Results 1 to 10 of 10
Thread: Audi A1 1.6 tdi spport
    Sep 2017
    Cumbria, UK
    Audi A1 1.6 tdi sport
    Its the wifes car and she doesn't do many miles in it but tonight on her way to work it started to loose power first thought was its gone into Regen mode as its a real pain in the ass for doing that but after a scan it shows some kind of injector fault .
    The dash has the heater coil light flashing and a message of engine control module fault please take to nearest dealer .
    If anyone has an idea of where to look to solve this please add a reply
    thanks in advance
    aturday,11,January,2020,22:10:57:56460
    VIN: WAUZZZ8X1Bxxxxxxx   License Plate:
    Chassis Type: 8X-AU21 (8X0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
    VIN: WAUZZZ8X1Bxxxxxxx   Mileage: 97970km-60875miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 KN    HW: 03L 906 023 KM
       Component: 1,6L R4 CR td H53 9056
       Revision: --H53---    Serial number:
       Coding: 00114016030501080000
       Shop #: WSC 00046 790 00000
       ASAM Dataset: EV_ECM16TDI02103L906023KN 003010
       ROD: EV_ECM16TDI02103L906023KM_003.rod
       VCID: 7CA2FCDE5666AF2795F-8028
    9840 - Injector: Cylinder 4 (N33)
              P0204 00 [167] - Circuit Malfunction
                        Mileage: 97799 km
                        Date: 2020.01.11
                        Time: 22:04:49
                        Engine speed: 1347.00 /min
                        Normed load value: 49.0 %
                        Coolant temperature: 68 °C
                        Intake air temperature: 32 °C
                        Voltage terminal 30: 14.005 V
                        Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
                        Injector valve 3: capacity-CAPA_INJ_MAIN[2]: 23.7212 µF
                        Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2]: 1428.9 µAs
                        Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2]: 43.036 mJ
                        Supply voltage of analog output 1-VCC_1: 4.98 V
                        Supply voltage of analog output 2-VCC_2: 4.99 V
                        Injection valve 3: voltage-V_INJ_MAIN[2]: 60.23 V
    Readiness: 1110 1000
    Address 03: ABS Brakes        Labels:
       VCID: 55F4897A9C0C9E6FCA1-FFFE
       Part No SW: 8X0 820 045 A    HW: 8X0 820 045 A
       Component: J255 Klima Manuell  0140
       Revision: 0000707S    Serial number: 03030004268934
       Shop #: WSC 00046 000 00000
       VCID: 343214FE3236A7671DF-8060
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 D    HW: 8X0 907 063 D
       Component: BCM PQ35  M   108 0621
       Revision: 00108 AC
       Coding: 0E000A2FA005F100201841E000000154430B6C0A00CF4122DC0087830041
       VCID: 3D2431DA0D7C662FE21-8068
       Subsystem 1 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0010
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
       Component: Airbag10.41   H04 0008
       Revision: --------    Serial number: 003JJ001N8YL
       Coding: 30314539303330303034554A305238583053
       ASAM Dataset: EV_Airba1041BPAAU210 001015
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 48CA500E523E3387417-801C
       Serial number: 3554VRB405J0ESC6HHPI
       Serial number: 3575HRB405705NLMDGP1
       Serial number: 3585HRB40690CE323OS9
       Rear Impact Crash Sensor:
       Serial number: 3515ZRB40690D6ISJO98
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 501 B    HW: 5K0 953 569 H
       Revision: FF010016    Serial number: 20110407300278
       Coding: 1184004000
       VCID: 392C25CA19D45A0FCE9-806C
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Component: E221 - MFL  H07 0009
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8X0 920 980 A    HW: 8X0 920 980 A
       Component: KOMBI         H07 0124
       Coding: 41DE00
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
       VCID: 3D2431DA0DFC662FE21-8068
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8X0 907 468 A    HW: 8X0 907 468 A
       Component: GAT 4CAN 1L M H04 0083
       Revision: 1C060023    Serial number: 2341C1131000BD
       Coding: FBCF005A000100010153
       VCID: 43D047226B9810DF945-8016
       Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
       Component: J367-BDM  H07 0171
       Serial number: 00000000007100751331
       Serial number: 11097001034011200181
       Component: IMMO          H07 0124
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 B    HW: 8X0 959 793 B
       Component: TSG FA        H09 0409
       Coding: 011802200101000100
       VCID: 4CC26C1E46C6DFA765F-8018
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11251
       Shop #: WSC 00046
       VCID: 2F381B92DE5084BF60D-807A
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 B    HW: 8X0 959 792 B
       Component: TSG BF        H09 0409
       VCID: 4BC06F0243C8D89F6C5-801E
       Part No SW: 8X0 035 183 B    HW: 8X0 035 183 B
       Component: RMC Cnct      H50 0647
       Coding: 01010000000051070023000103010000010000
       VCID: 36362EF6284AB57723B-8062
       Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9462CY0B0098169
    End----------(Elapsed Time: 01:18, VBatt start/end: 14.2V/14.3V)-----------
    Did you check wiring to number 4 injector from controller using RTFB and WD and or swap injectors to isolate or see if fault moves?
    Did you JPPSG yet?
    Sep 2017
    Cumbria, UK
    Did you JPPSG yet?
