2016 Audi A6 2.0T - transmission fluid pump control module feedback error
vietdtran
Orange CA, USA
C?ID=392034
Hi Brain Trust,
I purchased used Audi A6 and the check engine light error transmission fluid pump control module feedback show up after a couple weeks. I cleared the error code once but it came back again. Could someone tell me where I should look to correct this problem? This Audi comes with a 7 speed S-tronic DSG gearbox and the initial investigation show it was never been serviced. I am planning to perform a trans fluid drain and replace. See complete scan below. Any help would be appreciative.
20759 - Control Circuit for Aux. Trans. Fluid Pump
Sunday,12,January,2020,14:06:35:15065
VIN: WAUCFAFC2GN008520   License Plate: AUDI2016-SCAN
Mileage: 181255km-112626mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3B 42 44 46 52 53 5F 62 72
          8F 90
VIN: WAUCFAFC2GN008520   Mileage: 181255km-112626miles
Address 01: Engine (J623-CYNB)       Labels: None
   Part No SW: 4G5 907 115 A    HW: 8T2 907 115
   Revision: --H13---
   Coding: 0A2500122424010E2002
   ASAM Dataset: EV_ECM20TFS0204G5907115A 001003
   ROD: EV_ECM20TFS0204G5907115A.rod
   VCID: 2809FF598270B6D7A17-807C
15329 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [040] - -
                    Mileage: 181238 km
                    Date: 2020.01.05
                    Time: 16:05:33
                    Engine speed: 918.50 /min
                    Normed load value: 14.1 %
                    Coolant temperature: 100 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 11.835 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 1 s
                    MAP_MES_SAE: 27 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 12.109375 %
                    FUP_H_SAE: 6660.0 kPa
   Part No SW: 4G0 927 153 K    HW: 0CK 927 156 Q
   Component: 0CK 20TFSINAR H01 0002
   Revision: --H01---    Serial number: 0000000042
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002017
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 313F123DB1AAF71F769-8064
          P0C2C 00 [040] - Feedback Signal Implausible
                    Fault Frequency: 132
                    Mileage: 181177 km
                    Date: 2019.12.20
                    Time: 13:43:29
                    Engine speed: 790 /min
                    Driving position: d
                    Transmission fluid temperature: 61 °C
                    Transmission output speed: 56 /min
                    Voltage terminal 30: 13.9 V
                    Engine torque: 12 Nm
                    selected gear: 2
                    Ctrl. mod.: operating condition: regular operation
                    Auxiliary pump for transmission: requesting function: Fill hydraulic press. accum.
                    Auxiliary hydraulic pump for transmission oil: current: 19 A
                    Oil pressure reservoir: pressure: 24.4 bar
                    Pressure of clutch 1: actual value: 2.4 bar
                    Pressure of clutch 2: actual value: 2.7 bar
                    Clutch status: Creeping
                    Occurrence_counter_over_length_of_life: 255
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 41A29641824569821B00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDB440577FE116FF0D-806A
161280 - Tire Pressure Warning
          C102D 00 [040] - -
                    Fault Frequency: 128
                    Mileage: 179751 km
                    Date: 2019.11.01
                    Time: 14:21:00
                    VzRef: 3C
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    Uz: B9
                    Unlearning counter according OBD: 24
161792 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 4H0 907 064 FC    HW: 4H0 907 064 EC
   Component: BCM2 2.0      H36 0560
   Coding: 09A8704E000000000000
   VCID: 6FBBD445679EA1EF20D-803A
   Serial number: 3214000170942002
   Part No SW: 4G0 820 043 BP    HW: 4G0 820 043 BP
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 11021500111952
   Coding: 64813018490000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 6E85C9416014A8E72BB-803A
   Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
   Revision: 21020001    Serial number: 00001005079902
   Coding: 26000091063C9FE08100488380003D0CCF9CD208A6090221000004207100140200600000030000
   VCID: 76B5E12118C49027E3B-8022
   Component: WWS57X 150125  H37 0080
   Serial number:         150203170336
   Coding: 0045F7
   Serial number: 23729634
   Coding: 02006D
   Component: E1 - LDS  H07 0044
   Serial number: 09 02 2015  00000959
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01E238F9
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Serial number: 4D584197000000000001
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0001WJB$
   Coding: 303331343134303334374A55304C34473053
   VCID: 34311B294EB8C2371DF-8060
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y150001AMWT0O
   Serial number: 3575HRB40692RDNQ4HPG
   Serial number: 3585HRB405133PKMAOR5
   Serial number: 3515JRB40145358SB1CO
   Serial number: 3525JRB40165358SJ8D0
   Serial number: 3554VRB400K53406I1GY
   Serial number: 3564VRB400Q53406JI33
   Revision: --------    Serial number: 90372OBC0001H
   Coding: 000434
   VCID: 38292F1952502657317-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 20 01 2015  10058458
   Part No SW: 4G8 920 951 B    HW: 4G8 920 951 B
   Component: MBenUsa       H43 0506
   Revision: 28450303    Serial number: 658110215592021
   Coding: 0BE609040B41D705020000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: 2F3B1445A79EE1EF60D-807A
   Part No SW: 4G0 907 468 AE    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001731094
   Coding: C0CD072910
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 73B3D8350B36850FC45-8026
   Serial number: 8440185803
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 1412070000000000022D
   Revision: AA000000    Serial number: 00000135497886
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77ABEC251FCEE92FF8D-8022
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720FVZMK
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 333318354BB6C50F045-8066
   Coding: 011F17014E00628002000002
   VCID: 47CB5CE52FAE59AF48D-8012
   Component: RCevo         H55 0202
   Revision: 00000002    Serial number: 0000184010
   Coding: 101000010001
   Shop #: WSC 04391 003 1048576
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D35116CDC3447C73-806E
   Revision: 00002001    Serial number: 0358707880
   Coding: 0106063A00FA400480B0080402050E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000274083
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST00053DG100000
   Coding: 101F02
   VCID: 46D551E128A440A7B3B-8012
   Revision: --------    Serial number: 00000001365068
