Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Retrofit memory seats Passat B8
    Verified VCDS User sam1754's Avatar
    Mar 2019
    France
    I bought this :
    I have semi-electric driver seat. So I have to wire and code vehicule before I can use it...
    I need some help.
    Apr 2018
    ITALY
    buy one hour on erwin and print-to-PDF all schematics for you VIN.
    anyway, you already have power for the seat so you most probably need to run just the can-bus line.
    a few modules will need recoding but I am not sure which one and how...
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  3. Likes Uwe liked this post
    Mar 2019
    France
    Thanks for your reply, I have diagrams, downloaded here: https://vwts.ru/vw/b8/vw-passat-b8-w...agrams-eng.pdf
    And component location: https://vwts.ru/vw/b8/vw-passat-b8-c...ations-eng.pdf
    May it help someone and guide me through this retrofit.
    I think you-re right fordriver seat but for passenger one, it's different. I haven't yet any electric function...
    And I must drive wires from fuse panel to the back clim control unit to power rear seat heating.
    I think it'll be a very long job.
    Jul 2014
    Tallinn, Estonia
    You'll have to run Comfort CAN to the driver's seat anyway to get memory to work. If this seat also has ventilation, the ventilators are LIN submodules of the BCM, so there's wires to run for these also.
    Mar 2019
    France
    Ok, no ventilator.
    Where is located the comfort CAN?
    I'll check in documents above but it's good to have guidance through this retrofit.
    Mar 2019
    France
    Ok, I watched the diagram. I think you're talking about the CAN Gateway J533.
    I saw from driver seat controller plug T32b pin 15(CAN low) and pin 16(CAN high) to CAN gateway (J533) plug T20e pin 5 and pin 15 via coupling point under driver seat.
    So, I might just have to run two wires from CAN Gateway to driver seat coupling point?
    My back and my knees remember soldering job for A5 module retrofit...
    Downtime talked about a coupling point below A pillar. Any picture please?
    Mar 2019
    France
    Can I find some coupling points here to run to Can gateway?
  9. #8
    Mar 2019
    France
    I found that CAN gateway (J533) T20e pin 5 and pin 15 are wired to LID control module which is really easily reachable.
    My question is: Can I solder CanH an CanL from driver seat module on any corresponding wire?
  10. #9
    Mar 2019
    France
    So, I took time to learn a little about CAN system and I can now answer to myself. We can plug modules everywhere in CAN line (BUS). It's just a communication line where modules have to be declared in Can gateway to be allowed to communicate each others, sending requests and data responses.
    I think now I'll never pay again for plug and play wiring with silly implementation instructions. It's make you put your head upside down unusefully
    Now, I understand what Downtime said... searching the better coupling point to solder
  11. #10
    Mar 2019
    France
    I bought a complete harness for the rear bench. It'll be easier.
    Anyone could confirm or not what I said on this post about Can Bus wiring?