    I did check the wiring the best i could with no tools to hand and just the flash light on my phone no loose connections or wires that looked bad other than that until i can get it home tomorrow at some point swapping injectors around and testing with a multi meter will have to wait
    Sep 2017
    Cumbria, UK
    Tried to use 08 measuring blocks i on vcds but the option is locked out so i had to use the advanced version . No what i cant work out is it seems injector 3 is the problem ( 2 from the scan as its numbered 0-3) IT seems as if their is no voltage at the injector so am i right in thinking that the injector has to send the information back to the control module for vcds to report the info ?????
      Address 01: Engine  (03L 906 023 KN)
    07:01:09
      IDE00437-ENG99390   Injector valve 1: capacity-CAPA_INJ_MAIN[0] 6.5566 µF
      IDE00438-ENG103101   Injector valve 2: capacity-CAPA_INJ_MAIN[1] 6.5301 µF
      IDE00439-ENG102776   Injector valve 3: capacity-CAPA_INJ_MAIN[2] 0.0000 µF
      IDE00440-ENG104221   Injector valve 4: capacity-CAPA_INJ_MAIN[3] 6.5301 µF
      IDE03893-ENG101196   Injection valve 1: voltage-V_INJ_MAIN[0] 114.88 V
      IDE03894-ENG104143   Injection valve 2: voltage-V_INJ_MAIN[1] 114.14 V
      IDE03895-ENG101536   Injection valve 3: voltage-V_INJ_MAIN[2] 0.00 V
      IDE03896-ENG102925   Injection valve 4: voltage-V_INJ_MAIN[3] 113.91 V
      IDE05634-ENG103637   Voltage load of main injection cylinder 1-CHR_INJ_MAIN[0] 748.6 µAs
      IDE05635-ENG99789   Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1] 739.1 µAs
      IDE05636-ENG103475   Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2] 0.0 µAs
      IDE05637-ENG101402   Voltage load of main injection cylinder 4-CHR_INJ_MAIN[3] 742.2 µAs
    Maybe the stack is labeled wrong in controller, did you unplug each injector to corelate a block value?
    Sep 2017
    Cumbria, UK
    So just to add to the problems im having with the car i got my local garage to change injector 4 all fault codes gone and cleared (snap-on computer used) injector coded to the car and checked that the car has taken the coding but car now has a missfire at low revs and also you get diesel knock . My thinking here is either another injectors on its way out but not bad enough to throw a code yet or is there something that im missing .
  7. #7
    Jul 2014
    Hi AshB
    Was it a brand new injector? What does the garage that fitted it have to say?
    Regards HMC
  8. Likes Jack@European_Parts liked this post
  9. #8
    What are balance tests as observed in blocks compared to other cylinders?
  10. #9
    Sep 2017
    Cumbria, UK
    Quote Originally Posted by HMC View Post
    Hi AshB
    Regards HMC
    Yes the injector was new the garage are struggling to understand it and have said see how the car runs over the weekend
    @Jack@European_Parts hopefully i have the right data for you
    Scan after the injectors been fitted
    Friday,17,January,2020,17:00:55:56460
    VIN: WAUZZZ8X1BBxxxxxx   License Plate:
    VIN: WAUZZZ8X1BBxxxxxxx   Mileage: 98000km-60894miles
    Readiness: 0100 0000
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
       Component: ESP8.2i front H07 0001
       Revision: --------
       Coding: 330448E9437600B2CC2812E4C2DA00920C00
       VCID: 7F580BD247B0B43FB0D-802A
       Revision: 00108 AC
       Coding: 1184004000
       Coding: 41DE00
       Coding: 000002
       Coding: 11251
       Shop #: WSC 00046
    End----------(Elapsed Time: 00:55, VBatt start/end: 14.7V/14.8V)-----------
    16:48:31
      IDE00357-ENG99842   Fuel temperature-TFU 32 °C
      IDE00365-ENG99400   Injection amount deviation cylinder 1-FAC_CYL_BAL1 0.3895 mg/stroke
      IDE00366-ENG101187   Injection amount deviation cylinder 2-FAC_CYL_BAL2 0.2514 mg/stroke
      IDE00367-ENG101684   Injection amount deviation cylinder 3-FAC_CYL_BAL3 0.5125 mg/stroke
      IDE00368-ENG103465   Injection amount deviation cylinder 4-FAC_CYL_BAL4 -1.1629 mg/stroke  (the minus figure could this cause a problems ??? this is the new injector )
      IDE00437-ENG99390   Injector valve 1: capacity-CAPA_INJ_MAIN[0] 7.0498 µF
      IDE00438-ENG103101   Injector valve 2: capacity-CAPA_INJ_MAIN[1] 6.7848 µF
      IDE00439-ENG102776   Injector valve 3: capacity-CAPA_INJ_MAIN[2] 7.2316 µF
      IDE00440-ENG104221   Injector valve 4: capacity-CAPA_INJ_MAIN[3] 6.8705 µF
  11. #10
    ^^^^ I would defer my comments to Jack's more experienced response, but are you sure that the new injector is sealed properly?
    A healthy capacitance value has been re-established for the new injector (see the new micro farad value -uF), which suggests that the electrical side is OK .
    So, logic tends to point to a fuel side problem - perhaps the mating surface between the injector and the cylinder head is not properly sealed - or less likely, a dodgy internal seal in the new injector?
