Results 1 to 5 of 5
Thread: Old VW lupo airbag module issues ?
    Nov 2018
    Ireland
    Howdy Folks,
    looking at an old 2002 VW Lupo with an airbag module issue. The original module was water damaged and showing 65535 and other hardware fault codes, so a second hand module with same part no. 1C0 909 601 but different index no. (02 vs. original 04) was sourced. With this module, all faults were cleared except a new one appeared - 01299 - Diagnostic Interface for Data Bus (J533) 49-00 - No Communications. So the wiring was checked and the CAN bus was present at the connector, however there is very little activity on the bus when checked with a 'scope - apart from what looks like a request packet every few seconds. With the old airbag module back in, there is no activity on the bus at all. So it looks like the replacement airbag module is actually generating the request, and since there is no activity after that, it looks like its not getting an answer from any other control module. Now this car is very basic, and actually the only items physically on the CAN bus are the engine ECU, the instruments and the airbag module (the car has no ABS). And the gateway (J533) is part of the cluster. The cluster receives all of its signals via hardwired connections, so it looks like it would not need CAN for the engine, and the airbag module itself has a hardwired connection for the dash warning lamp and crash signal. so it would not need CAN either (proven by disconnecting the CAN wires from the cluster). all modules have diagnostics via the K-line to pin 7 of the diag connector.
    The coding of the two airbag modules is different, and I cannot change the coding on the replacement airbag module to match the old one - in VCDS it looks like the coding is accepted (the coding window disappears - no error message) but the coding remains the same. Also, I couldn't find any information on the coding of these modules. ERWIN doesn't seem to have any info either apart from some info for coding the gateway J533, which it seems is not accessible on this car - however the coding info I did find would suggest that you could tell it what modules are installed. We also checked the cluster to see if there were any coding options there, and there are options for different engines and country etc, but nothing to enable / disable CAN etc.
    just to be sure, we obtained another airbag module with exact same part no. and index no. as the original, however the same code still remains. (and the coding is again different - this module came from a 1U mk1 octavia).
    I could change the cluster to see if this will solve the issue, but these are like hens teeth now and buying anything new would make the car an economic write off, so I wanted to see if there is anything I am missing.. perhaps there is an undocumented login code for the airbag modules, and also maybe the gateway J533 should be accessible and its lack of communication would indicate a problem with the cluster.
    it seems as if this car is a halfway house between the time CAN came into use and when they stopped using individual wires for each signal. The fact that everything else works without CAN is a pointer.
    auto scan posted here with one of the replacement airbag modules, although I note it is missing the cluster for some reason (I will post again if needed).
    Thanks for any info or help..
    Owen.
    Saturday,11,January,2020,09:55:07:11065
    VIN: WVWZZZ6XZ2B030669   License Plate: 02-XX-XXXX
    Mileage: 83224 miles   Repair Order:
    Chassis Type: 6X (6X - VW Lupo (1999 > 2006))
    Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
       Part No: 030 906 032 CP
       Component: ME7.5.10            3573
       Coding: 00001
       Shop #: WSC 00046
       VCID: 5AED93BE450DCA47E73-51CE
       WVWZZZ6XZ2B030669     VWZ1Z0A1891787
    Readiness: 1110 0101
       Part No: 1C0 909 601
       Component: 1T AIRBAG VW51        02
       Coding: 12628
       Shop #: WSC 02314
       VCID: 5DE798A254233D7F821-4B5C
    Address 25: Immobilizer        Labels: 6X0-953-257.lbl
       Part No: 6X0 953 257
       Component: IMMO                0008
       Coding: 00001
       Shop #: WSC 00530
       VCID: 7DA7F822F4E3DD7FA21-4B1E
    End----(Elapsed Time: 03:14, VBatt start/end: 14.2V/14.2V. VIgn 0.0V)------
    On airbag modules like this, there is precisely one coding that they will accept, and it depends on the index.
    Airbag modules like this must be specified by part number and index.
    The module in your scan has an index of "01T".
    If the coding of a used replacement module is different than the original, then the index is also different.
    Please provide a scan of the original module.
    Have you checked continuity/integrity of the CAN bus wiring from the airbag module to wherever it goes?
    Nov 2018
    Ireland
    Hi Uwe,
    Thanks for reply. I know the coding is different even on the second one we got.. I have verified the CAN wiring to all of the modules it goes to, namely the instruments, airbag module and engine ECU. all looks ok. I will put the original module back and get an auto scan but I know the original module index was "1R" or "01R" - coding 12626. Its difficult to find these as these codes aren't on the labels externally. This being the case its probably going to have to be a new module or one out of an exact same poverty spec lupo..
    Thanks,
    Owen.
    Nov 2018
    Ireland
    Hi All,
    just posting this scan with the old airbag module as requested.. it looks like there is no way to fix this except for the exact replacement module..
    Wednesday,22,January,2020,10:46:40:11065
    VIN: WVWZZZ6XZ2B030669   Mileage: 133900km-83201miles
       Coding: 00001
       Shop #: WSC 00046
    Readiness: 1110 0001
       Component: 1R AIRBAG VW51      0004
       Coding: 12626
       Shop #: WSC 00046
    00532 - Supply Voltage B+
    01025 - Trigger for On Board Diagnostic Lamp; Malfunction
                35-10 - - - Intermittent
    65535 - Internal Control Module Memory Error
                00-10 - - - Intermittent
                32-10 - Resistance Too High - Intermittent
    00589 - Airbag Igniter 1; Passenger Side (N131)
    Address 17: Instruments        Labels: 6X0-920-xxx-17.lbl
       Part No: 6X0 920 901
       Component: KOMBIINSTRUMENT BOO V24
       Coding: 00441
       Shop #: WSC 35110
       VCID: 73B3DE1AC2A79B0FC45-5184
       Coding: 00001
       Shop #: WSC 00530
    End----(Elapsed Time: 03:17, VBatt start/end: 14.0V/14.0V. VIgn 0.0V)------
    Quote Originally Posted by stylers View Post
    Well, the correct replacement.
    The old one is 1C0 909 601 /01R
    It's entirely possible that it has been superseded.
