Hello. Is there any options to get boost pressure on radio screen? I know that in MK7 R there is "sport" menu, like "offroad" menu. But is there possible to code the "sport" menu to Ocravia MKIII?
Thanks!
Thanks!
Sunday,22,December,2019,16:55:30:19148
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Workshop Code: 358 14250 022663
VIN: TMBJK7NE2F0065601 License Plate: NJN-459
Mileage: 225476km-140104mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 20 2B 42 44 52 55 5F
69 6D A9
VIN: TMBJK7NE2F0065601 Mileage: 225476km-140104miles
Address 01: Engine (J623-CUPA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 EM HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7543
Revision: 83H22---
Coding: 111D001A047401081000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM20TDI01104L906021EM 002008
ROD: EV_ECM20TDI01104L906021EM.rod
VCID: 74B1DCC73E3F8367DDF-8020
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 225476 km
Date: 2019.12.21
Time: 00:00:56
Coolant temperature: 6 °C
Intake air temperature: 6 °C
Voltage terminal 30: 11.340 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
17161 - Databus
4814 - System Voltage
P0562 00 [032] - Too Low
Fault Frequency: 12
Mileage: 225436 km
Time: 00:00:00
Coolant temperature: 7 °C
Voltage terminal 30: 5.720 V
Limitation: torque: 0.0 Nm
Limitation: accelerator pedal: 126.6 Nm
Cruise Control System (CCS): status-Bits 0-7: 1
Accelerator pedal travel: raw value: 0.00 %
Engine torque: -500.0 Nm
Generator: load signal: 0.02 %
U0428 00 [039] - -
Mileage: 225476 km
Date: 2019.12.21
Time: 00:00:55
Voltage terminal 30: 11.360 V
4631 - ECM Power Relay Load Circuit
P068B 00 [237] - Opens Too Late
Time: 00:00:00
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
Readiness: 1 1 0 0 0
Part No SW: 0D9 300 041 Q HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4504
Revision: 05853104 Serial number: TFK01407291104
ROD: EV_TCMDQ250021.rod
VCID: 2615F68FB863A1F793B-8072
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 62214000000626
Coding: 1C076B9154260971007D060041C42938D62A9000608294F4F6615070C009
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100IPB_033_SK37.rod
VCID: 46D5560F182341F7B3B-8012
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 42
Mileage: 225476 km
Date: 2019.12.21
Time: 00:00:56
Reset counter: 42
Mileage: 225476 km
Date: 2019.12.21
Time: 00:01:08
Revision: 00021000 Serial number: 0342136735
Coding: 030C0C
Shop #: WSC 73430 790 00000
VCID: 3A2D32FF5CDB3517C73-806E
65813 - Supply voltage
Reset counter: 81
Time: 00:00:00
Part No SW: 5E0 907 044 P HW: 5E0 907 044 P
Component: Climatronic H03 0907
Revision: 00001K06
Coding: 02010104004101011005000100101000
VCID: 323D1ADF84ABCD570F3-8066
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [008] - Open or Short to Plus
Reset counter: 64
Mileage: 223028 km
Date: 2019.11.23
Time: 10:14:40
Voltage terminal 30: 11.3 V
Outside air temperature: 0.5 °C
Interior temperature: 4.4 °C
Right temperature flap: actual value: 240
Right temperature flap: actual value: 100.0 %
Right temperature flap: specified value: 235
B10CD 00 [008] - -
Reset counter: 81
Mileage: 225436 km
Date: 2019.12.21
Time: 13:37:37
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86582208140390
Coding: 0C531B76C24722FB4FE44004001C17280C00000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
ROD: EV_BCMBOSCH_013.rod
VCID: 79AFEDF3195DFE0F8E9-802C
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140721 041 0570
Serial number: 140731004426
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y14M08D14H04M32S18
Coding: 00885D
Sun Roof:
Subsystem 3 - Part No SW: 5E9 959 591 HW: 7P0 959 591 B
Component: J245 PS24.011 H01 0008
Serial number: WOO3085421/
Coding: 991800
Roof Blind:
Subsystem 4 - Part No SW: 5E9 959 591 A HW: 7P0 959 591 C
Component: J394 PS24.011 H01 0008
Serial number: WOO31045533
Coding: 991800
7 Faults Found:
131330 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten >]
Reset counter: 81
Mileage: 225436 km
Date: 2019.12.21
Time: 00:00:00
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
Reset counter: 82
Mileage: 225476 km
Date: 2019.12.21
Time: 00:01:00
919560 - Light Switch
B126A 29 [136] - Signal Implausible
Reset counter: 81
Mileage: 225436 km
Date: 2019.12.21
Time: 00:00:18
5898 - Bulb for Rear Left Side Turn Signal
B12D0 15 [008] - Open or Short to Plus
10762 - Bulb for Right Tail Light
B12BF 15 [008] - Open or Short to Plus
204290 - Remote key 1
B1479 18 [008] - Current Too Low
203016 - Unlock Switch in Rear Lid Handle
B140B 29 [008] - Signal Implausible
Reset counter: 81
Mileage: 225436 km
Date: 2019.12.21
Time: 00:01:19
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331420902316
Coding: 0071051151
Shop #: WSC 73430 790 00063
VCID: 3D2739E34DF5022FE21-8068
13637426 - Databus
Reset counter: 42
Mileage: 225476 km
Date: 2019.12.21
Time: 00:00:56
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 26081504402246
Coding: 000C1A00FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 42
Mileage: 225476 km
Date: 2019.12.21
Time: 00:00:56
Control Module temperature: 6 °C
Voltage terminal 15: 11.2 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 42
Mileage: 225476 km
Date: 2019.12.21
Time: 00:00:56
Voltage terminal 15: 11.1 V
1078 - Databus
[FAULT_CIS_SAS_INIT]
Reset counter: 42
Mileage: 225476 km
Date: 2019.12.21
Time: 00:00:57
