Results 1 to 8 of 8
Thread: Golf MK7 S/S deactivation?
    Feb 2019
    Hello. Does anybody know is there possibility to deactivate Start&Stop in that MK7? There isnt channel to change voltage to S/S. Is there any other possibility to do with VCDS?
     Saturday,11,January,2020,21:09:36:19148
    Workshop Code: 358 14250 022663
    VIN: WVWZZZAUZDP053588   License Plate:
    Mileage: 191209km-118811mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69
    VIN: WVWZZZAUZDP052588   Mileage: 191209km-118811miles
    Address 01: Engine (J623-CPTA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 AD    HW: 04E 907 309 G
       Component: R4 1.4l TFS   H02 9225
       Revision: WKH02---
       Coding: 01250032247405083000
       Shop #: WSC 73008 205 00000
       ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
       ROD: EV_ECM14TFS01104E906016AD.rod
       VCID: 6491AC878EDF13E74DF-8030
    17159 - Databus
       Part No SW: 0CW 300 047 T    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5211
       Revision: 00043014    Serial number: CU501302146978
       Shop #: WSC 00028 028 00024
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 4CC16427064FBBA765F-8018
       Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
       Component: ESC           H75 0537
       Coding: 01FA6AA12025126E037C060801CB2980560448C0608094F3F82A5028C1
       ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
       VCID: 7EA5FEEF0073D937BBB-802A
       Part No SW: 5Q0 959 435     HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0500
       Revision: 00021000    Serial number: 0203188523
       Coding: 030C0C
       VCID: 79AFEDF3195DFE0F8E9-802C
       Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
       Revision: 00001K06
       Coding: 00020004200100011005000000101000
       ROD: EV_ACClimaBHBVW37X_002_VW37.rod
       VCID: 363526CF68C3D17723B-8062
    328196 - Motor for Right Temperature Flap
              B108D 71 [008] - Actuator stuck
                        Reset counter: 133
                        Mileage: 189000 km
                        Date: 2019.11.14
                        Time: 16:27:38
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011303200467
       Coding: 00031A46C24122FB4FE44000001C0708180A000000000000000000000000
       ROD: EV_BCMBOSCH_010.rod
       VCID: 46D5560F182341F7B3B-8012
       Component: WWS    130128  042 0551
       Serial number:         130204132030
       Coding: 0E4DD5
       Component: RLFS  024 0042
       Serial number: Y14M02D28H20M43S40S8
       Coding: 028877
    12307 - License Plate Light
              B12CA 01 [009] - Electrical Failure
                        Reset counter: 7
                        Mileage: 187371 km
                        Date: 2019.10.18
                        Time: 19:03:18
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [009] - Electrical Failure
                        Fault Frequency: 9
                        Reset counter: 113
                        Mileage: 187292 km
                        Date: 2019.10.16
                        Time: 11:58:18
    204290 - Remote key 1
              B1479 18 [008] - Current Too Low
                        Reset counter: 149
                        Mileage: 190923 km
                        Date: 2019.12.27
                        Time: 11:47:46
    204546 - Remote key 2
                        Reset counter: 96
                        Mileage: 190598 km
                        Date: 2019.12.23
                        Time: 08:30:35
       Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  002 0026
       Revision: --------    Serial number: 94231303300904
       Coding: 0071051111
       ASAM Dataset: EV_EPHVA18AU3700000 002016
       VCID: 3A2D32FF5CDB3517C73-806E
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 J    HW: 5Q0 907 567 J
       Component: ACC3          H10 0396
       Serial number: 12051703033302
       Coding: 001E1900FE0309
       ASAM Dataset: EV_ACCBoschMQB 001023
       ROD: EV_ACCBoschMQB_VW37.rod
       VCID: 42DD4A1F340B7DD79F3-8016
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R02VUJ3
       Shop #: WSC 00028 028 00061
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 40D940173A076FC7897-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 802 13
       Serial number: 35767000000EAC189C08
       Subsystem 2 - Part No SW: -----------    HW: 480 000 602 13
       Serial number: 358670000000AB6C4C0+
