Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Auto-Scan Hangs at 52%
    Jan 2020
    Canada
    Exclamation Auto-Scan Hangs at 52%
    I'm unable to get Auto-Scan to complete past 52% or address 1C on my 2009 Touareg 3.0L TDI Highline (Canadian). I've tried from different devices, though all Safari. I can enter all the other modules and view/clear faults, so I do not believe it to be a vehicle problem, but I know nothing about that.
    Screenshot of the problem and the version info:
    VCDS Mobile 0.4508.0.4
    VIN: WVGDM67L49D036476
    Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 36 46 47 55 56 68 69
    	 6D 6E 76
    68-Wiper Electr. -- Status: OK 0000
    6E-Ctrl Head Roof -- Status: OK 0000
    Address 01: Engine	Labels: 059-907-401-CAT1.clb
    	Part No SW: 7L0 907 401 T	HW: 7L0907401K
    	Component: 3.0TDI FSA  G004AG   0140
    	Revision: 33H01---	Serial Number: VWX3Z0I2844357
    	Coding: 0421002A590F0968
    	Shop #: WSC 64005 002 1048576
    	VCID: 3C3BA7F37654B637F74A0B-5184
    008871 - NOx Sensor 2 Bank 1; Heating Circuit
    	P22A7 - 000 - Implausible Signal - MIL ON
    008705 - NOx Sensor 1 Bank 1
    	P2201 - 004 - Implausible Signal - Intermittent
    001025 - EGR System
    	P0401 - 000 - Insufficient Flow - Intermittent
    053285 - Please Check Fault Codes in Control Module for HVAC (J301)
    	U1025 - 003 - Mechanical Failure - Intermittent
    009231 - Exhaust Gas Recirculation System
    	P240F - 000 - Response too Slow - Intermittent
    008862 - NOx Sensor 2 Bank 1
    	P229E - 001 - Electrical Malfunction - Intermittent
    Address 02: Auto Trans	Labels: 09D-927-750.lbl
    	Part No SW: 09D 927 750 HN	HW: 09D927750HN
    	Component: AL 750 6A            3403
    	Revision: 00H75000	Serial Number:
    	Coding: 0004984
    	VCID: 81459607D1369BDF641C12-5160
    No fault codes found.
    Address 03: ABS Brakes	Labels: 7L0-907-379-MK25E1.clb
    	Part No SW: 7L0 907 379 P	HW: 7L0614517C
    	Component: ESP ALLRAD MK25E1    0304
    	Revision: 00H53001
    	Coding: 0004354
    	Shop #: WSC 31414 790 00001
    	VCID: 46CFC51B3898F9E791AE99-8013
    Address 05: Acc/Start Auth.	Labels: None
    	Part No SW: 7L0 909 135 C	HW: 7L0909135C
    	Component:    Kessy             6850
    	Revision: 00H22072	Serial Number: VWX3Z0I2844357
    	Coding: 0000232
    	VCID: 312586C7A1164E5F54FC82-8064
    	Subsystem 1 - 	Part No SW: XXX-XXX-XXX-XX
    	Component: ELV                  XXXX
    Address 08: Auto HVAC	Labels: 7L6-907-040.clb
    	Part No SW: 7L6 907 040 AL
    	Component: CLIMAtronic R/L      4537
    	Coding: 0003030
    	VCID: 7AB761EB3CE04D07A5D6DD-802F
    Address 09: Cent. Elect.	Labels: 7Lx-937-049-V2.clb
    	Part No SW: 7L6 937 049 AF	HW: 7L6937049AF
    	Component: 2004J519
    	Serial Number: --------------
    	Shop #: WSC 00000 000
    	VCID: 80439303DA3C97D76B121F-80D5
    Address 0F: Digital Radio	Labels: 8E0-035-593-SIR.lbl
    	Part No SW: 8E0 035 593 M	HW: 8E0035593M
    	Component: SDAR SIRIUS     H07  0150
    	Revision: 00000000	Serial Number: AUZ4Z7I0515345
    	Coding: 0000102
    	VCID: 33298CCF5B0A784F2610A8-8066
    00003 - Control Module
    	000 -  -
    Address 15: Airbags	Labels: 7L0-959-655.lbl
    	Part No SW: 7L0 959 655	HW: 7L0959655
    	Component: J234__3V VW8T        0250
    	Revision: 92012025	Serial Number: 0039P007688N
    	Coding: 0013142
    	VCID: FAB7E1EBBCE0CD0725D65D-80AF
    Address 16: Steering wheel	Labels: 7L6-953-549.lbl
    	Part No SW: 7L6 953 549 G
    	Component: J527                 3601
    	Coding: 0010211
    	VCID: 43C9DC0F0BAACCCFB6B078-8016
    Address 17: Instruments	Labels: 7L6-920-xxx-7L6.lbl
    	Part No SW: 7L6 920 876 BX	HW: 7L6920876BX
    	Component: J285 KOMBI-INST.     9833
    	Revision: KHH05V46
    	Coding: 0007301
    	Shop #: WSC 45338 001 1048576
    	VCID: 9369AC4FBB4A184FC6D0C8-80C6
    Address 19: CAN Gateway	Labels: 6N0-909-901-19.lbl
    	Part No SW: 6N0 909 901	HW: 7L6920876BX
    	Component: J533  GW-K-CAN TP20  9833
    	Coding: 77E2EF9B63066002
    	VCID: F0A3C3C3EA9C83579B72CF-80A5
    Address 1C: Position Sensing	Labels: 7L6-919-879.lbl
    	Part No SW: 7L6 919 879 B	HW: 7L6919879B
    	Component: Kompass         001  0001
    	Revision: 00001000	Serial Number: 1439802T14V502
    	VCID: 46CFC51B3898FDE791AE99-8013
    What can I do to further troubleshoot this?
