Hello. Does anybody know is there possibility to deactivate Start&Stop in that MK7? There isnt channel to change voltage to S/S. Is there any other possibility to do with VCDS?
Saturday,11,January,2020,21:09:36:19148
Workshop Code: 358 14250 022663
VIN: WVWZZZAUZDP053588 License Plate:
Mileage: 191209km-118811mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69
VIN: WVWZZZAUZDP052588 Mileage: 191209km-118811miles
Address 01: Engine (J623-CPTA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 AD HW: 04E 907 309 G
Component: R4 1.4l TFS H02 9225
Revision: WKH02---
Coding: 01250032247405083000
Shop #: WSC 73008 205 00000
ASAM Dataset: EV_ECM14TFS01104E906016AD 002015
ROD: EV_ECM14TFS01104E906016AD.rod
VCID: 6491AC878EDF13E74DF-8030
17159 - Databus
Part No SW: 0CW 300 047 T HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5211
Revision: 00043014 Serial number: CU501302146978
Shop #: WSC 00028 028 00024
ROD: EV_TCMDQ200021_VW31.rod
VCID: 4CC16427064FBBA765F-8018
Part No SW: 5Q0 907 379 AD HW: 5Q0 907 379 E
Component: ESC H75 0537
Revision: 00000000 Serial number:
Coding: 01FA6AA12025126E037C060801CB2980560448C0608094F3F82A5028C1
ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
VCID: 7EA5FEEF0073D937BBB-802A
Part No SW: 5Q0 959 435 HW: 5Q0 959 435
Component: VWKESSYMQB 021 0500
Revision: 00021000 Serial number: 0203188523
Coding: 030C0C
VCID: 79AFEDF3195DFE0F8E9-802C
Part No SW: 5G0 907 044 R HW: 5G0 907 044 R
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00020004200100011005000000101000
ROD: EV_ACClimaBHBVW37X_002_VW37.rod
VCID: 363526CF68C3D17723B-8062
328196 - Motor for Right Temperature Flap
B108D 71 [008] - Actuator stuck
Reset counter: 133
Mileage: 189000 km
Date: 2019.11.14
Time: 16:27:38
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011303200467
Coding: 00031A46C24122FB4FE44000001C0708180A000000000000000000000000
ROD: EV_BCMBOSCH_010.rod
VCID: 46D5560F182341F7B3B-8012
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130128 042 0551
Serial number: 130204132030
Coding: 0E4DD5
Component: RLFS 024 0042
Serial number: Y14M02D28H20M43S40S8
Coding: 028877
12307 - License Plate Light
B12CA 01 [009] - Electrical Failure
Reset counter: 7
Mileage: 187371 km
Date: 2019.10.18
Time: 19:03:18
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Fault Frequency: 9
Reset counter: 113
Mileage: 187292 km
Date: 2019.10.16
Time: 11:58:18
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Reset counter: 149
Mileage: 190923 km
Date: 2019.12.27
Time: 11:47:46
204546 - Remote key 2
Reset counter: 96
Mileage: 190598 km
Date: 2019.12.23
Time: 08:30:35
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231303300904
Coding: 0071051111
ASAM Dataset: EV_EPHVA18AU3700000 002016
VCID: 3A2D32FF5CDB3517C73-806E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 J HW: 5Q0 907 567 J
Component: ACC3 H10 0396
Serial number: 12051703033302
Coding: 001E1900FE0309
ASAM Dataset: EV_ACCBoschMQB 001023
ROD: EV_ACCBoschMQB_VW37.rod
VCID: 42DD4A1F340B7DD79F3-8016
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Serial number: 003F5R02VUJ3
Shop #: WSC 00028 028 00061
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 40D940173A076FC7897-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 802 13
Serial number: 35767000000EAC189C08
Subsystem 2 - Part No SW: ----------- HW: 480 000 602 13
Serial number: 358670000000AB6C4C0+
Subsystem 3 - Part No SW: ----------- HW: 480 400 902 13
Serial number: 3516502B10D36244B31
Subsystem 4 - Part No SW: ----------- HW: 480 400 502 13
Serial number: 35265029B0F53D64F29T
Subsystem 5 - Part No SW: ----------- HW: 480 402 501 13
Serial number: 35565029B0D3608390EG
Part No SW: 5Q0 953 507 BM HW: 5Q0 953 549
Revision: -------- Serial number: 01021308491400
Coding: 0C00
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 025D8A1F748BBDD7DF3-8056
Part No SW: 5G0 920 870 HW: 5G0 920 870
Component: KOMBI 335 0555
Coding: 07A401182F80000800882A01040000
VCID: 6695B68F78E361F753B-8032
Part No SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW MQB High 125 1109
Revision: -------- Serial number: 0000295622
Coding: 030100342B086400EF00025A1C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 34311CC77EBFC3671DF-8060
Component: E221__MFL-DC1 H12 0034
Serial number: 02120004383200010291
Coding: 2D0000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 2953889101
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000017126002
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 73B3DFDB3B31845FC45-8026
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000051758410
Coding: 003B1320D000020000001000
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000757252
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D2739E34DF5022FE21-8068
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000052800180
Coding: 003B1120DE00020000801000
VCID: 015F8513718DA6CFC69-8054
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000754104
Coding: 090000
65639 - Motor for Window Regulator
B1487 29 [008] - Signal Implausible
Reset counter: 141
Mileage: 190759 km
Date: 2019.12.25
Time: 11:07:47
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 029A00000B000200
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 819 HW: 5G0 035 819
Component: MU-S--ER 039 0142
Serial number: V1C00802130818
Coding: 02730000FF00000011110001000800001F0100840100010001
ASAM Dataset: EV_MUStd4CPASE 002036
ROD: EV_MUStd4CPASE_VW37.rod
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9M2401S1X
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 A HW: 5Q0 907 383 A
Component: Anhaenger H11 0030
Revision: 6B001003 Serial number: 00000192647117
Coding: 0100000200000000
ASAM Dataset: EV_TrailFunctPivotHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: 353721C375C5DA6F2A1-8060
End----------(Elapsed Time: 01:18, VBatt start/end: 14.7V/14.7V)-----------