       Subsystem 3 - Part No SW: -----------    HW: 480 400 902 13
       Serial number: 3516502B10D36244B31
       Subsystem 4 - Part No SW: -----------    HW: 480 400 502 13
       Serial number: 35265029B0F53D64F29T
       Subsystem 5 - Part No SW: -----------    HW: 480 402 501 13
       Serial number: 35565029B0D3608390EG
       Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
       Revision: --------    Serial number: 01021308491400
       Coding: 0C00
       Shop #: WSC 40195 333 37120
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 025D8A1F748BBDD7DF3-8056
       Part No SW: 5G0 920 870     HW: 5G0 920 870
       Component: KOMBI         335 0555
       Coding: 07A401182F80000800882A01040000
       VCID: 6695B68F78E361F753B-8032
       Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1109
       Revision: --------    Serial number: 0000295622
       Coding: 030100342B086400EF00025A1C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 34311CC77EBFC3671DF-8060
       Component: E221__MFL-DC1  H12 0034
       Serial number: 02120004383200010291
       Coding: 2D0000
       Serial number: 2953889101
       Part No SW: 5Q0 905 861     HW: 5Q0 905 861
       Component: ELV-MQBA      H06 0010
       Revision: 00000000    Serial number: 13000017126002
       Coding: 4900000000000000
       ASAM Dataset: EV_ELVMarquMQB 003008
       ROD: EV_ELVMarquMQB_003.rod
       VCID: 73B3DFDB3B31845FC45-8026
       Part No SW: 5Q4 959 593     HW: 5Q4 959 593
       Serial number: 0000051758410
       Coding: 003B1320D000020000001000
       Serial number: 00000000000000757252
       Coding: 01
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D2739E34DF5022FE21-8068
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Serial number: 0000052800180
       Coding: 003B1120DE00020000801000
       VCID: 015F8513718DA6CFC69-8054
       Serial number: 00000000000000754104
       Coding: 090000
    65639 - Motor for Window Regulator
              B1487 29 [008] - Signal Implausible
                        Reset counter: 141
                        Mileage: 190759 km
                        Date: 2019.12.25
                        Time: 11:07:47
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0080
       Coding: 029A00000B000200
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
       Part No SW: 5G0 035 819     HW: 5G0 035 819
       Component: MU-S--ER      039 0142
       Serial number: V1C00802130818
       Coding: 02730000FF00000011110001000800001F0100840100010001
       ASAM Dataset: EV_MUStd4CPASE 002036
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H44 0020
       Serial number: VWZ8Z9M2401S1X
       Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
       Component: Anhaenger     H11 0030
       Revision: 6B001003    Serial number: 00000192647117
       Coding: 0100000200000000
       ASAM Dataset: EV_TrailFunctPivotHella 001001
       ROD: EV_TrailFunctDemouHella.rod
       VCID: 353721C375C5DA6F2A1-8060
    End----------(Elapsed Time: 01:18, VBatt start/end: 14.7V/14.7V)-----------
    May 2014
    ^^^ HMM......... this car has done 191, 209 kms - so, I'm guessing that it's an "early" model. This being so, I suspect that the "temperature" method should be used to disable SS - rather than the "voltage" method.
    This tweak is a not sanctioned by Ross-Tech (for ethical reasons - I think)
    1. Slect the CAN Gateway module @ address hex19
    2. Select Adaptation
    3. Search for "ENG05990"
    4. Change the 2 x channels (their default value is minus 50.0 °C)
      ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature > 50.0 °C
      ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature > 50.0 °C
    Feb 2019
    Okey thanks, I Will try
    Feb 2020
    Any way to disable and not get the high power consumption message?
    Jun 2014
    Disable messages in Infortainement-system...
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  6. #6
    Quote Originally Posted by m3lv View Post
    Fit an add-on device that automatically presses the SS switch for you at every ignition on?
  7. #7
    Aug 2019
    NW Florida
    I've done this, works great...
    TW
    2019 Atlas SEL-R FWD
  8. Likes Uwe, darkchina811, PetrolDave, dennis. liked this post
  9. #8
    May 2014
    ^^^Just to add alternatives to above -I've done this, works great...
    And this.....
    And this (Arduino -Digispark version).....
  10. Likes PetrolDave, Super-VAG liked this post
