Results 1 to 3 of 3
Thread: A6 2.7tdi Vp44 fuel Pump
    New User
    Jan 2020
    Shropshire, UK
    I'm looking at buying an 2008 A6 2.7tdi with 98,000 miles but the only thing which is putting g me off is the fuel pump.
    I've had dealings with this kind of pump on a 2002 2.2 Saab 93 which was a nightmare and I don't want that Hassel again.
    So my question is, if the pump fails on this A6 and I get a 2nd hand replacement do I have to have it coded/married to the car ? And, does the 2nd hand replacement need divorcing from its original car before it can go onto into mine ?
    16.4905 S, 151.7375 W
    I believe this is only for the Injection Pump on 2.5l V6 TDI Engine, I could be wrong, but it does not look like the 2.7L TDI supports this function.
    By the way, did you buy the vehicle? If so post up a scan in the Reference Scans and Maps of Non-Broken Cars section of the Ross-Tech forum. Any of our current Ross-Tech interfaces will work with this vehicle,
    Hope this helps,
    drpter
    Sep 2016
    Riga, Latvia
    VAG 3,0l and 2,7l V6 TDI engines are equipped with the Common Rail fuel system. Nothing to do with VP44/PSG5 here.
    P.S. SAAB and Opel/Vauxhall have something even better than PSG5 - it is PSG16 - complete engine ECU integrated in upper part of HPFP
    P.S.2 Never had any problems with marrying or virginaizing/remarrying new or used PSG5 or PSG16. Correct knowledge, correct tools Nowadays only problem is to find a good used one. And price for new is two or more times higher than price for that car...
  4. Likes Uwe liked this post