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070E4DAD9293FF521-8078
   Part No SW: 4G1 035 187 A    HW: 4G1 035 187 A
   Component: RMC Cnct Sir  H61 0139
   Coding: 0100000001C0D94F400B040302010000000000
   VCID: 2517F66DF5E2ABBF9A1-8070
   Subsystem 1 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464BV0F2703490
   Subsystem 2 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
   Serial number: 90349OBA000L6
02617 - Satellite Antenna (R170)
                    Fault Status: 00101011
                    Fault Frequency: 9
                    Reset counter: 126
                    Mileage: 180201 km
                    Date: 2019.11.13
                    Time: 08:47:27
                    Voltage: 14.50 V
                    Reset counter: 103
                    Mileage: 181255 km
                    Date: 2020.01.12
                    Time: 13:58:30
                    Bin. Bits: 00000000 00000001
                    Bin. Bits: 00000000 00000000
   VCID: 49CF5ADD39BAAFDF5E9-801C
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D1D31B4ACCC070F3-8066
End----(Elapsed Time: 01:46, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
VCDS Release 19.6.2:  SRI Reset-SRI1.CLB
Control Module Part Number: 4G8 920 951 B       Labels:  .*4H0-920-xxx-17.clb-SRI1
Component:MBenUsa       H43 0506, Coding:0BE609040B41D705020000
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	no warning                                                  	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	100 km                                                      	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	22 Days                                                     	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	poor oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	0 km                                                        	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	200 km                                                      	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	16100 km                                                    	---
IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 Days                                                    	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	16100 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	365 Days                                                    	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	95600 km                                                    	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	928 Days                                                    	---
Operation: Reset ESI / OIL,(North America) or (Rest of World second service and later)
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	no warning                                                  	0
Address 17,4G8 920 951 B,channel IDE00342-ESI: Resetting ESI,adapted from,no warning ,to,Reset ,
Address 17,4G8 920 951 B,channel IDE03349-FIX: Max. distance until next mileage-related inspection,adapted from,16100 km,to,187840 km,
Address 17,4G8 920 951 B,channel IDE00515-ESI: oil quality,adapted from,poor oil quality ,to,good oil quality ,
Address 17,4G8 920 951 B,channel IDE01153-SIA: maximum value of distance to service,adapted from,16100 km,to,187840 km,
Address 17,4G8 920 951 B,channel IDE03351-FIX: Distance covered since last mileage-dependent inspection,adapted from,95600 km,to,179840 km,
Address 17,4G8 920 951 B,channel IDE03352-FIX: Time since last time-dependent inspection,adapted from,928 Days,to,30 Days,
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	Reset                                                       	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	0 km                                                        	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	0 Days                                                      	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	good oil quality                                            	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	0 km                                                        	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	187800 km                                                   	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	187800 km                                                   	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	179800 km                                                   	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	30 Days                                                     	---
Address 17,4G8 920 951 B,channel IDE00510-ESI: distance driven from inspection,adapted from,0 km,to,100 km,
Address 17,4G8 920 951 B,channel IDE00511-ESI: time from inspection,adapted from,0 Days,to,365 Days,
Address 17,4G8 920 951 B,channel IDE00510-ESI: distance driven from inspection,adapted from,100 km,to,0 km,
DrPeter
16.4905° S, 151.7375° W
It would appear that there could be a Software update for this fault code in some markets.
The J217's software version is at [0002], there could be a new version of [0005] or higher as per a TSB from the ROW market. I do not see one with Audi NAR, so you may want to check with your local dealer or Audi Customer Care. Also there does not appear to be any Recalls or Service Campaigns as per Audi.
Personally, I would clear the fault codes, see if it comes back and if so see if there is any software update for the J217-Transmission Controller.
Oh, yea, I would also use the Official Factory Repair manuals when working on these vehicles.
Hope this helps,
drpeter
[h=2]2016 Audi A6 2.0T - transmission fluid pump control module feedback error[/h]
Hi Brain Trust,
20759 - Control Circuit for Aux. Trans. Fluid Pump​
Did they just forget about us again, hmmm things like this make me wonder why the world is what it "is"? :rolleyes:
Auxiliary hydraulic fluid pump "is" pretty important!
I wouldn't just clear the DTC and use a wait and see approach for the additional "heat" either, would you really?
.......... faults came to trigger an MIL oh yeah they were?...............
Confirmed
That is like waiting to do a water pump that sometimes spins the impeller on the shaft & only until the day is so dam cold you get no heat or it is hot and you blow the engine! :banghead:
I'd log the temps instead & if a firmware update was available, I'd still check the temps reported with an actual temp gauge too & just to verify if I needed a larger cooler or sump, I mean hell we already have a second pump right OP?
You could always get ready for this dog pile too in below NHTSA link!
https://static.nhtsa.gov/odi/tsbs/2018/MC-10144635-9999.pdf
And why do you think the sender fails, oh I wonder? :popcorn:
