Results 1 to 10 of 14
Thread: Help with Factory Trailer Hitch Retrofit (2016 Mk.7)
    Feb 2020
    Hi, I'm new to VCDS and hoping to get some advice. I have just retrofitted a factory folding towbar to my Golf Mk7. I used a used ORIS factory fit towbar/trailer hitch, the Kufatec wiring loom and a genuine VW but used J345 module (5Q0 907 383 G). I'm in the UK if that makes a difference.
    This is the autoscan pre-fitting (there were a few fault codes, but old or known. I cleared them all before fitting):
    Sunday,23,February,2020,12:21:36:28737
    VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZAUZGP103579   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZGP103579   Mileage: 104356km-64843miles
    Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
       Component: R4 1.6l TDI   H06 2795
       Revision: 22004001
       Coding: 0111401243451D092000
       Shop #: WSC 00028 028 00072
       ASAM Dataset: EV_ECM16TDI03004L906056CL 002008
       ROD: EV_ECM16TDI03004L906056_002_VW37.rod
       VCID: 79AE161A595E56DF8EB-802C
    Readiness: N/A
       Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
       Component: ESC           H42 0625
       Revision: 00000000    Serial number: 90476000012945
       Coding: 01FA8AA12420096F077C060741CC2580512490E06082A4F31440F078C002
       VCID: 7EA40506407071E7BB9-802A
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 168
                        Mileage: 85581 km
                        Date: 2019.02.23
                        Time: 20:41:06
       Part No SW: 5G0 907 426 AA    HW: 5G0 907 426 AA
       Revision: 00001K06
       Coding: 00120104202100001000000000000002
       Shop #: WSC 00028 028 00068
       ROD: EV_ACManueBHBVW37X_003.rod
       VCID: 6A8C39562CF8ED47771-803E
    329220 - Motor for Air Distribution Flap
              B109D 71 [008] - Actuator stuck
                        Reset counter: 38
                        Mileage: 103278 km
                        Date: 2020.01.12
                        Time: 16:04:48
                        Voltage terminal 30: 14.1 V
                        Outside air temperature: 9.0 °C
                        Air distribution flap: actual value: 218
                        Air distribution flap: actual value: 71.0 %
                        Air distribution flap: specified value: 261
    1048835 - Functionality limited due to Engine Control Module
              P1719 00 [008] - -
              [PTC-Reduzierung durch MSG]
                        Fault Frequency: 8
                        Reset counter: 49
                        Mileage: 98988 km
                        Date: 2019.10.17
                        Time: 05:34:55
                        Voltage terminal 30: 14.2 V
                        Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                        Auxiliary heater: in stages-Act.val.: 1
                        Auxiliary heater: in stages-Specified value for control: 3
       Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
       Component: BCM MQBAB H   H24 0175
       Serial number: 01061606401268
       Coding: 03000846C241027B0BA44080B11C07281000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 045077EE2E9C1B37EDD-8050
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    160221  042 0551
       Serial number:         160226201744
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S2Y16M03D05H15M04S25
       Coding: 90A8DD
       Serial number: 000000000ZY112500FSH
       Component: Sirene, DWA  005 0313
       Serial number: 00000000000065172010
    12307 - License Plate Light
              B12CA 01 [008] - Electrical Failure
                        Fault Frequency: 7
                        Reset counter: 56
                        Time: 00:00:00
       Revision: --------    Serial number: 39391605700599
       Coding: 0071051001
       VCID: 43D2B4F26B12DC0F947-8016
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 19021603210553
       Coding: 00000300FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       VCID: 3A2CC9161CD89DC7C71-806E
       Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
       Component: AirbagVW20    015 0388
       Serial number: 003MLR1J2DU9
       Shop #: WSC 00028 028 00062
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F5AF802477A78EFB0F-802A
       Belt Pretensioner left:
       Serial number: 34169677B08031650781
       Coding: 333135
       Belt Pretensioner right:
       Serial number: 34169676B09031640668
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 703 16
       Serial number: 35767000000A6038991V
       Subsystem 4 - Part No SW: -----------    HW: 480 000 703 16
       Serial number: 35867000000B2748991.
       Subsystem 5 - Part No SW: -----------    HW: 480 401 003 16
       Serial number: 3516502AF1F353935207
       Subsystem 6 - Part No SW: -----------    HW: 480 401 003 16
       Serial number: 3526502A31F35395E15B
       Subsystem 7 - Part No SW: -----------    HW: 480 401 103 16
       Serial number: 3556502BF1F3539562AP
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 11031604401017
       Coding: 0400
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 0D4652CA7DD65A7FB23-8058
       Part No SW: 5G1 920 941 A    HW: 5G1 920 941 A
       Component: KOMBI         202 6420
       Coding: 27A41A002780260001886A011400000000000000
       VCID: 270A0062FF6A102FA8F-8072
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 05031610801327
       Coding: 030100041F087300FB00005C080F00010001050000000000000000000000
       ROD: EV_GatewConti_013.rod
       Serial number: 29160000506740126095
       Coding: 2CFFFF
       Serial number: 2934389403
       Component: TSG FS        010 0031
       Serial number: 0000189328020
       Coding: 00310220D001028000001000
       VCID: 47CAA0E25F2AF02F48F-8012
       Serial number: 00000000000012199033
       Coding: 0D0000
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 8103
       VCID: 44D0B7EE6E1CDB37ADD-8010
       Component: TSG BFS       010 0031
       Serial number: 0000189498101
       Coding: 00310020DE01028000801000
       VCID: 46D4ADE65820E927B39-8012
       Serial number: 00000000000012167820
       Coding: 050000
    65593 - Switch for Central Locking
              B122D 29 [009] - Signal Implausible
                        Reset counter: 82
                        Mileage: 91418 km
                        Date: 2019.06.27
                        Time: 12:43:38
       Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
       Component: MU-S-ND-ER    H24 0245
       Serial number: VWZAZ2S0107561
       Coding: 02730001FF00000051111101008808001F0100C601200100CF
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 3038EB3ECAA45797795-8064
       Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
       Component: ABT_Std-2_Nav  H43 4064
       Serial number: VWZ6Z9S0720728
       Subsystem 2 - Part No SW: 5NA 919 866 R    HW: -----------
       Component: ECE AS 19/20  --- 1115
              B201A 00 [009] - -
              [Check software version management]
                        Reset counter: 7
                        Mileage: 85463 km
                        Date: 2019.02.12
                        Time: 13:32:22
                        Voltage terminal 30: 14.7 V
                        Status_Software_Version_Management-module_name:
    5688 - Control Head for Mulimedia System
              B13C9 F2 [008] - On/Off Switch
                        Reset counter: 25
                        Mileage: 102198 km
                        Date: 2020.01.04
                        Time: 17:56:14
                        Voltage terminal 30: 12.6 V
    End----(Elapsed Time: 02:11, VBatt start/end: 11.7V/11.9V. VIgn 11.9V)-----
    So I fitted all the parts then used the guidance in this thread and links to do the coding. This is what I changed:
    19-CAN Gateway] > [Gateway coding] > Check-mark at [69]
    1 Engine Module:
    to
    0111401243551D092000
    10 Park/Steer Assist Module:
    0071051001
    to
    0071051201
    13 Auto Dist.Reg Module:
    00000300FE0739
    to
    00000B00FE0739
    03 ABS Module:
    Adaption: IDE04774 Vehicle and trailer stabilisation to ACTIVATED
    09 Central Electric Module:
    03000846C241027B0BA44080B11C0728100000000000000000 00000000000
    to
    03020846C241027B0BA44080B11C0728100000000000000000 00000000000
    I then did the, clear faultcodes, ignition on off cycle mentioned above.
    After the changes, dashboard is lit up with lots of warnings and errors. This is the autoscan:
     Tuesday,25,February,2020,11:51:52:28737
    Workshop Code: 123 12345 023456
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F 69
       Revision: 22004001
       Coding: 0111401243551D092000
       Shop #: WSC 12345 123 23456
    25126 - Databus
              U1123 00 [035] - Received Error Message
                        Mileage: 104356 km
                        Coolant temperature: 6 °C
                        Intake air temperature: 20 °C
                        Voltage terminal 30: 10.984 V
                        CAN status - engine control module: 0
                        Cruise Control System (CCS): status: Initializing
    Readiness: N/A
    0297 - Steering angle sensor
              B1168 16 [137] - Voltage Too Low
                        Reset counter: 16
                        Date: 2020.02.25
                        Time: 11:32:18
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:43
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:43
       Revision: 00001K06
       Coding: 03020846C241027B0BA44080B11C07281000000000000000000000000000
       Coding: 90A8DD
       Coding: 0071051201
    13637426 - Databus
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:17
       Coding: 00000B00FE0739
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:20
                        Control Module temperature: 28 °C
                        Voltage terminal 15: 11.6 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:17
    1078 - Databus
              [FAULT_CIS_SAS_INIT]
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:17
    1043 - Automatic Distance Control
              B10E7 F0 [009] - Disconnected
              [FAULT_CIS_TSK_IRREV_FAIL]
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:17
       Coding: 333135
       Coding: 333135
    1050117 - Databus
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:17
       Coding: 0400
       Coding: 2CFFFF
       Coding: 0D0000
       Coding: 8103
    16130 - Steering Angle Sensor
              B1168 F2 [009] - Not Initialized
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:17
                        Motor status: 00
                        Supply voltage: 11.50 V
                        Temperature: 15.0 °C
                        KFC: 3F
                        KFA: 00 02
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 11.52 V
                        uAdSensI_SwitchedKl30_xdu16: 11.52 V
       Coding: 050000
              B201A 00 [009] - -
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:17
                        Voltage terminal 30: 11.6 V
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0404707205
       Coding: 0100000202000000
       VCID: 3B22CC1213E2A4CFDC7-806E
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Reset counter: 16
                        Mileage: 104356 km
                        Date: 2020.02.25
                        Time: 11:32:19
    End----(Elapsed Time: 01:29, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
    So all the trailer stuff works perfectly: Lights, handle locking light, trailer alarm activation etc (only thing I haven't tested is the brake lights). However I currently have ACC, ESP, AIRBAG and TPMS errors in the car which I didn't have before. I haven't started it yet, I wasn't sure if this could help or would make things worse.
    I feel like I might have missed some code or got some wrong (hopefully it isn't becuase I have broken something). Can anyone help with what I did wrong or suggest any changes?
    As I said, this is my first post, so hopefully I gave the right amount of detail, if you need more or less just let me know.
    Thanks for your help.
  2. Likes Dana liked this post
  3. #2
    I've split this out into its own thread from this one.
    May 2014
    ^^^^ There's a kind-of "collective forum intelligence" in respect of the DTC on the hex 44 module HERE. The G85 sensor gets involved in lots of cross module activities on MQB platform vehicles - so clearing this DTC early-on in your post retrofit investigations is probably advantageous (IMO).
  5. Likes GolfOwner, Uwe liked this post
    Feb 2020
    Many thanks to Don, I have made a lot of progress. I did the "Simple Reset" mentioned in the MQB G85 Thread; thought I would give that a go before the full calibration. So I just did the drive round the block, go to both extremes of full lock, then clear the fault codes. This has solved most of the faults, so maybe these were actually as a result of the battery being disconnected. I'm certainly going to remember that in case I ever need to disconnect the battery again. Fitting the wiring to the fuseboard for this retrofit was impossible without disconnecting the power from the fuseboard; at least in a RHD car, very limited access (and the Kufatec instructions recommended disconnecting the battery anyway).
    On the trailer; all lights are working, dashboard tells you trailer hitch is being unlocked when you unfold it, eco mode is being made unavailable and the rear parking sensors deactivated (all stuff its supposed to do).