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 42
Mileage: 225476 km
Date: 2019.12.21
Time: 00:00:56
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4PFA2WA/
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5B03EB0779D03FB0D-802A
Subsystem 1 - Part No SW: ----------- HW: 454 002 207 14
Serial number: 3576U00000075B553012
Subsystem 2 - Part No SW: ----------- HW: 454 002 207 14
Serial number: 3586U000000DC555301A
Subsystem 3 - Part No SW: ----------- HW: 454 801 607 14
Component: SideSensor_Dr 111 0148
Serial number: 3516RACC61B04000000C
Subsystem 4 - Part No SW: ----------- HW: 454 800 107 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R47882204000000Z
Subsystem 5 - Part No SW: ----------- HW: 454 801 906 14
Component: FrontSensor_D 114 0149
Serial number: 3556V1796F2030000007
Part No SW: 5Q0 953 507 EJ HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 17081404400831
Coding: 6C10
VCID: 025D8A1F748BBDD7DF3-8056
Part No SW: 5E0 920 757 HW: 5E0 920 757
Component: KOMBI 304 4270
Coding: 07AD09182D80000801886A011000000000000000
VCID: 6889B8B772F77787617-803C
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: 9309
VCID: 363526CF68C3D17723B-8062
Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
Serial number: 00000000000000920153
0373 - Supply voltage
[SUPPLY VOLTAGE TO LOW]
Reset counter: 81
Time: 00:00:00
Operating condition of parking heater: System malfunction
71
Coolant temperature of parking heater: 7 °C
Engine running status: not recognized
Fuel level: 12 l
Heater output: 0 W
0375 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[DYSFUNCTION BY UNDERVOLTAGE]
Reset counter: 81
Mileage: 225436 km
Operating condition of parking heater: OFF
71
Coolant temperature of parking heater: 0 °C
Fuel level: 12 l
Heater output: 0 W
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002342305
Coding: 030100340F087300EF00027A1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_011.rod
VCID: 42DD4A1F340B7DD79F3-8016
Subsystem 2 - Part No SW: 5E0 919 719 B HW: 5E0 919 719 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A1488150714
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 0246694103
1282 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
Reset counter: 81
Time: 00:00:00
Supply voltage: Terminal 30: 6.0 V
Terminal 15: OFF
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02018F6B74745D545420363E01
VCID: 2B0307BBA3819C9F4C5-807E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000201589005
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311CC77EBFC3671DF-8060
U1400 00 [008] - -
[Under voltage (temporary)]
Reset counter: 81
Time: 00:00:00
ELV State: 02
Information Clamps: 00 08
CoCo State: E0 01
WFS State: 00 06
Vehicle speed: 655.34 km/h
Voltage: 3B
AD-Value H-bridge: 1D
Clamp15 flip flop: SSTx: button contacts: 09
CAN signals: 05
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000112219580
Coding: 001D0920D000040000001100
VCID: 44D14C072E1F73E7ADF-8010
Serial number: 00000000000003478097
Coding: 010200
65548 - Supply voltage
Reset counter: 81
Mileage: 225436 km
Date: 2019.12.21
Time: 00:17:48
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5063
Coding: 8103
Shop #: WSC 39896 001 1048576
VCID: 392F2DF359DD3E0FCE9-806C
16130 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Reset counter: 0
Motor status: 00
Supply voltage: 12.00 V
Temperature: 5.0 °C
KFC: 3F
KFA: 00 02
Environmental conditions: 5F
uioUdNotFilt_xdu16: 11.94 V
uAdSensI_SwitchedKl30_xdu16: 11.94 V
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000112434662
Coding: 001D0120D000040000001100
VCID: 43D34F1B2B1174DF945-8016
Serial number: 00000000000003471450
Coding: 190200
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 03DA02003F000000
VCID: 40D940173A076FC7897-8014
Subsystem 1 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H06 0009
Coding: 3E0000
Subsystem 2 - Part No SW: 1T0 941 329 B HW: 1T0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H06 0009
Coding: 3E0000
Address 5F: Information Electr. (J794) Labels:| 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 864 A HW: 5E0 035 864 A
Component: MU-S-N-ER 041 0435
Serial number: S3F00708140855
Coding: 037352010000000011110002000800002F0001A40100010046
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 2517F183C565AAEF9A1-8070
Subsystem 1 - Part No SW: 5E0 919 605 D HW: 5E0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: SKZ8Z9PT3008ZS
Subsystem 2 - Part No SW: 5E0 051 236 HW: -----------
Component: ECE 2016/17 --- 0059
1539 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to insufficient voltage - lower limit value not reached]
Reset counter: 81
Mileage: 225436 km
Date: 2019.12.21
Time: 14:40:15
Voltage terminal 30: 6.0 V
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 E HW: 5Q0 907 383 B
Component: Anhaenger H14 0137
Revision: 8C001001 Serial number: 0342633496
Coding: 0100000202000000
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 5E0 959 107 A HW: 5E0 959 107
Component: HDSG-Modul H01 0746
Revision: 42001001 Serial number: 193400626
Coding: 1233074003
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462_SK37.rod
VCID: 2A0D02BFAC7B8597B73-807E
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5E0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 140628200119
VCID: 698FBDB369FD4E8F7E9-803C
End----------(Elapsed Time: 01:56, VBatt start/end: 15.0V/14.8V)-----------
