Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: VW Transporter T6.1 ROD data
    Jun 2018
    Hi i am trying to access some coding information for the new 2020 VW Transporter T6.1
    in some of the modules VCDS is saying it could not find the ROD data for the UDS controller and to contact ross tech for assistance
    i have attached a copy of an auto scan from this vehicle but have checked 2 new 6.1s both with the same result.
    Monday,13,January,2020,13:58:45:64124
    Dealer/Shop Name: Exploria Ltd
    VIN: WV1ZZZ7HZLH023411   License Plate:
    Mileage: 1   Repair Order: democamper
    Chassis Type: 7H-VN75 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 17 19 20 44 55 5F 69 6D 75 D6 D7
    20-High Beam Assist. -- Status: Cannot be reached 0100
    5F-Information Electr. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CXEC)       Labels: None
       Part No SW: 04L 906 056 RQ    HW: 04L 907 445 N
       Component: R4 2.0l BTD   H01 9970
       Revision: 23401001
       Coding: 002540144374050800000000000000000000000000000000
       Shop #: WSC 00012 790 00059
       ASAM Dataset: EV_ECM20BTD03004L906056RQ 004005
       ROD: EV_ECM20BTD03004L906056AG.rod
       VCID: 0D465F3EDDDEF9AFB21-8058
    Readiness: N/A
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0BT 300 046 N    HW: 0GC 927 711 H
       Component: GSG DQ500     H06 3108
       Revision: 00H06V09
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 41DEB30ED1066DCF869-8014
       Part No SW: 7LA 614 517 A    HW: 7LA 614 517
       Component: ESC_high      H01 0700
       Serial number: 08512631191113
       Coding: 11552452C849E688885824A513676706393720B8
       ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
       ROD: EV_Brake1ESP90iBOSCHVN46X.rod
       VCID: 3D26CFFEADFE092FE21-8068
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 7LA 907 426 A    HW: 7LA 907 426 A
       Component: AC Manuell    H01 0502
       Coding: B03110000810000001000800504001050000000000011000800000000000
       ASAM Dataset: EV_AirCondiBHTCT6PA 001004
       ROD: N/A
    No ASAM data for: "EV_AirCondiBHTCT6PA" (VN75)
    459025 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:09
       Part No SW: 2Q5 937 090     HW: 2Q5 937 090
       Component: BCM T6PA Std+ H10 0935
       Serial number: 01101932400713
       Shop #: WSC 00012 790 00040
       ASAM Dataset: EV_BCMA0 205001
       ROD: EV_BCMA0_204.rod
       VCID: 74B02ADADE348867DDF-8020
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
       Component: FHSG_DRV  001 0002
       Serial number: 00000000000033022289
       Coding: 1F0007
       Subsystem 2 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000035231763
       Coding: 050007
       Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000047853084
    9 Faults Found:
    10506 - Bulb for Left Tail Light
              B12BE 15 [009] - Open or Short to Plus
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 10:54:30
                        Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                        Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                        Zusaetzliche Umgebungsdaten-Low beam: not activated
                        Zusaetzliche Umgebungsdaten-OFF: not activated
                        Zusaetzliche Umgebungsdaten-Outside air temperature: 0
                        Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
                        Zusaetzliche Umgebungsdaten-Parking light: not activated
                        Zusaetzliche Umgebungsdaten-Parking light left: not activated
                        Zusaetzliche Umgebungsdaten-Parking light right: not activated
                        Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                        Zusaetzliche Umgebungsdaten-last wakeup: 0
                        Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                        Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                        Zusaetzliche Umgebungsdaten-voltage measurement: 12.2 V
    10762 - Bulb for Right Tail Light
              B12BF 15 [009] - Open or Short to Plus
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 10:54:30
    264452 - No Communications with Anti-Theft Sensor
              U10F4 00 [009] - -
              [Sensor-DWA->kein Signal/ Kommunikation]
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:46:37
                        Zusaetzliche Umgebungsdaten-voltage measurement: 12.3 V
    331786 - Relay Output for Heated Exterior Mirror(s)
              B1730 15 [009] - Open or Short to Plus
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 11:20:44
                        Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
                        Zusaetzliche Umgebungsdaten-voltage measurement: 12.4 V
    527872 - Transport Mode Active
              U1105 00 [008] - -
                        Reset counter: 41
                        Mileage: 5 km