    Thank you,
    A.
    N.B. I do not have easy access to a Windows PC.
  2. Likes Dana liked this post
  3. #2
    United States
    Hi Adam,
    If possible, please try using VCDS on a PC via USB -and- NET at some point. Doing so would help rule out the possibility that something vehicle side could be misbehaving.
    Next, I switched your interface to the Beta channel. The next time you check for updates, VCDS-Mobile should download:
    CB to update from 0.4508 to 0.4513;
    DS to update from 0x55 to 0x57;
    If you power the interface via USB wire it can be update it in the house (rather than under the dash at the OBD2 connector) using VCDS-Mobile.
    Lastly, if the results are identical with the newest CB installed please try using AP mode. The interface wouldn't have internet access in AP mode but it isn't necessary as long as you aren't attempting to save the file to the cloud. Using AP mode would help rule out hotspot or router issues because the phone is connecting directly to your HEX-NET.
  4. Likes carbon60, Uwe liked this post
  5. #3
    Jan 2020
    Canada
    Hi Adam,
    Hi Dana,
    I updated and re-ran auto-scan in infrastructure (with Internet access) and AP mode: no difference in behaviour.
    How long should I wait for it before assuming it has hung?
    Here is the current info:
    I noticed that the messages that appear in this location as the unit scans modules completely stop after saying, I believe, something about 22:
    Not sure if that is relevant.
    What's next?
  6. Likes Dana liked this post
  7. #4
    Looks like it's finished with 1C and hanging on 22? Do you see "Trying 22-AWD" or something close to that just before it hangs?
    If it doesn't talk to a module within one minute or so, it isn't going to.
    Since we no longer have a Touareg of that vintage to test on, we'll need Shaun to chime in here with instructions to generate a debug file.
  8. Likes Dana, gawied liked this post
  9. #5
    Jan 2020
    Canada
    I think that it indeed was trying 22 before hanging. I can attempt to catch it, if that will help troubleshoot, let me know.
    I'll wait for Shaun's instructions.
    A.
  10. Likes gawied liked this post
  11. #6
    Jan 2020
    Canada
    So, Shaun, what are the debug instructions?
  12. #7
    What do the led's do when it starts trying 22, does it look like it resets? You can try making a debug log by entering debug level 001F on the options screen before you start the scan, but if the interface is resetting that is not going to help us here. Be sure any debug logs it makes are uploaded to the cloud, so we can see them. Feel free to post the doc id's here.
  13. Likes Uwe liked this post
  14. #8
    Jan 2020
    Canada
    How do I know if it is resetting? What should the LEDs be doing/not doing? I don't have enough experience with this to know what is normal.
    Thanks,
    A.
  15. #9
    Do the two leds by the button turn off for a second?
  16. Likes Dana liked this post
  17. #10
    Jan 2020
    Canada
    So, the two LEDs near the button. The outer LED flashes through different colors during the scan. The inner LED seemed to be solid the entire time, except for a very brief blink, maybe. (This is in infrastructure mode.)
    Note that when I first logged in today, a dataset update was available, but I was unable to download more than 6 kB of it.
    I enabled debug log, and have the .edl file, but was unable to upload it in the interface. How else can I provide it to you for analysis?
