem.
  6. Likes Jack@European_Parts, Uwe liked this post
