Golf MK7 S/S deactivation?
Dp41n8w
C?ID=372411
Hello. Does anybody know is there possibility to deactivate Start&Stop in that MK7? There isnt channel to change voltage to S/S. Is there any other possibility to do with VCDS?
 Saturday,11,January,2020,21:09:36:19148
Workshop Code: 358 14250 022663
VIN: WVWZZZAUZDP053588   License Plate:
Mileage: 191209km-118811mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69
VIN: WVWZZZAUZDP052588   Mileage: 191209km-118811miles
Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
   Component: R4 1.4l TFS   H02 9225
   Revision: WKH02---
   Coding: 01250032247405083000
   Shop #: WSC 73008 205 00000
   ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
   ROD: EV_ECM14TFS01104E906016AD.rod
   VCID: 6491AC878EDF13E74DF-8030
17159 - Databus
   Part No SW: 0CW 300 047 T    HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5211
   Revision: 00043014    Serial number: CU501302146978
   Shop #: WSC 00028 028 00024
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4CC16427064FBBA765F-8018
   Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
   Component: ESC           H75 0537
   Coding: 01FA6AA12025126E037C060801CB2980560448C0608094F3F82A5028C1
   ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
   VCID: 7EA5FEEF0073D937BBB-802A
   Part No SW: 5Q0 959 435     HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0500
   Revision: 00021000    Serial number: 0203188523
   Coding: 030C0C
   VCID: 79AFEDF3195DFE0F8E9-802C
   Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020004200100011005000000101000
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 363526CF68C3D17723B-8062
328196 - Motor for Right Temperature Flap
          B108D 71 [008] - Actuator stuck
                    Reset counter: 133
                    Mileage: 189000 km
                    Date: 2019.11.14
                    Time: 16:27:38
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011303200467
   Coding: 00031A46C24122FB4FE44000001C0708180A000000000000000000000000
   ROD: EV_BCMBOSCH_010.rod
   VCID: 46D5560F182341F7B3B-8012
   Component: WWS    130128  042 0551
   Serial number:         130204132030
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y14M02D28H20M43S40S8
   Coding: 028877
12307 - License Plate Light
          B12CA 01 [009] - Electrical Failure
                    Reset counter: 7
                    Mileage: 187371 km
                    Date: 2019.10.18
                    Time: 19:03:18
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [009] - Electrical Failure
                    Fault Frequency: 9
                    Reset counter: 113
                    Mileage: 187292 km
                    Date: 2019.10.16
                    Time: 11:58:18
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 149
                    Mileage: 190923 km
                    Date: 2019.12.27
                    Time: 11:47:46
204546 - Remote key 2
                    Reset counter: 96
                    Mileage: 190598 km
                    Date: 2019.12.23
                    Time: 08:30:35
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231303300904
   Coding: 0071051111
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   VCID: 3A2D32FF5CDB3517C73-806E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 J    HW: 5Q0 907 567 J
   Component: ACC3          H10 0396
   Serial number: 12051703033302
   Coding: 001E1900FE0309
   ASAM Dataset: EV_ACCBoschMQB 001023
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 42DD4A1F340B7DD79F3-8016
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Serial number: 003F5R02VUJ3
   Shop #: WSC 00028 028 00061
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 40D940173A076FC7897-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 802 13
   Serial number: 35767000000EAC189C08
   Subsystem 2 - Part No SW: -----------    HW: 480 000 602 13
   Serial number: 358670000000AB6C4C0+
   Subsystem 3 - Part No SW: -----------    HW: 480 400 902 13
   Serial number: 3516502B10D36244B31
   Subsystem 4 - Part No SW: -----------    HW: 480 400 502 13
   Serial number: 35265029B0F53D64F29T
   Subsystem 5 - Part No SW: -----------    HW: 480 402 501 13
   Serial number: 35565029B0D3608390EG
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 01021308491400
   Coding: 0C00
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_009_VW37.rod
   VCID: 025D8A1F748BBDD7DF3-8056
   Part No SW: 5G0 920 870     HW: 5G0 920 870
   Component: KOMBI         335 0555
   Coding: 07A401182F80000800882A01040000
   VCID: 6695B68F78E361F753B-8032
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1109
   Revision: --------    Serial number: 0000295622
   Coding: 030100342B086400EF00025A1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 34311CC77EBFC3671DF-8060
   Component: E221__MFL-DC1  H12 0034
   Serial number: 02120004383200010291
   Coding: 2D0000
   Serial number: 2953889101
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000017126002
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73B3DFDB3B31845FC45-8026
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000051758410
   Coding: 003B1320D000020000001000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000757252
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D2739E34DF5022FE21-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000052800180
   Coding: 003B1120DE00020000801000
   VCID: 015F8513718DA6CFC69-8054
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000754104
   Coding: 090000
65639 - Motor for Window Regulator
          B1487 29 [008] - Signal Implausible
                    Reset counter: 141
                    Mileage: 190759 km
                    Date: 2019.12.25
                    Time: 11:07:47
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A00000B000200
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5G0 035 819     HW: 5G0 035 819
   Component: MU-S--ER      039 0142
   Serial number: V1C00802130818
   Coding: 02730000FF00000011110001000800001F0100840100010001
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H44 0020
   Serial number: VWZ8Z9M2401S1X
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000192647117
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 353721C375C5DA6F2A1-8060
End----------(Elapsed Time: 01:18, VBatt start/end: 14.7V/14.7V)-----------
DV52
C?ID=194404
^^^ HMM......... this car has done 191, 209 kms - so, I'm guessing that it's an "early" model. This being so, I suspect that the "temperature" method should be used to disable SS - rather than the "voltage" method.
This tweak is a not sanctioned by Ross-Tech (for ethical reasons - I think)
  1. Slect the CAN Gateway module @ address hex19
  2. Select Adaptation
  3. Search for "ENG05990"
  4. Change the 2 x channels (their default value is minus 50.0 °C)
    ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature > 50.0 °C
    ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature > 50.0 °C
Dp41n8w
C?ID=372411
Okey thanks, I Will try :)
m3lv
C?ID=394166
Any way to disable and not get the high power consumption message?
Mari
C?ID=150535
Disable messages in Infortainement-system...
PetrolDave
Westbury, UK
C?ID=1423
Fit an add-on device that automatically presses the SS switch for you at every ignition on?
TWs/VW
NW Florida
C?ID=369048
I've done this, works great...
TW
DV52
C?ID=194404
^^^Just to add alternatives to above -I've done this, works great...
And this.....
And this (Arduino -Digispark version).....