    So that's the good news, below is a scan of the remaining fault codes:
    Wednesday,26,February,2020,09:03:32:28737
    VIN: WVWZZZAUZGP103579   Mileage: 104357km-64844miles
       Revision: 22004001
    Readiness: N/A
       Revision: 00001K06
       Coding: 90A8DD
       Coding: 0071051201
       Coding: 333135
       Coding: 333135
       Coding: 0400
       Coding: 2CFFFF
       Coding: 0D0000
       Coding: 8103
       Coding: 050000
              B201A 00 [009] - -
                        Reset counter: 16
                        Mileage: 104357 km
                        Date: 2020.02.26
                        Time: 08:59:31
                        Voltage terminal 30: 12.2 V
                        Reset counter: 16
                        Mileage: 104357 km
                        Date: 2020.02.26
                        Time: 08:59:33
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
    Two faults left. I'm not too worried about the SVM fault (that was there before). Not sure what to make of the supply voltage fault on the trailer module though?
    Also there isn't a trailer attached light on the dashboard and the start/stop is still available with a trailer connected (this is supposed to be deactivated). When I did the coding, it wouldn't let me change anything other than the adaption in 3C ABS. I also couldn't find any settings to change for A5 Start Stop.
    So I'm wondering if there is still a bit of coding missing, does anyone have any suggestions?
  7. Likes Uwe liked this post
  8. #5
    May 2014
    ^^^GolfOwner: wow you certainly have made progress - well done indeed!! Of course anything is possible, but the DTC descriptor on the hex 69 module is not evocative of a coding fault. "Supply Voltage" - "Open ciruit" sounds more like a physical problem with wiring and/or connectors/fuse.
    According to the pin-out on my WD for mk7's, Terminal 30 connections happen on Pin's #3, 4 and 5 of the 6 x pin connector on J345 module. I suggest that you grab a multi-meter and confirm that hard +12 volts appear on these pins. It might also be prudent to check the quality of the earth connection on pin #2.
    PS: Did the SVM fault occur after a MIB software update? if so, have you tried using the XOR calculator method to delete the DTC?
  9. Likes PetrolDave, Uwe, Dana liked this post
  10. #6
    Feb 2020
    I checked the voltages as suggested, all good. The earth pin was reading about 0.8 resistance to the wheel arch earth (729).
    There was a quirk (this is how I have understood the wiring diagram) in that the THRL connector that links the towbar earths to the 729 earth in the left rear wheel housing; the towbar loom has three earth cables, the wiring diagram shows three, but the Kufatec cable that links THRL to 729 only has two cables. I wasn't sure if this was important, but I added the extra cable; it hasn't cleared the code though.
    Kufatec's loom does have a cable that is supposed to connect to the fuesboard (that should link to that 6x pin connector on the J345 module) that I didn't connect. Their instructions said it was optional, only for version 34350-1. It was supposed to link to SC22 on the fuseboard, but mine didn't look like it had a space for it; do you think it could be needed and causing the fault?
    Re the coding; turns out the dashboard trailer light is only for errors (probably good that's not on!) and the start/stop isn't deactivated on factory fit towbars, only 3rd party ones; not sure why thats the case or how the car knows this... Either way it looks now like all the coding could be correct, but difficult to know if I have missed anything in the background.
  11. #7
    Feb 2020
    Re the SVM fault, we have had the car for a year and the last time it went to the dealer was a service when we bought it. The date the fault code first occurred was when or just after the dealer serviced it, so could be what you suggest. I haven't tried the XOR method, would you recommend it?
  12. #8
    Apr 2018
    ITALY
    SINCE THE DTC STATES YOU ARE MISSING A SUPPLY I WOULD DEFINITELY GIVE IT A SHOT.
    YES IT DOESN'T HURT TRYING...
  13. #9
    Feb 2020
    I made a new connection on the fuseboard for the SC22 wire. I think it was just for split charging, so possibly why I hadn't missed the function when I tested the towbar. The open circuit fault has persisted though. Any Ideas what else could be causing it?
                        Reset counter: 16
                        Mileage: 104357 km
                        Date: 2020.02.28
                        Time: 08:53:07
  14. #10
    Apr 2018
    ITALY
    double and triple check the wiring diagram. you're not sending +12V somewhere where you should... or the diagram is wrong, sometimes it happens.
  15. Likes Uwe, Dana liked this post