                        Date: 2019.12.14
                        Time: 01:47:48
                        Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                        Zusaetzliche Umgebungsdaten-voltage measurement: 12.5 V
    534549 - Databus
              [FLA_01 Datenbus fehlende Botschaft]
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:12
                        Zusaetzliche Umgebungsdaten-voltage measurement: 12.0 V
    592652 - Dimmer Switch; Driver Side
              B1752 01 [009] - Electrical Failure
                        Fault Frequency: 35
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 10:47:04
    609292 - Unknown Error Code
              B1A75 F0 [008] - Unknown Error Elaboration
                        Reset counter: 42
                        Mileage: 8 km
                        Date: 2020.01.09
                        Time: 16:42:54
                        Zusaetzliche Umgebungsdaten-voltage measurement: 13.0 V
    934148 - No Communications with Rain/Light Sensor
              U10F6 00 [009] - -
              [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:06
                        Zusaetzliche Umgebungsdaten-voltage measurement: 11.8 V
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058419322
       Coding: 0459051911
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       ROD: EV_EPHVA18AU3700000_003.rod
       VCID: 50F8864A0A6C9447197-8004
    1113875 - Parking Aid Indicator Lamp
              B10FF 13 [009] - Open Circuit
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:06
    Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
       Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0372
       Coding: 3200670A01FF8748949C815580508700000000000000000004
       ASAM Dataset: EV_ACCMRRCONTIVW376 003016
       VCID: 43D2B906CB1A7FDF945-8016
    0110 - Transport Mode Active
              U1105 00 [008] - -
              [FAULT_SYC_TRANSPORTMODE_ACTIVE]
                        Fault Frequency: 15
                        Reset counter: 41
                        Mileage: 5 km
                        Date: 2019.12.14
                        Time: 01:47:46
                        Voltage terminal 15: 12.3 V
                        Control Module temperature: 27 °C
       Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
       Component: VW22Airbag    013 0506
       Revision: --------
       Coding: 8800C00000000000800000CF008C40000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 7F5AF5F6E772DB3FB0D-802A
    9442836 - Front Passenger's Airbag Disabled Indicator Lamp
              B1016 14 [137] - Open or Short to Ground
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:06
    9445397 - Key switch for deactivation of passenger-side airbag
              B1020 15 [137] - Open or Short to Plus
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 11:05:09
    9446675 - Redundant signal path for airbag shut-off; passenger side
              B1025 13 [137] - Open Circuit
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 11:05:09
    9629972 - Indicator Lamp for Passenger Airbag Enabled
              B12F1 14 [137] - Open or Short to Ground
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:06
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 7LA 920 941     HW: 7LA 920 941
       Component: KOMBI         204 6750
       Coding: 27A40A0A2580260001882A011401000000200000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009069
       ROD: N/A
       VCID: 7DA60FFEED7EC92FA21-8028
    No ASAM data for: "EV_DashBoardVDDMQBAB" (VN75)
    16777018 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:15
    16777020 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:15
       Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5388
       Serial number: 20111910801907
       Coding: 030100344F05730401100018100F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF.rod
       VCID: 70B826CAAA2CB447397-8024
       Component: 4-00-11-01-04
       Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
       Component: E221__MFL-PR6  H06 0110
       Serial number: PR6-0440036336191125
       Coding: 2C1D00
       Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
       Component: J367-BDMConti  H03 1052
       Serial number: 773433010019111703D4
    131632 - High Beam Assistant Control Module
              U1070 00 [009] - No Communication
              [Timeout Knoten 0x30 / 20 - Steuergerät für Fernlichtassistent]
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:07
                        Supply voltage: Terminal 30: 11.8 V
                        Terminal 15: On
    66052 - Infotainment CAN Bus (SAE Bus E)
              U0065 00 [009] - Performance
              [Globaler Timeout CAN-Infotainment]
                        Fault Frequency: 15
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 11:35:25
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: OFF
    Address 20: High Beam Assist.
