I saw an "Audi Adaptive Light Defective" on the dash Tuesday, and I ran VCDS & saw that the M51 bulb for the Stationary Cornering Lamp was open-circuit. I bought a new H7 bulb and with some hassle managed to install the new bulb.
I'm still getting the same error message on the dash, and another VCDS scan last night shows the same error. I cleared all errors, and the error reappeared. The new bulb is conductive with a DVM, so it seems fine.
Is VCDS giving me the wrong error message and bulb indication?
Here's the scan from last Tuesday:
Tuesday,07,January,2020,17:30:11:47760
VCDS Version: 19.6.2.0 (x64)
VIN: WA1C8AFP7DA079130 License Plate: BURNEDOUTBULB
Mileage: 82280km-51126mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 40 42 44 46 47 51 52 53
56 5F 62 6C 6D 72 8C
VIN: WA1C8AFP7DA079130 Mileage: 82280km-51126miles
40-AC Compressor -- Status: OK 0000
Address 01: Engine (0-MA--CHJA) Labels: None
Part No SW: 8R1 907 115 D HW: 8R0 907 115 G
Component: 2.0l R4/4V TF H57 0003
Revision: NDH57---
Coding: 6A2A0013442600062000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TFS0118R1907115D 002005
ROD: EV_ECM20TFS_AU48.rod
VCID: 3663CAFD89FDEDFF4D-8062
Part No SW: 8R1 927 158 K HW: 0BW 927 156 P
Component: 0BW 20TFSIUSA H16 1001
Revision: --H16---
ASAM Dataset: EV_TCMAL551111 002022
ROD: EV_TCMAL551111_002.rod
VCID: 4683BA3DF91D7D7FDD-8012
Part No SW: 8R0 907 379 T HW: 8R0 907 379 T
Component: ESP8 quattro H09 0060
Coding: 2D1D1C
Shop #: WSC 48607 001 1048576
VCID: 51A999610853AAC778-8004
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H12 0633
Coding: 0DC54040000000000000
Shop #: WSC 06335 000 00000
VCID: 0407603587A18F6F83-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000040689010
Part No SW: 8K1 820 043 AL HW: 8K1 820 043 AL
Revision: C3000000 Serial number: 01080320130871
Coding: 64C120C200
VCID: 72EB36EDAD15B1DFA1-8026
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000566263501
Coding: 26000091863CAFC00000480000003D0D0F1C4608E0090225000008004000010200040034000000
Shop #: WSC 55826 001 1048576
VCID: 7AFB1ECDF565C99FE9-802E
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 130225 H11 0050
Serial number: 90243014130220165816
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 21062804
Coding: 03005C
Component: E1 - LDS H03 0031
Serial number: 00000000002802131292
Component: USHL4.2 H30 0030
Serial number: 0000002274555R55JW02
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0054053656
Coding: 0F0000
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 7 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 8 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: CD08C696000000000001
02235 - Stationary Cornering Lamp (Left) (M51)
Fault Status: 01101011
Reset counter: 42
Mileage: 82215 km
Date: 2019.12.30
Time: 16:09:58
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Serial number: 003GPD91CK1E
Coding: 303634313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 479DB739FE17647726-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R130000C63C
Serial number: 6334MSME78661A6CT
Serial number: 6344MSME76235861C
Serial number: 6352QSME5E2C3550N
Serial number: 6362QSME5E2C1E78+
Serial number: 63732SME4D2D264CC
Serial number: 63832SME462B007A/
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Revision: -------- Serial number: 90372MC1001PT
Coding: 000037
VCID: 4385A329C22F4857FA-8016
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 D HW: 8R0 920 981 D
Component: KOMBIINSTR. H35 0556
Revision: 00200000 Serial number: UWU381U2E
Coding: 8BBF23000B01D705020000
VCID: 3B75DBC9BADF3097B2-806E
Part No SW: 8R0 907 468 K HW: 8R0 907 468 E
Component: GW-BEM 5CAN-M H11 0055
Revision: 2A120022 Serial number: 2242A132200029
Coding: 80D00AFF00
VCID: 479DB739F617647726-8012
Subsystem 1 - Part No SW: 8R0 915 181 A HW: 8R0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000001580143173
Subsystem 2 - Part No SW: 8R0 915 181 B HW: 8R0 915 181 B
Component: J367-BDMLear2 H07 5040
Serial number: 00000000001770349767
Part No SW: 8R0 959 760 E HW: 8R0 959 760 C
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000049483487
Coding: C0581B000F0000000000
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H04 0060
Serial number: 0192517036
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3F8DAFD9A6C72CB79E-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H04 0060
Serial number: 0192496252
Coding: 000102
Address 40: AC Compressor (J842) Labels: 8R0-260-797.clb
Part No SW: 8R0 260 797 C HW: 8R0 260 797 C
Component: ES34 H01 0001
ASAM Dataset: EV_AirCondiCompr_ES34 S03001
ROD: EV_AirCondiCompr_ES34.rod
VCID: 3C77D8D5B7D137AFBB-8068
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0508
Revision: Serial number: 0000053762085
Coding: 011D13205E00440004
VCID: 4FAD9F191E67BC376E-801A
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0021290518
Coding: 000000000100
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B75DBC9B2DF3097B2-806E
Revision: 00002001 Serial number: 0301732617
Coding: 0126023A20FA709584B005321004000D
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000646281
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813011839502
VCID: 2D51E59174ABAE273C-8078
Address 51: Electric Drive (J841) Labels: 06F-907-080.clb
Part No SW: 06F 907 080 H HW: 06F 907 080 H
Component: MLB HYBRID H19 0001
Revision: --------
ASAM Dataset: EV_DMCM030202106F907080H 001003
ROD: EV_DMCM030202106F907080H.rod
VCID: 2C57E89547B1A72F2B-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0508
Revision: Serial number: 0000054093461
VCID: 4E93821D196DB53F65-801A
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001272350
ROD: EV_ParkiBrake_AU48.rod
VCID: 387FC4C583E91B8F5F-806C
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156C$0D7702883
Coding: 020007010000000001
VCID: 25411DB12C5B9667F4-8070
Part No SW: 8R1 035 746 K HW: 8R1 035 746 B
Component: H-BNT-NA H44 1040
Revision: -------- Serial number: 204C+0D7566667
Coding: 170200060005A1EF51038B4E00000403140000000000000002
VCID: 3F8DAFD9AEC72CB79E-806A
Subsystem 1 - Part No: 8R0 060 884 EN
Component: NAR 2017/2018 1602
Component: DU7 High H42 0104
Serial number: A130CJ0D2675021
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001436879
Component: CD-Database 4949
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000054061364
Coding: 010C13204000240004
VCID: 4683BA3DF11D7D7FDD-8012
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2ZA5M1
Coding: 1020010
VCID: 3467F0F55781FFEF73-8060
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Component: TSG HR H01 0506
Revision: Serial number: 0000054061609
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 8R0 915 591 HW: 8R0 915 591
Component: BMS H08 0543
Coding: 0A0200
Shop #: WSC 47336 001 1048576
ASAM Dataset: EV_BECM0722011 004016
ROD: EV_BECM0722011_004_AU48.rod
VCID: 78FF04C5C369DB8F9F-802C
End-------------------------(Elapsed Time: 05:07)--------------------------