    Address 44: Steering Assist (J500)       Labels: None
       Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
       Component: EPS_MQB_ZFLS  751 7150
       Coding: 0106
       ASAM Dataset: EV_SteerAssisMNB 002012
       ROD: N/A
       VCID: 45D6A71EC52E41EFBA1-8010
    No ASAM data for: "EV_SteerAssisMNB" (VN75)
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Coding: 0C8E020009200003
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: N/A
    No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VN75)
    13705478 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 2
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:08
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 5H0 907 383     HW: 5H0 907 383
       Component: Anhaenger     H09 0039
       Serial number: 000000000005344
       Coding: 0100000202001300
       ASAM Dataset: EV_TrailFunctGener3Hella 001009
       ROD: N/A
       VCID: 6B8231A6830A579F0C5-803E
    No ASAM data for: "EV_TrailFunctGener3Hella" (VN75)
    336920 - ROD - Unknown Error Code
              - 00 [040]
                        Fault Frequency: 7
                        Reset counter: 40
                        Mileage: 5 km
                        Date: 2019.12.16
                        Time: 01:29:24
    Address 6D: Trunk Elect. (J605)       Labels:* None
       Part No SW: 7LA 959 107     HW: 4M0 959 107 C
       Component: HDSG-Modul    H14 0672
       Revision: --------    Serial number: A2-C769-9790-2
       Coding: 4180
       ASAM Dataset: EV_DeckLidCONTIVN46T 001017
       ROD: EV_DeckLidCONTIVN46T.rod
       VCID: 035279068B9ABFDFD45-8056
    Address 75: Telematics (J949)       Labels: None
       Part No SW: 5WA 035 282     HW: 5WA 035 282
       Component: OCUGen3Low    H14 0083
       Serial number: 0000000908NVHJ3
       Coding: 06462000196818208005460160000607
       ASAM Dataset: EV_OCUGen3Low 002036
       ROD: N/A
       VCID: 015E730E9186ADCFC69-8054
    No ASAM data for: "EV_OCUGen3Low" (VN75)
    7 Faults Found:
    9455892 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 40
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:51:06
    1572115 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 40
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:46:39
    9458195 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 40
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:19:40
    9455635 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 40
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 14:17:41
    9457171 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 40
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 11:33:16
    12866049 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 40
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 11:05:10
    2566 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 40
                        Mileage: 19 km
                        Date: 2020.01.13
                        Time: 10:38:13
       Part No SW: 992 941 571 AA    HW: 992 941 571 A
       Component: LED1L         H08 9002
       ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
       ROD: EV_LLPGen3LKEBODPO68X.rod
       VCID: 619E538E71C60DCFA69-8034
       Component: LED1R         H08 9002
       ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
    End----------(Elapsed Time: 01:23, VBatt start/end: 12.1V/12.0V)-----------
    any help would be appreciated thanks
  2. Likes Dana liked this post
  3. #2
    United States
    Hi Greame,
    Thanks for posting the scan. We have a (pre-release) Beta version that should resolve all of the ROD issues. I'll send you a link to it via e-mail so you can test it on
    the T6.1s.
    Best,
    Dana
  4. Likes Eric, Uwe liked this post
  5. #3
    Dec 2016
    DE
    Is this the 19.10 beta?
  6. #4
    United States
    Hi Daniel,
    Close, Beta 19.11 is the version we sent him. The RODs loaded as expected (which is great) and he's going to experiment with 17 coding tomorrow.
    I don't know when the Beta will be available for customers so let us know if you are having any issues with the latest 2020 MY cars and we can get a link sent to you. To date, I've sent that to a handful of users with HEX-Net's or V2's so they could scan the latest Caddy and T6.1 models.
  7. Likes Uwe liked this post
  8. #5
    Dec 2016
    DE
    When the MY2020 Caddy is included I would love to get a link by mail.
    I just read somewhere, that there was a 19.10 beta with updated RODs for the T6.1, which wouldn’t help me, but if it contains stuff for the Caddy, I‘m hooked.
  9. #6
    Do we have a scan from this Caddy to see what's missing in the existing release?
  10. Likes PetrolDave, Dana liked this post
  11. #7
    United States
    Uwe,
    That's still the Mk6 based (Chassis Type: 2K-VN35 (7N0) | VIN: WV1ZZZ2K_L) but I know Release failed to load a 01-Engine ROD in at least one scan. I don't have a link handy to a broken scan but something like: EV_ECM20TDI01104L906016PA_VW36
    I added a few redirects recently for labels but I'm confident some didn't make the latest DV that Seb sent you.
    Daniel,
    If you have access to a new Caddy please feel free to send a scan from it to Support. That will allow us to see what is, and isn't, covered in Release and we can get you a Beta link sent in reply.
  12. Likes Uwe liked this post
  13. #8
    I send (e-mail) one just after Christmas, but to late for customer to test with VCDS test version.
    Styreenhed  01: Motor (J623-DFSD)     Forklaringsfil: Ingen
       Styreenhedsnr: SW: 04L 906 016 PM    HW: 04L 907 309 AB
       Komponent    : R4 2.0l TDI   H20 7038
       Revision    : 8EH20---
       Kodning    : 011D001A04240D090000
       Forhandler    : WSC 35110 790 50316
       ASAM datasæt    : EV_ECM20TDI01104L906016PM 004001
       ROD: Ikke tilgængelig
       VCID: 035388A36B997BDFD7B-8056
    Ingen ASAM data tilgængelig for: "EV_ECM20TDI01104L906016PM" (VN35)
  14. Likes Dana, Uwe liked this post
  15. #9
    Dec 2016
    DE
    Daniel,
    Does the VCDS language matter for this? Or is it acceptable to sent you a scan from a german 19.6.x?
  16. Likes Dana, Uwe liked this post
  17. #10
    United States
    The language does not matter. The German one is perfectly fine.
  18. Likes Uwe liked this post
